[gelöst]map Problem
Begonnen von grossmaggul, 30 März 2026, 03:10:09
grossmaggul
ich habe mir für picframe Pi3d ein MQTT Device gebastelt
   .FhemMetaInternals 1
   CID        picframe
   DEF        picframe
   FUUID      6990be2f-f33f-f310-5720-d6d976d6f8420d7b
   FVERSION   10_MQTT2_DEVICE.pm:0.305090/2025-11-09
   IODev      mqtt2_server
   LASTInputDev mqtt2_server
   MSGCNT     5932
   NAME       picframe
   NR         812
   STATE      OFF
   TYPE       MQTT2_DEVICE
   eventCount 5938
   mqtt2_server_CONN mqtt2_server_192.168.1.233_45025
   mqtt2_server_MSGCNT 5932
   mqtt2_server_TIME 2026-03-30 02:44:06
   .DT:
     DEVICETOPIC picframe
   .attraggr:
   .attrminint:
     2026-03-30 02:44:05   EXIF_DateTimeOriginal 1774644066.0
     2026-03-30 02:43:40   EXIF_ExposureTime 1/250
     2026-03-30 02:44:05   EXIF_FNumber    0.0
     2026-03-30 02:43:40   EXIF_FocalLength 20.0
     2026-03-30 02:44:05   EXIF_ISOSpeedRatings 0.0
     2026-03-29 17:19:13   IODev           mqtt2_server
     2026-03-30 02:44:05   Image_Make      Joint Photographic Experts Group
     2026-03-30 02:44:05   Image_Model     Jpeg File
     2026-03-30 02:44:06   available       online
     2026-03-30 02:44:06   avty_t          homeassistant/switch/picframe/available
     2026-03-30 02:44:06   brightness      1.0
     2026-03-30 02:44:06   command_topic   picframe/directory
     2026-03-30 02:44:06   date_from       -2147389200
     2026-03-30 02:44:06   date_to         2145913200
     2026-03-30 02:44:06   dev_ids_1       picframe
     2026-03-30 02:44:06   dev_mdl         PictureFrame
     2026-03-30 02:44:06   dev_mf          pi3d PictureFrame project
     2026-03-30 02:44:06   dev_name        picframe
     2026-03-30 02:44:06   dev_sw          2025.06.18
     2026-03-30 02:44:06   directory       bilder
     2026-03-30 02:44:06   display         ON
     2026-03-29 17:12:44   displayState    Error evaluating picframe userReading displayState: Can't call method "pausedState" without a package or object reference at (eval 1322619) line 3.\n
     2026-03-30 02:44:06   entity_category config
     2026-03-30 02:44:06   fade_time       15.0
     2026-03-30 02:44:06   icon            mdi:folder-multiple-image
     2026-03-30 02:44:06   image           2025-04-04 17.20.22.jpg
     2026-03-30 02:44:06   image_counter   1294
     2026-03-29 23:37:14   json_attributes_topic homeassistant/sensor/picframe_image/attributes
     2026-03-30 02:42:00   latitude        57.8627
     2026-03-30 02:42:00   location        Wilkhaven, Highland, Scotland, United Kingdom
     2026-03-30 02:44:06   location_filter
     2026-03-30 02:42:00   longitude       -3.7795
     2026-03-30 02:44:06   matting_images  1
     2026-03-29 23:37:14   max             1.0
     2026-03-29 23:37:14   min             0.0
     2026-03-30 02:44:06   name            directory
     2026-03-30 02:44:06   options_1       1983
     2026-03-30 02:44:06   options_10      2010
     2026-03-30 02:44:06   options_11      2011
     2026-03-30 02:44:06   options_12      2012
     2026-03-30 02:44:06   options_13      2013
     2026-03-30 02:44:06   options_14      2014
     2026-03-30 02:44:06   options_15      2015
     2026-03-30 02:44:06   options_16      2016
     2026-03-30 02:44:06   options_17      2017
     2026-03-30 02:44:06   options_18      2018
     2026-03-30 02:44:06   options_19      2019
     2026-03-30 02:44:06   options_2       1997
     2026-03-30 02:44:06   options_20      2020
     2026-03-30 02:44:06   options_21      2021
     2026-03-30 02:44:06   options_22      2022
     2026-03-30 02:44:06   options_23      2023
     2026-03-30 02:44:06   options_24      2024
     2026-03-30 02:44:06   options_25      2025
     2026-03-30 02:44:06   options_26      2026
     2026-03-30 02:44:06   options_27      bilder
     2026-03-30 02:44:06   options_3       1999
     2026-03-30 02:44:06   options_4       2004
     2026-03-30 02:44:06   options_5       2005
     2026-03-30 02:44:06   options_6       2006
     2026-03-30 02:44:06   options_7       2007
     2026-03-30 02:44:06   options_8       2008
     2026-03-30 02:44:06   options_9       2009
     2026-03-30 02:44:06   paused          OFF
     2026-03-29 23:37:15   payload_press   ON
     2026-03-30 02:44:06   shuffle         ON
     2026-03-29 23:37:15   state           OFF
     2026-03-30 02:44:06   state_topic     homeassistant/sensor/picframe/state
     2026-03-29 23:37:14   step            0.01
     2026-02-14 19:25:51   subscriptions   homeassistant/button/picframe_back/set homeassistant/button/picframe_delete/set homeassistant/button/picframe_next/set homeassistant/switch/picframe_caption_toggle/set homeassistant/switch/picframe_clock/set homeassistant/switch/picframe_date_toggle/set homeassistant/switch/picframe_directory_toggle/set homeassistant/switch/picframe_display/set homeassistant/switch/picframe_location_toggle/set homeassistant/switch/picframe_name_toggle/set homeassistant/switch/picframe_paused/set homeassistant/switch/picframe_shuffle/set homeassistant/switch/picframe_text_off/set homeassistant/switch/picframe_text_refresh/set homeassistant/switch/picframe_title_toggle/set picframe/brightness picframe/date_from picframe/date_to picframe/directory picframe/fade_time picframe/image picframe/image_counter picframe/location_filter picframe/matting_images picframe/purge_files picframe/stop picframe/tags_filter picframe/time_delay
     2026-03-30 02:44:06   tags_filter
     2026-03-30 02:44:06   time_delay      25.0
     2026-03-30 02:44:06   uniq_id         picframe_directory
     2026-03-30 02:44:06   value_template  {{ value_json.directory}}
   DbLogExclude .*
   IODev      mqtt2_server
   icon       file_image
   readingList picframe:homeassistant/sensor/picframe_image/attributes:.* { json2nameValue($EVENT) }
picframe:homeassistant/sensor/picframe_image/state:.* { json2nameValue($EVENT) }
picframe:homeassistant/select/picframe_directory/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/sensor/picframe/state:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_display/state:.* display
picframe:homeassistant/switch/picframe_shuffle/state:.* shuffle
picframe:homeassistant/switch/picframe_paused/state:.* paused
picframe:homeassistant/switch/picframe/available:.* available
picframe:homeassistant/text/picframe_date_from/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/text/picframe_date_to/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/text/picframe_location_filter/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/text/picframe_tags_filter/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/sensor/picframe_image_counter/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/sensor/picframe_image/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/number/picframe_brightness/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/number/picframe_time_delay/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/number/picframe_fade_time/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/number/picframe_matting_images/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_text_refresh/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_text_refresh/state:.* state
picframe:homeassistant/switch/picframe_name_toggle/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_name_toggle/state:.* state
picframe:homeassistant/switch/picframe_title_toggle/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_title_toggle/state:.* state
picframe:homeassistant/switch/picframe_caption_toggle/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_caption_toggle/state:.* state
picframe:homeassistant/switch/picframe_date_toggle/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_date_toggle/state:.* state
picframe:homeassistant/switch/picframe_location_toggle/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_location_toggle/state:.* state
picframe:homeassistant/switch/picframe_directory_toggle/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_directory_toggle/state:.* state
picframe:homeassistant/switch/picframe_text_off/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_text_off/state:.* state
picframe:homeassistant/switch/picframe_display/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_clock/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_clock/state:.* state
picframe:homeassistant/switch/picframe_shuffle/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/switch/picframe_paused/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/button/picframe_delete/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/button/picframe_back/config:.* { json2nameValue($EVENT) }
picframe:homeassistant/button/picframe_next/config:.* { json2nameValue($EVENT) }
   room       Geräte->Systeme->MQTT2
   setList    brightness:textField picframe/brightness $EVTPART1
timeDelay:textField picframe/time_delay $EVTPART1
fadeTime:textField picframe/fade_time $EVTPART1
matting:textField picframe/matting_images $EVTPART1
directory:textField picframe/directory $EVTPART1
dateFrom:textField homeassistant/text/picframe_date_from/cmd $EVTPART1
dateTo:textField homeassistant/text/picframe_date_to/cmd $EVTPART1
locationFilter:textField homeassistant/text/picframe_location_filter/cmd $EVTPART1
tagsFilter:textField homeassistant/text/picframe_tags_filter/cmd $EVTPART1
display:on,off { fhem("set mqtt2_server publish homeassistant/switch/picframe_display/set ".uc($EVTPART1)) }
paused:on,off { fhem("set mqtt2_server publish homeassistant/switch/picframe_paused/set ".uc($EVTPART1)) }
shuffle:on,off { fhem("set mqtt2_server publish homeassistant/switch/picframe_shuffle/set ".uc($EVTPART1)) }
Nun habe ich mir für FTUI3 Switches für paused, display und shuffle gebaut:
<ftui-switch [(value)]="picframe:display | map('ON:on,OFF:off')" ></ftui-switch>
weil z.B. display ON/OFF liefert, der switch aber auf on/off reagiert.
Ich bekomme aber eine Fehlermeldung, wenn ich den Switch betätige:
set map(ON on,OFF:off) undefined
Der switch ist gestrichelt rot umrandet, wenn ich ihn betätige.
Was übersehe ich?
gm
FHEM auf Debian 12 Bookworm Server, Supermicro XEON X5660, 2 TB HD RAID 1, 36GB RAM, 1 x nanoCUL868(MAX!); MAX, MiLight, HUE, WLED, diverse Zgibee und Tasmota Geräte
yersinia
Zitat von: grossmaggul am 30 März 2026, 03:10:09Der switch ist gestrichelt rot umrandet
Dann stimmt bereits im FTUI3 schon was nicht.
Zitat von: grossmaggul am 30 März 2026, 03:10:09<ftui-switch [(value)]="picframe:display | map('ON:on,OFF:off')" ></ftui-switch>
Müsste das nicht eher
<ftui-switch [(value)]="picframe:display | map('´ON´:on,´OFF´:off')" ></ftui-switch>sein?
viele Grüße, yersinia
FHEM 6.4 (SVN) on RPi 4B with RasPi OS Trixie (perl 5.40.1) | FTUI
grossmaggul
#2
Danke für Deine Antwort.
Mag sein, es funktioniert aber immer noch nicht, die Fehlermeldung bleibt.
Was ich gerade festgestellt habe, wenn ich die set picframe display on oder set picframe display off setze wird der Switch in FTUI3 entsprechend auf 'on' oder 'off' geändert. Wenn ich ihn anklicke funktioniert es aber nicht und ich bekomme besagte Fehlermeldung und den roten Rand.
TomLee
wenn Du aus dem Reading display Kleinbuchstaben machst, braucht man doch auch kein Mapping , oder?
picframe:homeassistant/switch/picframe_display/state:.* {display=>lc($EVENT)}
Gruß Thomas
grossmaggul
Danke, manchmal sieht man den Wald vor Bäumen nicht, funktioniert jetzt!
