[GELÖST] OpenCCU mit FHEM | Connection lost, trying a reconnect every 5 seconds
Begonnen von Burny4600, 28 Januar 2026, 18:25:03
Burny4600
Ich habe einen Pi3 mit OpenCCU (V3.85.7.20260124) errichtet und mit FHEM verbunden.
Auch das Geräte einlesen hat ohne Probleme funktioniert.
Nur bekomme ich bei jeder Aktion an den OpenCCU Geräten die FHEM-Meldung
ZitatConnection lost, trying a reconnect every 5 seconds
list OG1_KUE_GSFO
nternals:
   CFGFN
   DEF        OEQ1399812:1
   FUUID      697a23e1-f33f-f4d2-f4ae-1a736205478dc1ad
   IODev      OpenCCU
   NAME       OG1_KUE_GSFO
   NR         15905
   STATE      on
   TYPE       HMCCUCHN
   ccuaddr    OEQ1399812:1
   ccudevstate active
   ccuif      BidCos-RF
   ccuname    OG1_KUE_GSFO:1
   ccurolectrl SWITCH
   ccurolestate SWITCH
   ccusubtype HM-LC-Sw1-Pl-DN-R1
   ccutype    HM-LC-Sw1-Pl-DN-R1
   eventCount 31
   firmware   2.6
   readonly   no
     2026-01-28 15:57:37   INHIBIT         false
     2026-01-28 15:57:37   IODev           OpenCCU
     2026-01-28 18:16:36   STATE           on
     2026-01-28 18:16:36   WORKING         false
     2026-01-28 15:57:37   activity        alive
     2026-01-28 15:57:37   battery         ok
     2026-01-28 18:16:36   control         on
     2026-01-28 18:16:36   devstate        stickyUnreach
     2026-01-28 18:16:36   hmstate         on
     2026-01-28 15:57:37   rssidevice      -79
     2026-01-28 15:57:37   rssipeer        -181
     2026-01-28 15:57:37   sign            off
     2026-01-28 18:16:36   state           on
   hmccu:
     channels   1
     detect     1
     devspec    OEQ1399812:1
     nodefaults 0
     role       1:SWITCH
     setDefaults 0
     cmdlist:
       get
       set        on-till toggle:noArg on-for-timer off:noArg on:noArg
     control:
       chn        1
       dpt        STATE
     dp:
       0.AES_KEY:
         VALUES:
           NVAL       0
           SVAL       off
           VAL        0
       0.CONFIG_PENDING:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
       0.DEVICE_IN_BOOTLOADER:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
       0.DUTYCYCLE:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
       0.LOWBAT:
         VALUES:
           NVAL       0
           SVAL       ok
           VAL        0
       0.RSSI_DEVICE:
         VALUES:
           NVAL       -79
           SVAL       -79
           VAL        -79
       0.RSSI_PEER:
         VALUES:
           NVAL       -181
           SVAL       -181
           VAL        -181
       0.STICKY_UNREACH:
         VALUES:
           NVAL       1
           SVAL       true
           VAL        1
       0.UNREACH:
         VALUES:
           NVAL       0
           SVAL       alive
           VAL        0
       0.UPDATE_PENDING:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
       1.INHIBIT:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
       1.STATE:
         VALUES:
           NVAL       1
           ONVAL      0
           OSVAL      off
           OVAL       0
           SVAL       on
           VAL        1
       1.WORKING:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
     roleChannels:
       SWITCH     1
     roleCmds:
       get:
       set:
         off:
           channel    1
           ps         VALUES
           role       SWITCH
           rpc        0
           subcount   1
           syntax     V:STATE:0
           usage      off
           subcmd:
             000:
               args       0
               dpt        STATE
               fnc
               max        1
               min        0
               parname    STATE
               partype    3
               ps         VALUES
               scn        000
               type       BOOL
               unit
         on:
           channel    1
           ps         VALUES
           role       SWITCH
           rpc        0
           subcount   1
           syntax     V:STATE:1
           usage      on
           subcmd:
             000:
               args       1
               dpt        STATE
               fnc
               max        1
               min        0
               parname    STATE
               partype    3
               ps         VALUES
               scn        000
               type       BOOL
               unit
         on-for-timer:
           channel    1
           ps         VALUES
           role       SWITCH
           rpc        0
           subcount   2
           syntax     V:ON_TIME:?duration V:STATE:1
           usage      on-for-timer duration
           subcmd:
             000:
               args
               dpt        ON_TIME
               fnc
               max        85825945.600000
               min        0.000000
               parname    duration
               partype    2
               ps         VALUES
               scn        000
               type       FLOAT
               unit       s
             001:
               args       1
               dpt        STATE
               fnc
               max        1
               min        0
               parname    STATE
               partype    3
               ps         VALUES
               scn        001
               type       BOOL
               unit
         on-till:
           channel    1
           ps         VALUES
           role       SWITCH
           rpc        0
           subcount   2
           syntax     V:ON_TIME:?time V:STATE:1
           usage      on-till time
           subcmd:
             000:
               args
               dpt        ON_TIME
               fnc
               max        85825945.600000
               min        0.000000
               parname    time
               partype    2
               ps         VALUES
               scn        000
               type       FLOAT
               unit       s
             001:
               args       1
               dpt        STATE
               fnc
               max        1
               min        0
               parname    STATE
               partype    3
               ps         VALUES
               scn        001
               type       BOOL
               unit
         toggle:
           channel    1
           ps         VALUES
           role       SWITCH
           rpc        0
           subcount   1
           syntax     V:STATE:0,1
           usage      toggle
           subcmd:
             000:
               args       0,1
               dpt        STATE
               fnc
               max        1
               min        0
               parname    STATE
               partype    3
               ps         VALUES
               scn        000
               type       BOOL
               unit
     state:
       chn        1
       dpt        STATE
   cmdIcon    on:remotecontrol/black_btn_GREEN off:remotecontrol/black_btn_RED
   devStateIcon on:scene_dishwasher@0CFB0C off:scene_dishwasher@gray
   icon       scene_dishwasher
list OpenCCU
Das list ist ewiglange.
Liegt es an der OpenCCU Schnittstelle, dass diese Meldung bei jedem Schaltvorgang kommt?
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
Was sagt denn das Logfile?
Die Meldung kommt beispielsweise, wenn FHEM abstürzt und dann automatisch neu gestartet wird.
Burny4600
ZitatWas sagt denn das Logfile?
list OG1_KUE_GSFO
   CFGFN
   DEF        OEQ1399812:1
   IODev      OpenCCU
   NAME       OG1_KUE_GSFO
   NR         15905
   STATE      on
   TYPE       HMCCUCHN
   ccudevstate active
   ccuif      BidCos-RF
   ccurolectrl SWITCH
   ccurolestate SWITCH
   eventCount 31
   firmware   2.6
   readonly   no
   hmccu:
     channels   1
     detect     1
     nodefaults 0
     role       1:SWITCH
     setDefaults 0
     cmdlist:
       get
     control:
       chn        1
       dpt        STATE
     dp:
       0.AES_KEY:
         VALUES:
           NVAL       0
           SVAL       off
           VAL        0
       0.CONFIG_PENDING:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
       0.DUTYCYCLE:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
       0.LOWBAT:
         VALUES:
           NVAL       0
           SVAL       ok
           VAL        0
       0.RSSI_DEVICE:
         VALUES:
           NVAL       -79
           SVAL       -79
           VAL        -79
       0.RSSI_PEER:
         VALUES:
           NVAL       -181
           SVAL       -181
           VAL        -181
       0.STICKY_UNREACH:
         VALUES:
           NVAL       1
           SVAL       true
           VAL        1
       0.UNREACH:
         VALUES:
           NVAL       0
           SVAL       alive
           VAL        0
       0.UPDATE_PENDING:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
       1.INHIBIT:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
       1.STATE:
         VALUES:
           NVAL       1
           ONVAL      0
           OSVAL      off
           OVAL       0
           SVAL       on
           VAL        1
       1.WORKING:
         VALUES:
           NVAL       0
           SVAL       false
           VAL        0
     roleChannels:
       SWITCH     1
     roleCmds:
       get:
       set:
         off:
           channel    1
           ps         VALUES
           role       SWITCH
           rpc        0
           subcount   1
           syntax     V:STATE:0
           usage      off
           subcmd:
             000:
               args       0
               dpt        STATE
               fnc
               max        1
               min        0
               parname    STATE
               partype    3
               ps         VALUES
               scn        000
               type       BOOL
               unit
         on:
           channel    1
           ps         VALUES
           role       SWITCH
           rpc        0
           subcount   1
           syntax     V:STATE:1
           usage      on
           subcmd:
             000:
               args       1
               dpt        STATE
               fnc
               max        1
               min        0
               parname    STATE
               partype    3
               ps         VALUES
               scn        000
               type       BOOL
               unit
         on-for-timer:
           channel    1
           ps         VALUES
           role       SWITCH
           rpc        0
           subcount   2
           subcmd:
             000:
               args
               dpt        ON_TIME
               fnc
               max        85825945.600000
               min        0.000000
               parname    duration
               partype    2
               ps         VALUES
               scn        000
               type       FLOAT
               unit       s
             001:
               args       1
               dpt        STATE
               fnc
               max        1
               min        0
               parname    STATE
               partype    3
               ps         VALUES
               scn        001
               type       BOOL
               unit
         on-till:
           channel    1
           ps         VALUES
           role       SWITCH
           rpc        0
           subcount   2
           usage      on-till time
           subcmd:
             000:
               args
               dpt        ON_TIME
               fnc
               max        85825945.600000
               min        0.000000
               parname    time
               partype    2
               ps         VALUES
               scn        000
               type       FLOAT
               unit       s
             001:
               args       1
               dpt        STATE
               fnc
               max        1
               min        0
               parname    STATE
               partype    3
               ps         VALUES
               scn        001
               type       BOOL
               unit
         toggle:
           channel    1
           ps         VALUES
           role       SWITCH
           rpc        0
           subcount   1
           syntax     V:STATE:0,1
           usage      toggle
           subcmd:
             000:
               args       0,1
               dpt        STATE
               fnc
               max        1
               min        0
               parname    STATE
               partype    3
               ps         VALUES
               scn        000
               type       BOOL
               unit
     state:
       chn        1
       dpt        STATE
LOG-Eintrag beim AUS-Schalten
2026.01.29 12:22:07.954 3: CUL_HM HM_3F8B6C attack:01F123473F8B6C010E,01F123473F8B6C010E:11FF8BDF3F8B6C0201000000
2026.01.29 12:22:07.977 3: CUL_HM HM_3F8B6C attack:01F123473F8B6C010E,01F123473F8B6C010E:11FF8BDF3F8B6C0201000000
LOG-Eintrag beim EIN-Schalten
2026.01.29 12:22:14.457 3: CUL_HM HM_3F8B6C attack:01F123473F8B6C010E,01F123473F8B6C010E:11FF8BDF3F8B6C0201C80000
2026.01.29 12:22:14.469 3: CUL_HM HM_3F8B6C attack:01F123473F8B6C010E,01F123473F8B6C010E:11FF8BDF3F8B6C0201C80000
LG Chris
Zitat von: Burny4600 am 29 Januar 2026, 12:26:26CUL_HM HM_3F8B6C
Du betreibst eine Instanz mit CUL_HM und eine mit HMCCU (OpenCCU). Beide Systeme kennen das Gerät, es sollte aber nur eine Zentrale geben. Deswegen meldet CUL_HM : attack wenn Du mit OpenCCU schaltest. Ich denke, das Verhalten ist so zu erwarten. ;)
Burny4600
Zitat von: Otto123 am 29 Januar 2026, 22:20:59Du betreibst eine Instanz mit CUL_HM und eine mit HMCCU (OpenCCU)...................
Stimmt. Bei den ersten Tests hatte ich dieses Gerät doppelt vorhanden.
Danke für den Hinweis.
LG Chris
