Empfang BBQ-Thermometer Maverick ET 732
Begonnen von unimatrix, 27 April 2014, 19:43:25
herrmannj
hat den gleichen.
fw vom rfx erneuert ?
vg
joerg
Mikerick
Ahoi,
module ersetzt, Firmware ist die neue, autocreate an.
2016.02.07 09:51:37 1: TRX_WEATHER: ERROR: Unknown sensor_id=4e message='0a4e011933240019001b69'
2016.02.07 09:51:49 1: TRX_WEATHER: ERROR: Unknown sensor_id=4e message='0a4e011a33240019001b69'
2016.02.07 09:52:01 1: TRX_WEATHER: ERROR: Unknown sensor_id=4e message='0a4e011b33240019001b69'
Reset receiver/transceiver
Get Status
Packettype        = Interface Message
subtype           = Interface Response
Sequence nbr      = 1
response on cmnd  = Get Status
Transceiver type  = 433.92MHz
Firmware version  = 251
Transmit power    = 10dBm
Hardware version  = 1.3
Undec             off
X10               disabled
ARC               disabled
AC                enabled
HomeEasy EU       disabled
Meiantech/Atlantic disabled
Oregon Scientific enabled
ATI               disabled
Visonic           disabled
Mertik            disabled
AD                disabled
Hideki            enabled
La Crosse         enabled
FS20/Legrand      disabled
ProGuard          disabled
BlindsT0          disabled
BlindsT1          disabled
AE                disabled
RUBiCSON/Lacrosse/Banggood disabled
FineOffset        disabled
Lighting4         enabled
RSL               disabled
Byron SX          disabled
Imagintronix      disabled
KeeLoq            disabled
Home Confort      disabled
RFU2              disabled
RFU3              disabled
RFU4              disabled
RFU5              disabled
RFU6              disabled
RFU7              disabled
Packettype    = BBQ
subtype       = BBQ1 - Maverick ET-732
Sequence nbr  = 0
ID            = 13092
Sensor1 temp  = 24 °C
Sensor2 temp  = 25 °C
Signal level  = 8  -56dBi
Battery       = OK
Packettype    = BBQ
Sequence nbr  = 1
ID            = 13092
Battery       = OK
Packettype    = TEMP
subtype       = TEMP2 - THC238/268,THN132,THWR288,THRN122,THN122,AW129/131
                channel 4
Sequence nbr  = 2
ID            = 29188
Temperature   = 12 °C
Signal level  = 6  -72dBi
Battery       = OK
Packettype    = BBQ
Sequence nbr  = 3
ID            = 13092
Sensor2 temp  = 28 °C
Battery       = OK
Packettype    = BBQ
Sequence nbr  = 4
ID            = 13092
Sensor1 temp  = 25 °C
Sensor2 temp  = 35 °C
Battery       = OK
Beste Grüße
Mik
OliS.
#137
Guten Morgen zusammen,
Ja, den hatte ich gestern ja schon mit der RFXtrx433E Ext 251 geflasht.
Im Anhang habe ich ein Logfile des TRX_UNKNOWN_4e, welcher mit den "alten" TRX-Modulen angelegt wird, angehängt. Falls Ihr da Messreihen mit korrespondierenden Temperaturen benötigt, bräuchte ich ein bisschen mehr Zeit.
Wie gesagt, mit den modifizierten TRX-Modulen, die Willi gestern angehängt hat, wird das Thermometer gar nicht erkannt. Einen Log-Auszug beim Starten der Module liefere ich noch nach habe ich ebenfalls angehängt.
Oli
PVE auf MiniPC (N100) mit FHEM, Zigbee2MQTT, Homebridge, DeConz
OliS.
Zitat von: Mikerick am 07 Februar 2016, 10:15:57...Firmware ist die neue...
Moin!
Welche FW hast Du denn geflasht? Die RFXtrx433 Type2 195 oder die RFXtrx433E Ext 251?
Oli
Mikerick
Die neue 251er...
Das mt den Messreihen kannste Dir m.E. sparen. Die Dekodierung der Protokolls ist eigentlich auch 'durch'. Ich blicke zwar nicht, ob das die RFXTRX-Firmware macht, oder die Coder-Helden das in den Modulen umsetzen.
Ein Bissel 'Sorge' macht mir nun die Verquickung von Willi und Jörg. Ich denke Jörg macht das 'Rundum-Sorglos' Paket für alle BBQ-Thermos und Willi will ( :-) ) es in den 'normalen' TRX-Modulen (speziell TRX_WEATHER) unterbringen. Aber die beiden regeln das bestimmt.
Beide haben ja auf Sourceforge svn-Access und posten fleissig Diffs und Patches. Immer wieder toll zu sehen, wie aktiv das Projekt ist.
Nur kein Stress aufkommen lassen :-) Als neuer User helfe ich gerne wo ich kann.
Helau
Mik
Willi
Ich habe hoffentlich den Bug gefunden (hatte 4f statt 4e genommen).
Bitte die nachfolgenden Module verwenden.
Danach am besten fhem neustarten oder ein reload aller Module.
Willi
FHEM@Q600(debian) mit DS9490R (1Wire) | FHEM@Sheevaplug(debian) mit RFXCOM-Receiver(80002), CULv3 & USB-WDE1 | FHEM@odroid mit CULv2 & RFXtrx433
OliS.
OliS.
Jetzt kommen wir der Sache schon näher....
Lediglich das Komma ist verschoben.
Oli
Mikerick
:-) Ja, aber ehrlich, ich meine das wirklich nicht
!!Echt kein Stress!! :-)
Bug 1 ist weg:-)
2016.02.07 10:55:45 3: TRX_WEATHER: Unknown device ET732_97, please define it
2016.02.07 10:55:45 2: autocreate: define ET732_97 TRX_WEATHER ET732_97
2016.02.07 10:55:45 2: autocreate: define FileLog_ET732_97 FileLog /usr/local/FHEM/var/log/ET732_97-%Y.log ET732_97
Jetzt noch eine Kommastelle :-)
Habe 23 auf beiden Sensoren, im Log steht 2.3 ... Bilder anbei.
Top!
Bis denne
Mik
OliS.
#144
Mir ist noch aufgefallen, dass das Maverick, wenn man es aus- und wieder einschaltet, mit einer neuen ID reinkommt. Das heißt, das zuvor angelegt Device empfängt keine Daten mehr und muss neu angelegt werden oder in der DEF angepasst werden.
Oli
knochenmuehle
#145
ich habe hier einen RFXtrx433 ohne E und die neuste 95er (Typ1) und anschließend die 195er (Typ2) Firmware geflasht. Die hier im Thread veröffentlichten Module habe ich auch im Einsatz.
Es wird aber nur TRX_UNKNOWN_4e  0a4e01b000000018001679 erkannt. Woran könnte das liegen ?
hier noch einige Zeilen aus dem Log:
2016-02-07_11:37:00 TRX_UNKNOWN_4e 0a4e013e00000018001679
2016-02-07_11:37:10 TRX_UNKNOWN_4e 0a4e013f00000018001679
2016-02-07_11:37:22 TRX_UNKNOWN_4e 0a4e014100000018001679
2016-02-07_12:23:36 TRX_UNKNOWN_4e 0a4e01a000000018001679
2016-02-07_12:23:48 TRX_UNKNOWN_4e 0a4e01a100000018001679
2016-02-07_12:24:00 TRX_UNKNOWN_4e 0a4e01a200000018001679
2016-02-07_12:24:12 TRX_UNKNOWN_4e 0a4e01a300000018001679
2016-02-07_12:24:24 TRX_UNKNOWN_4e 0a4e01a400000018001679
2016-02-07_12:24:36 TRX_UNKNOWN_4e 0a4e01a700000018001679
2016-02-07_12:24:48 TRX_UNKNOWN_4e 0a4e01a800000018001679
2016-02-07_12:25:00 TRX_UNKNOWN_4e 0a4e01a900000018001679
2016-02-07_12:25:12 TRX_UNKNOWN_4e 0a4e01aa00000018001679
2016-02-07_12:25:25 TRX_UNKNOWN_4e 0a4e01ab00000018001679
2016-02-07_12:25:36 TRX_UNKNOWN_4e 0a4e01ae00000018001679
2016-02-07_12:25:48 TRX_UNKNOWN_4e 0a4e01af00000018001679
2016-02-07_12:26:00 TRX_UNKNOWN_4e 0a4e01b000000018001679
2016-02-07_12:26:12 TRX_UNKNOWN_4e 0a4e01b100000018001679
2016-02-07_12:26:24 TRX_UNKNOWN_4e 0a4e01b200000018001679
2016-02-07_12:26:36 TRX_UNKNOWN_4e 0a4e01b500000018001679
2016-02-07_12:26:48 TRX_UNKNOWN_4e 0a4e01b600000018001679
2016-02-07_12:27:00 TRX_UNKNOWN_4e 0a4e01b700000018001679
2016-02-07_12:27:12 TRX_UNKNOWN_4e 0a4e01b800000018001679
2016-02-07_12:27:24 TRX_UNKNOWN_4e 0a4e01b900000018001679
2016-02-07_12:27:36 TRX_UNKNOWN_4e 0a4e01bc00000018001679
2016-02-07_12:27:48 TRX_UNKNOWN_4e 0a4e01bd00000018001679
2016-02-07_12:28:00 TRX_UNKNOWN_4e 0a4e01be00000018001679
2016-02-07_12:28:12 TRX_UNKNOWN_4e 0a4e01bf00000018001679
nicht erkannt wird ein 733er Maverick.
Gruß Andreas
Mikerick
das mit der ID kann ich bestätigen. Denke das hat etwas mit der neuen Firmware zu tun. Evtl. by design, da für jeden Grill-Job ein neues File angelegt werden soll.
Mit einem kleinen
attr ET732_133 userReadings ET732_133.temp-food { ReadingsVal("ET732_133","temp-food",0) * 10},ET732_133.temp-bbq { ReadingsVal("ET732_133","temp-bbq",0) * 10}
können die Werte 'verbessert werden'. Denke aber das ist nicht Sinn der Sache :-) Hab ich halt mal Userreadings gelernt, ansatzweise.
2016-02-07_12:55:15 ET732_133 TF: 2.2 TB: 3 BAT: ok
2016-02-07_12:55:15 ET732_133 ET732_133.temp-bbq: 30
2016-02-07_12:55:15 ET732_133 ET732_133.temp-food: 22
2016-02-07_12:55:27 ET732_133 temp-food: 2.2
2016-02-07_12:55:27 ET732_133 temp-bbq: 2.9
2016-02-07_12:55:27 ET732_133 battery: ok
2016-02-07_12:55:27 ET732_133 TF: 2.2 TB: 2.9 BAT: ok
2016-02-07_12:55:27 ET732_133 ET732_133.temp-bbq: 29
2016-02-07_12:55:27 ET732_133 ET732_133.temp-food: 22
Daraus könnten dann eine Plot erstellt werden, denke ich.
Beste Grüße
Mik
herrmannj
Korrekt, das ist die neue fw (richtiger weise) und das Maverick.
Das Maverick vergibt bei jedem anschalten einen neue ID. Bisher hat RFXCOM die ID nicht ausgegeben weil die nicht decodiert werden konnte. Das (und das 733) hat RFXCOM in der neuen FW gelöst.
Die ID ist wichtig. Sonst könnte man nicht arbeiten wenn zB der Nachbar auch ein Maverick hat weil fhem die beiden nicht unterscheiden könnte. Das bbq modul wird mit wechselnden IDs umgehen können.
Btw,
bei mir funktionier der Empfang des 733 leider sehr instabil - da wollten wir eigentlich nooch was machen. Ich habe mit einem 433e und dem et733 teilweise mehrere dutzend Minuten in denen ich nichts empfange. Das ist auch unabhängig vom Abstand oder igrendwelchen anderen für mich erkennbaren Bedingungen.
Bert hatte eine andere Stromversorgung für den 433e vorgeschlagen, das muss ich noch testen.
Aber da die fw draussen ist würde mich sehr interessieren wie das bei Euch ist. Muss man einige Zeit laufen lassen um das zu beobachten.
vg
joerg
knochenmuehle
der Empfang ist hier nicht das Problem, die daten kommen regelmäßig 4x pro Minute, das ET733 wird nicht erkannt s.o. :(
Gruß Andreas
OliS.
Zitat von: herrmannj am 07 Februar 2016, 13:20:45Aber da die fw draussen ist würde mich sehr interessieren wie das bei Euch ist. Muss man einige Zeit laufen lassen um das zu beobachten.
Ich werde das den restlichen Tag mal beobachten. Hab mir dazu ein Überwachungs-DOIF gebaut.
define mav_empf_push DOIF ([ET732_240]) (set pushmsg msg 'Maverick' 'Kein Empfang')
attr mav_empf_push wait 60
attr mav_empf_push do resetwait
Ich werde berichten.
Oli
