nanoCUL Parse_MN, Error! id 117 ... message is to short
Begonnen von TobSch, 08 Juni 2026, 16:59:03
TobSch
seit folgender Änderung https://github.com/mhop/fhem-mirror/commit/cb7fd4982b0cf43c23ae98af51e3b853e4874b37 in SD_Protocols.pm bekomme ich Fehlermeldungen beim Verarbeiten der Sensordaten meiner BRESSER_7-in-1_Wetterstation:
2026.06.08 15:58:09 4: nanoCUL_868MHz: Read, msg: MN;D=372FB2BEBC8A18AAAAAAAAAAAAAA8B8ACEAAAA9FAAAA;R=58;A=4;
2026.06.08 15:58:09 4: nanoCUL_868MHz: Parse_MN, Error! id 117 msg=372FB2BEBC8A18AAAAAAAAAAAAAA8B8ACEAAAA9FAAAA, message is to short
Mit der SD_Protocols.pm 2.07 (anstatt 2.09) läuft es (die dazu passende SD_ProtocolData.pm vorausgesetzt):
   CODE       SD_WS_117
   DEF        SD_WS_117
   FUUID      64f43401-f33f-49f8-8899-cb8c3ca745098f0e
   FVERSION   14_SD_WS.pm:v1.1.7-s30748/2026-01-17
   LASTInputDev nanoCUL_868MHz
   MSGCNT     190
   NAME       SD_WS_117
   NR         277
   STATE      T: 21.3 H: 64 W: 0 R: 0 B: 0.103
   TYPE       SD_WS
   bitMSG     01001010101100000001100000010100000101100010000010110010000000000000000000000000000000000000000000000000000000000010000100110000011001000000000000000001000000110000000000000000
   eventCount 42
   lastMSG    4AB018141620B2000000000000002130640001030000
   lastReceive 1780930327.39694
   nanoCUL_868MHz_DMSG W117#4AB018141620B2000000000000002130640001030000
   nanoCUL_868MHz_FREQAFC 6
   nanoCUL_868MHz_MSGCNT 190
   nanoCUL_868MHz_Protocol_ID 117
   nanoCUL_868MHz_RAWMSG MN;D=E01AB2BEBC8A18AAAAAAAAAAAAAA8B9ACEAAABA9AAAA;R=58;A=4;
   nanoCUL_868MHz_RSSI -45
   nanoCUL_868MHz_TIME 2026-06-08 16:52:07
     2026-01-27 16:11:37   batteryChanged  1
     2026-06-08 16:52:07   batteryState    ok
     2026-06-08 16:52:07   brightness      0.103
     2026-06-08 16:52:07   humidity        64
     2026-06-08 16:10:09   model           Bresser 7-in-1 outdoor sensor
     2026-06-08 16:52:07   rain            0
