Notify for Android
Begonnen von Lectere, 07 April 2014, 10:49:47
Lectere
Can someone help me with the translation of this;
http://forum.fhem.de/index.php/topic,10402.msg58773.html
I see the APK file is from begining of 2013, is there a newer version available?
I'm looking for a notification service for android. To send push notifications from FHEM if the doorbell is pressed etc.
SMSPassword redundant two-factor authentication for Netscaler, Vmware View, Cisco, Juniper, etc via SMS
http://www.smspassword.com
Matscher
Hi Lecture,
the latest version (30th may 2013) of andNotify can be found on google playstore (https://play.google.com/store/apps/details?id=de.homegroup.andnotify&hl=de). I think, the developer has stopped the further development of this app, because his last log is long ago. But it works fine for me. :)
Matscher
Rasp 3
CUL V3 868Mhz + nanoCUL 868Mhz als RFR + nanoCUL 868Mhz für Homematic + SIGNALduino
Zigbee CC2531 - Aquara TempSensor
MySensors Ethernet Gateway, Water meter, Gas meter
Modul: 09_CUL_FHTTK.pm (assumed), culfw part HAS_FHT_TF
mi.ke
Hi Lectere,
another nice way to realize this is called Pushover
There is a APP for Android/IOS (about 3€) and a fhem modul 70_Pushover.pm
You are able to adress diverend devices, send and receive emails, build groups and many more.
Works fine for me, it send notifications if the doorbell rings, the window is open more than 20 min etc.
cheers
mi.ke
FHEM 31310 | Mini PC N100, RPi4 + 5 x RPi(Z) + FB7590 + FB 6890 LTE via LAN / WAN (VPN).
2 x CUL868 + 3 x RFXTRX(e) + 6 x HMwLanGW + 5 x z2tGw + 5 x LGW + 2 x IRBlast + CO2 +++
FS20, FHT, FMS, Elro(mod), CM160, Revolt, LGTV, STV, AVR, withings, HM-*, MQTT2, ZigBee, AMAD, PCA301, arlo, Aqara,
