zigbee2mqtt payload setzen
Begonnen von satprofi, 25 Juni 2026, 11:39:29
satprofi
Hallo.
Habe hier ein Sonoff Wasserventil. Wie ich jetzt erfahren habe muss beim setzen der ,z.b. runtime ,alles mitgegeben werden. wie kann ich jetzt die werte der readings autom. einsetzen, wenn ich nur die runtime verändern will ?
runtime:slider,0,1,719 $DEVICETOPIC/set {"manual_default_settings": {"irrigation_duration": $EVTPART1, "irrigation_mode": "duration", "irrigation_amount_unit": "liter", "irrigation_amount": 199, "fail_safe": 0}}
jetzt verändere ich nur die runtime, aber die fixen werte sollten von den readings übernommen werden. geht das?
das list des devices 2026-06-25 11:35:02   battery         100
     2026-06-25 11:35:02   child_lock      UNLOCK
     2026-06-25 11:35:02   hour_irrigation_duration 2
     2026-06-25 11:35:02   hour_irrigation_volume 1
     2026-06-25 11:35:02   irrigation_schedule_status_actual_end_time 2026-06-25T11:03:08+02:00
     2026-06-25 11:35:02   irrigation_schedule_status_actual_irrigation_amount 0
     2026-06-25 11:35:02   irrigation_schedule_status_expected_end_time 2026-06-25T11:41:07+02:00
     2026-06-25 11:35:02   irrigation_schedule_status_expected_irrigation_amount 200
     2026-06-25 11:35:02   irrigation_schedule_status_irrigation_amount_unit liter
     2026-06-25 11:35:02   irrigation_schedule_status_irrigation_mode duration
     2026-06-25 11:35:02   irrigation_schedule_status_schedule_index 0
     2026-06-25 11:35:02   irrigation_schedule_status_schedule_status end
     2026-06-25 11:35:02   irrigation_schedule_status_schedule_type manual
     2026-06-25 11:35:02   irrigation_schedule_status_start_time 2026-06-25T11:01:07+02:00
     2026-06-25 11:35:02   linkquality     135
     2026-06-25 11:35:02   manual_default_settings_fail_safe 0
     2026-06-25 11:35:02   manual_default_settings_irrigation_amount 199
     2026-06-25 11:35:02   manual_default_settings_irrigation_amount_unit liter
     2026-06-25 11:35:02   manual_default_settings_irrigation_duration 46
     2026-06-25 11:35:02   manual_default_settings_irrigation_mode duration
     2026-06-25 11:35:02   rain_delay_end_datetime
     2026-06-25 11:35:02   real_time_irrigation_duration 45
     2026-06-25 11:35:02   real_time_irrigation_volume 439
     2026-06-25 11:35:02   seasonal_watering_adjustment_april 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_august 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_december 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_february 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_january 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_july 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_june 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_march 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_may 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_november 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_october 1
     2026-06-25 11:35:02   seasonal_watering_adjustment_september 1
     2026-06-25 09:39:29   set_child_lock  UNLOCK
     2026-06-25 11:33:08   set_manual_default_settings_fail_safe 0
     2026-06-25 10:32:55   set_manual_default_settings_irrigation_amaount 199
     2026-06-25 11:33:08   set_manual_default_settings_irrigation_amount 199
     2026-06-25 11:33:08   set_manual_default_settings_irrigation_amount_unit liter
     2026-06-25 11:33:08   set_manual_default_settings_irrigation_duration 46
     2026-06-25 11:33:08   set_manual_default_settings_irrigation_mode duration
     2026-06-25 11:01:06   set_state       ON
     2026-06-25 11:35:02   state           OFF
HMLAN, HM-CC-RT-DN,Homematic Actoren,Zigbee,Shelly,
Tasmota,LD382A,Telegram
#1
Meine Suche ergab diesen Link: https://forum.fhem.de/index.php?msg=1363877
Bitte dazu meinen Hinweis aus https://forum.fhem.de/index.php?msg=1365698 beachten. Falls es dann "korrekt" ist, checke ich das Ergebnis gerne ein.
PS: "qq" würde die Lesbarkeit erhöhen...
satprofi
hallo.
ich schaffe es einfach nicht die setlist zu adaptieren.
habe mir ein script angelegt, wo der befehl einwandfrei abgestezt wird
sub Ventil{
   my $a=ReadingsNum("MQTT2_zigbee_WasserVentil","irrigation_duration",0);
   my $b=ReadingsVal("MQTT2_zigbee_WasserVentil","irrigation_amount_unit",0);
   my $c=ReadingsNum("MQTT2_zigbee_WasserVentil","irrigation_amount",0);
   my $d=ReadingsNum("MQTT2_zigbee_WasserVentil","irrigation_fail_safe",0);
   my $e=ReadingsVal("MQTT2_zigbee_WasserVentil","irrigation_mode",0);
   fhem("setreading MQTT2_zigbee_WasserVentil test {\"manual_default_settings\":{\"irrigation_duration\":$a,\"irrigation_mode\":\"$e\",\"irrigation_amount_unit\":\"$b\",\"irrigation_amount\":$c,\"fail_safe\":$d}}");
Ergebnis -> {"manual_default_settings":{"irrigation_duration":120,"irrigation_mode":"duration","irrigation_amount_unit":"liter","irrigation_amount":169,"fail_safe":0}}
übertrage ich das angepasst an die setlist irrigation_mode:duration,capacity {my $a=ReadingsNum("MQTT2_zigbee_WasserVentil","irrigation_duration",0);
   my $d=ReadingsNum("MQTT2_zigbee_WasserVentil","irrigation_fail_safe",0); return "$DEVICETOPIC/set {\"manual_default_settings\":{\"irrigation_duration\":$a,\"irrigation_mode\":\"$EVTPART1\",\"irrigation_amount_unit\":\"$b\",\"irrigation_amount\":$c,\"fail_safe\":$d} } }
erhalte ich folgende fehlermeldung
Missing right curly or square bracket at (eval 9346937) line 1, at end of line
syntax error at (eval 9346937) line 1, at EOF
wie blöd kann man sein?
lg
Schreib mal alles in eine Zeile... (Oder escape die Zeilenumbrüche).
satprofi
