[gelöst] : Doif mit Attribut Abfrage
Begonnen von Damu, 15 März 2026, 16:22:55
Damu
Versuche ein Doif mit einer Abfrage an einem Attribut am Device zu erstellen.
define JA_1_4_FT_Aut_Do DOIF ([FT_02:state] eq "B0" and [?JA_1_4:position] ne "0" and AttrVal("JA_1_4","FT_Auf","") eq "Ein") (set JA_1_4 position 0)\
    DOELSEIF ([FT_02:state] eq "B1" and [?JA_1_4:position] ne "100" and AttrVal("JA_1_4","FT_Ab","") eq "Ein") (set JA_1_4 position 100)
attr JA_1_4_FT_Aut_Do do always
attr JA_1_4_FT_Aut_Do room Test_Store
#   DEF        ([FT_02:state] eq "B0" and [?JA_1_4:position] ne "0" and AttrVal("JA_1_4","FT_Auf","") eq "Ein") (set JA_1_4 position 0)
#    DOELSEIF ([FT_02:state] eq "B1" and [?JA_1_4:position] ne "100" and AttrVal("JA_1_4","FT_Ab","") eq "Ein") (set JA_1_4 position 100)
#   FUUID      5cf04ac2-f33f-2006-5ea5-0ce0522339b70511
#   MODEL      FHEM
#   NAME       JA_1_4_FT_Aut_Do
#   NOTIFYDEV  FT_02,global
#   NR         81
#   NTFY_ORDER 50-Store_Automat_Do
#   STATE      initialized
#   TYPE       DOIF
#   VERSION    30659 2025-12-25 12:37:16
#   eventCount 66
#   READINGS:
#     2026-03-15 16:19:05   cmd             0
#     2026-03-15 16:19:05   mode            enabled
#     2026-03-15 16:19:05   state           initialized
#   Regex:
#     accu:
#     bar:
#     barAvg:
#     collect:
#     cond:
#       FT_02:
#         0:
#           state      ^FT_02$:^state:
#         1:
#   attr:
#     cmdState:
#     wait:
#     waitdel:
#   condition:
#     0          ::ReadingValDoIf($hash,'FT_02','state') eq "B0" and ::ReadingValDoIf($hash,'JA_1_4','position') ne "0" and AttrVal("JA_1_4","FT_Auf","") eq "Ein"
#     1          ::ReadingValDoIf($hash,'FT_02','state') eq "B1" and ::ReadingValDoIf($hash,'JA_1_4','position') ne "100" and AttrVal("JA_1_4","FT_Ab","") eq "Ein"
#   do:
#     0:
#       0          set JA_1_4 position 0
#     1:
#       0          set JA_1_4 position 100
#     2:
#   helper:
#     globalinit 1
#     last_timer 0
#     sleeptimer -1
#   readings:
#     all         FT_02:state
#   uiState:
#   uiTable:
setstate JA_1_4_FT_Aut_Do initialized
setstate JA_1_4_FT_Aut_Do 2026-03-15 16:19:05 cmd 0
setstate JA_1_4_FT_Aut_Do 2026-03-15 16:19:05 mode enabled
setstate JA_1_4_FT_Aut_Do 2026-03-15 16:19:05 state initialized
Das klappt leider nicht.
So sollte es doch gehen?
Damian
ja, sollte gehen, da musst du genau schauen welcher Teil der Bedingung nicht das liefert, was du erwartest. Du kannst die Bedingung nur mit einer Angabe testen und schauen, ob diese klappt oder nicht. Damit kannst du einkreisen, wo das Problem liegt.
Damu
Danke, hat geklappt.
define JA1_1_FT_Aut_Do DOIF ([FT_02:"^A0"] and [?JA_1_1:position] > 0 and AttrVal("JA_1_1","FT_Auf","") eq "T1") (set JA_1_1 position 0)\
DOELSEIF ([FT_02:"^AI"] and [?JA_1_1:position] < 100 and AttrVal("JA_1_1","FT_Ab","") eq "T1") (set JA_1_1 position 100)\
DOELSEIF ([FT_02:"^B0"] and [?JA_1_1:position] > 0 and AttrVal("JA_1_1","FT_Auf","") eq "T2") (set JA_1_1 position 0)\
DOELSEIF ([FT_02:"^BI"] and [?JA_1_1:position] < 100 and AttrVal("JA_1_1","FT_Ab","") eq "T2") (set JA_1_1 position 100)
attr JA1_1_FT_Aut_Do do always
attr JA1_1_FT_Aut_Do room Test_Store
#   CFGFN
#   DEF        ([FT_02:"^A0"] and [?JA_1_1:position] > 0 and AttrVal("JA_1_1","FT_Auf","") eq "T1") (set JA_1_1 position 0)
# DOELSEIF ([FT_02:"^AI"] and [?JA_1_1:position] < 100 and AttrVal("JA_1_1","FT_Ab","") eq "T1") (set JA_1_1 position 100)
# DOELSEIF ([FT_02:"^B0"] and [?JA_1_1:position] > 0 and AttrVal("JA_1_1","FT_Auf","") eq "T2") (set JA_1_1 position 0)
# DOELSEIF ([FT_02:"^BI"] and [?JA_1_1:position] < 100 and AttrVal("JA_1_1","FT_Ab","") eq "T2") (set JA_1_1 position 100)
#   FUUID      69b6f233-f33f-d169-783e-a1b0d462307ad83f
#   MODEL      FHEM
#   NAME       JA1_1_FT_Aut_Do
#   NR         609
#   NTFY_ORDER 50-JA1_1_FT_Aut_Do
#   STATE      initialized
#   TYPE       DOIF
#   eventCount 3
#   READINGS:
#     2026-03-15 19:39:34   Device          FT_02
#     2026-03-15 18:59:43   cmd             0
#     2026-03-15 19:39:34   e_FT_02_events  buttons: released
#     2026-03-15 18:59:43   mode            enabled
#     2026-03-15 18:59:43   state           initialized
#   Regex:
#     accu:
#     bar:
#     barAvg:
#     collect:
#     cond:
#       FT_02:
#         0:
#           &STATE     ^FT_02$
#         1:
#           &STATE     ^FT_02$
#         2:
#           &STATE     ^FT_02$
#         3:
#           &STATE     ^FT_02$
#   condition:
#     0          ::EventDoIf('FT_02',$hash,'^A0',1) and ::ReadingValDoIf($hash,'JA_1_1','position') > 0 and AttrVal("JA_1_1","FT_Auf","") eq "T1"
#     1          ::EventDoIf('FT_02',$hash,'^AI',1) and ::ReadingValDoIf($hash,'JA_1_1','position') < 100 and AttrVal("JA_1_1","FT_Ab","") eq "T1"
#     2          ::EventDoIf('FT_02',$hash,'^B0',1) and ::ReadingValDoIf($hash,'JA_1_1','position') > 0 and AttrVal("JA_1_1","FT_Auf","") eq "T2"
#     3          ::EventDoIf('FT_02',$hash,'^BI',1) and ::ReadingValDoIf($hash,'JA_1_1','position') < 100 and AttrVal("JA_1_1","FT_Ab","") eq "T2"
#   do:
#     0:
#       0          set JA_1_1 position 0
#     1:
#       0          set JA_1_1 position 100
#     2:
#     3:
#     4:
#   helper:
#     event      buttons: released
#     globalinit 1
#     last_timer 0
#     sleeptimer -1
#     triggerDev FT_02
#     triggerEvents:
#       buttons: released
#     triggerEventsState:
#       buttons: released
#   internals:
#   readings:
#   trigger:
#     all         FT_02
#   uiState:
#   uiTable:
setstate JA1_1_FT_Aut_Do initialized
setstate JA1_1_FT_Aut_Do 2026-03-15 19:39:34 Device FT_02
setstate JA1_1_FT_Aut_Do 2026-03-15 18:59:43 cmd 0
setstate JA1_1_FT_Aut_Do 2026-03-15 19:39:34 e_FT_02_events buttons: released
setstate JA1_1_FT_Aut_Do 2026-03-15 18:59:43 mode enabled
setstate JA1_1_FT_Aut_Do 2026-03-15 18:59:43 state initialized
