Zigbee2MQTT - Funktioniert nicht in FHEM > Neues Problem
Begonnen von Brad Majors, 07 Oktober 2025, 15:03:49
Brad Majors
Zum Hintergrund:
Nachdem Phoscon alle paar Monate die Verbindung von den meisten Lampen verliert möchte ich ZB2MQTT versuchen.
- ZB2MQTT wurde auf einem separaten PI eingerichtet und Frontend funktioniert.
In FHEM wurde eine bridge eingerichtet:
   CID        zigbee_pi
   DEF        zigbee_pi
   FUUID      68e505ab-f33f-2a6c-1482-092b9754e2bfa3da
   IODev      m2server
   NAME       MQTT2_zigbee_pi
   NR         660
   STATE      ???
   TYPE       MQTT2_DEVICE
     2025-10-07 14:42:55   IODev           m2server
     2025-10-07 14:41:30   attrTemplateVersion 20240628
   autocreate 1
   bridgeRegexp zigbee2mqtt/((?!bridge)[A-Za-z0-9._]+)/?.*:.* "zigbee_$1"
   comment    To check for new updates of the deamon software, you might want to use a separate HTTPMOD device. See HTTPMOD template zigbee2mqtt_daemon_updates for further details.
   devicetopic zigbee2mqtt
   getList    networkmap_raw:noArg raw $DEVICETOPIC/bridge/request/networkmap raw
  networkmap_graphviz:noArg graphviz $DEVICETOPIC/bridge/request/networkmap graphviz
   icon       mqtt
   model      zigbee2mqtt_bridge
   readingList $DEVICETOPIC/bridge/state:.* state
  $DEVICETOPIC/bridge/config/devices:.* {}
  $DEVICETOPIC/bridge/config/log_level:.* log_level
  $DEVICETOPIC/bridge/config/permit_join:.* permit_join
  $DEVICETOPIC/bridge/config/rename:.* { json2nameValue($EVENT, 'rename_') }
  $DEVICETOPIC/bridge/config:.* { json2nameValue($EVENT) }
  $DEVICETOPIC/bridge/log:.*\"type\".\"devices\".\"message\".* devices
  $DEVICETOPIC/bridge/log:.* log
  $DEVICETOPIC/bridge/logging:.* { json2nameValue($EVENT,'log_') }
  $DEVICETOPIC/bridge/response/networkmap:.* { my $type = $EVENT =~ m/.*,"type":"(raw|graphviz)",.*/ ? $1 : 'networkmap'; $EVENT =~ m/{"data":\{.*"value":"?(.*[^"])"?\},"status":"ok"\}/ ? { $type=>$1 } : {} }
  $DEVICETOPIC/bridge/devices:.* devices
  $DEVICETOPIC/bridge/info:.* info
  $DEVICETOPIC/bridge/groups:.* groups
  $DEVICETOPIC/bridge/event:.* { json2nameValue($EVENT) }
  $DEVICETOPIC/bridge/extensions:.* extensions
  $DEVICETOPIC/bridge/response/permit_join:.* { json2nameValue($EVENT) }
  $DEVICETOPIC/bridge/definitions:.* {}
   room       97_ZB2MQTT
   setList    log_level:debug,info,warn,error $DEVICETOPIC/bridge/config/log_level $EVTPART1
  permit_join:true,false $DEVICETOPIC/bridge/request/permit_join $EVTPART1
  remove:textField $DEVICETOPIC/bridge/config/remove $EVTPART1
  ota_update:textField $DEVICETOPIC/bridge/ota_update/update $EVTPART1
  ota_update_check:textField $DEVICETOPIC/bridge/ota_update/check $EVTPART1
  y_device_setting:textField $DEVICETOPIC/$EVTPART1/set {"$EVTPART2": "$EVTPART3"}
  x_bind:textField $DEVICETOPIC/bridge/bind/$EVTPART1 $EVTPART2
  x_bind_unbind:textField $DEVICETOPIC/bridge/unbind/$EVTPART1 $EVTPART2
  x_device_options:textField $DEVICETOPIC/bridge/config/device_options {"friendly_name":"$EVTPART1","options": {"$EVTPART2": "$EVTPART3"}}
  x_group_add_to:textField $DEVICETOPIC/bridge/group/$EVTPART1/add $EVTPART2
  x_group_rm_from:textField $DEVICETOPIC/bridge/group/$EVTPART1/remove $EVTPART2
  x_group_rm_from_all:textField $DEVICETOPIC/bridge/group/$EVTPART1/remove_all $EVTPART2
  x_group_add_group:textField $DEVICETOPIC/bridge/config/add_group $EVTPART1
  x_group_rm_group:textField $DEVICETOPIC/bridge/config/remove_group $EVTPART1
  z_elapsed:textField $DEVICETOPIC/bridge/config/elapsed $EVTPART1
  z_last_seen:disable,ISO_8601,epoch,ISO_8601_local $DEVICETOPIC/bridge/config/last_seen $EVTPART1
  z_ban:textField $DEVICETOPIC/bridge/config/ban $EVTPART1
  z_rename:textField $DEVICETOPIC/bridge/config/rename  {"old":"$EVTPART1","new":"$EVTPART2"}
  z_reset_CC:noArg $DEVICETOPIC/bridge/config/reset
   setStateList on off
Im Frontend lässt sich eine Lampe sowie ein Schalter problemlos bedienen.
Sollten diese jetzt nicht in FHEM aufschlagen?
Wo liegt mein Denkfehler?
Raspberry Pi. * Eigenbau Nano Cul 433 und 866 * EnOcean TCM_3 * Netatmo * Max! Thermostate * SMA PV Inverter * Zigbee über ConBeeII / Phoscon
binford6000
Zitat von: Brad Majors am 07 Oktober 2025, 15:03:49Sollten diese jetzt nicht in FHEM aufschlagen?
Ja das sollten sie.
  • Ist das IODev (mserver) connected?
  • Was ist das IODev für ein Typ? Bei MQTT2CLIENT/SERVER kannst du dir den Traffic anschauen. Kommt da was an?
  • Stimmt das topic überhaupt?
  • Ist das globale (FEHM) autocreate auch enabled?
VG Sebastian
passibe
Zum Bridge-Device, die Definition aus dem Wiki ist inzwischen wegen Z2M Version 2 veraltet.
Hier hatte ich mal eine rudimentäre Definition gepostet: https://forum.fhem.de/index.php?topic=140307.msg1333978#msg1333978
Bin mir grade aber nicht sicher, ob das für autocreate noch so valide ist, das nutze ich nicht. (Ich würde aber eigentlich sowieso empfehlen, nicht autocreate zu nutzen, sondern einfach die Geräte manuell in FHEM anzulegen, schön sauber mit json2nameValue und devicetopic, etc. Die attrTemplates kann man natürlich als Inspiration nutzen.)
Brad Majors
#3
> Ja, aber jetzt wird es kompliziert, das ist ein mserver der auch mqtt von den Tasmota Wifi Schaltern abgreift.
> Muss ich einen neuen für die Zigbee MQTT anlegen? Oder läuft das über einen? Sorry für die blöde Frage.
> m2server
> Wo schaut man das?
> Ja, da bin ich mir sicher, das habe ich im Z2M im GUI sehen können
> zigbee2mqtt
> Ja, steht auf simple
Oder muß ich noch was im Z2M eintragen?
Zitat von: Brad Majors am 07 Oktober 2025, 16:54:32Bei MQTT2CLIENT/SERVER kannst du dir den Traffic anschauen. Kommt da was an?
> Wo schaut man das?
Da wo auf der Detailseite Deines m2server in FHEM steht "Show MQTT traffic"
Ziemlich weit oben links, direkt unter der FHEM Befehlszeile.
Zitat> Muss ich einen neuen für die Zigbee MQTT anlegen?
Nein, ein MQTT Server reicht, solange die Geraete unterschiedliche Topics oder MQTT-ClientIDs verwenden.
Damit autocreate funktioniert, muss sowohl eine autocreate Instanz definiert sein (ist in der initialen Version von fhem.cfg der Fall), wie auch das Attribut autocreate des IODevs.
Bei MQTT2_SERVER ist das Attribut per Voreinstellung no, bei MQTT2_SERVER simple.
D.h. wenn man nichts geaendert oder geloescht hat, dann ist bei MQTT2_SERVER autocreate aktiv.
MQTT2_DEVICE Instanzen werden dann automatisch angelegt, wenn eine Nachricht von einem Geraet empfangen wurde.
Bei gateways wie z2m muss zusaetzlich ein bridgeRegexp Attribut gesetzt sein (siehe oben, ist der Fall), damit das Modul die Nachrichten den einzelnen Geraeten zuordnen kann.
Brad Majors
Traffic kommt nur von den shellys und Tasmotas an. Vom Z2MQTT erscheint nichts.
Ich glaube in meinen Einstellungen in Z2MQTT fehlen noch Daten.
Das sieht noch ziemlich leer aus, schaut euch mal das Bild an.
Und ich bin mir auch nicht sicher was ich dort alles eintragen muß.
FHEM läuft auf einem anderen PI mit der 192.168.178.117
Der neue PI mit Z2MQTT nutzt die 192.168.178.118
Auto create funktioniert bisher auch mit den Tasmotas usw., denke also nicht das es daran liegt.
ZitatFHEM läuft auf einem anderen PI mit der 192.168.178.117
Dann sollte der Eintrag unter "MQTT Server" auch diese Adresse haben.
passibe
Und ggfs. auch die im zugehörigen allowed-Device konfigurierte Benutzername-Passwort-Kombination ...
Am besten die MQTT-Serverdaten (Host, Port, Benutzername, Passwort) so einstellen wie auf den bereits funktionierenden Tasmota-Geräten.
Brad Majors
Vielen Dank an euch alle!
Nachdem ich den Server 192.168.178.117 im Z2MQTT Pi eingetragen habe kamen die Daten an. Die Test Lampe und der Test Schalter sind schon mal sichtbar und wurden erkannt.
Jetzt muss ich mal in FHEM basteln und damit spielen.
Ohne euch wäre ich nicht auf die Lösung gekommen, mit dem traffic ist mir auch neu, gefällt mir aber gut.
Brad Majors
#10
Wobei so wie es aussieht kommen die Daten zwar in FHEM an, wenn ich aber z.B. versuche eine GU10 Dimm LED zu schalten kommt diese Meldung in Z2MQTT an?
z2m: Entity 'PAR16\x20GU10\x20-\x20Kueche\x2001' is unknown
Zitat von: Brad Majors am 07 Oktober 2025, 20:45:45Wobei so wie es aussieht kommen die Daten zwar in FHEM an, wenn ich aber z.B. versuche eine GU10 Dimm LED zu schalten kommt diese Meldung in Z2MQTT an?
a) Der Thread gehört nach MQTT.
b) zu friendly names siehe z.B. https://forum.fhem.de/index.php?msg=1337347
