Modul für Ecoflow-Komponenten (über HTTP-REST)
Begonnen von Neolux, 17 Februar 2025, 13:10:08
dergolem
Hi, werde mich dann mit der Doku Auseinandersetzen müssen.
Es werden bei den Stream Geräten tatsächlich bis zu 6 Stück im Verbund betrieben um in gewissen Grenzen die 800W Beschränkungen bei Balkonkraftwerken aufzuweichen.
Gruß Denis
dergolem
so ich habe mal angefangen:
"STREAM MAX" => {
        "Adjustments" => {},
        "Gets" => {
            "relay2Onoff" => "",
            "backupReverseSoc" => "",
            "energyStrategyOperateMode.operateSelfPoweredOpen" => "",
            "energyStrategyOperateMode.operateIntelligentScheduleModeOpen" => "",
            "feedGridMode" => "",
        "Sets" => {
            "cfgRelay2Onoff" => ":true,false",
            "cfgBackupReverseSoc"=> ":slider,3,1,95",
            "cfgEnergyStrategyOperateMode.operateSelfPoweredOpen" => ":true",
            "cfgEnergyStrategyOperateMode.operateIntelligentScheduleModeOpen" => ":true",
            "cfgFeedGridMode" => ":1,2",
        "SetCmdCodes" => {
            "cfgRelay2Onoff" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "dest" => 2, "needAck" => "true", "params.cfgRelay2Onoff" => "a[2]"},
            "cfgBackupReverseSoc" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "dest" => 2, "needAck" => "true", "params.cfgBackupReverseSoc" => "a[2]" },
            "cfgEnergyStrategyOperateMode.operateSelfPoweredOpen" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "dest" => 2, "needAck" => "true", "params.cfgEnergyStrategyOperateMode.operateSelfPoweredOpen" => "a[2]"},
            "cfgEnergyStrategyOperateMode.operateIntelligentScheduleModeOpen" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "dest" => 2, "needAck" => "true", "params.cfgEnergyStrategyOperateMode.operateIntelligentScheduleModeOpen" => "a[2]"},
            "cfgFeedGridMode" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "dest" => 2, "needAck" => "true", "params.cfgFeedGridMode" => "a[2]"},
leider bekomme ich keinen _ProduktName in der Antwort dehalb habe ich mir mit mit dem _deviceName der in der Response ausgeholfen.
my $product = $v{$base . "_productName"} || '';
if(length($product)) {
$param->{hash}->{Model} = uc($product);
else {
my $dev = $v{$base . "_deviceName"} || '';
Ecoflow_Log($param->{hash}, 4, "Ecoflow_Response(): " . $dev);
if ($dev =~ /STREAM Max/i) {
$param->{hash}->{Model} = "STREAM MAX";
elsif ($dev =~ /STREAM Ultra/i) {
$param->{hash}->{Model} = "STREAM ULTRA";
elsif ($dev =~ /STREAM Pro/i) {
$param->{hash}->{Model} = "STREAM PRO";
elsif ($dev =~ /STREAM AC/i) {
$param->{hash}->{Model} = "STREAM AC";
Da der Name in der App geändert werden kann, muss mann dann darauf achten, das der Name "STREAM xyz" enthält.
Das Setzten des Ausgangs funktioniert leider nicht Fehler "Validation failed, Please check your param: cfgRelay2Onoff". Kann es sein das true und false nicht in Anführungsstrichen stehen dürten?
Gruß Denis
KölnSolar
#107
Eigentlich nicht.
andere set/get funktionieren ?
mal mit verbose=5 set ausführen u. Log posten.
dergolem
#108
hier mal ein Log:
2026.01.08 06:30:17 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model = STREAM MAX
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = params.cfgRelay2Onoff
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $str_value = a[2]
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dest
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdFunc
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = needAck
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirSrc
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirDest
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdId
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = PUT
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=440880 $timestamp=1767850231752
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"cmdFunc": "254","cmdId": "17","dest": "2","dirDest": "1","dirSrc": "1","needAck": "true","sn": "BKxxxxxxxxxxx55", "params": {"cfgRelay2Onoff": "false"}}
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = cmdFunc=254&cmdId=17&dest=2&dirDest=1&dirSrc=1&needAck=true¶ms.cfgRelay2Onoff=false&sn=BKxxxxxxx7155&accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx&nonce=440880×tamp=1767850231752
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"cmdFunc": "254","cmdId": "17","dest": "2","dirDest": "1","dirSrc": "1","needAck": "true","sn": "BKxxxxxxxxx5", "params": {"cfgRelay2Onoff": "false"}}
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.08 06:30:31 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"8524","message":"Validation failed, Please check your param: cfgRelay2Onoff","eagleEyeTraceId":"","tid":""}
2026.01.08 06:30:31 0: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): ERROR! {"code":"8524","message":"Validation failed, Please check your param: cfgRelay2Onoff","eagleEyeTraceId":"","tid":""}
2026.01.08 06:30:31 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
Gruß Denis
KölnSolar
#109
Hast nicht alle Sn unkenntlich gemacht.
Die hast Du Dir über GET: /iot-open/sign/device/system/main/sn?sn=DeineSngeholt ?
Edit: wat is dat denn ?
dergolem
die Seriennummer hab ich aus der App.
woher das kommt weis ich nicht, alles was ich geändert hab ist in dem Post oben.
KölnSolar
Zitatandere set/get funktionieren ?
Hast Du ignoriert.
Ggfs. mal mit "get devices" und "get relay2Onoff" probieren und wenn es nicht klappt, noch einmal mit verbose=5 und Ergebnisse hier einstellen.
dergolem
nein andere Set/get fuktionieren auch nicht.
2026.01.08 14:15:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = GET
2026.01.08 14:15:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=16536 $timestamp=1767878129927
2026.01.08 14:15:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"sn": "BKxxxxxxxxxxxxx", "params": {"quotas":["relay2Onoff"]}}
2026.01.08 14:15:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = params.quotas[0]=relay2Onoff&sn=BKxxxxxxxxxxxxx&accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&nonce=16536×tamp=1767878129927
2026.01.08 14:15:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2026.01.08 14:15:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=913650 $timestamp=1767878129959
2026.01.08 14:15:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/list $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&nonce=913650×tamp=1767878129959
2026.01.08 14:15:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=212146 $timestamp=1767878129962
2026.01.08 14:15:29 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota/all?sn=BKxxxxxxxxxxxxxx $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&nonce=212146×tamp=1767878129962
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"405","message":"Method Not Allowed","eagleEyeTraceId":"","tid":""}
2026.01.08 14:15:30 0: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): ERROR! {"code":"405","message":"Method Not Allowed","eagleEyeTraceId":"","tid":""}
2026.01.08 14:15:30 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/list
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"0","message":"Success","data":[{"sn":"BKxxxxxxxxxxx","deviceName":"STREAM Max-7155gol","online":1}],"eagleEyeTraceId":"","tid":""}
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): code = 0
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_deviceName = STREAM Max-7155gol
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_online = 1
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn = BKxxxxxxxxxxxxx
2026.01.08 14:15:30 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn : Comparing SerialNo BKxxxxxxxxxxxxxxxxx
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $base = data_1
2026.01.08 14:15:30 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): STREAM Max-7155gol
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): eagleEyeTraceId =
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): message = Success
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): tid =
2026.01.08 14:15:30 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota/all?sn=BKxxxxxxxxxxxxxx
Gruß Denis
KölnSolar
OK.
get device.....funktioniert.
der$url = /iot-open/sign/device/quota/allging in die Hose.
Den kenne ich schon.  :)
Such mal if(uc($model) eq "POWEROCEAN"){in der sub Ecoflow_Get.
Diese und die übernächste Zeile(ist nur die abschließende Klammer des if) kommentieren und noch einmal versuchen.
dergolem
funktioniert nicht, Antwort sieht so aus.
2026.01.09 06:11:18 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model = STREAM MAX
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirDest
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdId
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = needAck
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirSrc
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdFunc
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = params.cfgBackupReverseSoc
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $str_value = a[2]
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dest
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = PUT
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=578149 $timestamp=1767935484329
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"cmdFunc": "254","cmdId": "17","dest": "2","dirDest": "1","dirSrc": "1","needAck": "true","sn": "BKxxxxxxxxxxxxxx", "params": {"cfgBackupReverseSoc": "29"}}
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = cmdFunc=254&cmdId=17&dest=2&dirDest=1&dirSrc=1&needAck=true¶ms.cfgBackupReverseSoc=29&sn=BKxxxxxxxxxxx&accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&nonce=578149×tamp=1767935484329
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"cmdFunc": "254","cmdId": "17","dest": "2","dirDest": "1","dirSrc": "1","needAck": "true","sn": "BKxxxxxxxxxxxxxxx", "params": {"cfgBackupReverseSoc": "29"}}
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.09 06:11:24 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"8524","message":"cfgBackupReverseSoc validator error","eagleEyeTraceId":"","tid":""}
2026.01.09 06:11:24 0: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): ERROR! {"code":"8524","message":"cfgBackupReverseSoc validator error","eagleEyeTraceId":"","tid":""}
2026.01.09 06:11:24 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
das mit dem "&needAck=true¶ms.cfgBackupReverseSoc" ist immer noch da...
KölnSolar
#115
aber besser. POST genau wie bei mir für die gets.
url muss so aussehen
url = /iot-open/sign/device/quota $query_str = cmdFunc=254&cmdId=17&dest=2&dirDest=1&dirSrc=1&needAck=true&params.cfgBackupReverseSoc=29&sn=BKxxxxxxxxxxx&accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&nonce=578149×tamp=1767935484329das xtamp ist auch immer xtamp anstatt &timestamp ?
Poste nochmal Deine gesamte %Ecoflow_Vars
Edit: das Für die Anbindung benötigt ihr noch folgende Perl-Module:
Time::HiRes,Digest::SHA,URL::Encode
hast Du installiert ?
dergolem
hier estmal die Variablen:
"STREAM MAX" => {
"Gets" => {
"Sets" => {
"SetCmdCodes" => {
    "cfgRelay2Onoff" => { "cmdId" => 17, "cmdFunc" => 254, "dirDest" => 1, "dirSrc" => 1, "needAck" => "true", "dest" => 2, "params.cfgRelay2Onoff" => "a[2]"},
klar, die Perl-Module sind installiert.
dergolem
#117
und hier nochmal ein Längerern Auszug aus der Logdatei:
2026.01.09 10:47:52 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model = STREAM MAX
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirDest
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdId
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = needAck
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirSrc
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdFunc
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = params.cfgBackupReverseSoc
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $str_value = a[2]
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dest
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = PUT
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=713898 $timestamp=1767952080224
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"cmdFunc": "254","cmdId": "17","dest": "2","dirDest": "1","dirSrc": "1","needAck": "true","sn": "BKXXXXXXXXXXXXX", "params": {"cfgBackupReverseSoc": "34"}}
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = cmdFunc=254&cmdId=17&dest=2&dirDest=1&dirSrc=1&needAck=true¶ms.cfgBackupReverseSoc=34&sn=BKXXXXXXXXXXXXX&accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=713898×tamp=1767952080224
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.09 10:48:00 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"8524","message":"cfgBackupReverseSoc validator error","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:00 0: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): ERROR! {"code":"8524","message":"cfgBackupReverseSoc validator error","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:00 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = GET
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=84976 $timestamp=1767952085420
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/list $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=84976×tamp=1767952085420
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=88113 $timestamp=1767952085422
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota/all?sn=BKXXXXXXXXXXXXX $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=88113×tamp=1767952085422
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota/all?sn=BKXXXXXXXXXXXXX
2026.01.09 10:48:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/list
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"0","message":"Success","data":[{"sn":"BKXXXXXXXXXXXXX","deviceName":"STREAM Max-7155gol","online":1}],"eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): code = 0
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_deviceName = STREAM Max-7155gol
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_online = 1
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn = BKXXXXXXXXXXXXX
2026.01.09 10:48:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn : Comparing SerialNo BKXXXXXXXXXXXXX
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $base = data_1
2026.01.09 10:48:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): STREAM Max-7155gol
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): eagleEyeTraceId =
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): message = Success
2026.01.09 10:48:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): tid =
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dest
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = params.cfgRelay2Onoff
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $str_value = a[2]
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdFunc
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = needAck
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirSrc
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdId
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirDest
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = PUT
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=564982 $timestamp=1767952090441
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"cmdFunc": "254","cmdId": "17","dest": "2","dirDest": "1","dirSrc": "1","needAck": "true","sn": "BKXXXXXXXXXXXXX", "params": {"cfgRelay2Onoff": "false"}}
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = cmdFunc=254&cmdId=17&dest=2&dirDest=1&dirSrc=1&needAck=true¶ms.cfgRelay2Onoff=false&sn=BKXXXXXXXXXXXXX&accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=564982×tamp=1767952090441
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.09 10:48:10 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"8524","message":"Validation failed, Please check your param: cfgRelay2Onoff","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:10 0: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): ERROR! {"code":"8524","message":"Validation failed, Please check your param: cfgRelay2Onoff","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:10 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = params.cfgFeedGridMode
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $str_value = a[2]
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirDest
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdFunc
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = cmdId
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = needAck
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dest
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Set(): $key = dirSrc
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = PUT
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=985369 $timestamp=1767952103448
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $json = {"cmdFunc": "254","cmdId": "17","dest": "2","dirDest": "1","dirSrc": "1","needAck": "true","sn": "BKXXXXXXXXXXXXX", "params": {"cfgFeedGridMode": "2"}}
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota $query_str = cmdFunc=254&cmdId=17&dest=2&dirDest=1&dirSrc=1&needAck=true¶ms.cfgFeedGridMode=2&sn=BKXXXXXXXXXXXXX&accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=985369×tamp=1767952103448
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Get(): EcoFlowMax: $model = STREAM MAX
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota
2026.01.09 10:48:23 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"8524","message":"Validation failed, Please check your param: cfgFeedGridMode","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:23 0: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): ERROR! {"code":"8524","message":"Validation failed, Please check your param: cfgFeedGridMode","eagleEyeTraceId":"","tid":""}
2026.01.09 10:48:23 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): Method = GET
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=816752 $timestamp=1767952145429
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/list $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=816752×tamp=1767952145429
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $nonce=143763 $timestamp=1767952145431
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $url = /iot-open/sign/device/quota/all?sn=BKXXXXXXXXXXXXX $query_str = accessKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxD&nonce=143763×tamp=1767952145431
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Request(): $sign = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/list
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $data = {"code":"0","message":"Success","data":[{"sn":"BKXXXXXXXXXXXXX","deviceName":"STREAM Max-7155gol","online":1}],"eagleEyeTraceId":"","tid":""}
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): code = 0
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_deviceName = STREAM Max-7155gol
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_online = 1
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn = BKXXXXXXXXXXXXX
2026.01.09 10:49:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): data_1_sn : Comparing SerialNo BKXXXXXXXXXXXXX
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $base = data_1
2026.01.09 10:49:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): STREAM Max-7155gol
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): eagleEyeTraceId =
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): message = Success
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): tid =
2026.01.09 10:49:05 5: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): $url = https://api-e.ecoflow.com/iot-open/sign/device/quota/all?sn=BKXXXXXXXXXXXXX
2026.01.09 10:49:05 4: EcoFlowMax(Ecoflow 0.3.9.0): Ecoflow_Response(): Setting Reading Vars
KölnSolar
Erste Auffälligkeit: wo sind Deine GetCmdCodes ?
Du testet immer mit sets. Das ist komplizierter.
dergolem
sorry am WE ist immer schlecht mit antworten.
Die Get hab ich noch nicht gemacht, ich dachte erstmal die SetCmd zum laufen bringen und dann weitermachen. Ich werde die Montag fertig machen.
Gruß Denis
