Warning $lastCmd in Log-File
Begonnen von Nobbynews, 14 Oktober 2025, 09:40:44
Nobbynews
Guten Morgen,
ich habe gestern nach 2 Monaten mal wieder ein Update durchgeführt.
Seit dem habe ich beim Abschalten des Gäste-Wlans folgendes warning in der Log-Datei stehen:
2025.10.14 07:37:52 1: PERL WARNING: Use of uninitialized value $lastCmd in concatenation (.) or string at ./FHEM/72_FRITZBOX.pm line 8999.
2025.10.14 07:37:52 1: stacktrace:
2025.10.14 07:37:52 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8999)
2025.10.14 07:37:52 1:     main::FRITZBOX_Readout_SetGet_Aborted called by FHEM/Blocking.pm (285)
2025.10.14 07:37:52 1:     main::BlockingKill                  called by fhem.pl (3514)
2025.10.14 07:37:52 1:     main::HandleTimeout                 called by fhem.pl (710)
2025.10.14 07:37:52 1: [FritzDach | 1750 | 134.07.32 | Readout_SetGet_Aborted.8999] - ERROR:Timeout reached for:
2025.10.14 07:37:52 3: [FritzOG | 2400 | 169.07.58 | Set.1869] - BASIC:set FritzOG guestWlan - off
2025.10.14 07:38:02 1: PERL WARNING: Odd number of elements in hash assignment at ./FHEM/72_FRITZBOX.pm line 8310.
2025.10.14 07:38:02 3: eval: {FRITZBOX_Readout_SetGet_Done('FritzOG|2|Ym94X2d1ZXN0V2xhbnxvZmZ8Ym94X2d1ZXN0V2xhblJlbWFpbnwwfGJveF9tYWNGaWx0ZXJfYWN0aXZlfG9mZnxyZXRTdGF0X1NldEdldF9ub25CbG9ja2luZ3xzZXQgZ3Vlc3RXbGFuOiBvZmZ8ZmhlbS0+c2lkfDQ1YzRmZjlmNjM3MmRlZGN8ZmhlbS0+c2lkVGltZXwxNzYwNDIwMjc0LjU5NTE2fGZoZW0tPnNpZEVyckNvdW50fDB8cmVhZG91dFRpbWV8MS40OXxib3hfd2xhbkJhbmRfMi40R0h6X2FjdGl2ZXxvbnxib3hfd2xhbkJhbmRfMi40R0h6X3VzZWFibGV8fGJveF93bGFuQmFuZF81R0h6X2FjdGl2ZXxvbnxib3hfd2xhbkJhbmRfNUdIel91c2VhYmxlfA==')}
2025.10.14 07:38:02 1: stacktrace:
2025.10.14 07:38:02 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8310)
2025.10.14 07:38:02 1:     main::FRITZBOX_Readout_Process      called by ./FHEM/72_FRITZBOX.pm (8963)
2025.10.14 07:38:02 1:     main::FRITZBOX_Readout_SetGet_Done  called by (eval 964238) (1)
2025.10.14 07:38:02 1:     (eval)                              called by fhem.pl (1180)
2025.10.14 07:38:02 1:     main::AnalyzePerlCommand            called by fhem.pl (1209)
2025.10.14 07:38:02 1:     main::AnalyzeCommand                called by fhem.pl (1136)
2025.10.14 07:38:02 1:     main::AnalyzeCommandChain           called by ./FHEM/98_telnet.pm (263)
2025.10.14 07:38:02 1:     main::telnet_Read                   called by fhem.pl (3994)
2025.10.14 07:38:02 1:     main::CallFn                        called by fhem.pl (789)
2025.10.14 07:38:02 1: PERL WARNING: Use of uninitialized value $rValue in substitution (s///) at ./FHEM/72_FRITZBOX.pm line 8374.
2025.10.14 07:38:02 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8374)
2025.10.14 07:38:02 1: PERL WARNING: Use of uninitialized value $rValue in string ne at ./FHEM/72_FRITZBOX.pm line 8513.
2025.10.14 07:38:02 1:     main::__ANON__                      called by ./FHEM/72_FRITZBOX.pm (8513)
JoWiemann
dann muss ich mal mit meiner alten 7330 schauen, ob ich das reproduziert bekomme. Kann etwas dauern.
Grüße Jörg
Jörg Wiemann
JoWiemann
Mit der FB 7330 und einem Fritz!OS 6.56 funktioniert es. Eine FritzBox mit einem Fritz!OS 7.32 bzw 7.58 befindet sich nicht in meinem FritzBox-Zoo.
Bitte für beide FB einmal verbose auf 4 setzen und das entstehende Log posten.
Grüße Jörg
Jörg Wiemann
Nobbynews
Hallo Jörg,
mit dem Hinweis auf die Versionen habe ich folgendens festgestellt:
7.32: Repeater 1750E  ->  keine Warnings
7.58: Repeater 2400   ->  Warnings
Habe gar nicht mitbekommen, dass für die 2400er jetzt auch 8.20 zur Verfügung steht.
Das Log-File mit verbose 4 habe ich mal als Datei angehängt.
Norbert
JoWiemann
Hallo Norbert,
ab morgen 08:00 ist eine neue Version per update verfügbar.
Grüße Jörg
Jörg Wiemann
