Autor Thema: enocean pi  (Gelesen 2593 mal)
Offline hansgans
  • New Member
enocean pi
« am: 15 Februar 2014, 21:28:07 »
2014.02.15 21:20:43 3: HMLAN1 device opened
2014.02.15 21:20:43 1: HMLAN_Parse: HMLAN1 new condition init
2014.02.15 21:20:47 1: Including ./log/fhem.save
2014.02.15 21:20:50 1: usb create starting
2014.02.15 21:20:51 4: ### ttyAMA0: checking if it is a CUL
2014.02.15 21:20:51 3: Probing CUL device /dev/ttyAMA0
2014.02.15 21:20:52 4: got wrong answer for a CUL
2014.02.15 21:20:52 4: ### ttyAMA0: checking if it is a TCM310
2014.02.15 21:20:52 3: Probing TCM310 device /dev/ttyAMA0
2014.02.15 21:20:52 4: create as a fhem device with: define TCM310_0 TCM 310 /dev/ttyAMA0@57600
2014.02.15 21:20:52 1: define TCM310_0 TCM 310 /dev/ttyAMA0@57600
2014.02.15 21:20:52 3: Opening TCM310_0 device /dev/ttyAMA0
2014.02.15 21:20:52 3: Setting TCM310_0 baudrate to 57600
2014.02.15 21:20:52 3: TCM310_0 device opened
2014.02.15 21:20:52 2: TCM TCM310_0 BaseID=FFA15F80,RemainingWriteCycles=0A
2014.02.15 21:20:52 1: usb create end
und kurz drauf gehts rund bei homematic
2014.02.15 21:21:56 4: eventTypes: CUL_HM st_Kueche_airplay IOerr -> IOerr
2014.02.15 21:21:56 4: eventTypes: CUL_HM st_kaffee IOerr -> IOerr
2014.02.15 21:21:56 4: eventTypes: CUL_HM st_kueche_licht IOerr -> IOerr
2014.02.15 21:21:56 4: eventTypes: CUL_HM st_kueche_licht_r IOerr -> IOerr
2014.02.15 21:21:56 4: eventTypes: CUL_HM st_schlaf IOerr -> IOerr
2014.02.15 21:21:56 4: eventTypes: CUL_HM st_tv_pc IOerr -> IOerr
2014.02.15 21:21:56 4: eventTypes: CUL_HM sw_bad IOerr -> IOerr
2014.02.15 21:21:56 4: eventTypes: CUL_HM sw_flur_anfang IOerr -> IOerr
2014.02.15 21:21:57 4: eventTypes: CUL_HM sw_flur_mitte IOerr -> IOerr
2014.02.15 21:21:57 4: eventTypes: CUL_HM sw_kueche IOerr -> IOerr
2014.02.15 21:21:57 4: eventTypes: CUL_HM sw_schlafen IOerr -> IOerr
2014.02.15 21:21:57 4: eventTypes: CUL_HM sw_spuel IOerr -> IOerr
2014.02.15 21:21:57 4: eventTypes: CUL_HM sw_wasch IOerr -> IOerr
2014.02.15 21:21:57 4: eventTypes: CUL_HM bw_mitte brightness: 33 -> brightness: .*
2014.02.15 21:21:57 4: eventTypes: CUL_HM bw_mitte cover: closed -> cover: closed
2014.02.15 21:21:57 4: eventTypes: CUL_HM bw_mitte battery: ok -> battery: ok
FS20 geräte funktionieren weiter ohne probleme
Homematic streikt vollkommen
was kann man da machen ?
Offline hansgans
  • New Member
Antw:enocean pi
« Antwort #1 am: 15 Februar 2014, 21:39:55 »
nach nem update force gehts jetzt so wie alles aussieht :) kann also geschlossen werden
djhans
  • Gast
Antw:enocean pi
« Antwort #2 am: 24 Februar 2014, 13:05:57 »
habe heute das enocean Pi-Modul bekommen und es auf den PI gesteckt. Leider passt das raspberry Gehäuse nicht mehr, aber dann muss ich den Deckle halt runterlassen. Wenn ich den draufquetsche, dann hängt das Pi Modul schief drin und das könnte auf Dauer ungesund sein.....
Aber nun zu meiner Frage:
Ich habe das Pi Modul gemäß WhitePaper eingerichtet und die Ausgabe der seriellen Console deaktiviert. Danach unter fhem folgenden Befehl ausgeführt:
define TCM310_0 TCM 310 /dev/ttyAMA0@57600Im Logfile steht nun:
2014.02.24 12:55:43 3: Opening TCM310_0 device /dev/ttyAMA0
2014.02.24 12:55:43 3: Setting TCM310_0 baudrate to 57600
2014.02.24 12:55:43 3: TCM310_0 device opened
2014.02.24 12:55:43 2: TCM TCM310_0 BaseID=FF94C080,RemainingWriteCycles=0A
War es das schon? Wie kann ich überprüfen, ob das Modul richtig eingebunden wurde? Ich habe noch keine enocean Komponenten zur Hand.
Was mich halt wundert ist, dass der Connection Test laut Whitepaper nichts liefert.
hexdump </dev/ttyAMA0Danke und Gruß,
Christian
« Letzte Änderung: 24 Februar 2014, 13:07:47 von djhans »
Offline klaus.schauer
Antw:enocean pi
« Antwort #3 am: 24 Februar 2014, 13:44:17 »
Das sieht gut aus, da die BaseID richtig ausgelesen wird.
djhans
  • Gast
Antw:enocean pi
« Antwort #4 am: 24 Februar 2014, 14:08:01 »
danke Klaus! Jetzt wird es Zeit, dass meine enocean-Devices kommen, damit ich endlich ein wenig rumspielen kann. Leider ist meine Anfrage bein Händler verschütt gegangen, sodaß ich das heute alles noch einmal aufgleisen musste...:-(
Christian
decade-submarginal
