MapleCUN kein Empfang vom MAX! Heizungsregler
Begonnen von erdnar, 05 Juni 2025, 18:27:37
erdnar
ich habe auf einem neuen PC (debian) Fhem neu installiert und bin beim "Fhem-Umzug".
Ein MapleCUN hat und soll meine MAX! Heizungsregler steuern.
MapleCUN neu installiert, scheint auch zu funktionieren.
   CMDS       bCFiAZNEGMKLUYRTVWXfxz*
   Clients    :FS20:FHT.*:KS300:USF1000:BS:HMS:FS20V: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_HOERMANN: :ESA2000:CUL_IR:CUL_TX:Revolt:IT:UNIRoll:SOMFY: :STACKABLE_CC:TSSTACKED:STACKABLE:CUL_RFR::CUL_TCM97001:CUL_REDIRECT:
   DEF        MapleCUN_1_433
   FUUID      683c4230-f33f-cc74-caac-bdb085d5097a4cce
   IODev      MapleCUN_1_433
   MapleCUN_2_868_MAX_MSGCNT 46
   MapleCUN_2_868_MAX_TIME 2025-06-05 17:26:58
   NAME       MapleCUN_2_868_MAX
   NOTIFYDEV  MapleCUN_1_433
   NR         228
   NTFY_ORDER 50-MapleCUN_2_868_MAX
   PARTIAL
   RAWMSG     T60780C81F5
   RSSI       -79.5
   STACKED    MapleCUN_3_868_HM
   STATE      Initialized
   StackLevel 2
   TYPE       STACKABLE_CC
   VERSION    V 1.26.04 a-culfw Build: private build (unknown) MapleCUNx4_8F (F-Band: 868MHz)
   eventCount 8
   initString X21
Za123456
Zw111111
   MatchList:
     0:FS20V    ^81..(04|0c)..0101a001......00[89a-f]...
     1:USF1000  ^81..(04|0c)..0101a001a5ceaa00....
     2:BS       ^81..(04|0c)..0101a001a5cf
     3:FS20     ^81..(04|0c)..0101a001
     4:FHT      ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     5:KS300    ^810d04..4027a001
     6:CUL_WS   ^K.....
     7:CUL_EM   ^E0.................$
     8:HMS      ^810e04......a001
     9:CUL_FHTTK ^T[A-F0-9]{8}
     A:CUL_RFR  ^[0-9A-F]{4}U.
     B:CUL_HOERMANN ^R..........
     C:ESA2000  ^S................................$
     D:CUL_IR   ^I............
     E:CUL_TX   ^TX[A-F0-9]{10}
     F:Revolt   ^r......................$
     G:IT       ^i......
     H:STACKABLE_CC ^\*
     I:UNIRoll  ^[0-9A-F]{5}(B|D|E)
     J:SOMFY    ^Y[r|t|s]:?[A-F0-9]+
     K:CUL_TCM97001 ^s[A-F0-9]+
     L:CUL_REDIRECT ^o+
     M:TSSTACKED ^\*
     N:STACKABLE ^\*
     2025-06-05 16:45:18   cmds             b C F i A Z N E G M K L U Y R T V W X f x z *
     2025-06-05 17:06:41   credit10ms      3296
     2025-06-05 17:26:58   state           Initialized
   helper:
     bm:
       CUL_Get:
         cnt        1
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        05.06. 17:27:52
         max        0.000277996063232422
         tot        0.000277996063232422
         mAr:
           HASH(0x565559849a30)
           MapleCUN_2_868_MAX
       CUL_Set:
         cnt        3
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        05.06. 17:27:52
         max        5.79357147216797e-05
         tot        0.000159025192260742
         mAr:
           MapleCUN_2_868_MAX
   devStateIcon Initialized:message_ok@green ; .*:message_attention@red
   group      CUL
   icon       cul@orange
   room       SYSTEM
Den CULMAX0 habe ich vom alten System kopiert.
   DEF        123456
   FUUID      683c4b6c-f33f-cc74-8485-35ab252851ff18d9
   IODev      MapleCUN_2_868_MAX
   LASTInputDev
   NAME       CULMAX0
   NR         231
   STATE      MapleCUN_2_868_MAX:ok
   SVN        22175
   TYPE       CUL_MAX
   addr       123456
   cnt        0
   eventCount 12
   pairmode   0
   retryCount 0
   sq         0
     2025-06-05 16:45:25   IODev           MapleCUN_2_868_MAX
     2020-06-06 12:05:09   packetsLost     5018
     2025-06-05 17:06:41   state           MapleCUN_2_868_MAX:ok
   helper:
     bm:
       CUL_MAX_Get:
         cnt        2
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        05.06. 17:07:30
         max        1.9073486328125e-05
         tot        3.814697265625e-05
         mAr:
           HASH(0x565559847a70)
           CULMAX0
       CUL_MAX_Set:
         cnt        18
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        05.06. 17:21:05
         max        0.000325918197631836
         tot        0.00147557258605957
         mAr:
           CULMAX0
           pairmode
           60
   sendQueue:
   broadcastTimeDiff 10
   devStateIcon .*ok:temp_temperature_max@green Defined:temp_temperature_max@blue
   fakeSCaddr 222222
   fakeWTaddr 111111
   group      CUL
   icon       cul_max@grey
   room       Devices->MAX
   sortby     00000
Auch er funktioniert und kann die ebenfalls kopierten Heizungsregler ansteuern.
ABER: Es werden keine Daten vom Regler empfangen.
Also habe ich versucht Fhem mit den Reglern zu pairen. Funktioniert nicht.
Also Regler resettet. Gepairt ... nix.
Also Heizungsregler im Fhem gelöscht. Gepairt ... wieder nix.
Was mache ich falsch?  :(
Danke vorab.
ErdnaR
Wzut
Dein Maple CUN stimmt nicht :
a. scheint der auf 433Mhz aktiv zu sein statt 868
b. kein Attribut rfmode MAX gesetzt
erdnar
Das mit Pkt a. war mir auch aufgefallen. Irgendwie ist dass aber beim MapleCUN wohl so, auch bei der alten Fhem-Version.
ABER...
Der Tip mit dem rfmode war der Treffer.
Kaum macht man es richtig, klappt es auch.. ;D  ;D  ;D
Also vielen Dank
ErdnaR
