Homebridge-Fhem: Installation unter Trixie erfolglos
Begonnen von Tom S, 29 April 2026, 09:38:13
Tom S
ich habe versucht einen Raspberry Pi 3B mit Trixie und der Homebridge und Homebridge-Fhem zu installieren. Leider ohne Erfolg!
Die Homebridge selbst war noch einwandfrei installierbar wie im WIKI beschrieben aber die Installation des Homebridge-Fhem Plugins ergab kein lauffähiges Plugin.
Die Config.json entsprechend der WIKI-Anleitung ergänzt.
Hier das Log des letzten Homebbrigde Starts:
[29.4.2026, 08:26:52] ====================
[29.4.2026, 08:26:52] ERROR LOADING PLUGIN homebridge-fhem:
[29.4.2026, 08:26:53] Error: Cannot find module '/var/lib/homebridge/node_modules/homebridge-fhem/index.js'
Require stack:
- /var/lib/homebridge/node_modules/homebridge/lib/plugin.js
- /var/lib/homebridge/node_modules/homebridge/lib/pluginManager.js
- /var/lib/homebridge/node_modules/homebridge/lib/api.js
- /var/lib/homebridge/node_modules/homebridge/lib/server.js
- /var/lib/homebridge/node_modules/homebridge/lib/cli.js
- /var/lib/homebridge/node_modules/homebridge/bin/homebridge
    at Module._resolveFilename (node:internal/modules/cjs/loader:1476:15)
    at wrapResolveFilename (node:internal/modules/cjs/loader:1049:27)
    at defaultResolveImplForCJSLoading (node:internal/modules/cjs/loader:1073:10)
    at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1094:12)
    at Module._load (node:internal/modules/cjs/loader:1262:25)
    at wrapModuleLoad (node:internal/modules/cjs/loader:255:19)
    at Module.require (node:internal/modules/cjs/loader:1576:12)
    at require (node:internal/modules/helpers:153:16)
    at Plugin.load (/var/lib/homebridge/node_modules/homebridge/src/plugin.ts:228:93)
    at PluginManager.initializeInstalledPlugins (/var/lib/homebridge/node_modules/homebridge/src/pluginManager.ts:141:22)
[29.4.2026, 08:26:53] ====================
[29.4.2026, 08:26:53] Loading 2 platforms...
[29.4.2026, 08:26:53] No plugin was found for the platform "FHEM" in your config.json. Please make sure the corresponding plugin is installed correctly.
Das Ergebnis war auch nach einer kompletten Deinstallation der Hombridge und des Plugins und einer erneuten Installation identisch.
Ist das Plugin Homebridge-Fhem unter Trixie evtl. noch nicht lauffähig?
Wer kann helfen?
Thomas
Tom S
3 x Pi 3B mit FHEM, CUL868/Selbstbau, USB Cam, IPCAM, SolarView PV-Überwachung, I2C, 1-wire
DeeSPe
Das Plugin funktioniert nach wie vor einwandfrei.
Ich würde die offizielle Installation von Homebridge empfehlen:
https://github.com/homebridge/homebridge/wiki/Install-Homebridge-on-Debian-or-Ubuntu-Linux
Dan
passibe
Wie hast du das Plugin denn installiert?
Da homebridge ja zu laufen scheint, würde ich eine Installation von homebridge-fhem über die Weboberfläche von homebridge empfehlen. Dann müsste es eigentlich problemlos laufen.
