FB_CALLMONITOR: new reading "direction" for incoming/outgoing calls. all readings will be triggered for each call event (call, ring, connect and disconnect)
Begonnen von System, 15 Juli 2014, 14:00:03
System
FB_CALLMONITOR: new reading "direction" for incoming/outgoing calls. all readings will be triggered for each call event (call, ring, connect and disconnect)View Changes
Source: FB_CALLMONITOR: new reading "direction" for incoming/outgoing calls. all readings will be triggered for each call event (call, ring, connect and disconnect)
