Revision 31668: 14_SD_RSL.pm: precompile Match regex, use code references for module ...
Begonnen von System, 20 September 2026, 18:11:04
System
14_SD_RSL.pm: precompile Match regex, use code references for module functions, add FHEM::Meta support
Source: Revision 31668: 14_SD_RSL.pm: precompile Match regex, use code references for module ...
