Wifilight.pm
Begonnen von herrmannj, 18 Januar 2014, 04:10:07
herrmannj
yepp. Hab mich gequält und das help geschrieben ....
vbs
Ahh, jetzt hab ich verstanden, was du meintest! Dann Danke dafür und natürlich auch Danke für das Modul!
betonmoewe
ich habe grad ein update für das wifilight modul durchgeführt.
Dabei gab es folgende Meldungen:
UPD FHEM/32_WifiLight.pm
New entries in the CHANGED file:
HSV2fourChannel bug fixed, thnx to lexorius
LW12FC added (another LW12 clone)
LD382A added (LD382 version with fw 1.0.6)
fix ramp 0 with deault ramp settings
SengLED White added
milight white, improved reliability
milight rgbw2 dim bug
Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
EN FHEM/95_Alarm.pm: Unbalanced tr (-1, last line ok: 856)
EN FHEM/57_Calendar.pm: Unbalanced table (-3, last line ok: 1259)
EN FHEM/00_MAXLAN.pm: Unbalanced tr (1, last line ok: 868)
EN FHEM/00_MAXLAN.pm: Unbalanced td (1, last line ok: 868)
EN FHEM/40_RFXCOM.pm: Unbalanced tr (1, last line ok: 381)
EN FHEM/40_RFXCOM.pm: Unbalanced td (1, last line ok: 381)
EN FHEM/51_RPI_GPIO.pm: Unbalanced table (-4, last line ok: 705)
EN FHEM/45_TRX.pm: Unbalanced tr (1, last line ok: 411)
EN FHEM/45_TRX.pm: Unbalanced td (1, last line ok: 411)
EN WifiLight: nonempty line after =begin html ignored
EN FHEM/32_WifiLight.pm: No a-tag with name="WifiLight"
*** EN FHEM/01_fronthem.pm: No document text found
*** EN FHEM/31_fronthemDevice.pm: No document text found
EN FHEM/95_remotecontrol.pm: Unbalanced td (-1, last line ok: 409)
DE FHEM/57_Calendar.pm: Unbalanced table (-3, last line ok: 1465)
DE FHEM/98_HMinfo.pm: Unbalanced tr (1, last line ok: 2888)
DE FHEM/98_HMinfo.pm: Unbalanced td (1, last line ok: 2888)
DE FHEM/51_RPI_GPIO.pm: Unbalanced table (-4, last line ok: 898)
DE WifiLight: nonempty line after =begin html ignored
DE FHEM/95_remotecontrol.pm: Unbalanced td (-1, last line ok: 495)
update finished, "shutdown restart" is needed to activate the changes.
sind diese Meldungen normal und kann ich dies ignorieren oder ist irgendetwas falsch gelaufen ????
Gruß und schon mal Danke
Die etwas verunsicherte Betonmöwe
herrmannj
das war die git hub version oder ?
Ich habe wifilight inzwischen in das reguläre fhem update aufgenommen.
vg
joerg
betonmoewe
wie kann ich denn die GitHub Version losbekommen und auf die fhem version switchen ????
Die Betonmöwe
vbs
Probier mal die git-Quelle einfach zu entfernen mit "update delete <source>" und danach ein normales update zu machen.
betonmoewe
ok zu spät ...
ich habe mir die fhem config gesichert, danach fhem deinstalliert, das Verzeichnis gelöscht, dann fhem wieder installiert und dann noch ein update durchgeführt. Scheint bisher alles ok zu sein ...
Die Betonmöwe
vbs
So kann mans natürlich auch machen :)
Mr_Tembo
#1718
hat jemand bereits versucht das Wifi-104 System in fhem einzubinden? Die Milight-Bridge funktioniert nicht mit diesem System.
Controller: WIFI-104 Multizonen LED WiFI Controller 4-Kanal inkl. RF Fernbedienung
(http://www.everen.de/wifi-104_multizonen_led_wifi_controller_4-kanal_inkl_rf_fernbedienung_c487_367_p4989.html)
Empfänger: R4-CC Empfänger 350/750/1050mA x4 für WIFI-104 System
Danke Mr Tembo
herrmannj
Hast Du das schon ?
vg
joerg
herrmannj
herrmannj
#1721
a, ok.
es gibt eine geringe Chance den als sunricher einzubinden. Gering!.  Mehr nicht.
Die sunricher Unterstützung ist insgesamt auch beta
vg
joerg
ergänze: sehr! gering
Mr_Tembo
Hallo Jörg,
Danke für die Info. Frau hätte gern zusätzlich das DX8. Dies funktioniert leider nur mit Wifi-104.
Grüße Mr Tembo
herrmannj
was soll ich sagen. Außer viele Grüße :)
Probier es aus. Die Chance besteht.
ZitatGering!.  Mehr nicht.
Lesestoff:
http://forum.fhem.de/index.php/topic,34254.0.html
vg
joerg
Mr_Tembo
Hallo Jörg
ich glaube das geht. Sieht ziemlich baugleich aus. 3 Markennamen aber visuell fast identisch. Versuch ist es wert.
Grüße Mr_Tembo
