fhempy system_update, Reading sate kein Event.
Begonnen von heinzfo, 24 November 2026, 10:26:56
heinzfo
fhempy system_update, Reading "sate" erzeugt keinen Event, taucht im Event Monitor nicht auf, Timestamp wird rot eingefärbt.
list:
   DEF        system_update
   FHEMPYTYPE system_update
   FUUID      6afc922c-f33f-25ac-03a0-06835985a37ec0a6
   IODev      pyBinding
   NAME       system_update_rpi
   NR         833
   NTFY_ORDER 50-system_update_rpi
   PYTHONTYPE system_update
   STATE      up to date
   TYPE       fhempy
   disableNotifyFn 1
   eventCount 13
   timeout    3000
     2026-11-24 07:28:25   backup          no github_backup
     2026-11-24 10:14:48   last_check      2026-11-24 10:14:48
     2026-11-24 07:30:32   last_error      update failed: update was interrupted. Use set repair if it was interrupted.
     2026-11-24 07:30:32   last_update     2026-11-24 07:30:32
     2026-11-24 07:30:32   packages_kept_back -
     2026-11-24 07:30:32   packages_updated chromium-l10n, chromium, chromium-common
     2026-11-24 10:14:48   state           up to date
     2026-11-24 10:14:48   updates         -
     2026-11-24 10:14:48   updates_available 0
     2026-11-24 10:14:48   updates_held    -
     2026-11-24 10:14:48   updates_security 0
   args:
     system_update_rpi
     fhempy
     system_update
   argsh:
   auto_update off
   group      system_update
   icon       system_fhem_update
   room       IT_Equipment,fhempy
   sortby     01
   update_time 03:15
Grüße, Heinz
