Ja, hab's auch gerade gefunden.
Wenn die Kids im Bett sind, wird getestet...
Edit:
Testversion geladen, geflasht und Shutdown Restart.
Hier das Ergebnis (mit verbose 3):
2014.06.28 21:09:18 1: CULflash (dfu-programmer atmega32u4 erase && dfu-programmer atmega32u4 flash ./FHEM/CUL_V3.hex && dfu-programmer atmega32u4 start) 2>&1
2014.06.28 21:09:22 1: CULflash Validating...
23204 bytes used (80.93%)
dfu-programmer: failed to release interface 0.
2014.06.28 21:09:22 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2014.06.28 21:09:25 3: Setting CUL_0 baudrate to 9600
2014.06.28 21:09:25 1: /dev/ttyACM0 reappeared (CUL_0)
2014.06.28 21:09:25 3: CUL_0: Possible commands: BbCFiAZEGMKUYRTVWXefmltux
2014.06.28 21:11:20 3: update get http://fhem.de/fhemupdate4/svn/controls_fhem.txt
2014.06.28 21:11:25 0: Server shutdown
2014.06.28 21:11:31 1: Including fhem.cfg
2014.06.28 21:11:31 3: Opening fritzbox device localhost:2002
2014.06.28 21:11:31 3: fritzbox device opened
2014.06.28 21:11:31 1: FBAHA fritzbox registered with handle: 00000003
2014.06.28 21:11:31 3: Opening CUL_0 device /dev/ttyACM0
2014.06.28 21:11:32 3: Setting CUL_0 baudrate to 9600
2014.06.28 21:11:32 3: CUL_0 device opened
2014.06.28 21:11:32 3: CUL_0: Possible commands: BbCFiAZEGMKUYRTVWXefmltux
2014.06.28 21:11:32 2: Setting CUL fhtid from A0085A05F30684708E61A05F30684708E61A05F30684708E61A05F30684708E61A05F30684708E61A05F30684708E611034A05F30684708E61A05F30684708E61A05F30684708E61A05F30684708E61A05F30684708E61 to 1034
2014.06.28 21:11:32 2: Switched CUL_0 rfmode to HomeMatic
2014.06.28 21:11:34 3: WEB: port 8083 opened
2014.06.28 21:11:34 3: WEBphone: port 8084 opened
2014.06.28 21:11:34 3: WEBtablet: port 8085 opened
2014.06.28 21:11:35 2: eventTypes: loaded 4346 events from ./log/eventTypes.txt
2014.06.28 21:11:31 2: Deleting fhem-2014-06-26.log
2014.06.28 21:11:35 3: [STV] defined with host: 192.168.1.5 port: 55000 MAC: C0:25:06:99:B2:7A
2014.06.28 21:11:38 3: Stehlampe_links_1: I/O device is bridge
2014.06.28 21:11:38 3: Stehlampe_links_2: I/O device is bridge
2014.06.28 21:11:38 3: Stehlampe_links_3: I/O device is bridge
2014.06.28 21:11:38 3: Stehlampe_links: I/O device is bridge
2014.06.28 21:11:43 1: Including ./log/fhem.save
2014.06.28 21:11:45 0: Server started with 88 defined entities (version $Id: fhem.pl 6080 2014-06-07 16:12:09Z rudolfkoenig $, os linux, user fhem, pid 4298)
2014.06.28 21:11:45 2: CUL_0: unknown message A05F30684708E
2014.06.28 21:11:45 2: CUL_0: unknown message A00
2014.06.28 21:11:49 3: Device Bewegungsmelder_Haustuer added to ActionDetector with 000:10 time
2014.06.28 21:11:49 3: Device Fenster_Schlafzimmer added to ActionDetector with 028:00 time
2014.06.28 21:11:49 3: Device Fenster_Waschraum added to ActionDetector with 028:00 time
2014.06.28 21:11:49 3: Device Heizung_Bad added to ActionDetector with 000:10 time
2014.06.28 21:11:49 3: Device Heizung_Buero added to ActionDetector with 000:10 time
2014.06.28 21:11:50 3: Device Heizung_Waschraum added to ActionDetector with 000:10 time
2014.06.28 21:11:50 3: Device Heizung_Wohnzimmer_links added to ActionDetector with 000:10 time
2014.06.28 21:11:50 3: Device Heizung_Wohnzimmer_rechts added to ActionDetector with 000:10 time
2014.06.28 21:11:51 3: Device Thermostat_Abstellraum added to ActionDetector with 000:10 time
P.S.: Ein get CUL_0 version
oder auch get CUL_0 raw V
liefert übrigens immer noch die 1.60. Hoffe, ich hab da nix falsch gemacht.
