nach update 1.1.2014 Fehler im Log
Begonnen von LuckyDay, 01 Januar 2014, 16:23:06
LuckyDay
Event monitor
Use of uninitialized value $dev in hash element at fhem.pl line 2539.
2014.01.01 16:18:08.547 1: readingsUpdate(,Activity,unknown) missed to call readingsBeginUpdate first.
Use of uninitialized value $name in concatenation (.) or string at fhem.pl line 3446.
Use of uninitialized value $m in int at ./FHEM/10_CUL_HM.pm line 4937.
2014.01.01 16:18:07.029 1: HMLAN_Parse: hmlan2 new condition ok
2014.01.01 16:18:06.752 1: HMLAN_Parse: hmlan1 new condition ok
2014.01.01 16:18:06.389 0: Server started with 188 defined entities (version $Id: fhem.pl 4501 2013-12-29 17:59:52Z rudolfkoenig $, os linux, user fhem, pid 8063)
franky08
#1
Hallo, und hier auch etliche Fehler im Log:
Use of uninitialized value $a[1] in substitution (s///) at ./FHEM/98_SVG.pm line 938.
Use of uninitialized value in join or string at ./FHEM/98_SVG.pm line 938.
2014.01.01 14:36:39 2: CUL_HM set Herdlicht statusRequest
2014.01.01 14:36:40 2: CUL_HM set Ladegeraet statusRequest
2014.01.01 14:36:41 2: CUL_HM set Licht_Wohnungstuer statusRequest
2014.01.01 14:36:42 2: CUL_HM set Radio statusRequest
2014.01.01 14:36:44 2: CUL_HM set Schalter_SZ statusRequest
2014.01.01 14:36:46 2: CUL_HM set Stehlampe statusRequest
2014.01.01 14:36:47 2: CUL_HM set 16_LED_8 led green
2014.01.01 14:36:47 2: CUL_HM set 16_LED_1 led red
2014.01.01 14:36:48 2: CUL_HM set 16_LED_7 led red
2014.01.01 14:36:49 2: CUL_HM set 16_LED_2 led red
2014.01.01 14:36:49 2: CUL_HM set 16_LED_12 led red
2014.01.01 14:36:50 2: CUL_HM set 16_LED_3 led green
2014.01.01 14:36:51 2: CUL_HM set 16_LED_9 led red
2014.01.01 14:36:52 2: CUL_HM set 16_LED_10 led red
2014.01.01 14:36:52 2: CUL_HM set 16_LED_4 led red
2014.01.01 14:36:55 2: CUL_HM set 16_LED_5 led green
2014.01.01 14:37:14 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 14:37:54 2: CUL_HM set Herdlicht off
2014.01.01 14:37:54 2: CUL_HM set 16_LED_2 led red
Argument "\x{4e}\x{6f}..." isn't numeric in localtime at fhem.pl line 2392.
Argument "\x{4e}\x{6f}..." isn't numeric in localtime at ./FHEM/70_ENIGMA2.pm line 743.
2014.01.01 14:39:36 2: CUL_HM set 16_LED_11 led red
2014.01.01 14:39:40 2: CUL_HM set 16_LED_11 led green
2014.01.01 14:41:16 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 14:46:58 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 14:52:10 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 14:56:54 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:01:09 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:06:20 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:07:02 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:07:03 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:07:17 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:11:31 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:17:08 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:22:17 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:26:24 2: CUL_HM set Aquarium off
2014.01.01 15:26:24 2: CUL_HM set 16_LED_8 led red
2014.01.01 15:26:57 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:31:08 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:36:59 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:42:20 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:47:13 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:50:39 2: CUL_HM set 16_LED_11 led red
2014.01.01 15:50:43 2: CUL_HM set 16_LED_11 led green
2014.01.01 15:51:37 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:52:28 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:52:43 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 15:57:11 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 16:01:18 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 16:02:01 2: CUL_HM set Flurlicht on
2014.01.01 16:02:01 2: CUL_HM set Stehlampe on
2014.01.01 16:02:01 2: CUL_HM set 16_LED_7 led green
2014.01.01 16:02:01 2: CUL_HM set 16_LED_4 led green
2014.01.01 16:07:05 2: CUL_HM set 16_LED ilum 1 0
2014.01.01 16:07:42 2: ENIGMA2 set Dreambox statusRequest
2014.01.01 16:10:36 2: CUL_HM set ActionDetector getConfig
2014.01.01 16:12:20 3: Device TH_Sensor_WZ added to ActionDetector with 000:10 time
2014.01.01 16:12:23 2: CUL_HM set 16_LED ilum 0 0
2014.01.01 16:12:27 2: CUL_HM set 16_LED getConfig
2014.01.01 16:17:12 2: CUL_HM set 16_LED ilum 0 0
2014.01.01 16:21:32 2: CUL_HM set 16_LED ilum 0 0
VG
Frank
P.S. Nach einem shutdown -r vom Beaglebone sind die Fehler im Log weg!
mit FHEM aktuell
martinp876
#3
@Harry,
wie stehen die actCycle in deinem system?
set hm param -d actCycle
Martin
sollte erledigt sein - morgen im update
LuckyDay
param done:
param list
    entity                 : actCycle                |
    EG_KU                  : 028:00
    EG_SZ                  : 028:00
    EG_WZ                  : 028:00
    HZsw                   : 7200:00
    Sz_og_vd               : 028:00
    Tor_re                 : 025:00
    eg_Halle_Hz1           : 000:10
    og_Schlafzimmer        : 000:10
    og_Wohnzimmer          : 000:10
    wz_Balkon              : 025:00
