98_version.pm - beim restart von fhem seit heute folgende fehler im log
Begonnen von the ratman, 25 Mai 2026, 09:03:44
the ratman
scheint keinen großen einfluß auf anderes zu haben, aber ...
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 258.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 318.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 355.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 514.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 553.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 790.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 1972.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2039.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2063.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2119.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2173.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2196.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2223.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2248.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2276.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2294.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2427.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2523.
2026.05.25 09:01:28 1: PERL WARNING: Use of uninitialized value $max in numeric lt (<) at ./FHEM/98_version.pm line 40, <$fh> line 2742.
→do↑p!dnʇs↓shit←
