Viele Perl-Warnings bei DWD-OpenData und Weather.pm nach Debian-13 -Umstieg
Begonnen von juemuc, 22 September 2025, 11:32:39
juemuc
Hallo
ich habe jetzt mein FHEM-Testsysstem auf Debian 13 (trixie) umgezogen. Nun erhalte ich folgende Perl-Warnings:
2025.09.22 10:36:25.559 1: PERL WARNING: when is deprecated at ./FHEM/55_DWD_OpenData.pm line 1020, <$fh> line 3399.
2025.09.22 10:36:25.560 1: PERL WARNING: when is deprecated at ./FHEM/55_DWD_OpenData.pm line 1040, <$fh> line 3399.
2025.09.22 10:36:25.560 1: PERL WARNING: when is deprecated at ./FHEM/55_DWD_OpenData.pm line 1058, <$fh> line 3399.
2025.09.22 10:36:25.560 1: PERL WARNING: when is deprecated at ./FHEM/55_DWD_OpenData.pm line 1062, <$fh> line 3399.
2025.09.22 10:36:25.560 1: PERL WARNING: when is deprecated at ./FHEM/55_DWD_OpenData.pm line 1065, <$fh> line 3399.
2025.09.22 10:36:25.560 1: PERL WARNING: when is deprecated at ./FHEM/55_DWD_OpenData.pm line 1068, <$fh> line 3399.
025.09.22 10:36:26.098 1: PERL WARNING: given is deprecated at lib/FHEM/Core/Weather.pm line 227, <$fh> line 4495.
2025.09.22 10:36:26.099 1: PERL WARNING: when is deprecated at lib/FHEM/Core/Weather.pm line 228, <$fh> line 4495.
2025.09.22 10:36:26.099 1: PERL WARNING: when is deprecated at lib/FHEM/Core/Weather.pm line 235, <$fh> line 4495.
2025.09.22 10:36:26.099 1: PERL WARNING: when is deprecated at lib/FHEM/Core/Weather.pm line 242, <$fh> line 4495.
2025.09.22 10:36:26.099 1: PERL WARNING: when is deprecated at lib/FHEM/Core/Weather.pm line 249, <$fh> line 4495.
2025.09.22 10:36:26.099 1: PERL WARNING: when is deprecated at lib/FHEM/Core/Weather.pm line 256, <$fh> line 4495.
2025.09.22 10:36:26.102 1: PERL WARNING: given is deprecated at lib/FHEM/Core/Weather.pm line 865, <$fh> line 4495.
2025.09.22 10:36:26.102 1: PERL WARNING: when is deprecated at lib/FHEM/Core/Weather.pm line 866, <$fh> line 4495.
2025.09.22 10:36:26.102 1: PERL WARNING: when is deprecated at lib/FHEM/Core/Weather.pm line 878, <$fh> line 4495.
2025.09.22 10:36:26.102 1: PERL WARNING: when is deprecated at lib/FHEM/Core/Weather.pm line 883, <$fh> line 4495.
verbose steht auf 2.
Jürgen
3x Sonos Play 1, 1x Sonos Arc + Sub, 1 Sonos-One, 1x Sonos Playbar
FB6690 + FB7490 mit 4x Dect 200 und 3 Dect-ULE-Thermostate,  raspberry3B+, HM Funkmodul HM-MOD-RPI-PCB, HM Klingelsensor HM-Sen-DB-PCB, HM (IP) Fensterkontakte und  Amazon Echo Dot,  piVCCU, pi OS (bookworm).
JoWiemann
hatten wir hier auch schon mal: https://forum.fhem.de/index.php?topic=138614.0
PS: Wurde mit der Version vom 05.06.2025 behoben. Da hast Du wohl kein aktuelles Fhem.
Grüße Jörg
Am Besten den Maintainer mal anschreiben.
Jörg Wiemann
