Hallo Zusammen
Ich habe eine neue Feature bei ThermokonSR04 entdeckt
Ich sehe seit 3 Tage "Rausch" in der Logfiles
anbei auch Teil der Logfiles
2013-08-18_09:18:32 Term_EG_Cucina temperature: 23.8
2013-08-18_09:18:32 Term_EG_Cucina set_point: 0.0
2013-08-18_09:20:03 Term_EG_Cucina temperature: 20
2013-08-18_09:20:03 Term_EG_Cucina set_point: 0.0
2013-08-18_09:20:04 Term_EG_Cucina temperature: 20
2013-08-18_09:20:04 Term_EG_Cucina set_point: 0.0
2013-08-18_09:35:27 Term_EG_Cucina T: 23.8 SP: 0 F: 3 SW: 1
2013-08-18_09:35:27 Term_EG_Cucina fanStage: 3
2013-08-18_09:35:27 Term_EG_Cucina switch: 1
2013-08-18_09:35:27 Term_EG_Cucina setpoint: 0
2013-08-18_09:35:27 Term_EG_Cucina temperature: 23.8
2013-08-18_09:35:27 Term_EG_Cucina set_point: 0.0
2013-08-18_09:52:21 Term_EG_Cucina T: 24.0 SP: 0 F: 3 SW: 1
2013-08-18_09:52:21 Term_EG_Cucina fanStage: 3
2013-08-18_09:52:21 Term_EG_Cucina switch: 1
2013-08-18_09:52:21 Term_EG_Cucina setpoint: 0
2013-08-18_09:52:21 Term_EG_Cucina temperature: 24.0
2013-08-18_09:52:21 Term_EG_Cucina set_point: 0.0
2013-08-18_10:01:27 Term_EG_Cucina temperature: 20
2013-08-18_10:01:27 Term_EG_Cucina set_point: 0.0
2013-08-18_10:01:28 Term_EG_Cucina temperature: 20
2013-08-18_10:01:28 Term_EG_Cucina set_point: 0.0
2013-08-18_10:09:16 Term_EG_Cucina T: 24.0 SP: 0 F: 3 SW: 1
2013-08-18_10:09:16 Term_EG_Cucina fanStage: 3
2013-08-18_10:09:16 Term_EG_Cucina switch: 1
2013-08-18_10:09:16 Term_EG_Cucina setpoint: 0
2013-08-18_10:09:16 Term_EG_Cucina temperature: 24.0
2013-08-18_10:09:16 Term_EG_Cucina set_point: 0.0
M.e. Der Rausch (die 20°C) kommt aus defaultWerte
if ($st eq "roomSensorControl.05") {
# Room Sensor and Control Unit (EEP A5-10-01 ... A5-10-0D)
# [Eltako FTF55D, FTF55H, Thermokon SR04 *, Thanos SR *, untested]
$rorg = "A5";
# primarily temperature from the reference device then the attribute actualTemp is read
my $temperatureRefDev = AttrVal($name, "temperatureRefDev", undef);
my $actualTemp = AttrVal($name, "actualTemp", 20);
$actualTemp = ReadingsVal($temperatureRefDev, "temperature", 20) if (defined $temperatureRefDev);
$actualTemp = 20 if ($actualTemp !~ m/^[+-]?\d+(\.\d+)?$/);
$actualTemp = 0 if ($actualTemp < 0);
$actualTemp = 40 if ($actualTemp > 40);
readingsSingleUpdate($hash, "temperature", $actualTemp, 1);
my $setCmd = 8;
Ich möchte mehr dazu verstehen.
1) Entweder die Routine wird jeztz ohne ein Telegramm getriggert.
2) Oder 2% der Telegramme sind immer fehlerhaft gewesen und vorher wurden einfach ignoriert.
danke und gruess
immi
