Homematic via CCU reagiert nicht mehr: "Sending data to FHEM failed 100 times."
Begonnen von stobor, 11 Oktober 2025, 14:30:18
stobor
im FHEM-Log erhalte ich seit 2 Tagen diese Fehler, ohne dass sich an der CCU oder FHEM etwas geändert hat:
2025.10.11 09:56:02 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Sending data to FHEM failed 100 times. select found no reader
2025.10.11 09:57:46 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Sending data to FHEM failed 100 times. select found no reader
2025.10.11 11:53:57 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.063524007797 seconds
2025.10.11 12:00:12 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.061312913895 seconds
2025.10.11 12:10:12 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.049233198166 seconds
2025.10.11 12:20:12 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.042794942856 seconds
2025.10.11 12:30:12 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.069442987442 seconds
2025.10.11 12:40:12 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.059836149216 seconds
2025.10.11 12:50:13 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.053718090057 seconds
2025.10.11 13:00:13 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.04188990593 seconds
2025.10.11 13:10:13 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.046332836151 seconds
2025.10.11 13:20:13 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.057385921478 seconds
2025.10.11 13:30:13 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.060159921646 seconds
2025.10.11 13:40:13 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.05544090271 seconds
2025.10.11 13:50:13 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.056032180786 seconds
2025.10.11 14:00:13 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Received no events from interface CB2001179010179011 for 600.044595003128 seconds
2025.10.11 14:00:13 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Read stopped after 1 events read: no data
Ich kann über FHEM weder Befehle via CCU an Homwmatic-Geräte senden noch empfängt FHEM Statusänderungen von der CCU.
Ich habe sowohl die CCU als auch FHEM schon neu gestartet, doch nach ein paar Stunden tritt das Problem wieder auf.
Auch wenn ich nur HMCCU (d_ccu) stoppe und starte, läuft wieder alles. Log-Auszug nach dem Restart per FHEM (set d_ccu off dann set d_ccu on):
2025.10.11 14:15:23 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:15:23 1: HMCCURPCPROC [d_rpc179011HmIP_RF] Stopping RPC server CB2010179010179011
2025.10.11 14:15:23 1: HMCCURPCPROC [d_rpc179011HmIP_RF] Deregistering RPC server http://192.168.179.10:7420/fh2010 with ID CB2010179010179011 at http://192.168.179.11:2010
2025.10.11 14:15:23 1: HMCCURPCPROC [d_rpc179011HmIP_RF] Callback for RPC server CB2010179010179011 deregistered
2025.10.11 14:15:23 2: HMCCURPCPROC [d_rpc179011HmIP_RF] Sending signal INT to RPC server process CB2010179010179011 with PID=1997
2025.10.11 14:15:23 2: HMCCURPCPROC [d_rpc179011HmIP_RF] Scheduling cleanup in 30 seconds
2025.10.11 14:15:23 2: HMCCURPCPROC [d_rpc179011HmIP_RF] CB2010179010179011 received signal INT
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:15:24 1: HMCCURPCPROC [d_rpc179011BidCos_RF] Stopping RPC server CB2001179010179011
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Set state to busy
2025.10.11 14:15:24 1: HMCCURPCPROC [d_rpc179011BidCos_RF] Deregistering RPC server http://192.168.179.10:7411/fh2001 with ID CB2001179010179011 at http://192.168.179.11:2001
2025.10.11 14:15:24 1: HMCCURPCPROC [d_rpc179011BidCos_RF] Callback for RPC server CB2001179010179011 deregistered
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Set rpcstate to deregistered
2025.10.11 14:15:24 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Sending signal INT to RPC server process CB2001179010179011 with PID=1996
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Set rpcstate to stopping
2025.10.11 14:15:24 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Scheduling cleanup in 30 seconds
2025.10.11 14:15:24 2: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 received signal INT
2025.10.11 14:15:24 1: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 stopped handling connections. PID=1996 run=0
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Event statistics = 691|191|0|0|0|0|0|0|0|0|0
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 event type = EV: 448
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 event type = ND: 242
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 event type = DD: 0
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 event type = RD: 0
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 event type = RA: 0
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 event type = UD: 0
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 event type = IN: 0
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 event type = EX: 1
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 event type = SL: 1
2025.10.11 14:15:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 event type = TO: 0
2025.10.11 14:15:24 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Number of I/O errors = 0
2025.10.11 14:15:25 1: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server process CB2001179010179011 terminated.
2025.10.11 14:15:25 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Set rpcstate to inactive
2025.10.11 14:15:25 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Stop I/O handling
2025.10.11 14:15:25 3: HMCCURPCPROC [d_rpc179011BidCos_RF] Close child socket
2025.10.11 14:15:25 3: HMCCURPCPROC [d_rpc179011BidCos_RF] Close parent socket
2025.10.11 14:15:25 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Set state to OK
2025.10.11 14:15:25 2: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server stopped. Cancel delayed shutdown.
2025.10.11 14:15:53 1: HMCCURPCPROC [d_rpc179011HmIP_RF] Housekeeping called. Cleaning up RPC environment
2025.10.11 14:15:53 2: HMCCURPCPROC [d_rpc179011HmIP_RF] CB2010179010179011 received signal INT
2025.10.11 14:15:53 1: HMCCURPCPROC [d_rpc179011HmIP_RF] RPC server CB2010179010179011 stopped handling connections. PID=1997 run=0
2025.10.11 14:15:53 2: HMCCURPCPROC [d_rpc179011HmIP_RF] Number of I/O errors = 0
2025.10.11 14:15:55 2: HMCCURPCPROC [d_rpc179011HmIP_RF] RPC server process CB2010179010179011 deleted
2025.10.11 14:15:55 1: HMCCU [d_ccu] All RPC servers inactive
2025.10.11 14:15:55 2: HMCCURPCPROC [d_rpc179011HmIP_RF] Stop I/O handling
2025.10.11 14:15:55 2: HMCCURPCPROC [d_rpc179011HmIP_RF] RPC server stopped. Cancel delayed shutdown.
2025.10.11 14:15:57 1: PERL WARNING: Use of uninitialized value in sprintf at (eval 881545) line 1.
2025.10.11 14:16:01 2: HMCCU [d_ccu] RPC device for interface HmIP-RF: d_rpc179011HmIP_RF
2025.10.11 14:16:01 2: HMCCU [d_ccu] RPC device for interface BidCos-RF: d_rpc179011BidCos_RF
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011HmIP_RF] RPC server process started for interface HmIP-RF with PID=2005
2025.10.11 14:16:01 1: HMCCURPCPROC [d_rpc179011HmIP_RF] RPC server starting
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011HmIP_RF] Initializing RPC server CB2010179010179011 for interface HmIP-RF
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server process started for interface BidCos-RF with PID=2006
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Set state to busy
2025.10.11 14:16:01 1: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server starting
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Set rpcstate to starting
2025.10.11 14:16:01 2: HMCCU [d_ccu] RPC server start: 2 started, 0 already running, 0 failed to start
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Initializing RPC server CB2001179010179011 for interface BidCos-RF
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011HmIP_RF] Callback server CB2010179010179011 created. Listening on port 7420
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011HmIP_RF] RPC server CB2010179010179011 enters server loop
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011HmIP_RF] Registering callback http://192.168.179.10:7420/fh2010 of type A with ID CB2010179010179011 at http://192.168.179.11:2010
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011HmIP_RF] CB2010179010179011 accepting connections. PID=2005
2025.10.11 14:16:01 1: HMCCURPCPROC [d_rpc179011HmIP_RF] RPC server CB2010179010179011 running
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Callback server CB2001179010179011 created. Listening on port 7411
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Adding callback for events for server CB2001179010179011
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Adding callback for new devices for server CB2001179010179011
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Adding callback for deleted devices for server CB2001179010179011
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Adding callback for modified devices for server CB2001179010179011
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Adding callback for replaced devices for server CB2001179010179011
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Adding callback for readded devices for server CB2001179010179011
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Adding callback for list devices for server CB2001179010179011
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 accepting connections. PID=2006
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 enters server loop
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Set rpcstate to working
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011BidCos_RF] Registering callback http://192.168.179.10:7411/fh2001 of type A with ID CB2001179010179011 at http://192.168.179.11:2001
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 processing request
2025.10.11 14:16:01 1: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 running
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Set rpcstate to running
2025.10.11 14:16:01 1: HMCCU [d_ccu] All RPC servers running
2025.10.11 14:16:01 2: HMCCU [d_ccu] Updating 50 of 81 devices matching devexp=.* filter=ccudevstate=active,ccuif=HmIP-RF|BidCos-RF nonBlocking
2025.10.11 14:16:01 2: HMCCU [d_ccu] CCU device list 2b updated: HM-RC-Auto-Mirko,HM-HT-Wohnzimmer-West,HM-SC-Schuppen-West,HM-HT-Arbeitszimmer,HmIP-PIR-CarportOst,HM-HT-Schlafzimmer,HM-WS-Kueche-Boden,HM-HT-Flur,HM-PIR-Sued-Ost,HM-HT-Wohnzimmer-Sued,HM-HT-Kinderzimmer,HmIP-HWR-8fachSender,HM-SC-Kinderzimmer,HM-RM-Flur-EG,HM-SC-Kueche-Sued,HM-RM-Schlafzimmer,HM-SC-Schlafzimmer,HM-RC-Auto-Julia,HM-SC-Wohnzimmer-Sued,HM-SC-Badezimmer,HM-SC-Arbeitszimmer,HM-RM-Kind,HM-RM-Arbeitszimmer,HM-WS-HWR,HmIP-HWR-8fachReceiver,HM-SC-Wohnzimmer-West-Nord,HmIP-PS-2_Steckdose1,HM-PIR-Carport-Ost,HM-SC-Wohnzimmer-West-Sued,HM-Temperatur-Pool,HM-Sw-Kueche-Sued,HM-SC-Haustuer,HM-RM-Flur-OG,HM-RC-Schuppen,HM-SC-HWR-Tuer,HM-WT-Wohnzimmer,HM-SC-GaesteWC,HM-HT-Kueche,HM-SC-HWR-Fenster,HM-SC-Schuppen-Carport,HM-SC-Wohnzimmer-Terrassentuer,HM-WT-Bad,HM-HT-GaesteWC,HM-TH-Garten,HM-Sw-Kueche-West,HM-RM-HWR,HM-WS-Kueche-Schrank,HM-SC-Kueche-Ost,HM-HT-Bad,HM-PIR-Wohnzimmer
2025.10.11 14:16:01 2: HMCCU [d_ccu] FHEM device list 2b updated: HM_SC_EG_HWRFenster,HM_SC_Schuppen_West,HM_TH_Garten,HM_RC1_Btn_04,HM_SC_EG_WohnzimmerSued,HmIP_PIR_CarportOst,HM_Sw_Kueche_West,HmIP_MOD_RC8_00145F29B409A2_5,HM_SC_EG_HWRTuer,HM_HT_Wohnzimmer_West,HmIP_MOD_OC8_000D20C9A8C464_21_TasterGruen_LED,HmIP_MOD_OC8_000D20C9A8C464_29,HM_SC_OG_Arbeitszimmer,HM_HT_GaesteWC,HM_HT_Kueche,HM_SC_EG_WohnzimmerWestSued,HmIP_MOD_RC8_00145F29B409A2_4,HM_RM_Flur_EG,HM_SC_OG_Schlafzimmer,HmIP_MOD_RC8_00145F29B409A2_8,HM_RM_HWR,HM_6C104A_Btn_03,HmIP_MOD_RC8_00145F29B409A2_2,HM_6C104A_Btn_05,HM_RM_Arbeitszimmer,HM_SC_EG_Haustuer,HM_WDS30_OT2_SM_UEQ1875731_1,HM_SC_EG_WohnzimmerTerrassentuer,HM_WDS30_OT2_SM_UEQ1875731_2,HM_RM_Flur_OG,HmIP_MOD_OC8_000D20C9A8C464_17_verzoegerteUeberwachung_LED,HM_PIR_Wohnzimmer,HM_SC_OG_Kinderzimmer,HmIP_MOD_OC8_000D20C9A8C464_33_BlinkLED,HmIP_MOD_OC8_000D20C9A8C464_13_Tuersummer_LED,HM_6C104A_Btn_02,HM_RM_Schlafzimmer,HM_SC_Schuppen_Carport,HmIP_MOD_RC8_00145F29B409A2_6,HM_HT_Flur,HM_RC2_Btn_04,HM_HT_Bad,HM_WDS30_OT2_SM_UEQ1875731_3,HM_WT_Wohnzimmer,HM_6C104A_Btn_04,HmIP_FensterbankWohnzimmer,HmIP_MOD_OC8_000D20C9A8C464_9_CarportLicht_LED,HM_6C104A_Btn_07,HM_HT_Arbeitszimmer,HM_Bewegungsmelder_Carport_Ost,HM_6C104A_Btn_06,HmIP_MOD_OC8_000D20C9A8C464_37,HM_RC2_Btn_01,HM_WT_Bad,HM_RC1_Btn_02,HM_WS_HWR,HM_RM_Kind,HM_RC1_Btn_03,HM_WS_Kueche_Boden,HM_HT_Schlafzimmer,HmIP_MOD_OC8_000D20C9A8C464_25_TasterSchwarz_LED,Bewegungsmelder_Sued_HM,HM_WDS30_OT2_SM_UEQ1875731_5,HM_RC2_Btn_03,HM_SC_OG_Badezimmer,HM_WDS30_OT2_SM_UEQ1875731_4,HM_WS_Kueche_Schrank,HM_RC2_Btn_02,HM_6C104A_Btn_08,HM_RC1_Btn_01,HM_SC_EG_KuecheSued,HmIP_MOD_RC8_00145F29B409A2_1,HM_Sw_Kueche_Sued,HmIP_MOD_RC8_00145F29B409A2_7,HM_SC_EG_GaesteWC,HM_SC_EG_WohnzimmerWestNord,HM_HT_Wohnzimmer_Sued,HM_6C104A_Btn_01,HmIP_MOD_RC8_00145F29B409A2_3,HM_HT_Kinderzimmer,HM_SC_EG_KuecheOst
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Set state to OK
2025.10.11 14:16:01 1: HMCCURPCPROC [d_rpc179011BidCos_RF] Scheduled CCU ping every 300 seconds
2025.10.11 14:16:01 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Read stopped after 1 events read: no data
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011HmIP_RF] CB2010179010179011 NewDevice received 146 device and channel specifications
2025.10.11 14:16:01 2: HMCCURPCPROC [d_rpc179011BidCos_RF] CB2001179010179011 NewDevice received 242 device and channel specifications
2025.10.11 14:16:02 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:02 2: HMCCU [d_ccu] Update success=81 failed=0
2025.10.11 14:16:02 2: HMCCU [d_ccu] Updated devices: HM-SC-Schuppen-Carport,HM-HT-Wohnzimmer-Sued,HM-TH-Garten,HmIP-PIR-CarportOst,HM-SC-Haustuer,HM-SC-Kinderzimmer,HM-SC-Schlafzimmer,HmIP-HWR-8fachSender,HM-RM-Arbeitszimmer,HM-SC-HWR-Fenster,HM-HT-Flur,HM-SC-Wohnzimmer-Terrassentuer,HmIP-PS-2_Steckdose1,HM-SC-Schuppen-West,HM-PIR-Sued-Ost,HM-HT-Bad,HmIP-HWR-8fachReceiver,HM-SC-Arbeitszimmer,HM-HT-Schlafzimmer,HM-Temperatur-Pool,HM-RM-Kind,HM-SC-Wohnzimmer-Sued,HM-RM-Schlafzimmer,HM-SC-Kueche-Sued,HM-RC-Auto-Mirko,HM-SC-GaesteWC,HM-HT-Wohnzimmer-West,HM-WS-Kueche-Schrank,HM-HT-GaesteWC,HM-PIR-Carport-Ost,HM-RM-HWR,HM-RC-Schuppen,HM-HT-Kueche,HM-WS-Kueche-Boden,HM-WS-HWR,HM-WT-Bad,HM-SC-Kueche-Ost,HM-RM-Flur-OG,HM-RC-Auto-Julia,HM-PIR-Wohnzimmer,HM-WT-Wohnzimmer,HM-SC-Wohnzimmer-West-Sued,HM-HT-Arbeitszimmer,HM-Sw-Kueche-Sued,HM-Sw-Kueche-West,HM-RM-Flur-EG,HM-SC-Wohnzimmer-West-Nord,HM-SC-HWR-Tuer,HM-SC-Badezimmer,HM-HT-Kinderzimmer
2025.10.11 14:16:02 2: HMCCU [d_ccu] Update failed for:
2025.10.11 14:16:02 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Read stopped after 100 events
2025.10.11 14:16:02 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Read stopped after 40 events read: no data
2025.10.11 14:16:03 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:04 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:05 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:06 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:07 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:08 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:09 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:10 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:11 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:12 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:13 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:14 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:15 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:16 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:17 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:18 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:19 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:19 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 processing request
2025.10.11 14:16:19 4: HMCCURPCPROC [d_rpc179011BidCos_RF] Read stopped after 1 events read: no data
2025.10.11 14:16:20 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:21 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:22 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:23 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:24 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:25 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
2025.10.11 14:16:26 4: HMCCURPCPROC [d_rpc179011BidCos_RF] RPC server CB2001179010179011 accepting connections
Meine FHEM.cfg für die CCU-Anbindung sieht so aus:
# Homematic via CCU
define d_ccu HMCCU 192.168.179.11
setuuid d_ccu 67658243-f33f-2cfb-13c4-7e39c5fbb59dfb67
attr d_ccu ccuGetVars 60:D.*
attr d_ccu ccuflags logCommand
attr d_ccu event-on-change-reading .*
attr d_ccu room Homematic
attr d_ccu rpcinterfaces BidCos-RF,HmIP-RF
attr d_ccu rpcserver on
attr d_ccu stateFormat rpcstate/state
attr d_ccu verbose 3
# NEU:
define FileLog_d_ccu FileLog ./log/d_ccu-%Y-%m.log d_ccu:DutyC.*
setuuid FileLog_d_ccu 67b6cf7b-f33f-2cfb-d184-f7efde5991b5fb6f
attr FileLog_d_ccu logtype text
attr FileLog_d_ccu room Logs,Homematic
define d_rpc179011HmIP_RF HMCCURPCPROC http://192.168.179.11 HmIP-RF
setuuid d_rpc179011HmIP_RF 67658243-f33f-2cfb-cb96-326106ac99baff20
attr d_rpc179011HmIP_RF alias CCU 179011 RPC HmIP-RF
attr d_rpc179011HmIP_RF eventMap /rpcserver on:on/rpcserver off:off/
attr d_rpc179011HmIP_RF room Homematic
attr d_rpc179011HmIP_RF stateFormat rpcstate/state
attr d_rpc179011HmIP_RF verbose 2
define d_rpc179011BidCos_RF HMCCURPCPROC http://192.168.179.11 BidCos-RF
setuuid d_rpc179011BidCos_RF 6765824c-f33f-2cfb-70d5-6ba11d197fdacbf6
attr d_rpc179011BidCos_RF alias CCU 179011 RPC BidCos-RF
attr d_rpc179011BidCos_RF eventMap /rpcserver on:on/rpcserver off:off/
attr d_rpc179011BidCos_RF room Homematic
attr d_rpc179011BidCos_RF stateFormat rpcstate/state
attr d_rpc179011BidCos_RF verbose 4
#define d_rpc179011CUxD HMCCURPCPROC http://192.168.179.11 CUxD
#setuuid d_rpc179011CUxD 6765824d-f33f-2cfb-6443-d76eb73a86c49063
#attr d_rpc179011CUxD alias CCU 179011 RPC CUxD
#attr d_rpc179011CUxD eventMap /rpcserver on:on/rpcserver off:off/
#attr d_rpc179011CUxD room Homematic
#attr d_rpc179011CUxD stateFormat rpcstate/state
#attr d_rpc179011CUxD verbose 2
define d_rpc179011VirtualDevices HMCCURPCPROC http://192.168.179.11 VirtualDevices
setuuid d_rpc179011VirtualDevices 6765824d-f33f-2cfb-8691-f78bd3bd0e52e514
attr d_rpc179011VirtualDevices alias CCU 179011 RPC VirtualDevices
attr d_rpc179011VirtualDevices eventMap /rpcserver on:on/rpcserver off:off/
attr d_rpc179011VirtualDevices room Homematic
attr d_rpc179011VirtualDevices stateFormat rpcstate/state
attr d_rpc179011VirtualDevices verbose 2
Hat jemand eine Idee, warum ich auf einmal diese Probleme haben könnte?
Danke für eure Hilfe.
Intel NUC (Ubuntu 24.04.4 LTS)  mit CUL V3.2 (FW 1.57 CUL868) für FS20 und CCU3 für HM(IP) + Arduino Mega (Firmata) - FHEM Revision: 31515 - FS20, HM(IP), MQTT, Philips HUE, ModBus
passibe
Steht irgendwas auffälliges im Log der CCU, wenn der Fehler auftritt? Log ist über SSH abrufbar.
Firewall auf dem FHEM-System ist nicht konfiguriert bzw. loggt nichts auffälliges (wenn ufw, syslog überprüfen)?
Ansonsten:
Ich mache jede Nacht ein set ccu off; sleep 60; set ccu on. Wurde hier schonmal irgendwo diskutiert, finde es gerade aber nicht. Vielleicht reicht das ja erstmal, damit das System benutzbar ist, vorausgesetzt der rpcserver "überlebt" mindestens 24h (wobei man den Zeitraum natürlich auch kürzen kann)?
Ansonsten 2 (hat aber nix mit deinem Problem zu tun):
Immer erst die CCU neustarten und dann FHEM bzw. immer nach einem Neustart der CCU in FHEM den rpcserver neustarten. Nach einem Neustart der CCU verliert der rpcserver immer die Verbindung und muss immer manuell neugestartet werden.
stobor
passibe
Unter /var/log. Relevant dürften messages und hmserver.log sein.
Aber keine Garantie, dass da etwas Interessantes drin steht, ist mehr so ein erster Anlaufpunkt. Aber vielleicht hast du ja Glück und ein Ereignis im Log korreliert mit dem Zeitpunkt, in dem der Fehler auftritt.
stobor
Danke!
Ich werde die Logs einmal herunterladen, sobald das Problem wieder auftritt.
