Letztes Reading anzeigen lassen
Begonnen von Damu, 09 November 2025, 10:52:17
Damu
Weis nicht ob ich hier richtig bin.
Möchte bei einem ReadingsProxi das Reading zusätzlich als Alt_Reading anzeigen lassen (immer das vorherige Reading)
Zitatdefine JA_2_1 readingsProxy JA2:position01
attr JA_2_1 userattr ASC_Adv:on,off ASC_Antifreeze:off,soft,hard,am,pm ASC_Antifreeze_Pos:5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100 ASC_AutoAstroModeEvening:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeEveningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_AutoAstroModeMorning:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeMorningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_BlockingTime_afterManual ASC_BlockingTime_beforeDayOpen ASC_BlockingTime_beforeNightClose ASC_BrightnessSensor ASC_Closed_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_ComfortOpen_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_CommandTemplate ASC_Down:time,astro,brightness,roommate ASC_DriveUpMaxDuration ASC_Drive_Delay ASC_Drive_DelayStart ASC_ExternalTrigger ASC_GuestRoom:on,off ASC_LockOut:soft,hard,off ASC_LockOut_Cmd:inhibit,blocked,protection ASC_Mode_Down:absent,always,off,home ASC_Mode_Up:absent,always,off,home ASC_Open_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Partymode:on,off ASC_Pos_Reading ASC_PrivacyDownValue_beforeNightClose ASC_PrivacyDown_Pos ASC_PrivacyUpValue_beforeDayOpen ASC_PrivacyUp_Pos ASC_RainProtection:on,off ASC_Roommate_Device ASC_Roommate_Reading ASC_Self_Defense_AbsentDelay ASC_Self_Defense_Mode:absent,gone,off ASC_Shading_BetweenTheTime ASC_Shading_InOutAzimuth ASC_Shading_MinMax_Elevation ASC_Shading_Min_OutsideTemperature ASC_Shading_Mode:absent,always,off,home ASC_Shading_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Shading_StateChange_SunnyCloudy ASC_Shading_WaitingPeriod ASC_Shutter_IdleDetection ASC_ShuttersPlace:window,terrace,awning,EG_window ASC_SlatPosCmd_SlatDevice ASC_Sleep_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_TempSensor ASC_Time_Down_Early ASC_Time_Down_Late ASC_Time_Up_Early ASC_Time_Up_Late ASC_Time_Up_WE_Holiday ASC_Up:time,astro,brightness,roommate ASC_Ventilate_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Ventilate_Window_Open:on,off ASC_WiggleValue ASC_WindParameters ASC_WindProtection:on,off ASC_WindowRec ASC_WindowRec_PosAfterDayClosed:open,lastManual ASC_WindowRec_subType:twostate,threestate
attr JA_2_1 ASC 1
attr JA_2_1 ASC_Antifreeze off
attr JA_2_1 ASC_AutoAstroModeEvening HORIZON
attr JA_2_1 ASC_AutoAstroModeEveningHorizon -2
attr JA_2_1 ASC_AutoAstroModeMorning HORIZON
attr JA_2_1 ASC_AutoAstroModeMorningHorizon -4
attr JA_2_1 ASC_Closed_Pos 100
attr JA_2_1 ASC_Down astro
attr JA_2_1 ASC_Drive_Delay 10
attr JA_2_1 ASC_Drive_DelayStart 15
attr JA_2_1 ASC_Mode_Down off
attr JA_2_1 ASC_Mode_Up off
attr JA_2_1 ASC_Partymode off
attr JA_2_1 ASC_Pos_Reading position
attr JA_2_1 ASC_RainProtection off
attr JA_2_1 ASC_Shading_Mode off
attr JA_2_1 ASC_Time_Down_Early 17:00
attr JA_2_1 ASC_Time_Down_Late 22:00
attr JA_2_1 ASC_Time_Up_Early 05:00
attr JA_2_1 ASC_Time_Up_Late 08:00
attr JA_2_1 ASC_Time_Up_WE_Holiday 05:45
attr JA_2_1 ASC_Up astro
attr JA_2_1 ASC_WindProtection off
attr JA_2_1 alias Store_KücheL
attr JA_2_1 cmdIcon opens:fts_shutter_up stop:fts_shutter_shadding_stop closes:fts_shutter_down
attr JA_2_1 devStateIcon 0:fts_shutter_10 100:fts_shutter_100
attr JA_2_1 event-on-change-reading position, state
attr JA_2_1 icon fts_shutter
attr JA_2_1 room ASC,Storen
attr JA_2_1 setFn {$CMD eq "position" ? "$CMD $ARGS -1 1" : "$CMD 1"}
attr JA_2_1 setList opens:noArg stop:noArg closes:noArg position:slider,0,1,100
attr JA_2_1 userReadings position { ReadingsVal("JA2","position01",0);;;;;;;; }, lastposition { ReadingsVal("JA2","position01",0);;;;;;;; }
attr JA_2_1 valueFn ""
attr JA_2_1 webCmd opens:stop:closes:position
#   DEF        JA2:position01
#   DEVICE     JA2
#   FUUID      6816fff9-f33f-d169-a137-dc31ca6d5ff9c209
#   NAME       JA_2_1
#   NOTIFYDEV  JA2,global
#   NR         472
#   NTFY_ORDER 50-JA_2_1
#   READING    position01
#   STATE      0
#   TYPE       readingsProxy
#   eventCount 5380
#   CONTENT:
#     JA2        1
#   READINGS:
#     2025-05-04 11:29:48   ASC_Enable      on
#     2025-08-19 09:53:49   ASC_ShadingMessage <html> INFO:  shading was deactivated in the device </html>
#     2025-11-09 09:03:42   ASC_ShuttersLastDrive manual
#     2025-11-09 07:02:35   ASC_Time_DriveDown 09.11.2025 - 17:09
#     2025-11-09 07:02:35   ASC_Time_DriveUp 10.11.2025 - 07:04
#     2025-10-31 19:32:20   associatedWith  ASC
#     2025-11-08 13:49:07   lastCmd         position
#     2025-11-09 09:03:42   lastposition    0
#     2025-05-04 08:35:19   pct             1
#     2025-11-09 09:03:42   position        0
#     2025-11-09 09:03:41   state           0
setstate JA_2_1 0
setstate JA_2_1 2025-05-22 22:18:53 .ASC_AttrUpdateChanges_v1.0.1 1
setstate JA_2_1 2025-05-04 11:29:48 ASC_Enable on
setstate JA_2_1 2025-08-19 09:53:49 ASC_ShadingMessage <html> INFO:  shading was deactivated in the device </html>
setstate JA_2_1 2025-11-09 09:03:42 ASC_ShuttersLastDrive manual
setstate JA_2_1 2025-11-09 07:02:35 ASC_Time_DriveDown 09.11.2025 - 17:09
setstate JA_2_1 2025-11-09 07:02:35 ASC_Time_DriveUp 10.11.2025 - 07:04
setstate JA_2_1 2025-10-31 19:32:20 associatedWith ASC
setstate JA_2_1 2025-11-08 13:49:07 lastCmd position
setstate JA_2_1 2025-11-09 09:03:42 lastposition 0
setstate JA_2_1 2025-05-04 08:35:19 pct 1
setstate JA_2_1 2025-11-09 09:03:42 position 0
setstate JA_2_1 2025-11-09 09:03:41 state 0
Besser nur das wesentliche:
#   DEVICE     JA2
#   NAME       JA_2_1
#   NR         472
#   STATE      0
#   eventCount 5380
#   CONTENT:
#     JA2        1
#   READINGS:
setstate JA_2_1 0
Das Reading wäre: position
Und das zusätzliche: lastposition
Brauche das für ein Doif (Wenn lastposition = 100 muss bei der nächsten Fahrt die anglePos im Device auf 0, sonst geht die Jalosie wieder 1.5Sec hoch)
mi.ke
Zitat von: CoolTux am 06 April 2020, 08:37:19Du musst das Attribut oldreadings auf den Readingnamen setzen wo du das alte haben willst. Danach muss wenigstens einmal das Reading neu gesetzt worden sein.
oder aus der Commandref:
  • oldreadings
    Dieses Attribut enthält eine durch Kommata getrennte Liste von Readings. regex sind erlaubt. Für jedes Reading aus der Liste speichert FHEM intern den vorherigen Wert wenn sich das Reading ändert. Zum Zugriff auf die Werte gibt es die OldReadings.* Routinen. Falls der vorherige Wert immer, d.h. auch wenn es sich nicht ändert, gespeichert werden soll, dann muss der letzte Werte der Komma getrennten Liste oldreadingsAlways sein.
cheers
mi.ke
FHEM 31310 | Mini PC N100, RPi4 + 5 x RPi(Z) + FB7590 + FB 6890 LTE via LAN / WAN (VPN).
2 x CUL868 + 3 x RFXTRX(e) + 6 x HMwLanGW + 5 x z2tGw + 5 x LGW + 2 x IRBlast + CO2 +++
FS20, FHT, FMS, Elro(mod), CM160, Revolt, LGTV, STV, AVR, withings, HM-*, MQTT2, ZigBee, AMAD, PCA301, arlo, Aqara,
Damu
Oldreadings natürlich.
Vielen Dank klappt eigentlich.
Die Jalosie ist auf Position 0 AnglsPos 0.
Fahre mit set Position 50 auf Position 50 AnglePos 0
Sollte aber AnglePos 100 sein.
Das Doif setzt die AnglePos 0 auf 100 wenn in lastposition eine 0 steht.
Sehe aber jetzt Position 5 dann Position 20....
Der Aktor erhält den Befehl noch während der Fahrt (Position 5).
Ob das immer klappt?
Damu
Klappt leider nicht immer.
Ist es möglich das:
Zitatattr JA_2_1 setFn {$CMD eq "position" ? "$CMD $ARGS -1 1" : "$CMD 1"}
Zu Teilen
So zu mache das wenn: "position = 0" ist kommt das: {$CMD eq "position" ? "$CMD $ARGS 100 1" : "$CMD 1"}
Sonst {$CMD eq "position" ? "$CMD $ARGS -1 1" : "$CMD 1"}
Oder ein useratr mit -1 oder 100 einsetzen?
