Aktion bei Bewegungserkennung durch HM-Sen-MDIR-O
Begonnen von raspklaus, 18 April 2014, 11:50:43
raspklaus
irgendwo habe ich einen Denkfehler in meiner Konfiguration. Ich habe einen HM-Sen-MDIR-O Aussensensor mit einem HM Lanadapter gepaired. Das sollte eigentlich funktionieren.
Hier ein List
   DEF        24F44A
   HMLAN1_MSGCNT 2
   HMLAN1_RAWMSG E24F44A,0000,E65DBAFF,FF,FFA9,5F841024F44A3531430601C500
   HMLAN1_RSSI -87
   HMLAN1_TIME 2014-04-18 10:53:28
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     2
   NAME       Bewegungsmelder
   NR         193
   STATE      motion
   TYPE       CUL_HM
   lastMsg    No:5F - t:10 s:24F44A d:353143 0601C500
   protLastRcv 2014-04-18 10:53:28
   protSnd    2 last_at:2014-04-18 10:50:27
   protState  CMDs_done
   rssi_at_HMLAN1 avg:-85.5 min:-87 max:-84 lst:-87 cnt:2
   Readings:
     2014-04-18 10:50:09   Activity        alive
     2014-04-08 16:36:38   CommandAccepted yes
     2014-04-08 16:36:38   D-firmware      1.6
     2014-04-08 16:36:38   D-serialNr      KEQ1070235
     2014-04-08 16:32:27   PairedTo        0x353143
     2014-04-08 16:29:06   R-brightFilter  7
     2014-04-08 16:29:06   R-captInInterval off
     2014-04-08 16:29:06   R-evtFltrNum    1
     2014-04-08 16:28:21   R-evtFltrPeriod 1 s
     2014-04-08 16:28:21   R-ledOnTime     0 s
     2014-04-08 16:29:06   R-minInterval   240
     2014-04-08 16:32:27   R-pairCentral   0x353143
     2014-04-08 16:32:27   RegL_00:        02:01 0A:35 0B:31 0C:43 00:00
     2014-04-08 16:32:27   RegL_01:        01:12 02:74 08:00 22:00 00:00
     2014-04-18 10:53:28   battery         ok
     2014-04-18 10:53:28   brightness      197
     2014-04-18 10:53:28   cover           closed
     2014-04-18 10:50:27   motion          on (to HMLAN1)
     2014-04-18 10:50:27   motionCount     152_next:8-240
     2014-04-18 10:53:28   recentStateType info
     2014-04-08 16:36:38   sabotageAttackId ErrIoId_353143 cnt:12
     2014-04-18 10:50:27   state           motion
   Helper:
     mId        005D
     rxType     28
     Io:
       newChn     +24F44A,00,01,1E
       nextSend   1397811208.25861
     Prt:
       bErr       0
       sProc      0
       sleeping   1
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rssi:
       At_hmlan1:
         avg        -85.5
         cnt        2
         lst        -87
         max        -84
         min        -87
   IODev      HMLAN1
   actCycle   000:10
   actStatus  alive
   alias      Hintere Kellertür
   autoReadReg 4_reqStatus
   expert     2_full
   firmware   1.6
   model      HM-Sen-MDIR-O
   peerIDs    00000000,
   room       Keller
   serialNr   KEQ1070235
   subType    motionDetector
Nun die Konfiguration:
define ActionDetector CUL_HM 000000
attr ActionDetector actCycle 600
attr ActionDetector event-on-change-reading .*
define Bewegungsmelder CUL_HM 24F44A
attr Bewegungsmelder IODev HMLAN1
attr Bewegungsmelder actCycle 000:10
attr Bewegungsmelder actStatus alive
attr Bewegungsmelder alias Hintere Kellertür
attr Bewegungsmelder autoReadReg 4_reqStatus
attr Bewegungsmelder expert 2_full
attr Bewegungsmelder firmware 1.6
attr Bewegungsmelder model HM-Sen-MDIR-O
attr Bewegungsmelder peerIDs 00000000,
attr Bewegungsmelder room Keller
attr Bewegungsmelder serialNr KEQ1070235
attr Bewegungsmelder subType motionDetector
# attr Bewegungsmelder event-on-change-reading motion
define FileLog_Bewegungsmelder FileLog ./log/Bewegungsmelder-%Y.log Bewegungsmelder
attr FileLog_Bewegungsmelder logtype text
attr FileLog_Bewegungsmelder room Keller
Die Definition der Steckdose die Schalten soll (über die FHEM Oberfläche schaltet sie):
# Brennenstuhl Funksteckdose
define Keller IT FFFFFFFF0F FF F0
attr Keller alias Fernseher Schlafzimmer
attr Keller loglevel 1
attr Keller model itswitch
attr Keller room Keller
attr Keller alias Türalarm Keller
und nun die Definition der Aktion (Bei Bewegungserkennung soll die Steckdose schalten:
define Bewegung notify Bewegungsmelder:motion set Keller on-for-timer 600
Aber sie tut es nicht. Kann mir jemand von Euch sagen warum nicht ?
Puschel74
schau in den EventMonitor, das Logfile und kontrollier das regexp.
raspklaus
Die Bewegung wird erkannt:
2014-04-18_11:57:38 Bewegungsmelder motion
2014-04-18_11:57:38 Bewegungsmelder motion: on (to HMLAN1)
2014-04-18_11:57:38 Bewegungsmelder motionCount: 153_next:8-240
2014-04-18_11:57:38 Bewegungsmelder brightness: 193
So steht es auch im Logfile
raspklaus
Im Logfile erscheint nun:
2014.04.18 10:50:27 3: Bewegung return value: Unknown argument on-for-timer, choose one of off on
2014.04.18 11:57:38 3: Bewegung return value: Unknown argument on-for-timer, choose one of off on
2014.04.18 12:19:56 3: Bewegung return value: Unknown argument on-for-timer, choose one of off on
2014.04.18 12:30:50 3: Bewegung return value: Unknown argument on-for-timer, choose one of off on
2014.04.18 12:49:05 3: Bewegung return value: Unknown argument on-for-timer, choose one of off on
raspklaus
Es liegt definitiv an:
Ein
funktioniert.
Invers
Deine Steckdose unterstützt vielleicht gar kein on-for-timer.
Puschel74
#6
ZitatDeine Steckdose unterstützt vielleicht gar kein on-for-timer.
Steht ja auch im Logfile so drinnen  ::)
Zitat2014.04.18 10:50:27 3: Bewegung return value: Unknown argument on-for-timer, choose one of off on
Edith: define Keller IT FFFFFFFF0F FF F0
Ohne jetzt den IT-Bereich durchgesucht zu haben behaupte ich mal das IT kein on-for-timer kann.
Ich meine das das auch dort so diskutiert wurde.
Paul
Das deine Steckdose kein on-for-timer kann weißt du ja jetzt.
Dann mach es so:
..... set Keller on;define aus at +00:10 set Keller off
Cubietruck, HM-USB, CUL, FS20, FHT, HUE, Keymatic
raspklaus
An geht sie jetzt, aber nach 10 Minuten aus funktioniert nicht
Paul
raspklaus
Der gesamte cde steht doch im ersten Beitrag. Felt da noch etwas ?
Puschel74
#11
die Frage war
ZitatWo gibst du das notify ein?
nicht
Zitatwas steht im notify.
Edith: Was steht im FHEM-Logfile?
Edith2:
ZitatDer gesamte cde steht doch im ersten Beitrag.
Dieser Code
steht im ersten Beitrag und dieser funktioniert doch nicht - hab ich glaube ich gelesen  :o
Paul
Wenn du es direkt in die cfg-Datei eingibst musst du 2 ;; setzen
Puschel74
ZitatWenn du es direkt in die cfg-Datei eingibst musst du 2 ;; setzen
Wovon ich aber abraten würde.
Also als Anfänger (und auch später) die fhem.cfg direkt zu bearbeiten meine ich  8)
raspklaus
Das notify steht in der FHEM.conf
define Bewegung notify Bewegungsmelder:motion set Keller on;define aus at +00:10 set Keller off
nach der Definition des Bewegungsmelders
also
Was fehlt da ?
