neues modul mailcheck
Begonnen von justme1968, 02 August 2013, 19:08:55
cocojambo
So ich habe ich jetzt mal gemacht. Der Logfile wird allerdings dabei sehr voll und man muß die Stelle suchen wann diese Errormeldungen auftauchen. Ich hoffe das die unten angehangenen Zeilen weiter helfen. Was anderes habe ich im LOG nicht gefunden:
ERROR: error while reading data from server: Connection reset by peer at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1629
Mail::IMAPClient::_read_line('Mail::IMAPClient=HASH(0x2b80050)') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1381
Mail::IMAPClient::_get_response('Mail::IMAPClient=HASH(0x2b80050)', 232, undef) called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1315
Mail::IMAPClient::_imap_command_do('Mail::IMAPClient=HASH(0x2b80050)', 'HASH(0x2db1560)', 'DONE') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1214
Mail::IMAPClient::_imap_command('Mail::IMAPClient=HASH(0x2b80050)', 'HASH(0x2db1560)', 'DONE') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1156
Mail::IMAPClient::done('Mail::IMAPClient=HASH(0x2b80050)') called at ./FHEM/32_mailcheck.pm line 254
main::mailcheck_poll(undef) called at fhem.pl line 2539
main::HandleTimeout() called at fhem.pl line 535
ERROR: error while reading data from server: Connection reset by peer at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1263
ERROR: NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1477
Mail::IMAPClient::_send_line('Mail::IMAPClient=HASH(0x2b80050)', '234 SELECT INBOX', 0) called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1309
Mail::IMAPClient::_imap_command_do('Mail::IMAPClient=HASH(0x2b80050)', 'SELECT INBOX') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1214
Mail::IMAPClient::_imap_command('Mail::IMAPClient=HASH(0x2b80050)', 'SELECT INBOX') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 836
Mail::IMAPClient::select('Mail::IMAPClient=HASH(0x2b80050)', 'INBOX') called at ./FHEM/32_mailcheck.pm line 255
2014.12.01 04:27:11 1: PERL WARNING: Trying command when NOT connected! at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 122
Mail::IMAPClient::LastError('Mail::IMAPClient=HASH(0x2b80050)', 'NO not connected') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1477
ERROR: Error sending '234 SELECT INBOX': NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1310
ERROR: Error sending '234 SELECT INBOX': NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1263
Mail::IMAPClient::_send_line('Mail::IMAPClient=HASH(0x2b80050)', '235 IDLE', 0) called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1309
Mail::IMAPClient::_imap_command_do('Mail::IMAPClient=HASH(0x2b80050)', 'IDLE', '+') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1214
Mail::IMAPClient::_imap_command('Mail::IMAPClient=HASH(0x2b80050)', 'IDLE', '+') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1109
Mail::IMAPClient::idle('Mail::IMAPClient=HASH(0x2b80050)') called at ./FHEM/32_mailcheck.pm line 256
ERROR: Error sending '235 IDLE': NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1310
ERROR: Error sending '235 IDLE': NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1263
ERROR: NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1554
Mail::IMAPClient::_get_response('Mail::IMAPClient=HASH(0x2b80050)', '*', 'Regexp=REGEXP(0x2c06110)') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1133
Mail::IMAPClient::idle_data('Mail::IMAPClient=HASH(0x2b80050)') called at ./FHEM/32_mailcheck.pm line 358
main::mailcheck_Read('HASH(0x2b3c2d8)') called at fhem.pl line 2928
main::CallFn('xxxxx_gmx_net', 'ReadFn', 'HASH(0x2b3c2d8)') called at fhem.pl line 598
2014.12.01 04:27:12 1: PERL WARNING: Trying command when NOT connected! LastError was: Error sending '235 IDLE': NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 122
Mail::IMAPClient::LastError('Mail::IMAPClient=HASH(0x2b80050)', 'NO not connected') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1554
Mail::IMAPClient::_send_line('Mail::IMAPClient=HASH(0x2b80050)', 'DONE', 0) called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1309
Mail::IMAPClient::_imap_command_do('Mail::IMAPClient=HASH(0x2b80050)', 'HASH(0x2f44be8)', 'DONE') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1214
Mail::IMAPClient::_imap_command('Mail::IMAPClient=HASH(0x2b80050)', 'HASH(0x2f44be8)', 'DONE') called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1156
Mail::IMAPClient::done('Mail::IMAPClient=HASH(0x2b80050)') called at ./FHEM/32_mailcheck.pm line 362
2014.12.01 04:27:12 1: PERL WARNING: Trying command when NOT connected! at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 122
ERROR: Error sending 'DONE': NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1310
ERROR: Error sending 'DONE': NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1263
Mail::IMAPClient::_send_line('Mail::IMAPClient=HASH(0x2b80050)', '237 IDLE', 0) called at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1309
Mail::IMAPClient::idle('Mail::IMAPClient=HASH(0x2b80050)') called at ./FHEM/32_mailcheck.pm line 449
ERROR: Error sending '237 IDLE': NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1310
ERROR: Error sending '237 IDLE': NO not connected at /usr/local/share/perl/5.14.2/Mail/IMAPClient.pm line 1263
Gruß aus Köln
nobbi
FHEM6.2 FB7490 FB7430 3xraspi2+3+4 2xHM-LAN-CFG 2xESP CUL868 CUNO868 HUE-Bridge Harmony-Hub 5xHM-LC-Sw-PI-2 3xHM-WDS30-T2-SN 1xHM-LC_Sw4-DR 3xHM-ES-PMSw1-PI 7xFS20SIG2 6xFS20KSE 2xHM-ES-PMSW1-PL 5xS300TH 1xASH2200 1xEM1000
justme1968
der server auf der gegenseite scheint aus irgendeinem grund plötzlich die verbindung zu schließen.
ich schaue mal ob und wie man das abfangen kann.
gruß
  andre
cocojambo
Hallo Andre,
und hast schon eine Idee wie mans lösen kann? der Fehler müßte doch auch bei dir und anderen hier im Board auftauchen oder nicht?
nobbi
justme1968
ich bin noch nicht dazu gekommen.
  andre
Sargon
Hallo zusammen,,
ich versuche seit einiger Zeit per cpan install Mail::IMAPClient zu installieren aber bekomme immer den Fehler "Can't exec "make": No such file or directory at /usr/share/perl5/core_perl/CPAN/Distribution.pm line 2084."
Ich habe Fhem auf einer Synology DS 212+ am laufen und bin mich so langsam am einarbeiten habe aber von Perl nicht wirklich Ahnung. Ich habe make über die iPKGui installiert, das liegt aber in einem falschen/anderen Pfad wie bekomme ich es hin das ich den IMAPClient installiert bekomme?
Thomas
Unitymedia IPv6, Synology 212+, Cul, 4 Max Thermostate und 4 Fensterkontakte
justme1968
das  Mail::IMAPClient modul braucht native c libs. zum installieren wird make und der c kompilier benötigt. schau mal welche ipkg pakete es für dein modell gibt. vermutlich wirst du auch mit der ipkg perl version glücklicher.
  andre
Sargon
Ich habe Perl auch bereits per Ipkg installiert habe aber auch das Synology packet noch drauf kann ich das einfach deinstallieren oder funktioniert dann wahrscheinlich gar nichts mehr? Und wenn ich es deinstalliert habe wird dann das make funktionieren oder muss ich dann auch noch etliche Sachen anpassen? Wie gesagt habe nicht wirklich Ahnung von Perl.
Thomas
justme1968
Schau erst mal ob du ein perl imap modul per ipkg findest. wenn nicht musst du make und gcc per ipkg Installieren und dann das imap Modul per cpan.
im fhem start script musst du dran denke die ipkg perl version zu verwenden. nicht die von synology.
dir kannst du im paket center dann einfach deinstallieren.
gruß
  andre
Sargon
Ich habe inzwischen das Perl Packet deinstalliert und Fhem habe ich entsprechend angepasst. Nun kann ich aber mit Putty nicht mehr Perl ausführen, was muss ich hier anpassen damit er Perl findet?
Thomas
justme1968
wenn die ipkg installation korrekt ist sollte /opt/bin in deinem pfad sein und /opt/bin/perl gefunden werden.
  andre
Sargon
inzwischen konnte ich das Mail::IMAPClient Modul installieren. Ich habe auch ein Mailcheck Modul angelegt. Bekomme aber keine Verbindung mit meinem Arcor Postfach.
Im Log steht nur: 2014.12.26 23:35:54 3: arcorEmailFhem: failed to connect to imap.arcor.de
Hier meine Defines:
define arcorEmailFhem mailcheck imap.arcor.de xxxxxr@arcor.de {myPassword()}
define FileLogArcorEmailFhem FileLog /volumeUSB2/usbshare/FHEM/var/log/ArcorEmailFhemLog-%Y.log arcorEmailFhem
Das neuangelegte Logfile hat keine Inhalte.
Was mache ich hier falsch
Thomas
cocojambo
@justme1968
Hi Andre,
Ich hoffe ich mache nix falsch, wenn ich nochmal nachfrage ob du inzwischen mal Zeit gefunden hast um raus zu kriegen warum der server auf der gegenseite bei mir plötzlich die verbindung zu schließen scheint. Ich würde nämlich gerne dein Modul benutzen, aber bei etlichen Email Konten sind die Fehlerwarnungen und Errors was viel im LOG und machen ihn auch unnütz groß und unübersichtlich.
nobbi
justme1968
@Sargon: eventuell hast du ein ssl problem. schau mal weiter oben im thread da gibt es ein paar posts zu. du kannst auch versuchen nossl zu setzen. ansonsten verstoße auf 5 setzen und ins fhem log schauen.
@cocojambo: du machst nichts falsch. ich kann das problem nur nicht reproduzieren. eigentlich sollte die konstellation wie sie in deinem log auftaucht nicht passieren können bzw. ist innerhalb von Mail::IMAPClient.
  andre
Sargon
ich bekomme das Paket Net::SSLeay und damit das Paket IO::Socket::SSL nicht installiert. Beim installieren meldet er das OpenSSL-1.0.1j bereits installiert ist und ich bekomme es auch nicht deinstalliert. Die erste "Fehlerausgabe" beim installieren von Net::SSLeay ist "getcwd: No such file or Directory" und dann fehlen die OppenSSL Klassen:
SSLeay.xs:163:25: error: openssl/err.h: No such file or directory
SSLeay.xs:164:27: error: openssl/lhash.h: No such file or directory
SSLeay.xs:165:26: error: openssl/rand.h: No such file or directory
SSLeay.xs:166:28: error: openssl/buffer.h: No such file or directory
SSLeay.xs:167:25: error: openssl/ssl.h: No such file or directory
SSLeay.xs:168:28: error: openssl/pkcs12.h: No such file or directory
SSLeay.xs:169:74: error: openssl/comp.h: No such file or directory
SSLeay.xs:171:25: error: openssl/md2.h: No such file or directory
SSLeay.xs:173:25: error: openssl/md4.h: No such file or Directory
Ich habe auch kein Paket gefunden über das OpenSSL-1.0.1j installiert wurde, ich hab ein Skript gefunden das Pakete deinstallieren kann aber er kann mit OpenSSL-1.0.1j nichts anfangen "http://perltricks.com/article/3/2013/3/27/How-to-cleanly-uninstall-a-Perl-module".
Kann mir jemand hier helfen? Bin langsam am verzweifeln
Thomas
SSLeay.xs:174:93: error: openssl/md5.h: No such file or directory
SSLeay.xs:178:26: error: openssl/x509.h: No such file or directory
SSLeay.xs:179:28: error: openssl/x509v3.h: No such file or directory
Sargon
ich habe es inzwischen geschaft die fehlenden Pakete zu installieren habe aber leider habe ich ein neues Problem. Ich kann das Mailcheck Modul nicht laden er meldet mir das es die Mail/IMAPClient.pm nicht findet.
Hier der Logauszug:
2015.01.01 22:14:05 5: Loading /usr/local/FHEM/share/fhem/FHEM/32_mailcheck.pm
2015.01.01 22:14:05 1: reload: Error:Modul 32_mailcheck deactivated:
Can't locate Mail/IMAPClient.pm in @INC (@INC contains: /usr/local/perl/lib/5.16.0/armv5tel-linux /usr/local/perl/lib/5.16.0 /usr/local/perl/lib/site_perl/5.16.0/armv5tel-linux /usr/local/perl/lib/site_perl/5.16.0 /usr/local/perl/lib/site_perl/5.16.0/armv5tel-linux /usr/local/perl/lib/site_perl/5.16.0 /usr/local/perl/lib/5.16.0/armv5tel-linux /usr/local/perl/lib/5.16.0 . /usr/local/FHEM/share/fhem/FHEM) at /usr/local/FHEM/share/fhem/FHEM/32_mailcheck.pm line 11, <$fh> line 81.
BEGIN failed--compilation aborted at /usr/local/FHEM/share/fhem/FHEM/32_mailcheck.pm line 11, <$fh> line 81.
2015.01.01 22:14:05 0: Can't locate Mail/IMAPClient.pm in @INC (@INC contains: /usr/local/perl/lib/5.16.0/armv5tel-linux /usr/local/perl/lib/5.16.0 /usr/local/perl/lib/site_perl/5.16.0/armv5tel-linux /usr/local/perl/lib/site_perl/5.16.0 /usr/local/perl/lib/site_perl/5.16.0/armv5tel-linux /usr/local/perl/lib/site_perl/5.16.0 /usr/local/perl/lib/5.16.0/armv5tel-linux /usr/local/perl/lib/5.16.0 . /usr/local/FHEM/share/fhem/FHEM) at /usr/local/FHEM/share/fhem/FHEM/32_mailcheck.pm line 11, <$fh> line 81.
Aber  Mail/IMAPClient.pm wurde installiert aber anscheinend nicht im erwarteten Pfad siehe Screenshot.
Hier der @INC Pfad (eigentlich zeigt es den Pfad)
perl -le 'print foreach @INC'
/opt/lib/perl5/5.10.0/arm-linux
/opt/lib/perl5/site_perl/5.10.0/arm-linux
Was mache ich falsch?
Thomas
