HM-CC-RT-DN pairen
Begonnen von verwegener, 02 November 2025, 18:36:49
verwegener
ich habe letzte Woche neue HM-CC-RT-DN bekommen.
Aber das Pairen will nicht funktionieren.
Auch mit den beiden Anleitungen aus der FHEM HM-CC-RT-DN wird das nichts. Während FHem die Meldungen empfängt, reagiert der Thermostat nicht auf die Befehle.
Hier noch der List :
define HM_7A0604 CUL_HM 7A0604
attr HM_7A0604 .mId 0095
attr HM_7A0604 IODev myHmUART
attr HM_7A0604 actCycle 000:10
attr HM_7A0604 actStatus alive
attr HM_7A0604 autoReadReg 4_reqStatus
attr HM_7A0604 expert 2_raw
attr HM_7A0604 firmware 1.5
attr HM_7A0604 model HM-CC-RT-DN
attr HM_7A0604 room CUL_HM
attr HM_7A0604 serialNr TEQ1358781
attr HM_7A0604 subType thermostat
attr HM_7A0604 webCmd getConfig:clear msgEvents:burstXmit
define FileLog_HM_7A0604 FileLog ./log/HM_7A0604-%Y.log HM_7A0604
attr FileLog_HM_7A0604 logtype text
attr FileLog_HM_7A0604 room CUL_HM
setstate FileLog_HM_7A0604 active
setstate FileLog_HM_7A0604 2025-11-02 18:31:09 linesInTheFile 102
setstate HM_7A0604 MISSING ACK
setstate HM_7A0604 2025-11-02 18:22:33 .D-devInfo 00FFFF
setstate HM_7A0604 2025-11-02 18:22:33 .D-stc 59
setstate HM_7A0604 2025-11-02 18:31:06 .protLastRcv 2025-11-02 18:31:06
setstate HM_7A0604 2025-11-02 18:22:33 Activity alive
setstate HM_7A0604 2025-11-02 18:22:33 CommandAccepted no
setstate HM_7A0604 2025-11-02 18:22:33 D-firmware 1.5
setstate HM_7A0604 2025-11-02 18:22:33 D-serialNr TEQ1358781
setstate HM_7A0604 2025-11-02 18:16:22 R-pairCentral set_0xF10000
setstate HM_7A0604 2025-11-02 18:31:06 actuator 0
setstate HM_7A0604 2025-11-02 18:25:28 battery ok
setstate HM_7A0604 2025-11-02 18:31:06 batteryLevel 3.1
setstate HM_7A0604 2025-11-02 18:31:06 desired-temp 10.0
setstate HM_7A0604 2025-11-02 18:31:06 measured-temp 24.9
setstate HM_7A0604 2025-11-02 18:31:06 motorErr communicationERR
setstate HM_7A0604 2025-11-02 18:21:01 powerOn 2025-11-02 18:21:01
setstate HM_7A0604 2025-11-02 18:21:01 recentStateType info
setstate HM_7A0604 2025-11-02 18:31:09 state MISSING ACK
Hat einer von Euch noch Tipps ??
Mfg
verwegener
#1
  • falsches Unterforum für Fragen zu Homematic. Den Button zum Verschieben in den richtigen Bereich findest Du unten links auf der Seite.
  • Bitte code-tags verwenden, um solche Daten-Blöcke zu posten. Danke.
  • setstate HM_7A0604 2025-11-02 18:16:22 R-pairCentral set_0xF10000
    Das deutet darauf hin, dass das Pairing nicht korrekt abgeschlossen wurde. Es wurde zwar versucht, mit einer Zentrale, die die ID F10000 hat, zu verbinden, aber die Verbindung ist noch nicht komplett bestätigt. Hast Du nach dem Pairing mal versucht, ein "set ... getConfig" auszuführen und dann die Konfigurationstaste am Thermostaten nochmal zu drücken?
verwegener
ja GetConfig und Anlerntaste mehrfach betätigt.
Auch die Pairing Zeit bei FHem auf 5 Minuten gesetzt und während der Zeit mehrfach die Anlerntaste gedrückt.
Irgendwann kommt dann nach kurzer Zeit Fehlermeldung F4 ( Anlernfehler, Gerät schon bekannt).
War aber trotzdem nicht richtig angelernt.
Mfg verwegener
verwegener
hier noch das List der Gegenstelle :
define myHmUART HMUARTLGW /dev/ttyAMA0
attr myHmUART alias CUL für HM
attr myHmUART hmId F10000
attr myHmUART room CUL_HM,Gaszähler
setstate myHmUART opened
setstate myHmUART 2025-10-22 17:17:38 D-HMIdAssigned F10000
setstate myHmUART 2025-10-22 17:17:38 D-HMIdOriginal 671388
setstate myHmUART 2025-10-22 17:17:38 D-firmware 1.4.1
setstate myHmUART 2025-10-22 17:17:38 D-serialNr PEQ0174639
setstate myHmUART 2025-10-22 17:16:58 D-type HM-MOD-UART
setstate myHmUART 2025-10-22 17:17:38 cond ok
setstate myHmUART 2025-11-02 19:26:43 load 8
setstate myHmUART 2025-10-22 17:17:38 loadLvl low
setstate myHmUART 2025-10-22 17:17:32 state opened
Das ist ein CUL von Busware.
Mfg
verwegener
#4
Entweder stimmt die Info busware-CUL nicht, oder der TYPE ist falsch (HMUARTLGW => CUL).
Sieht aber nicht danach aus, als wäre das falsch konfiguriert, viel eher wurde der RT nicht zurückgesetzt. (Nur) Falls der Vorbesitzer einen eigenen aes-key gesetzt hatte, wird es schwierig, sonst sollte es in der Bedienungsanleitung stehen, wie das geht.
PS: code-Tags waren schon mal angeregt...
