logFiles
Begonnen von LotharRappsilber, 16 Februar 2014, 12:08:56
LotharRappsilber
hallo,
es werden keine LogFiles geschrieben, obwohl es in der fhem.cfg drin steht:
attr global logfile ./log/fhem-%Y-%m.log
attr global modpath .
attr global motd SecurityCheck:\
WEB,WEBphone,WEBtablet has no basicAuth attribute.\
telnetPort has no password/globalpassword attribute.\
Running with root privileges.\
Restart fhem for a new check if the problem is fixed,\
or set the global attribute motd to none to supress this message.\
attr global statefile ./log/fhem.save
attr global updateInBackground 1
attr global userattr devStateIcon devStateStyle fp_Haus icon sortby webCmd
attr global verbose 3
define telnetPort telnet 7072 global
attr WEB hiddenroom CUL_HM,CUL_WS,KS300
attr WEB stylesheetPrefix dark
define WEBphone FHEMWEB 8084 global
attr WEBphone stylesheetPrefix smallscreen
attr WEBtablet stylesheetPrefix touchpad
# Fake FileLog entry, to access the fhem log from FHEMWEB
define Logfile FileLog ./log/fhem-%Y-%m.log fakelog
define autocreate autocreate
attr autocreate autosave 1
attr autocreate device_room %TYPE
attr autocreate filelog ./log/%NAME-%Y.log
attr autocreate weblink 1
attr autocreate weblink_room Plots
define initialUsbCheck notify global:INITIALIZED usb create
# If the above notify did not helped, then you probably have to enable some of
# the following lines.  Verify first that /dev/xxx ist correct.
#define FHZ FHZ /dev/USB0
#define CUL CUL /dev/ttyACM0@9600 1234
#attr CUL rfmode HomeMatic
#define EUL TCM 310 /dev/ttyACM0@57600
#define BscBor TCM 120 /dev/ttyUSB0@9600
#define BscSmartConnect TCM 310 /dev/ttyUSB0@57600
define fbaha FBAHA localhost:2002
define eventTypes eventTypes ./log/eventTypes.txt
define CUL_0 CUL /dev/ttyACM0@9600 1034
attr CUL_0 rfmode HomeMatic
define Poolwasser CUL_WS 4
attr Poolwasser fp_Haus 580,1055,2,
attr Poolwasser room Poolwasser
define FileLog_Poolwasser FileLog ./log/Poolwasser-%Y.log Poolwasser:T:.*
attr FileLog_Poolwasser logtype temp4hum6:Temp/Hum,text
attr FileLog_Poolwasser room CUL_WS
define SVG_Poolwasser SVG FileLog_Poolwasser:temp4hum6:CURRENT
attr SVG_Poolwasser label "Poolwasser Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_Poolwasser room Plots
define Warmwasser CUL_WS 7
attr Warmwasser fp_Haus 250,1100,2,
attr Warmwasser room Wirtschaftsraum
define FileLog_Warmwasser FileLog ./log/Warmwasser-%Y.log Warmwasser:T:.*
attr FileLog_Warmwasser logtype temp4hum6:Temp/Hum,text
attr FileLog_Warmwasser room CUL_WS
define SVG_Warmwasser SVG FileLog_Warmwasser:temp4hum6:CURRENT
attr SVG_Warmwasser label "Warmwasser Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_Warmwasser room Plots
define Heizung CUL_WS 6
attr Heizung fp_Haus 333,1050,2,
attr Heizung room Wirtschaftsraum
define FileLog_Heizung FileLog ./log/Heizung-%Y.log Heizung:T:.*
attr FileLog_Heizung logtype temp4hum6:Temp/Hum,text
attr FileLog_Heizung room CUL_WS
define SVG_Heizung SVG FileLog_Heizung:temp4hum6:CURRENT
attr SVG_Heizung label "Heizung Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_Heizung room Plots
define Poolraum CUL_WS 3
attr Poolraum fp_Haus 460,1000,2,
attr Poolraum room Poolraum
define FileLog_Poolraum FileLog ./log/Poolraum-%Y.log Poolraum:T:.*
attr FileLog_Poolraum logtype temp4hum6:Temp/Hum,text
attr FileLog_Poolraum room CUL_WS
define SVG_Poolraum SVG FileLog_Poolraum:temp4hum6:CURRENT
attr SVG_Poolraum label "Poolraum Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_Poolraum room Plots
define Kombisensor KS300 1234
attr Kombisensor fp_Haus 140,355,2,
attr Kombisensor room Aussentemperatur
define FileLog_Kombisensor FileLog ./log/Kombisensor-%Y.log Kombisensor:T:.*
attr FileLog_Kombisensor logtype temp4rain10:Temp/Rain,hum6wind8:Wind/Hum,text
attr FileLog_Kombisensor room KS300
define SVG_Kombisensor SVG FileLog_Kombisensor:temp4rain10:CURRENT
attr SVG_Kombisensor label "Kombisensor Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_Kombisensor room Plots
define SVG_KS300_2 SVG FileLog_KS300:hum6wind8:CURRENT
attr SVG_KS300_2 label "KS300 Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_KS300_2 room Plots
define Waermepumpen CUL_WS 2
attr Waermepumpen fp_Haus 360,1150,2,
attr Waermepumpen room Wirtschaftsraum
define FileLog_Waermepumpen FileLog ./log/Waermepumpen-%Y.log Waermepumpen:T:.*
attr FileLog_Waermepumpen logtype temp4hum6:Temp/Hum,text
attr FileLog_Waermepumpen room CUL_WS
define SVG_Waermepumpen SVG FileLog_Waermepumpen:temp4hum6:CURRENT
attr SVG_Waermepumpen label "Waermepumpen Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_Waermepumpen room Plots
define Wohnzimmer CUL_WS 1
attr Wohnzimmer fp_Haus 300,700,2,
attr Wohnzimmer room Wohnzimmer
define FileLog_Wohnzimmer FileLog ./log/Wohnzimmer-%Y.log Wohnzimmer:T:.*
attr FileLog_Wohnzimmer logtype temp4hum6:Temp/Hum,text
attr FileLog_Wohnzimmer room CUL_WS
define SVG_Wohnzimmer SVG FileLog_Wohnzimmer:temp4hum6:CURRENT
attr SVG_Wohnzimmer label "Wohnzimmer Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_Wohnzimmer room Plots
define Schlafzimmer CUL_WS 8
attr Schlafzimmer fp_Haus 100,900,2,
attr Schlafzimmer room Schlafzimmer
define FileLog_Schlafzimmer FileLog ./log/Schlafzimmer-%Y.log Schlafzimmer:T:.*
attr FileLog_Schlafzimmer logtype temp4hum6:Temp/Hum,text
attr FileLog_Schlafzimmer room CUL_WS
define SVG_Schlafzimmer SVG FileLog_Schlafzimmer:temp4hum6:CURRENT
attr SVG_Schlafzimmer label "Schlafzimmer Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_Schlafzimmer room Plots
define CUL_HM_HM_CC_RT_DN_22A139 CUL_HM 22A139
attr CUL_HM_HM_CC_RT_DN_22A139 .devInfo 00FFFF
attr CUL_HM_HM_CC_RT_DN_22A139 .stc 59
attr CUL_HM_HM_CC_RT_DN_22A139 actCycle 000:10
attr CUL_HM_HM_CC_RT_DN_22A139 actStatus alive
attr CUL_HM_HM_CC_RT_DN_22A139 expert 2_full
attr CUL_HM_HM_CC_RT_DN_22A139 firmware 1.1
attr CUL_HM_HM_CC_RT_DN_22A139 model HM-CC-RT-DN
attr CUL_HM_HM_CC_RT_DN_22A139 peerIDs
attr CUL_HM_HM_CC_RT_DN_22A139 room CUL_HM
attr CUL_HM_HM_CC_RT_DN_22A139 serialNr KEQ0724332
attr CUL_HM_HM_CC_RT_DN_22A139 subType thermostat
define FileLog_CUL_HM_HM_CC_RT_DN_22A139 FileLog ./log/CUL_HM_HM_CC_RT_DN_22A139-%Y.log CUL_HM_HM_CC_RT_DN_22A139
attr FileLog_CUL_HM_HM_CC_RT_DN_22A139 logtype text
attr FileLog_CUL_HM_HM_CC_RT_DN_22A139 room CUL_HM
define CUL_HM_HM_CC_RT_DN_22A139_Weather CUL_HM 22A13901
attr CUL_HM_HM_CC_RT_DN_22A139_Weather expert 1
attr CUL_HM_HM_CC_RT_DN_22A139_Weather model HM-CC-RT-DN
attr CUL_HM_HM_CC_RT_DN_22A139_Weather peerIDs
attr CUL_HM_HM_CC_RT_DN_22A139_Weather room CUL_HM
define CUL_HM_HM_CC_RT_DN_22A139_Climate CUL_HM 22A13902
attr CUL_HM_HM_CC_RT_DN_22A139_Climate expert 1
attr CUL_HM_HM_CC_RT_DN_22A139_Climate model HM-CC-RT-DN
attr CUL_HM_HM_CC_RT_DN_22A139_Climate peerIDs
attr CUL_HM_HM_CC_RT_DN_22A139_Climate room Bad
define FileLog_CUL_HM_HM_CC_RT_DN_22A139_Climate FileLog ./log/CUL_HM_HM_CC_RT_DN_22A139_Climate-%Y.log CUL_HM_HM_CC_RT_DN_22A139_Climate
attr FileLog_CUL_HM_HM_CC_RT_DN_22A139_Climate logtype text
attr FileLog_CUL_HM_HM_CC_RT_DN_22A139_Climate room CUL_HM
define CUL_HM_HM_CC_RT_DN_22A139_WindowRec CUL_HM 22A13903
attr CUL_HM_HM_CC_RT_DN_22A139_WindowRec expert 1
attr CUL_HM_HM_CC_RT_DN_22A139_WindowRec model HM-CC-RT-DN
attr CUL_HM_HM_CC_RT_DN_22A139_WindowRec peerIDs
attr CUL_HM_HM_CC_RT_DN_22A139_WindowRec room CUL_HM
attr CUL_HM_HM_CC_RT_DN_22A139_WindowRec stateFormat last:trigLast
define FileLog_CUL_HM_HM_CC_RT_DN_22A139_WindowRec FileLog ./log/CUL_HM_HM_CC_RT_DN_22A139_WindowRec-%Y.log CUL_HM_HM_CC_RT_DN_22A139_WindowRec
attr FileLog_CUL_HM_HM_CC_RT_DN_22A139_WindowRec logtype text
attr FileLog_CUL_HM_HM_CC_RT_DN_22A139_WindowRec room CUL_HM
define Bad CUL_HM 22A13904
attr Bad expert 1
attr Bad fp_Haus 100,730,2,
attr Bad model HM-CC-RT-DN
attr Bad peerIDs
attr Bad room Bad
define FileLog_Bad FileLog ./log/Bad-%Y.log CUL_HM_HM_CC_RT_DN_22A139_Weather|Bad|bad:.*
attr FileLog_Bad logtype text
attr FileLog_Bad room CUL_HM
define CUL_HM_HM_CC_RT_DN_22A139_ClimaTeam CUL_HM 22A13905
attr CUL_HM_HM_CC_RT_DN_22A139_ClimaTeam expert 1
attr CUL_HM_HM_CC_RT_DN_22A139_ClimaTeam model HM-CC-RT-DN
attr CUL_HM_HM_CC_RT_DN_22A139_ClimaTeam peerIDs
attr CUL_HM_HM_CC_RT_DN_22A139_ClimaTeam room CUL_HM
define FileLog_CUL_HM_HM_CC_RT_DN_22A139_ClimaTeam FileLog ./log/CUL_HM_HM_CC_RT_DN_22A139_ClimaTeam-%Y.log CUL_HM_HM_CC_RT_DN_22A139_ClimaTeam
attr FileLog_CUL_HM_HM_CC_RT_DN_22A139_ClimaTeam logtype text
attr FileLog_CUL_HM_HM_CC_RT_DN_22A139_ClimaTeam room CUL_HM
define CUL_HM_HM_CC_RT_DN_22A139_remote CUL_HM 22A13906
attr CUL_HM_HM_CC_RT_DN_22A139_remote expert 1
attr CUL_HM_HM_CC_RT_DN_22A139_remote model HM-CC-RT-DN
attr CUL_HM_HM_CC_RT_DN_22A139_remote peerIDs
attr CUL_HM_HM_CC_RT_DN_22A139_remote room CUL_HM
define FileLog_CUL_HM_HM_CC_RT_DN_22A139_remote FileLog ./log/CUL_HM_HM_CC_RT_DN_22A139_remote-%Y.log CUL_HM_HM_CC_RT_DN_22A139_remote
attr FileLog_CUL_HM_HM_CC_RT_DN_22A139_remote logtype text
attr FileLog_CUL_HM_HM_CC_RT_DN_22A139_remote room CUL_HM
define ActionDetector CUL_HM 000000
attr ActionDetector actCycle 600
attr ActionDetector event-on-change-reading .*
attr ActionDetector room CUL_HM
define FileLog_ActionDetector FileLog ./log/ActionDetector-%Y.log ActionDetector
attr FileLog_ActionDetector logtype text
attr FileLog_ActionDetector room CUL_HM
define Haus FLOORPLAN
attr Haus commandfield 0
attr Haus fp_arrange 0
FB 7590, FHEM, 1xCCU2, 6xDECT200, 1xDECT201, 1xHMIP-SWO-PL, 1xHMIP-PS, 1xDECT301,  2xHM-LC-Sw1-PL
Puschel74
#1
Zitates werden keine LogFiles geschrieben, obwohl es in der fhem.cfg drin steht:
Kann sein.
Versuch mal das Raute-Symbol für Code und das "Sprechblasensymbol" für Zitate.
Vielleicht fällt dir dann auf das der Text etwas übersichtlicher wird  ;)
Guter Anlaufpunkt ist aber dennoch immer mal das FHEM-Logfile.
Edith: Was aber durchaus auch hilfreich sein kann - für dich und auch für uns: Verteile deine Fragen zu EINEM Problem nicht auf mehrere Beiträge sondern konzentriere dich auf einen Beitrag.
Entscheide dich wo du dein LogFile-Problem weiter verfolgen möchtest und schliesse die anderen Beiträge bitte.
Einmal dieser Beitrag hier
und dann dieser http://forum.fhem.de/index.php/topic,20277.msg138265.html#msg138265
Edith2: Und noch was - wenn du schon Antworten bekommst wäre es auch nett wenn du auf diese Beiträge eingehst.
Die Hilfe hier ist freiwillig und wundere dich mal nicht wenn dir freiwillig niemand mehr helfen will.
Rince
Jetzt mach es halt nicht so spannend Lothar, und poste mal das Logfile. Als Zitat wenn es geht.
Zitat von: Puschel74 am 16 Februar 2014, 14:40:32Die Hilfe hier ist freiwillig und wundere dich mal nicht wenn dir freiwillig niemand mehr helfen will.
... und gezwungen wird hier auch niemand :P
Puschel74
Zitat... und gezwungen wird hier auch niemand
Zu helfen oder zu fragen  8)
Puschel74
ich geh mal hinten nach zusammen fegen.
Grüsse
