Multiple systems
Begonnen von H3nr1, 03 November 2013, 15:29:27
H3nr1
I think it is posible to connect multiple CUL for HM or FS20 or Enocean.
If it is possible can you configure the HM switch to operate the FS20 actuator ?
I have Enocean but a like some of the hardware from HM. Do i have to stick to 1 System?
Thanks
Henri
Correct.
Not directly, but with FHEM inbetween and a notify set up to trigger for the HM switch, you can operate the FS20 actuator
No, but you have to buy an RF-Transcever for each system (1xCUL OR 1xHMLAN) AND (1x EUL OR 1xBSC OR ...)
