FHEMduino
Begonnen von mdorenka, 06 Dezember 2013, 15:34:39
chris1284
was sagt dmesg nach deim einstecken? ich hatte mal sowas da wurde für den nano/ftdi ein falscher treiber geladen
link611
#1666
nach dem einstecken:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.13-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3                               (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #894 SMP Mon Jun 13 13:13:27 BS                              T 2016
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio                              n cache
[    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] cma: Reserved 8 MiB at 0x3a800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 241664
[    0.000000] free_area_init_node: node 0, pgdat 808c0e00, node_mem_map b9fa600                              0
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (9520->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 13 pages/cpu @b9f62000 s22592 r8192 d22464 u5324                              8
[    0.000000] pcpu-alloc: s22592 r8192 d22464 u53248 alloc=13*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pag                              es: 239540
[    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_                              fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=                              0x863402ce smsc95xx.macaddr=B8:27:EB:34:02:CE bcm2708_fb.fbswap=1 bcm2709.uart_c                              lock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm                              _enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4                               elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 939080K/966656K available (6344K kernel code, 432K rwdata                              , 1712K rodata, 476K init, 764K bss, 19384K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
    lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x807e6470   (8058 kB)
      .init : 0x807e7000 - 0x8085e000   ( 476 kB)
      .data : 0x8085e000 - 0x808ca108   ( 433 kB)
       .bss : 0x808cd000 - 0x8098c1ac   ( 765 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:                               0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 43980                              46511078ns
[    0.000024] Switching to timer-based delay loop, resolution 52ns
[    0.000282] Console: colour dummy device 80x30
[    0.001336] console [tty1] enabled
[    0.001379] Calibrating delay loop (skipped), value calculated using timer fr                              equency.. 38.40 BogoMIPS (lpj=192000)
[    0.001447] pid_max: default: 32768 minimum: 301
[    0.001785] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001828] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002770] Disabling cpuset control group subsystem
[    0.002829] Initializing cgroup subsys io
[    0.002880] Initializing cgroup subsys memory
[    0.002940] Initializing cgroup subsys devices
[    0.002983] Initializing cgroup subsys freezer
[    0.003027] Initializing cgroup subsys net_cls
[    0.003098] CPU: Testing write buffer coherency: ok
[    0.003183] ftrace: allocating 21209 entries in 63 pages
[    0.053689] CPU0: update cpu_capacity 1024
[    0.053756] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.053788] [bcm2709_smp_prepare_cpus] enter
[    0.053936] Setting up static identity map for 0x8240 - 0x8274
[    0.055566] [bcm2709_boot_secondary] cpu:1 started (0) 18
[    0.055892] [bcm2709_secondary_init] enter cpu:1
[    0.055934] CPU1: update cpu_capacity 1024
[    0.055940] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.056316] [bcm2709_boot_secondary] cpu:2 started (0) 16
[    0.056577] [bcm2709_secondary_init] enter cpu:2
[    0.056598] CPU2: update cpu_capacity 1024
[    0.056604] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.056962] [bcm2709_boot_secondary] cpu:3 started (0) 18
[    0.057143] [bcm2709_secondary_init] enter cpu:3
[    0.057163] CPU3: update cpu_capacity 1024
[    0.057169] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.057230] Brought up 4 CPUs
[    0.057329] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.057358] CPU: All CPU(s) started in HYP mode.
[    0.057384] CPU: Virtualization extensions available.
[    0.058015] devtmpfs: initialized
[    0.068111] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3                               rev 4
[    0.068469] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma                              x_idle_ns: 19112604462750000 ns
[    0.069231] pinctrl core: initialized pinctrl subsystem
[    0.069787] NET: Registered protocol family 16
[    0.074935] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.081810] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint                               registers.
[    0.081859] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.082040] Serial: AMBA PL011 UART driver
[    0.082199] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gp                              io@7e200000/uart0_pins, deferring probe
[    0.082405] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.145847] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dma                              chans=0x1
[    0.146445] SCSI subsystem initialized
[    0.146643] usbcore: registered new interface driver usbfs
[    0.146753] usbcore: registered new interface driver hub
[    0.146870] usbcore: registered new device driver usb
[    0.153254] raspberrypi-firmware soc:firmware: Attached to firmware from 2016                              -06-20 18:13
[    0.180467] clocksource: Switched to clocksource arch_sys_counter
[    0.225230] FS-Cache: Loaded
[    0.225522] CacheFiles: Loaded
[    0.237821] NET: Registered protocol family 2
[    0.238690] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.238828] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.239039] TCP: Hash tables configured (established 8192 bind 8192)
[    0.239154] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.239221] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.239473] NET: Registered protocol family 1
[    0.239813] RPC: Registered named UNIX socket transport module.
[    0.239845] RPC: Registered udp transport module.
[    0.239873] RPC: Registered tcp transport module.
[    0.239901] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.240993] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counter                              s available
[    0.242327] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.255621] VFS: Disk quotas dquot_6.6.0
[    0.255953] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.258255] FS-Cache: Netfs 'nfs' registered for caching
[    0.259170] NFS: Registering the id_resolver key type
[    0.259232] Key type id_resolver registered
[    0.259261] Key type id_legacy registered
[    0.261598] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2                              52)
[    0.261766] io scheduler noop registered
[    0.261805] io scheduler deadline registered (default)
[    0.261880] io scheduler cfq registered
[    0.264412] BCM2708FB: allocated DMA memory fac00000
[    0.264459] BCM2708FB: allocated DMA channel 0 @ f3007000
[    0.269645] Console: switching to colour frame buffer device 82x26
[    1.142374] bcm2835-rng 3f104000.rng: hwrng registered
[    1.143899] vc-cma: Videocore CMA driver
[    1.145306] vc-cma: vc_cma_base      = 0x00000000
[    1.146709] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.148060] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.149556] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000                              000(1008 MiB)
[    1.166817] brd: module loaded
[    1.176673] loop: module loaded
[    1.178776] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[    1.181502] Loading iSCSI transport class v2.0-870.
[    1.183389] usbcore: registered new interface driver smsc95xx
[    1.184732] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.386252] Core Release: 2.80a
[    1.387478] Setting default values for core params
[    1.388740] Finished setting default values for core params
[    1.590363] Using Buffer DMA mode
[    1.591643] Periodic Transfer Interrupt Enhancement - disabled
[    1.592953] Multiprocessor Interrupt Enhancement - disabled
[    1.594291] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.595610] Dedicated Tx FIFOs mode
[    1.597162] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac                              14000 dma = 0xfac14000 len=9024
[    1.599869] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[    1.606734] dwc_otg: Microframe scheduler enabled
[    1.606787] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80446a60
[    1.608209] WARN::hcd_init_fiq:414: FIQ ASM at 0x80446dd0 length 36
[    1.609589] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb922000
[    1.610980] dwc_otg 3f980000.usb: DWC OTG Controller
[    1.612339] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number                               1
[    1.613722] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    1.615092] Init: Port Power? op_state=1
[    1.616404] Init: Power Port (0)
[    1.617866] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.619210] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=                              1
[    1.620566] usb usb1: Product: DWC OTG Controller
[    1.621877] usb usb1: Manufacturer: Linux 4.4.13-v7+ dwc_otg_hcd
[    1.623199] usb usb1: SerialNumber: 3f980000.usb
[    1.625299] hub 1-0:1.0: USB hub found
[    1.626596] hub 1-0:1.0: 1 port detected
[    1.628375] dwc_otg: FIQ enabled
[    1.628384] dwc_otg: NAK holdoff enabled
[    1.628392] dwc_otg: FIQ split-transaction FSM enabled
[    1.628429] Module dwc_common_port init
[    1.628693] usbcore: registered new interface driver usb-storage
[    1.630186] mousedev: PS/2 mouse device common for all mice
[    1.632166] bcm2835-cpufreq: min=600000 max=1200000
[    1.633715] sdhci: Secure Digital Host Controller Interface driver
[    1.635028] sdhci: Copyright(c) Pierre Ossman
[    1.636623] sdhost: log_buf @ bac13000 (fac13000)
[    1.710499] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.714056] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    1.715389] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    1.767580] mmc0: host does not support reading read-only switch, assuming wr                              ite-enable
[    1.770582] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.772122] mmc0: new high speed SDHC card at address 59b4
[    1.772360] ledtrig-cpu: registered to indicate activity on CPUs
[    1.772478] hidraw: raw HID events driver (C) Jiri Kosina
[    1.772656] usbcore: registered new interface driver usbhid
[    1.772658] usbhid: USB HID core driver
[    1.773183] Initializing XFRM netlink socket
[    1.773215] NET: Registered protocol family 17
[    1.773339] Key type dns_resolver registered
[    1.773838] Registering SWP/SWPB emulation handler
[    1.774640] registered taskstats version 1
[    1.774822] vc-sm: Videocore shared memory driver
[    1.774830] [vc_sm_connected_init]: start
[    1.782026] [vc_sm_connected_init]: end - returning 0
[    1.783387] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud =                               0) is a PL011 rev2
[    1.783759] of_cfs_init
[    1.783835] of_cfs_init: OK
[    1.795042] Waiting for root device /dev/mmcblk0p2...
[    1.795391] mmcblk0: mmc0:59b4 USD   15.0 GiB
[    1.796964]  mmcblk0: p1 p2
[    1.802202] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesyst                              em
[    1.803469] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    1.815017] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.817841] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.820582] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.820586] Indeed it is in host mode hprt0 = 00021501
[    1.825706] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.917673] mmc1: new high speed SDIO card at address 0001
[    2.000503] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.001849] Indeed it is in host mode hprt0 = 00001101
[    2.200749] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.202042] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.204068] hub 1-1:1.0: USB hub found
[    2.205448] hub 1-1:1.0: 5 ports detected
[    2.249536] EXT4-fs (mmcblk0p2): recovery complete
[    2.265421] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O                              pts: (null)
[    2.267997] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.272400] devtmpfs: mounted
[    2.274518] Freeing unused kernel memory: 476K (807e7000 - 8085e000)
[    2.480520] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.580820] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.582297] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber                              =0
[    2.586508] smsc95xx v1.0.4
[    2.588653] random: systemd urandom read with 69 bits of entropy available
[    2.594374] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SEL                              INUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    2.597872] systemd[1]: Detected architecture 'arm'.
[    2.653773] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-                              1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:34:02:ce
[    2.715865] NET: Registered protocol family 10
[    2.719025] systemd[1]: Inserted module 'ipv6'
[    2.723958] systemd[1]: Set hostname to <raspberrypi>.
[    3.148773] systemd[1]: Starting Forward Password Requests to Wall Directory                               Watch.
[    3.152389] systemd[1]: Started Forward Password Requests to Wall Directory W                              atch.
[    3.155670] systemd[1]: Starting Remote File Systems (Pre).
[    3.159450] systemd[1]: Reached target Remote File Systems (Pre).
[    3.161327] systemd[1]: Starting Arbitrary Executable File Formats File Syste                              m Automount Point.
[    3.167041] systemd[1]: Set up automount Arbitrary Executable File Formats Fi                              le System Automount Point.
[    3.170512] systemd[1]: Starting Encrypted Volumes.
[    3.174232] systemd[1]: Reached target Encrypted Volumes.
[    3.176030] systemd[1]: Starting Swap.
[    3.179613] systemd[1]: Reached target Swap.
[    3.181330] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    3.184938] systemd[1]: Starting Root Slice.
[    3.188556] systemd[1]: Created slice Root Slice.
[    3.190191] systemd[1]: Starting User and Session Slice.
[    3.193762] systemd[1]: Created slice User and Session Slice.
[    3.195361] systemd[1]: Starting Delayed Shutdown Socket.
[    3.198772] systemd[1]: Listening on Delayed Shutdown Socket.
[    3.200321] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    3.203721] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    3.205241] systemd[1]: Starting Journal Socket (/dev/log).
[    3.208550] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.210099] systemd[1]: Starting udev Control Socket.
[    3.213439] systemd[1]: Listening on udev Control Socket.
[    3.215009] systemd[1]: Starting udev Kernel Socket.
[    3.218305] systemd[1]: Listening on udev Kernel Socket.
[    3.219883] systemd[1]: Starting Journal Socket.
[    3.223270] systemd[1]: Listening on Journal Socket.
[    3.224898] systemd[1]: Starting System Slice.
[    3.228260] systemd[1]: Created slice System Slice.
[    3.229825] systemd[1]: Starting File System Check on Root Device...
[    3.261042] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    3.264775] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.266341] systemd[1]: Starting system-getty.slice.
[    3.269978] systemd[1]: Created slice system-getty.slice.
[    3.271748] systemd[1]: Starting Increase datagram queue length...
[    3.277533] systemd[1]: Starting Restore / save the current clock...
[    3.286726] systemd[1]: Mounted Huge Pages File System.
[    3.288894] systemd[1]: Starting Create list of required static device nodes                               for the current kernel...
[    3.328892] systemd[1]: Starting Load Kernel Modules...
[    3.383169] systemd[1]: Started Set Up Additional Binary Formats.
[    3.385974] systemd[1]: Mounting Debug File System...
[    3.417145] fuse init (API version 7.23)
[    3.441109] systemd[1]: Starting udev Coldplug all Devices...
[    3.448642] systemd[1]: Mounting POSIX Message Queue File System...
[    3.452352] i2c /dev entries driver
[    3.457905] systemd[1]: Starting Slices.
[    3.462230] systemd[1]: Reached target Slices.
[    3.469578] systemd[1]: Mounted POSIX Message Queue File System.
[    3.474114] systemd[1]: Mounted Debug File System.
[    3.479841] systemd[1]: Started Increase datagram queue length.
[    3.495549] systemd[1]: Started Restore / save the current clock.
[    3.499901] systemd[1]: Started Create list of required static device nodes f                              or the current kernel.
[    3.506566] systemd[1]: Started Load Kernel Modules.
[    3.515962] systemd[1]: Time has been changed
[    3.563965] systemd[1]: Started udev Coldplug all Devices.
[    3.618709] systemd[1]: Started File System Check on Root Device.
[    3.673911] systemd[1]: Mounting Configuration File System...
[    3.710905] systemd[1]: Starting Apply Kernel Variables...
[    3.717589] systemd[1]: Mounting FUSE Control File System...
[    3.724816] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.732349] systemd[1]: Starting Syslog Socket.
[    3.736876] systemd[1]: Listening on Syslog Socket.
[    3.738850] systemd[1]: Starting Journal Service...
[    3.747867] systemd[1]: Started Journal Service.
[    3.899939] systemd-udevd[138]: starting version 215
[    4.325292] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[    4.327689] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f2                              00000
[    4.609876] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    4.671018] usbcore: registered new interface driver brcmfmac
[    4.812584] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2                              016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[    4.833621] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    5.003162] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    5.003201] cfg80211: World regulatory domain updated:
[    5.003212] cfg80211:  DFS Master region: unset
[    5.003221] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gai                              n, max_eirp), (dfs_cac_time)
[    5.003235] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 m                              Bm), (N/A)
[    5.003248] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 m                              Bm), (N/A)
[    5.003260] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 m                              Bm), (N/A)
[    5.003275] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AU                              TO), (N/A, 2000 mBm), (N/A)
[    5.003289] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AU                              TO), (N/A, 2000 mBm), (0 s)
[    5.003301] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000                               mBm), (0 s)
[    5.003313] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 m                              Bm), (N/A)
[    5.003325] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0                               mBm), (N/A)
[    5.274202] systemd-journald[136]: Received request to flush runtime journal                               from PID 1
[    5.917223] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[    5.917236] brcmfmac: brcmf_add_if: ignore IF event
[    5.920905] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    5.920934] brcmfmac: power management disabled
[    6.065939] uart-pl011 3f201000.uart: no DMA platform data
[    6.071362] random: nonblocking pool is initialized
[    6.542187] cfg80211: Regulatory domain changed to country: DE
[    6.542211] cfg80211:  DFS Master region: ETSI
[    6.542221] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gai                              n, max_eirp), (dfs_cac_time)
[    6.542235] cfg80211:   (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 m                              Bm), (N/A)
[    6.542250] cfg80211:   (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AU                              TO), (N/A, 2000 mBm), (N/A)
[    6.542264] cfg80211:   (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AU                              TO), (N/A, 2000 mBm), (0 s)
[    6.542277] cfg80211:   (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698                               mBm), (0 s)
[    6.542289] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 40                              00 mBm), (N/A)
[    6.563161] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:1                              02396k SSFS
[    7.482715] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    7.482965] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    9.045721] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    9.046647] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E                              1
[   10.848605] Bluetooth: Core ver 2.21
[   10.848690] NET: Registered protocol family 31
[   10.848700] Bluetooth: HCI device and connection manager initialized
[   10.848722] Bluetooth: HCI socket layer initialized
[   10.848739] Bluetooth: L2CAP socket layer initialized
[   10.848772] Bluetooth: SCO socket layer initialized
[   10.857307] Bluetooth: HCI UART driver ver 2.3
[   10.857326] Bluetooth: HCI UART protocol H4 registered
[   10.857335] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   10.858018] Bluetooth: HCI UART protocol BCM registered
[   11.047670] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   11.047690] Bluetooth: BNEP filters: protocol multicast
[   11.047712] Bluetooth: BNEP socket layer initialized
[  174.951884] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[  175.080606] usb 1-1.2: New USB device found, idVendor=0403, idProduct=6001
[  175.080627] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber                              =3
[  175.080640] usb 1-1.2: Product: FT232R USB UART
[  175.080652] usb 1-1.2: Manufacturer: FTDI
[  175.080664] usb 1-1.2: SerialNumber: A402YIQV
[  176.141242] usbcore: registered new interface driver usbserial
[  176.141335] usbcore: registered new interface driver usbserial_generic
[  176.141417] usbserial: USB Serial support registered for generic
[  176.151099] usbcore: registered new interface driver ftdi_sio
[  176.151208] usbserial: USB Serial support registered for FTDI USB Serial Devi                              ce
[  176.151495] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
[  176.151696] usb 1-1.2: Detected FT232RL
[  176.152740] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUS                              B0
root@raspberrypi:~# dmesg
[    0.000000] Linux version 4.4.13-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #894 SMP Mon Jun 13 13:13:27 BST 2016
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] free_area_init_node: node 0, pgdat 808c0e00, node_mem_map b9fa6000
[    0.000000] PERCPU: Embedded 13 pages/cpu @b9f62000 s22592 r8192 d22464 u53248
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x863402ce smsc95xx.macaddr=B8:27:EB:34:02:CE bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] Memory: 939080K/966656K available (6344K kernel code, 432K rwdata, 1712K rodata, 476K init, 764K bss, 19384K reserved, 8192K cma-reserved)
[    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001379] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.068469] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.082199] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.145847] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[    0.153254] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-06-20 18:13
[    0.240993] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.261598] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.149556] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    1.597162] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[    1.619210] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.767580] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.802202] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    2.265421] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.582297] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.594374] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    2.653773] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:34:02:ce
[    3.152389] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.161327] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    3.167041] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.499901] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    4.327689] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    4.812584] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[    5.003221] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    5.003235] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    5.003248] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    5.003260] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    5.003275] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    5.003289] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    5.003313] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    6.542221] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    6.542235] cfg80211:   (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    6.542250] cfg80211:   (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    6.542264] cfg80211:   (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    6.542289] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[    6.563161] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
[    9.046647] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[  175.080627] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  176.151208] usbserial: USB Serial support registered for FTDI USB Serial Device
[  176.152740] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
interessanterweise scheint er jetzt aufzutauchen....
link611
ok, Problem gefunden.
der fhemduino wird nicht erkannt, sobald der HMUSB angeschlossen ist.
Denke mal, dass das 1,2A Netzteil zu schwach ist für den RPi3 (hatte derzeit kein anderes da^^)
Sobald ich einen USB Hub ran hänge funktioniert er.
dmesg hat mir dabei geholfen =D dankeschön.
Wernieman
Zeigt er überhaupt USB-Geräte?
- Bitte um Input für Output
Teamdrachen
Ich hab mal noch eine Frage / Bitte zu den Bresser 3Ch Sensoren.
Momentan hat Lidl die 15€ Wetterstation wieder im Angebot und auch die Sensoren wurden inzwischen decodiert.
Quelle: http://forum.iobroker.net/viewtopic.php?f=35&t=3831&p=35623#p35623
Start Bit L: 740 H: 712
Data Bits: 40
L: 504 272 260 508 260 276 264 508 512 512 260 268 504 268 268 508 260 508 512 264 508 268 508 512 516 512 276 508 264 512 524 268 504 264 264 508 508 508 504 272
H: 228 456 464 224 464 464 452 220 220 212 464 464 220 468 460 212 472 216 220 464 216 464 216 220 212 212 456 216 460 220 212 452 220 464 464 220 224 216 220 464
1001000111001001011010111101011010011110
Start Bit L: 750 H: 704
Data Bits: 40
L: 508 276 264 508 260 268 268 508 508 504 272 268 508 268 260 504 280 520 516 268 508 280 516 508 508 508 268 508 268 512 512 272 512 272 264 508 512 516 516 280
H: 220 452 460 224 464 464 456 224 216 220 464 456 216 464 464 224 452 208 212 456 220 452 208 224 216 216 464 216 464 216 212 460 216 456 460 216 224 208 216 452
Start Bit L: 740 H: 704
Data Bits: 40
L: 508 264 272 508 264 276 260 512 512 512 268 264 520 272 280 516 272 520 516 264 508 268 512 512 512 512 264 512 264 516 512 264 512 272 268 520 516 524 516 276
H: 224 460 460 216 460 464 456 224 212 212 464 460 216 452 452 208 452 212 208 460 224 460 220 212 212 220 460 220 460 212 224 456 220 452 460 212 208 216 200 452
Start Bit L: 750 H: 700
Data Bits: 40
L: 512 272 264 500 272 272 276 520 508 516 268 276 512 272 280 512 272 512 512 272 512 272 508 508 516 512 272 504 272 512 520 280 512 280 276 512 512 512 508 280
H: 216 460 460 224 460 456 452 208 216 216 456 456 212 460 452 208 456 216 220 452 212 460 216 224 212 212 460 220 460 212 208 452 212 452 448 212 220 212 224 452
Start Bit L: 750 H: 696
Data Bits: 40
L: 512 264 272 516 264 280 264 512 512 512 272 264 512 264 272 512 260 520 520 272 512 268 512 512 512 516 276 520 276 520 524 272 516 268 272 512 504 512 508 276
H: 220 460 460 212 460 456 456 220 212 220 452 460 224 456 464 212 464 216 200 460 212 460 220 212 220 212 448 212 448 212 204 448 216 456 460 212 220 220 216 460
Data Bits: 40
L: 520 272 268 520 272 284 272 508 512 512 272 264 516 276 264 512 272 516 512 268 512 268 520 520 516 520 272 520 272 516 520 268 512 264 264 512 512 512 512 272
H: 212 452 456 212 452 456 444 220 216 212 460 460 220 448 460 220 456 212 212 460 220 456 212 208 204 216 452 212 452 208 220 448 220 460 460 220 212 220 216 452
Data Bits: 40
L: 504 280 268 516 268 272 268 508 512 512 272 268 516 272 268 512 264 508 520 272 520 272 520 508 516 512 264 512 272 508 516 268 516 268 264 512 512 512 516 284
H: 220 456 456 216 456 460 452 224 216 212 460 460 208 460 456 220 460 216 216 452 212 452 212 216 208 220 460 220 452 216 224 452 216 456 460 220 212 220 212 448
Data Bits: 40
L: 508 272 264 512 264 264 272 508 512 512 272 272 516 284 284 520 272 512 520 272 520 264 504 508 512 512 268 512 272 516 512 268 512 268 264 520 516 512 516 264
H: 216 460 460 220 460 460 464 220 216 212 460 452 212 448 448 204 452 212 216 452 212 456 220 228 212 220 456 220 452 208 220 460 216 460 460 212 208 220 208 460
Data Bits: 40
L: 508 276 268 520 268 284 276 524 516 516 280 272 520 280 276 520 272 508 516 268 512 268 516 508 516 520 264 516 268 516 528 272 516 280 276 524 520 520 520 276
H: 216 456 456 216 452 456 444 204 212 208 452 452 208 452 448 208 456 212 220 456 220 456 216 220 204 216 456 220 456 208 212 444 220 444 448 208 204 212 204 456
Data Bits: 40
L: 516 276 268 516 272 276 268 508 524 520 284 276 520 280 280 520 268 516 516 268 516 272 516 520 508 516 268 520 272 516 520 268 512 272 284 520 516 512 512 280
H: 216 452 456 216 452 456 456 220 208 204 448 448 212 444 452 204 456 216 208 456 220 452 212 208 216 216 456 212 456 212 212 448 220 456 448 204 208 220 212 456
Data Bits: 40
L: 512 268 276 520 276 284 276 524 520 520 284 268 516 268 276 516 276 516 516 280 516 272 516 520 516 512 272 520 280 524 524 284 524 276 284 520 520 516 516 272
H: 220 456 456 208 448 448 448 208 204 204 448 456 216 456 456 208 456 208 212 452 208 452 216 204 216 212 456 212 444 208 200 448 204 444 452 204 208 212 208 456
Start Bit L: 750 H: 692
Data Bits: 40
L: 516 268 280 524 284 288 272 516 520 520 268 268 512 264 276 516 272 512 516 276 516 288 520 524 520 520 284 516 272 516 512 276 512 276 268 512 516 516 516 268
H: 216 456 456 200 448 440 448 216 204 212 456 456 220 460 460 208 456 212 212 456 208 452 196 204 212 204 448 208 452 212 216 456 212 456 456 212 220 208 216 456
Start Bit L: 750 H: 708
Data Bits: 40
L: 512 268 264 512 264 272 264 512 516 516 276 268 516 268 268 512 272 520 524 276 520 272 520 524 516 512 264 508 268 516 516 268 508 268 276 512 516 512 520 280
H: 220 456 460 220 460 460 460 224 208 208 456 456 216 456 456 220 456 212 204 444 212 452 212 208 208 212 460 224 460 216 208 456 224 456 456 212 220 212 204 456
Test data for the wireless Temperature/Humidity outdoor sensor
Bresser Thermo-/Hygro-Sensor 3CH
Art. Nr.: 7009994
EAN: 4007922031194
http://www.bresser.de/Wetter/BRESSER-Thermo-Hygro-Sensor-3CH-passend-fuer-BRESSER-Thermo-Hygrometer.html
Bresser also has two other Thermo-/Hygro-Sensors types most likely using different protocols:
- Bresser Thermo-/Hygro-Sensor 5CH (7009993)
- Bresser Thermo-/Hygro-Sensor 3CH (7009994)
- Bresser Thermo-/Hygro-Sensor 3CH for Temeo (7009995)
The sensor sends 15 identical packages of 40 bits each ~60s.
The bits are PWM modulated with On Off Keying.
Transmissions also include channel code, sync id, batt-low, and test/sync.
+----+  +----+  +--+    +--+      high
-+    +--+    +--+  +----+  +----  low
^       ^       ^       ^       ^  clock cycle
|   1   |   1   |   0   |   0   |  translates as
Each transmission is 40 bits long (i.e. 29 ms, 36 incl. preamble)
Data is transmitted in pure binary values, NOT BCD-coded.
Temperature is given in Centi-Fahrenheit and offset by 900.
Burst length is ~36ms (41 pulses + 8 syncs) * 750us.
CH1 has a period of 57 s
CH2 has a period of 67 s
CH3 has a period of 79 s
A short pulse of 250 us followed by a 500 us gap is a 0 bit,
a long pulse of 500 us followed by a 250 us gap is a 1 bit,
there is a sync preamble of pulse, gap, 750 us each, repeated 4 times.
Actual received and demodulated timings might be 2% shorter.
The data is grouped in 5 bytes / 10 nibbles
1111 1100 | 0001 0110 | 0001 0000 | 0011 0111 | 0101 1001 0  65.1 F 55 %
iiii iiii | bscc tttt | tttt tttt | hhhh hhhh | xxxx xxxx
- i: 8 bit random id (changes on power-loss)
- b: battery indicator (0=>OK, 1=>LOW)
- s: Test/Sync (0=>Normal, 1=>Test-Button pressed / Sync)
- c: Channel (MSB-first, valid channels are 1-3)
- t: Temperature (MSB-first, Big-endian)
     12 bit unsigned fahrenheit offset by 90 and scaled by 10
- h: Humidity (MSB-first) 8 bit relative humidity percentage
- x: checksum (byte1 + byte2 + byte3 + byte4) % 256
     Check with e.g. (byte1 + byte2 + byte3 + byte4 - byte5) % 256) = 0
bekommt man die Sensoren noch in den FHEMDuino mir rein ?
Grafkox
ich hoffe ich finde hier Hilfe, nachdem ich bereits das gesamte Forum und auch das Internet erfolglos durchforstet habe.
Ich habe mir aus den nachfolgenden Komponenten einen FHEMduino zusammengebaut:
RXB6-433-Mhz-Superheterodyne-Funkempfänger
http://www.ebay.de/itm/172297596527?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
2x 433 Mhz Antenne für Sender & Empfänger Raspberry Pi Arduino Helical
http://www.ebay.de/itm/252531538038?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
ATmega328P Arduino Compatible Nano V3
https://www.amazon.de/gp/product/B00Q6WTWGO/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Da ich dachte der Empfänger ist defekt, habe ich nochmals einen zweiten nachbestellt:
http://www.ebay.de/itm/381199588108?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Der Sender arbeitet ohne Probleme, allerdings ist der Empfang unterirdisch. Ich empfange gerade mal die Somfy RTS Wand- und Handsender über eine Reichweite von 0,5m.
Ich habe auch normalen Draht  versucht (wie auch die 433MHz Antenne angelötet) und von 17cm Milimeterweise auf 16cm gekürzt, aber es zeigte sich keine Besserung.
Da hier nun viele von diesen Empfängern schreiben, dass sie über mehrere Etagen und Stahldecken gehen, erhoffe ich mir eine Antwort auf mein Problem.
Es wäre super, wenn mir jemand einen helfenden Tipp geben könnte.
Vielen lieben Dank und viele Grüße
Thorsten
Raspberry Pi 3 mit Fhem 5.9, Tablet UI 2.6, SIGNALduino, Somfy RTS, Fritzbox 7490, IT-Steckdosen, Hikvision Kameras, Xiaomi Sensoren, Tecalor THZ, E3/DC
Ralf9
Ich verwende den RXB6-433-Mhz-Superheterodyne-Funkempfänger mit einer ca 17 cm Drahtantenne am Signalduino.
Ich empfange damit auch Temperatursensoren durch mindestens eine Decke oder Wand.
Gruß Ralf
Grafkox
Kleines Update:
Weiterhin verzweifelt!
Ich habe mir nun eine externe Antenne https://www.amazon.de/gp/product/B00JG4XNBY/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 geholt und angelötet, aber die Reichweite hat sich nur geringfügig (0,5m) verbessert.
Gibt es ggf. softwareseitig noch Punkte, an denen man ein wenig feintunen könnte?
Ich habe auch mal einen Somfy RTS-Wandsender genommen und bin in den Keller gegangen, von hier lassen sich immer noch die Rolläden schalten offensichtlich kann es also anscheinend nicht an einer schlechten Sendeleistung der Wandsender liegen.
Wäre echt für jeden Tipp dankbar.
noice
Nur so ne frage ... wieviel volt bringt dein arduino? 3,3 oder 5 ?
Mobil erstellt daher kurz gehalten
BananaPI, RaspberryPi+AddonBoard,HMLAN,  miniCUL 433,nanoCUL 433,nanoCUL868,FHEMduino 433, Jeelink clone diverse Homematic, FS20, MAX, TFA und IT Komponenten.
10" Tablet mit andFhem, Daitem D14000
Grafkox
5V sind angegeben, 4,79V habe ich gerade gemessen
noice
Okay sollte langen ... dann weiss ich auch nicht weiter
Kawaci
hallo
ich will meine somfy Markise mit fhemduino auslesen aber irgendwas funktioniert nicht aber ich weis nicht was nicht funktioniert! hab in den Attributen keine Auswahl an rfmodulen usw! hie mal ein list von meinem fhemduino
[Internals:
   CMDS       VifdhtRq
   Clients    :IT:CUL_TX:OREGON:FHEMduino_Env:FHEMduino_EZ6:FHEMduino_Oregon:FHEMduino_PT2262:FHEMduino_FA20RF:FHEMduino_TCM:FHEMduino_HX:FHEMduino_DCF77:FHEMduino_Gas:FHEMduino_SomfyR:
   DEF        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A700CVK6-if00-port0@9600
   DeviceName /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A700CVK6-if00-port0@9600
   FD         28
   NAME       fhemduino
   NR         49
   PARTIAL
   STATE      Initialized
   TYPE       FHEMduino
   VERSION    V 2.3v FHEMduino - compiled at Nov  4 216 9:46:14
   Matchlist:
     10:FHEMduino_DCF77 D...............$
     11:OREGON  ^(3[8-9A-F]|[4-6][0-9A-F]|7[0-8]).*
     12:FHEMduino_Gas G...........$
     13:FHEMduino_SomfyR Ys .. .. .... ......$
     1:IT       ^i......$
     2:CUL_TX   ^TX..........
     3:FHEMduino_Env W.*$
     4:FHEMduino_EZ6 E...........$
     5:FHEMduino_Oregon OSV2:.*$
     6:FHEMduino_PT2262 IR.*$
     7:FHEMduino_FA20RF F............$
     8:FHEMduino_TCM M.....$
     9:FHEMduino_HX H...$
   Readings:
     2016-11-01 00:18:27   FAParms         FAParams:  10
     2016-11-01 00:18:35   HXParms         No answer
     2016-11-01 00:19:05   ITParms         ITParams: 6 6 35
     2016-11-01 00:19:16   TCParms         No answer
     2016-11-04 10:14:32   cmds             V i f d h t R q
     2016-10-29 21:36:27   raw             No answer
     2016-11-04 10:14:29   state           opened
     2016-11-04 09:48:17   uptime          0 00:00:22
     2016-11-04 00:50:41   version         V 2.3v FHEMduino - compiled at Oct 27 2016 08:24:50
   flashCommand avrdude -c arduino -b 57600 -P [PORT] -p atmega328p -vv -U flash:w:[HEXFILE] 2>[LOGFILE]
   room       Gateways
   verbose    5
vielleicht kann mir wer helfen!
viegener
Zitat von: Kawaci am 04 November 2016, 10:19:43
hallo
[Internals:
   CMDS       VifdhtRq
   FD         28
   NAME       fhemduino
   NR         49
   PARTIAL
   STATE      Initialized
   TYPE       FHEMduino
   Matchlist:
     1:IT       ^i......$
   Readings:
   room       Gateways
   verbose    5
Generell sieht der FHEMDuino in Ordnung aus, ich bin mir nicht klar, welche Auswahl an RFModulen du vermisst?
Der FHEMDuino unterstützt grundsätzlich mehrere Protokolle und über autocreate werden die Devices normalerweise automatisch angelegt. Ansonsten müsste man für Somfy den Device manuell anlegen, dazu müsste man die Adresse aus dem log herauslesen. Vielleicht postest Du mal den fhem-log wenn Du eine Taste an der SOmfy-Fernbedienung drückst?
Ist autocreate aktiv?
Nur zur Sicherheit: FHEMDuino kann Signale von Fernbedienungen empfangen, aber keine Signale senden und auch keinen Empfänger "auslesen"
Kawaci
Ich bekomme nichts in ein logfile wenn ich auf die fb drücke! Hab alles so angeschlossen wie im fhemwiki beschrieben! Das einzige was ich gemacht habe ist das ich die Firmware auf nem mac über die arduino ide eingespielt habe! Müsste man im sketch etwas aktivieren oder so denn ich empfange nicht mal meine steckdosen die ich über einem cul clone schalte!
viegener
#1679
Die Informationen bleiben etwas dürftig, wenn Du den aktuellen Stand aus github kompiliert hast, sollte SOMFY aktiv sein.
Du erklärst nicht was für Steckdosen Du zusätzlich empfangen willst, welche Frequenz/Protokoll werden die vom FHEMDuino unterstützt? Es gibt hier im Thread einiges an Information wie man Debugging einschalten kann aber...
Wenn gar nichts empfangen wird, vermute ich kein Problem auf FHEM-Seite sondern eher in der Hardware.
Welchen Empfänger / Sender hast Du verwendet?
Johannes
