FTUI3: nach dem Update Probleme mit <ftui-departure>
Begonnen von PNinBB, 17 Juli 2025, 09:12:43
PNinBB
Vor dem update:
1. Es gibt eine FHEM-Instanz: BAD_Bus, nachfolgend das 'list'
ZitatInternals:
   .Content-Type  application/json
   .FhemMetaInternals 1
   .LASTSEND  1752735842.03287
   .LastUpdate 1752735818.23845
   .TRIGGERTIME 1752735848.23845
   .getList   Ebertplatz:noArg
   .setList   interval reread:noArg stop:noArg start:noArg clearCookies:noArg upgradeAttributes:noArg storeKeyValue
   .updateRequestHash 1
   BUSY       1
   DEF        none 30
   FUUID      66b61e5e-f33f-9b26-c06f-d1ef0abe4de1e5c4
   FVERSION   98_HTTPMOD.pm:0.291590/2024-09-23
   Interval   30
   MainURL
   ModuleVersion 4.2.0 - 11.8.2023
   NAME       BAD_Bus
   NOTIFYDEV  global
   NR         212
   NTFY_ORDER 50-BAD_Bus
   STATE      state
   TYPE       HTTPMOD
   eventCount 6639
   nextQueueRun 1752735843.04931
   value
   .attraggr:
   .attrminint:
   .readingParseList:
   CompiledRegexes:
   HttpUtils:
     NAME
     addr       https://transport.stefan-biermann.de:443
     auth       0
     buf
     code       200
     compress   1
     conn
     data
     displayurl https://transport.stefan-biermann.de/publictransportapi/rest/departure/FHEM?from=7031949&provider=Kvv
     header
     host       transport.stefan-biermann.de
     httpheader HTTP/1.0 200 OK
Content-Length: 379
Content-Type: application/json
Date: Thu, 17 Jul 2025 07:04:02 GMT
Strict-Transport-Security: max-age=31536000; includeSubDomains; preload
X-Content-Type-Options: nosniff
X-Frame-Options: SAMEORIGIN
X-Robots-Tag: noindex,nofollow,nosnippet,noarchive,notranslate,noimageindex
X-Xss-Protection: 1; mode=block
     httpversion 1.0
     hu_blocking 0
     hu_filecount 1
     hu_port    443
     hu_portSfx
     ignoreredirects 1
     loglevel   4
     path       /publictransportapi/rest/departure/FHEM?from=7031949&provider=Kvv
     protocol   https
     redirects  0
     timeout    30
     sslargs:
   QUEUE:
     HASH(0x78c7610)
     2025-07-17 09:04:02   Ebertplatz      [["201","Baden-Baden Bahnhof","1"],["207","BAD Leopoldsplatz (Luisenstraße)","5"],["216","Haueneberstein Industriegebiet","4"],["201","Lichtental","5"],["205","Baden-Baden Merkurwald","12"],["201","Baden-Baden Bahnhof","13"],["205","Baden-Baden Bahnhof über Cité","13"],["201","Oberbeuern","16"],["201","Baden-Baden Bahnhof","24"],["206","BAD Augustapl. / Museum Burda","28"]]
   REQUEST:
     context    get
     data
     header
     ignoreredirects 0
     num        01
     retryCount 0
     type       get01
     value
   defptr:
     readingBase:
       Ebertplatz get
     readingNum:
       Ebertplatz 01
     readingOutdated:
     requestReadings:
       get01:
         Ebertplatz get 01
   get01Name  Ebertplatz
   get01Regex (\[\[.*\]\]).*
   get01URL   https://transport.stefan-biermann.de/publictransportapi/rest/departure/FHEM?from=7031949&provider=Kvv
   getDecode  UTF-8
   room       Verkehr
   stateFormat state
   timeout    30
In ftui3 ein Skript wie folgt:
Zitat<ftui-label class="size-3" text="Busverkehr" color="red"></ftui-label>
<ftui-column align-items="top">
 <ftui-departure class="size-3"
    ="BAD_Bus:Ebertplatz" DVB icon="bus" getinterval="10" station="Ebertplatz" manuell alternate></ftui-departure>
    </ftui-column>
Vor dem update funktionierte es über ein Jahr perfekt. Nach dem update bleibt die ftui-Anzeige leer, genauer Bild, refresh-Option. icon etc. sind in Ordnung: nur der Text: 'keine Abfahrten vorhanden' wird angezeigt. Die Angaben auf der FHEM - Seite werden weiter korrekt aktualisiert !
Hat jemand ähnliche Erfahrungen und/oder eventuell einen Tipp.
Besten Dank im voraus.
Peter[/list]
Raspi 4B + RaZberry2 (Deb 10), FritzBox 7490;
AEOTec: KeyFobGen5: 1x;
Danfoss: Living Connect 2.51: 3x;
Fibaro: FGK: 10x: 3x; FGBS: 001: 8x, 222: 1x; FGMS001: 2x; FGR: 222: 3x, 223: 2x; FGRGBWM-441: 1x; FGBS: 222: 2x, 223: 2x,224: 1x;
Philio: PAN06-1A: 3x;
juemuc
setstate hat mit den letzten Updates umfassende Änderungen vorgenommen. Da wirst Du dich leider step bei step durchhangeln müssen. Da haben viele ihre Installation anpassen müssen.
Jürgen
3x Sonos Play 1, 1x Sonos Arc + Sub, 1 Sonos-One, 1x Sonos Playbar
FB6690 + FB7490 mit 4x Dect 200 und 3 Dect-ULE-Thermostate,  raspberry3B+, HM Funkmodul HM-MOD-RPI-PCB, HM Klingelsensor HM-Sen-DB-PCB, HM (IP) Fensterkontakte und  Amazon Echo Dot,  piVCCU, pi OS (bookworm).
PNinBB
Danke für die Antwort. Die ganzen Layoutprobleme hatte ich schon angepasst, da ich ja auch diesbezügliches gelesen hatte. Das einzigste Problem, was geblieben war, betraf die Abfahrtsanzeigen des Busses (departure - Modul). Das habe ich nicht hinbekommen. Nun bin ich erst einmal wieder zurück zur vorhergehenden Version und da funktioniert es wieder.
Peter.
