FTUI 3 nach FHEM update Syntax Error
Begonnen von Schniebi, 19 April 2026, 19:50:42
Schniebi
Ich habe heute ein updat von FHEM durchgeführt. Seit dem habe ich folgenden Fehler auf den Tablet UIs:
FHEM Command failed
SyntaxError: JSON.parse: unexpected end od data at line 1column 1 of the JSON data
Refresh request failed: Result is null
Es werden viele Sachen nicht mehr dar gestellt.
Hier mal meine HTML:
<!DOCTYPE html>
<html>
<head>
    /* FHEM tablet ui - FTUI */
    * UI builder framework for FHEM
    * Version: 3.0.0
    * Copyright (c) 2015-2021 Mario Stephan <mstephan@shared-files.de>
    * Under MIT License (http://www.opensource.org/licenses/mit-license.php)
    * https://github.com/knowthelist/ftui
  <script src="ftui.js"></script>
  <link href="ftui.css" rel="stylesheet">
  <link href="themes/ftui-theme.css" rel="stylesheet">
  <link href="favicon.ico" rel="icon" type="image/x-icon" />
  <link href="themes/retro-theme.css" rel="stylesheet"
        ftui-binding [disabled]="local:theme | map('`.*`:true, retro:false') | toBool()">
  <!-- avoid 300ms delay on click-->
  <meta name="viewport" content="width=device-width">
  <meta name="mobile-web-app-capable" content="yes">
  <meta name="toast_position" content="topLeft">
  <!-- verbose level 0-4 -->
  <meta name="debug" content="0">
  <title>FTUI Schniebi</title>
</head>
<body>
  <ftui-speak [text]="speakFlur:state"></ftui-speak>
  <ftui-grid base-width="106" base-height="85" margin="5" shape="round" color="success">
      <ftui-grid-tile row="1" col="1" height="3" width="5" shape="round" color="dark">
        <ftui-row width="80%" height="0%">
          <ftui-clock format="ee" class="size-9 thin" unit="."></ftui-clock>
          <ftui-clock format="DD.MM.YYYY" class="size-9 thin"></ftui-clock>
        </ftui-row>
        <ftui-row width="90%" height="0%">
          <ftui-clock format="hh:mm" class="size-11 thin"></ftui-clock>
          <ftui-label class="size-11 thin">Uhr</ftui-label>
        </ftui-row>
      </ftui-grid-tile>
      <ftui-grid-tile row="4" col="1" height="2" width="5" color="dark">
        <header class="thin"><ftui-label size="3" color="orange">WETTERVOHERSAGE</ftui-label></header>
         <ftui-row width="80%" height="10%">
          <ftui-label size="4">Heute</ftui-label>
         <ftui-weather icon-set="meteocons" provider="proplanta" [condition]="DWD_Wetter:fc0_3_wwd" size="1"></ftui-weather>
           <ftui-label [text]="DWD_Wetter:fc0_Tn | round(0)" size="4" unit="°C">min.    </ftui-label>
           <ftui-label [text]="DWD_Wetter:fc0_Tx | round(0)" size="4" unit="°C">max.    </ftui-label>
        </ftui-row>
          <ftui-label size="4">Morgen</ftui-label>
          <ftui-weather icon-set="meteocons" provider="DWD" [condition]="DWD_Wetter:fc1_3_wwd" size="1"></ftui-weather>
           <ftui-label [text]="DWD_Wetter:fc1_Tn | round(0)" size="4" unit="°C">min.    </ftui-label>
           <ftui-label [text]="DWD_Wetter:fc1_Tx | round(0)" size="4" unit="°C">max.    </ftui-label>
        </ftui-row>
      </ftui-grid-tile>
     <ftui-grid-tile row="4" col="6" height="2" width="2" color="dark">
        <header class="thin"><ftui-label size="3" color="orange">POOL</ftui-label></header>
        <ftui-column width="80%" height="10%">
          <ftui-column align-items="center">
             <ftui-label [text]="ESPEasy_Pool_Temp_Pool:temperature | fix(1)" class="size-8 thin" unit="°C"></ftui-label>
          </ftui-column>
       <ftui-row width="65%">
          <ftui-column height="10%">
             <ftui-icon class="size-1" [name]="ESPEasy_Pool_Pumpe:State | map('off:sani_garden_pump, on:sani_garden_pump')" [color]="ESPEasy_Pool_Pumpe:State | map('off:gray, on:green')"></ftui-icon>
          </ftui-column>
             <ftui-icon class="size-1" [name]="ESPEasy_Pool_Heizung:State | map('off:sani_heating, on:sani_heating')" [color]="ESPEasy_Pool_Heizung:State | map('off:gray, on:green')"></ftui-icon>
          </ftui-column>
       </ftui-row>
      </ftui-column>
   <ftui-column>
         <ftui-column>
            <ftui-label size="1">Pumpe</ftui-label>
         </ftui-column>
         <ftui-column>
            <ftui-label size="1">Heizung</ftui-label>
         </ftui-column>
      </ftui-row>
   </ftui-column>
      </ftui-grid-tile>
     <ftui-grid-tile row="4" col="8" height="4" width="1" color="dark">
        <header class="thin"><ftui-label size="3" color="orange">ESPs</ftui-label></header>
      <ftui-icon class="size-0" [name]="MQTT2_ESP_Strom:LWT | map('Offline:it_memory, Online:it_memory')" [color]="MQTT2_ESP_Strom:LWT | map('Offline:red, Online:green')"></ftui-icon>
       <ftui-label size="1">Strom</ftui-label>
       <ftui-icon class="size-0" [name]="ESPEasy_Pool_state:presence | map('absent:it_memory, present:it_memory')" [color]="ESPEasy_Pool_state:presence | map('absent:red, present:green')"></ftui-icon>
       <ftui-label size="1">Pool</ftui-label>
       <ftui-icon class="size-0" [name]="ESPEasy_Aquarium_state:presence | map('absent:it_memory, present:it_memory')" [color]="ESPEasy_Aquarium_state:presence | map('absent:red, present:green')"></ftui-icon>
       <ftui-label size="1">Aquarium</ftui-label>
       <ftui-icon class="size-0" [name]="ESPEasy_MV_State:presence | map('absent:it_memory, present:it_memory')" [color]="ESPEasy_MV_State:presence | map('absent:red, present:green')"></ftui-icon>
       <ftui-label size="1">Magnetventile</ftui-label>
       <ftui-icon class="size-0" [name]="ESPEasy_Temp_Schlafzimmer_state:presence | map('absent:it_memory, present:it_memory')" [color]="ESPEasy_Temp_Schlafzimmer_state:presence | map('absent:red, present:green')"></ftui-icon>
       <ftui-label size="1">Schlafzimmer</ftui-label>
       <ftui-icon class="size-0" [name]="ESPEasy_Temp_Lena_state:presence | map('absent:it_memory, present:it_memory')" [color]="ESPEasy_Temp_Lena_state:presence | map('absent:red, present:green')"></ftui-icon>
       <ftui-label size="1">Lena</ftui-label>
      </ftui-grid-tile>
     <ftui-grid-tile row="4" col="9" height="2" width="1" color="dark">
        <header class="thin"><ftui-label size="3" color="orange">MÄHNDY</ftui-label></header>
        <ftui-icon class="size-4" [name]="dummy_Landroid_Steuerung:state | map('off:scene_robo_lawnmower, on:scene_robo_lawnmower')" [color]="dummy_Landroid_Steuerung:state | map('off:gray, on:green')"></ftui-icon>
      <ftui-label size="1" [text]="dummy_Landroid_Steuerung:state | map('off:Partymodus, on:Aktiv')"></ftui-label>
      </ftui-grid-tile>
      <ftui-grid-tile row="6" col="1" height="1" width="2" color="dark">
       <header class="thin"><ftui-label size="3" color="orange">AUSSENTEMPERATUR</ftui-label></header>
        <ftui-label [text]="Gartenpumpe:temperature_0 | fix(1)" class="size-7 thin" unit="°C"></ftui-label>
      </ftui-grid-tile>
      <ftui-grid-tile row="7" col="1" height="1" width="2" color="dark">
       <header class="thin"><ftui-label size="3" color="orange">INNENTEMPERATUR</ftui-label></header>
        <ftui-label [text]="HM_54BF41:temperature | fix(1)" class="size-7 thin" unit="°C"></ftui-label>
      </ftui-grid-tile>
     <ftui-grid-tile row="6" col="3" height="2" width="5" color="dark">
      <header class="thin"><ftui-label size="3" color="orange">ABFALLTERMINE</ftui-label></header>
      <ftui-column>
      <ftui-row margin-top="3" margin-bottom="3" width="70%">
       <ftui-label size="3">Biotonne:</ftui-label>
         <ftui-label [text]="abfall_Abfall:calendar_Abfall_Biotonne_date" size="3"></ftui-label>
       <ftui-label [text]="abfall_Abfall:calendar_Abfall_Biotonne_weekday" size="3"></ftui-label>
      </ftui-row>
      </ftui-column>
      <ftui-column>
       <ftui-label size="3">Gelber Sack:</ftui-label>
         <ftui-label [text]="abfall_Abfall:calendar_Abfall_GelberSack_date" size="3"></ftui-label>
       <ftui-label [text]="abfall_Abfall:calendar_Abfall_GelberSack_weekday" size="3"></ftui-label>
      </ftui-row>
      </ftui-column>
      <ftui-column>
       <ftui-label size="3">Papiertonne:</ftui-label>
         <ftui-label [text]="abfall_Abfall:calendar_Abfall_Papiertonne_date" size="3"></ftui-label>
       <ftui-label [text]="abfall_Abfall:calendar_Abfall_Papiertonne_weekday" size="3"></ftui-label>
      </ftui-row>
      </ftui-column>
      <ftui-column>
       <ftui-label size="3">Restabfall:</ftui-label>
         <ftui-label [text]="abfall_Abfall:calendar_Abfall_Restabfall_date" size="3"></ftui-label>
       <ftui-label [text]="abfall_Abfall:calendar_Abfall_Restabfall_weekday" size="3"></ftui-label>
      </ftui-row>
       </ftui-column>
      </ftui-grid-tile>
      <ftui-grid-tile row="1" col="6" height="3" width="3" color="dark">
        <header class="thin"><ftui-label size="3" color="orange">SOLAR</ftui-label></header>
        <ftui-column>
         <ftui-row margin-top="3" margin-bottom="3" width="80%">
            <ftui-column align-items="left">
            <ftui-label text="Ersparnis:" size="4"></ftui-label>
            </ftui-column>
             <ftui-column align-items="right">
            <ftui-label [text]="dummy_Stromersparnis_gesamt:Preis | fix(2)" size="4" unit="€"></ftui-label>
            </ftui-column>
         </ftui-row>
            <ftui-label text="Momentan:" size="4"></ftui-label>
            </ftui-column>
            <ftui-label [text]="dummy_PV_Leistung_Momentan:Leistung | round(0)" size="4" unit="W"></ftui-label>
            </ftui-column>
         </ftui-row>
            <ftui-label text="Gesamt:" size="4"></ftui-label>
            </ftui-column>
            <ftui-label [text]="PV_Leistung_Gesamt:STATE | round(1)" size="4" unit="Kwh"></ftui-label>
            </ftui-column>
         </ftui-row>
            <ftui-label text="Effektivität:" size="4"></ftui-label>
            </ftui-column>
            <ftui-label [text]="dummy_Effektivitaet:Prozent | round(1)" size="4" unit="%"></ftui-label>
            </ftui-column>
         </ftui-row>
            <ftui-label text="Stromzähler:" size="4"></ftui-label>
            </ftui-column>
            <ftui-label [text]="StromzaehlerMomentan:state | round(0)" size="4" unit="W"></ftui-label>
            </ftui-column>
         </ftui-row>
         </ftui-column>
      </ftui-grid-tile>
     <ftui-grid-tile row="1" col="9" height="3" width="1" color="dark">
        <header class="thin"><ftui-label size="3" color="orange">ABFALL</ftui-label></header>
        <ftui-icon name="trash-o" size="7" [class-name]="dummy_Abfall_morgen:state  | step('0:``, 1:hop, 2:``')" [color]="dummy_Abfall_morgen:state  | step('0:gray, 1:orange, 2:gray')"></ftui-icon>
        </ftui-row>
        <ftui-row width="40%" height="0%">
         <ftui-label [text]="abfall_Abfall:next_weekday" size="1"></ftui-label>
        </ftui-row>
      </ftui-grid-tile>
     <ftui-grid-tile row="6" col="9" height="2" width="1" color="dark">
        <header class="thin"><ftui-label size="3" color="orange">NACHT-PV</ftui-label></header>
      <ftui-label class="size-5" [text]="MQTT2_solar_114184531895:power | round(0)" [color]="MQTT2_solar_114184531895:power | map('0.0:gray, .*:green')" unit="W"></ftui-label>
      </ftui-grid-tile>
   </ftui-grid>
</body>
</html>
Schniebi
Zur Lösung kann ich schon mal beitragen das die ganzen Größenverhältnisse für Höhe und Breite,egal ob bei Schrift, Icons oder Grid nicht mehr stimmen und daher einige Sachen nicht mehr zu sehen sind/waren. Aber das Syntaxproblem bleibt weiterhin. Mir ist noch aufgefallen das auch Schaltflächen bei mir momentan nicht funktionieren. In dem Cod meiner index.html sind kein schaltflächen enthalten diese habe ich auf anderen Tablets, Handys.
