Perl Warning in Zusammenhang mit event-aggregator (median) nach Neustart
Begonnen von Adimarantis, 04 Mai 2025, 12:52:00
Adimarantis
Ich habe auf einem TRX_Weather Device einen Median wie folgt gesetzt:
event-aggregator temperature::none:median:720,humidity::none:median:7200 Nachvollziehbar nur bei diesem Device (hab für die Zuordnung ein extra "print" eingebaut) bekomme ich nach dem Neustart einmalig folgende Warnings:
2025.05.04 11:25:17.384 1: PERL WARNING: Argument "" isn't numeric in numeric ge (>=) at FHEM/TimeSeries.pm line 272.
2025.05.04 11:25:17.384 1: stacktrace:
2025.05.04 11:25:17.384 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (272)
2025.05.04 11:25:17.384 1:     TimeSeries::elapsed                 called by fhem.pl (5166)
2025.05.04 11:25:17.384 1:     main::readingsBulkUpdate            called by ./FHEM/46_TRX_WEATHER.pm (1646)
2025.05.04 11:25:17.384 1:     main::TRX_WEATHER_Parse             called by fhem.pl (4188)
2025.05.04 11:25:17.384 1:     main::Dispatch                      called by ./FHEM/45_TRX.pm (680)
2025.05.04 11:25:17.385 1:     main::TRX_Parse                     called by ./FHEM/45_TRX.pm (650)
2025.05.04 11:25:17.385 1:     main::TRX_Read                      called by fhem.pl (3988)
2025.05.04 11:25:17.385 1:     main::CallFn                        called by fhem.pl (789)
2025.05.04 11:25:17.385 1: PERL WARNING: Argument "" isn't numeric in numeric ge (>=) at FHEM/TimeSeries.pm line 272.
2025.05.04 11:25:17.385 1: stacktrace:
2025.05.04 11:25:17.386 1:     main::__ANON__                      called by FHEM/TimeSeries.pm (272)
2025.05.04 11:25:17.386 1:     TimeSeries::elapsed                 called by fhem.pl (5166)
2025.05.04 11:25:17.386 1:     main::readingsBulkUpdate            called by ./FHEM/46_TRX_WEATHER.pm (1675)
2025.05.04 11:25:17.386 1:     main::TRX_WEATHER_Parse             called by fhem.pl (4188)
2025.05.04 11:25:17.386 1:     main::Dispatch                      called by ./FHEM/45_TRX.pm (680)
2025.05.04 11:25:17.386 1:     main::TRX_Parse                     called by ./FHEM/45_TRX.pm (650)
2025.05.04 11:25:17.386 1:     main::TRX_Read                      called by fhem.pl (3988)
2025.05.04 11:25:17.386 1:     main::CallFn                        called by fhem.pl (789)
Die Stellen im TRX_Weather Code sind die für Temperature und Humidity und laut meinem "print" bekommt das readingsBulkUpdate sinnvolle Werte.
Stimmt mein event-aggregator nicht, oder ist da ein Bug, der zuschlägt, wenn es (nach dem Neustart) nur einen Wert zum Aggregieren gibt?
Jörg
enno
Moin Jörg,
ich bekomme eine ähnliche Fehlermeldung durch
EG_FL_EM3_Shelly         emeter_._current::none:median:300,emeter_._voltage::none:median:300,emeter_._energy::none:median:300,emeter_._power::none:median:300,emeter_._kWh::none:median:300
Hier habe ich beschrieben wie ich sie weg bekommen habe: https://forum.fhem.de/index.php?topic=145485.0
Vielleicht hilft es in deinem Fall auch.
Gruss
  Enno
Einfacher FHEM Anwender auf Intel®NUC mit Proxmox und Debian
