at genau zu jeder vollen Stunde erzeugen ...
Begonnen von ritchie, 18 November 2013, 17:45:56
ritchie
Hallo Zusamen,
wie erzeuge ich eigentlich einen at zu jeder vollen Stunde /halben Stunde genau !
define evtRoutineEveryHour at +*01:00:00 { .... }
startet zwar jede Stunde, aber nicht synchron zu jeder zeitlichen Stunde. Also um 17:00, 18:00, 19:00, ....
Gruss R.
IPU662  IPFIRE & FHEM (Homematic + MAX) - Produktiv
Intel iCore 3 / 16GBRAM / 500GB SSD / Ubuntu  (1Wire - USB) - Produktiv
justme1968
attr evtRoutineEveryHour alignTime 00:00
  andre
ritchie
#2
habe ich doch glatt gerade in der Doku. gefunden.
Attributes
    disable
    Can be applied to at/watchdog/notify/FileLog devices.
    Disables the corresponding at/notify or FileLog device. Note: If applied to an at, the command will not be executed, but the next time will be computed.
    skip_next
    Used for at commands: skip the execution of the command the next time.
    alignTime
    Applies only to relative at definitions: adjust the time of the next command execution so, that it will also be executed at the desired alignTime. The argument is a timespec, see above for the definition.
    Example:
        # Make sure that it chimes when the new hour begins
        define at2 at +*01:00 set Chime on-for-timer 1
        attr atr2 alignTime 00:00
für jede halbe Stunde wäre es dann:
attr evtRoutineEveryHalfHour alignTime 00:30
Gruss R.
