HMW_IO_12_Sw14_DR Status
Begonnen von cerberus, 20 Juli 2014, 20:54:23
stephan-221
#15
Hallo Gevoo,
ich habe die Version eingespielt und neugestartet.
Übrigens kann ich deine Version leider nicht dauerhaft laufen lassen. Die Logs bringen irgendwann nach Stunden fhem zum einfrieren. Der Raspberry kann aber noch angesprochen werden.
FHEM log:
2014.07.31 21:03:23 1: Including fhem.cfg
2014.07.31 21:03:24 3: telnetPort: port 7072 opened
2014.07.31 21:03:27 3: WEB: port 8083 opened
2014.07.31 21:03:27 3: WEBphone: port 8084 opened
2014.07.31 21:03:27 3: WEBtablet: port 8085 opened
2014.07.31 21:03:29 2: eventTypes: loaded 1450 events from ./log/eventTypes.txt
2014.07.31 21:03:29 3: Opening CUL1 device /dev/ttyACM0
2014.07.31 21:03:31 3: Setting CUL1 baudrate to 9600
2014.07.31 21:03:31 3: CUL1 device opened
2014.07.31 21:03:37 3: CUL1: Possible commands: BCFiAZEGMRTVWXefmltux
2014.07.31 21:03:37 2: Switched CUL1 rfmode to HomeMatic
2014.07.31 21:04:03 3: HM485: HM485: Loading available device files
2014.07.31 21:04:03 3: HM485: =====================================
2014.07.31 21:04:03 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw-sen-sc-12.pm
2014.07.31 21:04:03 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_io12_fm.pm
2014.07.31 21:04:03 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_io12_sw14_dr.pm
2014.07.31 21:04:03 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_io12_sw7_dr.pm
2014.07.31 21:04:03 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_io12_sw7_dr_v3_02.pm
2014.07.31 21:04:03 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_io_4_fm.pm
2014.07.31 21:04:03 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_io_4_fm_v3_02.pm
2014.07.31 21:04:03 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_lc_bl1_dr.pm
2014.07.31 21:04:04 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_lc_bl1_dr_v3_02.pm
2014.07.31 21:04:04 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_lc_dim1l_dr.pm
2014.07.31 21:04:04 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_lc_sw2_dr.pm
2014.07.31 21:04:04 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_lc_sw2_dr_v3_02.pm
2014.07.31 21:04:04 3: HM485: Loading device file: ./FHEM/lib/HM485/Devices/hmw_virtual.pm
2014.07.31 21:04:04 2: HM485: Assigned HMW_IO_12_Sw14_DR_LEQ0251870 (0000DBA7) to HM485_LAN
2014.07.31 21:04:05 2: HM485: Assigned HMW_LC_Bl1_DR_LEQ0249544 (0000DD95) to HM485_LAN
2014.07.31 21:04:05 2: HM485: Assigned HMW_LC_Bl1_DR_LEQ0249184 (0000DEFE) to HM485_LAN
2014.07.31 21:04:05 2: HM485: Assigned HMW_LC_Bl1_DR_LEQ0249523 (0000DDA2) to HM485_LAN
2014.07.31 21:04:05 1: Including ./log/fhem.save
2014.07.31 21:04:08 1: usb create starting
2014.07.31 21:04:10 3: Probing CUL device /dev/ttyAMA0
2014.07.31 21:04:10 3: Probing TCM310 device /dev/ttyAMA0
2014.07.31 21:04:10 3: Probing FRM device /dev/ttyAMA0
2014.07.31 21:04:15 3: Probing TCM310 device /dev/ttyUSB0
2014.07.31 21:04:16 3: Probing TCM120 device /dev/ttyUSB0
2014.07.31 21:04:16 3: Probing FHZ device /dev/ttyUSB0
2014.07.31 21:04:16 3: Probing TRX device /dev/ttyUSB0
2014.07.31 21:04:17 3: Probing ZWDongle device /dev/ttyUSB0
2014.07.31 21:04:17 3: Probing FRM device /dev/ttyUSB0
2014.07.31 21:04:22 1: usb create end
2014.07.31 21:04:22 3: OWSERVER: Opening connection to OWServer localhost:4304...
2014.07.31 21:04:22 3: OWSERVER: Successfully connected to localhost:4304.
2014.07.31 21:04:23 2: SecurityCheck:  WEB,WEBphone,WEBtablet has no basicAuth attribute. telnetPort has no password/globalpassword attribute.  Restart FHEM for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2014.07.31 21:04:23 0: Server started with 128 defined entities (version $Id: fhem.pl 6249 2014-07-13 10:41:00Z rudolfkoenig $, os linux, user fhem, pid 1910)
2014.07.31 21:04:23 3: HM485_LAN: connected to device localhost:2000
2014.07.31 21:04:24 3: Device CUL_HM_HM_CC_RT_DN_2284D3 added to ActionDetector with 000:10 time
2014.07.31 21:04:24 3: Device Heizung.Kueche added to ActionDetector with 000:10 time
2014.07.31 21:04:24 3: Device Rauchmelder_EG_Flur added to ActionDetector with 099:00 time
2014.07.31 21:04:24 3: HM485: Request config for device 0000DBA7
2014.07.31 21:04:25 3: HM485: Request config for device 0000DD95
2014.07.31 21:04:25 3: Please define HMW_LC_Bl1_DR_LEQ0249544_03 first
2014.07.31 21:04:25 3: HM485: Request config for device 0000DEFE
2014.07.31 21:04:25 3: Please define HMW_LC_Bl1_DR_LEQ0249184_03 first
2014.07.31 21:04:25 3: HM485: Request config for device 0000DDA2
2014.07.31 21:04:25 3: Please define HMW_LC_Bl1_DR_LEQ0249523_03 first
2014.07.31 21:04:25 3: HM485_LAN: Lan Device Information
2014.07.31 21:04:25 3: HM485_LAN: Protocol-Version: 01
2014.07.31 21:04:25 3: HM485_LAN: Interface-Type: HMW-SOFT-GW
2014.07.31 21:04:25 3: HM485_LAN: Firmware-Version: 0.2.1
2014.07.31 21:04:25 3: HM485_LAN: Serial-Number: SGW0123456
2014.07.31 21:04:25 3: HM485_LAN: Initialize the interface
2014.07.31 21:04:27 3: HM485_LAN: ACK: (2)
2014.07.31 21:04:27 3: HM485_LAN: Response: (2) 1C00
2014.07.31 21:04:27 3: HM485_LAN: ACK: (3)
2014.07.31 21:04:27 3: HM485_LAN: Response: (3) 4C455130323531383730
2014.07.31 21:04:27 3: HM485_LAN: ACK: (4)
2014.07.31 21:04:27 3: HM485_LAN: Response: (4) 0032
2014.07.31 21:04:27 3: HM485_LAN: ACK: (5)
2014.07.31 21:04:27 3: HM485_LAN: Response: (5) 1500
2014.07.31 21:04:27 3: HM485_LAN: ACK: (6)
2014.07.31 21:04:27 3: HM485_LAN: Response: (6) 4C455130323439353434
2014.07.31 21:04:27 3: HM485_LAN: ACK: (7)
2014.07.31 21:04:27 3: HM485_LAN: Response: (7) 0306
2014.07.31 21:04:27 3: HM485_LAN: ACK: (8)
2014.07.31 21:04:27 3: HM485_LAN: Response: (8) 1500
2014.07.31 21:04:28 3: HM485_LAN: ACK: (9)
2014.07.31 21:04:28 3: HM485_LAN: Response: (9) 4C455130323439313834
2014.07.31 21:04:28 3: HM485_LAN: ACK: (10)
2014.07.31 21:04:28 3: HM485_LAN: Response: (10) 0306
2014.07.31 21:04:28 3: HM485_LAN: ACK: (11)
2014.07.31 21:04:28 3: HM485_LAN: Response: (11) 1500
2014.07.31 21:04:28 3: HM485_LAN: ACK: (12)
2014.07.31 21:04:28 3: HM485_LAN: Response: (12) 4C455130323439353233
2014.07.31 21:04:28 3: HM485_LAN: ACK: (13)
2014.07.31 21:04:28 3: HM485_LAN: Response: (13) 0306
2014.07.31 21:04:28 3: HM485_LAN: ACK: (14)
2014.07.31 21:04:28 3: HM485_LAN: Response: (14) FF14FFFFFFFFFEFF3F097F7F7F7F7F7F
2014.07.31 21:04:28 3: HM485_LAN: ACK: (15)
2014.07.31 21:04:28 3: HM485_LAN: Response: (15) 00000000000000000064000000000000
2014.07.31 21:04:28 3: HM485_LAN: ACK: (16)
2014.07.31 21:04:28 3: HM485_LAN: Response: (16) FF14FFFFFFFFFEFFFFFFFF000500C800
2014.07.31 21:04:28 3: HM485_LAN: ACK: (17)
2014.07.31 21:04:28 3: HM485_LAN: Response: (17) AA000000DD950002F900C800000000FF
2014.07.31 21:04:28 3: HM485_LAN: ACK: (18)
2014.07.31 21:04:28 3: HM485_LAN: Response: (18) FFFFFFFF21027007FD00C800000000FF
2014.07.31 21:04:28 3: HM485_LAN: ACK: (19)
2014.07.31 21:04:28 3: HM485_LAN: Response: (19) FFFFFF05210270070000DD950102F900
2014.07.31 21:04:28 3: HM485_LAN: ACK: (20)
2014.07.31 21:04:28 3: HM485_LAN: Response: (20) C800000000FFFFFFFFFF34436546FD00
2014.07.31 21:04:28 3: HM485_LAN: ACK: (21)
2014.07.31 21:04:28 3: HM485_LAN: Response: (21) C800000000FFFFFFFF0534436546FFFF
2014.07.31 21:04:28 3: HM485_LAN: ACK: (22)
2014.07.31 21:04:28 3: HM485_LAN: Response: (22) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:28 3: HM485_LAN: ACK: (23)
2014.07.31 21:04:28 3: HM485_LAN: Response: (23) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (24)
2014.07.31 21:04:29 3: HM485_LAN: Response: (24) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (25)
2014.07.31 21:04:29 3: HM485_LAN: Response: (25) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (26)
2014.07.31 21:04:29 3: HM485_LAN: Response: (26) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (27)
2014.07.31 21:04:29 3: HM485_LAN: Response: (27) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (28)
2014.07.31 21:04:29 3: HM485_LAN: Response: (28) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (29)
2014.07.31 21:04:29 3: HM485_LAN: Response: (29) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (30)
2014.07.31 21:04:29 3: HM485_LAN: Response: (30) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (31)
2014.07.31 21:04:29 3: HM485_LAN: Response: (31) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (32)
2014.07.31 21:04:29 3: HM485_LAN: Response: (32) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (33)
2014.07.31 21:04:29 3: HM485_LAN: Response: (33) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (34)
2014.07.31 21:04:29 3: HM485_LAN: Response: (34) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (35)
2014.07.31 21:04:29 3: HM485_LAN: Response: (35) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (36)
2014.07.31 21:04:29 3: HM485_LAN: Response: (36) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (37)
2014.07.31 21:04:29 3: HM485_LAN: Response: (37) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:29 3: HM485_LAN: ACK: (38)
2014.07.31 21:04:29 3: HM485_LAN: Response: (38) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (39)
2014.07.31 21:04:30 3: HM485_LAN: Response: (39) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (40)
2014.07.31 21:04:30 3: HM485_LAN: Response: (40) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (41)
2014.07.31 21:04:30 3: HM485_LAN: Response: (41) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (42)
2014.07.31 21:04:30 3: HM485_LAN: Response: (42) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (43)
2014.07.31 21:04:30 3: HM485_LAN: Response: (43) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (44)
2014.07.31 21:04:30 3: HM485_LAN: Response: (44) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (45)
2014.07.31 21:04:30 3: HM485_LAN: Response: (45) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (46)
2014.07.31 21:04:30 3: HM485_LAN: Response: (46) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (47)
2014.07.31 21:04:30 3: HM485_LAN: Response: (47) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (48)
2014.07.31 21:04:30 3: HM485_LAN: Response: (48) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (49)
2014.07.31 21:04:30 3: HM485_LAN: Response: (49) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (50)
2014.07.31 21:04:30 3: HM485_LAN: Response: (50) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (51)
2014.07.31 21:04:30 3: HM485_LAN: Response: (51) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:30 3: HM485_LAN: ACK: (52)
2014.07.31 21:04:30 3: HM485_LAN: Response: (52) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (53)
2014.07.31 21:04:31 3: HM485_LAN: Response: (53) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (54)
2014.07.31 21:04:31 3: HM485_LAN: Response: (54) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (55)
2014.07.31 21:04:31 3: HM485_LAN: Response: (55) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (56)
2014.07.31 21:04:31 3: HM485_LAN: Response: (56) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (57)
2014.07.31 21:04:31 3: HM485_LAN: Response: (57) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (58)
2014.07.31 21:04:31 3: HM485_LAN: Response: (58) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (59)
2014.07.31 21:04:31 3: HM485_LAN: Response: (59) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (60)
2014.07.31 21:04:31 3: HM485_LAN: Response: (60) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (61)
2014.07.31 21:04:31 3: HM485_LAN: Response: (61) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (62)
2014.07.31 21:04:31 3: HM485_LAN: Response: (62) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (63)
2014.07.31 21:04:31 3: HM485_LAN: Response: (63) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (64)
2014.07.31 21:04:31 3: HM485_LAN: Response: (64) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (65)
2014.07.31 21:04:31 3: HM485_LAN: Response: (65) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (66)
2014.07.31 21:04:31 3: HM485_LAN: Response: (66) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:31 3: HM485_LAN: ACK: (67)
2014.07.31 21:04:31 3: HM485_LAN: Response: (67) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (68)
2014.07.31 21:04:32 3: HM485_LAN: Response: (68) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (69)
2014.07.31 21:04:32 3: HM485_LAN: Response: (69) FFFFFFFFFFFF000000DD9502010000DD
2014.07.31 21:04:32 3: HM485_LAN: ACK: (70)
2014.07.31 21:04:32 3: HM485_LAN: Response: (70) 9502FFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (71)
2014.07.31 21:04:32 3: HM485_LAN: Response: (71) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (72)
2014.07.31 21:04:32 3: HM485_LAN: Response: (72) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (73)
2014.07.31 21:04:32 3: HM485_LAN: Response: (73) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (74)
2014.07.31 21:04:32 3: HM485_LAN: Response: (74) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (75)
2014.07.31 21:04:32 3: HM485_LAN: Response: (75) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (76)
2014.07.31 21:04:32 3: HM485_LAN: Response: (76) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (77)
2014.07.31 21:04:32 3: HM485_LAN: Response: (77) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (78)
2014.07.31 21:04:32 3: HM485_LAN: Response: (78) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (79)
2014.07.31 21:04:32 3: HM485_LAN: Response: (79) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:32 3: HM485_LAN: ACK: (80)
2014.07.31 21:04:32 3: HM485_LAN: Response: (80) 6902C800
2014.07.31 21:04:32 3: HM485_LAN: ACK: (81)
2014.07.31 21:04:32 3: HM485_LAN: Response: (81) FF14FFFFFFFFFE030AFFFF0005000E01
2014.07.31 21:04:33 3: HM485_LAN: ACK: (82)
2014.07.31 21:04:33 3: HM485_LAN: Response: (82) DC000000DEFE0002F900C800000000FF
2014.07.31 21:04:33 3: HM485_LAN: ACK: (83)
2014.07.31 21:04:33 3: HM485_LAN: Response: (83) FFFFFFFF21027007FD00C800000000FF
2014.07.31 21:04:33 3: HM485_LAN: ACK: (84)
2014.07.31 21:04:33 3: HM485_LAN: Response: (84) FFFFFF05210270070000DEFE0102F900
2014.07.31 21:04:33 3: HM485_LAN: ACK: (85)
2014.07.31 21:04:33 3: HM485_LAN: Response: (85) C800000000FFFFFFFFFF34436546FD00
2014.07.31 21:04:34 3: HM485_LAN: ACK: (86)
2014.07.31 21:04:34 3: HM485_LAN: Response: (86) C800000000FFFFFFFF0534436546FFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (87)
2014.07.31 21:04:34 3: HM485_LAN: Response: (87) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (88)
2014.07.31 21:04:34 3: HM485_LAN: Response: (88) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (89)
2014.07.31 21:04:34 3: HM485_LAN: Response: (89) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (90)
2014.07.31 21:04:34 3: HM485_LAN: Response: (90) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (91)
2014.07.31 21:04:34 3: HM485_LAN: Response: (91) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (92)
2014.07.31 21:04:34 3: HM485_LAN: Response: (92) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (93)
2014.07.31 21:04:34 3: HM485_LAN: Response: (93) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (94)
2014.07.31 21:04:34 3: HM485_LAN: Response: (94) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (95)
2014.07.31 21:04:34 3: HM485_LAN: Response: (95) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (96)
2014.07.31 21:04:34 3: HM485_LAN: Response: (96) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (97)
2014.07.31 21:04:34 3: HM485_LAN: Response: (97) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:34 3: HM485_LAN: ACK: (98)
2014.07.31 21:04:34 3: HM485_LAN: Response: (98) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (99)
2014.07.31 21:04:35 3: HM485_LAN: Response: (99) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (100)
2014.07.31 21:04:35 3: HM485_LAN: Response: (100) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (101)
2014.07.31 21:04:35 3: HM485_LAN: Response: (101) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (102)
2014.07.31 21:04:35 3: HM485_LAN: Response: (102) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (103)
2014.07.31 21:04:35 3: HM485_LAN: Response: (103) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (104)
2014.07.31 21:04:35 3: HM485_LAN: Response: (104) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (105)
2014.07.31 21:04:35 3: HM485_LAN: Response: (105) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (106)
2014.07.31 21:04:35 3: HM485_LAN: Response: (106) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (107)
2014.07.31 21:04:35 3: HM485_LAN: Response: (107) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (108)
2014.07.31 21:04:35 3: HM485_LAN: Response: (108) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (109)
2014.07.31 21:04:35 3: HM485_LAN: Response: (109) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:35 3: HM485_LAN: ACK: (110)
2014.07.31 21:04:36 3: HM485_LAN: Response: (110) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (111)
2014.07.31 21:04:36 3: HM485_LAN: Response: (111) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (112)
2014.07.31 21:04:36 3: HM485_LAN: Response: (112) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (113)
2014.07.31 21:04:36 3: HM485_LAN: Response: (113) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (114)
2014.07.31 21:04:36 3: HM485_LAN: Response: (114) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (115)
2014.07.31 21:04:36 3: HM485_LAN: Response: (115) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (116)
2014.07.31 21:04:36 3: HM485_LAN: Response: (116) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (117)
2014.07.31 21:04:36 3: HM485_LAN: Response: (117) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (118)
2014.07.31 21:04:36 3: HM485_LAN: Response: (118) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (119)
2014.07.31 21:04:36 3: HM485_LAN: Response: (119) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (120)
2014.07.31 21:04:36 3: HM485_LAN: Response: (120) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (121)
2014.07.31 21:04:36 3: HM485_LAN: Response: (121) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (122)
2014.07.31 21:04:36 3: HM485_LAN: Response: (122) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (123)
2014.07.31 21:04:36 3: HM485_LAN: Response: (123) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:36 3: HM485_LAN: ACK: (124)
2014.07.31 21:04:36 3: HM485_LAN: Response: (124) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:37 3: HM485_LAN: ACK: (125)
2014.07.31 21:04:37 3: HM485_LAN: Response: (125) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:37 3: HM485_LAN: ACK: (126)
2014.07.31 21:04:37 3: HM485_LAN: Response: (126) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:37 3: HM485_LAN: ACK: (127)
2014.07.31 21:04:37 3: HM485_LAN: Response: (127) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:37 3: HM485_LAN: ACK: (128)
2014.07.31 21:04:37 3: HM485_LAN: Response: (128) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (129)
2014.07.31 21:04:38 3: HM485_LAN: Response: (129) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (130)
2014.07.31 21:04:38 3: HM485_LAN: Response: (130) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (131)
2014.07.31 21:04:38 3: HM485_LAN: Response: (131) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (132)
2014.07.31 21:04:38 3: HM485_LAN: Response: (132) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (133)
2014.07.31 21:04:38 3: HM485_LAN: Response: (133) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (134)
2014.07.31 21:04:38 3: HM485_LAN: Response: (134) FFFFFFFFFFFF000000DEFE02010000DE
2014.07.31 21:04:38 3: HM485_LAN: ACK: (135)
2014.07.31 21:04:38 3: HM485_LAN: Response: (135) FE02FFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (136)
2014.07.31 21:04:38 3: HM485_LAN: Response: (136) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (137)
2014.07.31 21:04:38 3: HM485_LAN: Response: (137) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (138)
2014.07.31 21:04:38 3: HM485_LAN: Response: (138) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (139)
2014.07.31 21:04:38 3: HM485_LAN: Response: (139) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (140)
2014.07.31 21:04:38 3: HM485_LAN: Response: (140) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (141)
2014.07.31 21:04:38 3: HM485_LAN: Response: (141) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (142)
2014.07.31 21:04:38 3: HM485_LAN: Response: (142) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:38 3: HM485_LAN: ACK: (143)
2014.07.31 21:04:38 3: HM485_LAN: Response: (143) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:39 3: HM485_LAN: ACK: (144)
2014.07.31 21:04:39 3: HM485_LAN: Response: (144) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:39 3: HM485_LAN: ACK: (145)
2014.07.31 21:04:39 3: HM485_LAN: Response: (145) 6902C800
2014.07.31 21:04:39 3: HM485_LAN: ACK: (146)
2014.07.31 21:04:39 3: HM485_LAN: Response: (146) FF14FFFFFFFFFEFFFFFFFF000500C800
2014.07.31 21:04:39 3: HM485_LAN: ACK: (147)
2014.07.31 21:04:39 3: HM485_LAN: Response: (147) BE000000DDA20002F900C800000000FF
2014.07.31 21:04:39 3: HM485_LAN: ACK: (148)
2014.07.31 21:04:39 3: HM485_LAN: Response: (148) FFFFFFFF21027007FD00C800000000FF
2014.07.31 21:04:39 3: HM485_LAN: ACK: (149)
2014.07.31 21:04:39 3: HM485_LAN: Response: (149) FFFFFF05210270070000DDA20102F900
2014.07.31 21:04:39 3: HM485_LAN: ACK: (150)
2014.07.31 21:04:39 3: HM485_LAN: Response: (150) C800000000FFFFFFFFFF34436546FD00
2014.07.31 21:04:39 3: HM485_LAN: ACK: (151)
2014.07.31 21:04:39 3: HM485_LAN: Response: (151) C800000000FFFFFFFF0534436546FFFF
2014.07.31 21:04:39 3: HM485_LAN: ACK: (152)
2014.07.31 21:04:39 3: HM485_LAN: Response: (152) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:39 3: HM485_LAN: ACK: (153)
2014.07.31 21:04:39 3: HM485_LAN: Response: (153) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:39 3: HM485_LAN: ACK: (154)
2014.07.31 21:04:39 3: HM485_LAN: Response: (154) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:39 3: HM485_LAN: ACK: (155)
2014.07.31 21:04:39 3: HM485_LAN: Response: (155) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:39 3: HM485_LAN: ACK: (156)
2014.07.31 21:04:39 3: HM485_LAN: Response: (156) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:39 3: HM485_LAN: ACK: (157)
2014.07.31 21:04:39 3: HM485_LAN: Response: (157) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (158)
2014.07.31 21:04:40 3: HM485_LAN: Response: (158) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (159)
2014.07.31 21:04:40 3: HM485_LAN: Response: (159) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (160)
2014.07.31 21:04:40 3: HM485_LAN: Response: (160) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (161)
2014.07.31 21:04:40 3: HM485_LAN: Response: (161) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (162)
2014.07.31 21:04:40 3: HM485_LAN: Response: (162) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (163)
2014.07.31 21:04:40 3: HM485_LAN: Response: (163) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (164)
2014.07.31 21:04:40 3: HM485_LAN: Response: (164) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (165)
2014.07.31 21:04:40 3: HM485_LAN: Response: (165) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (166)
2014.07.31 21:04:40 3: HM485_LAN: Response: (166) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (167)
2014.07.31 21:04:40 3: HM485_LAN: Response: (167) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (168)
2014.07.31 21:04:40 3: HM485_LAN: Response: (168) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (169)
2014.07.31 21:04:40 3: HM485_LAN: Response: (169) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (170)
2014.07.31 21:04:40 3: HM485_LAN: Response: (170) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (171)
2014.07.31 21:04:40 3: HM485_LAN: Response: (171) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:40 3: HM485_LAN: ACK: (172)
2014.07.31 21:04:40 3: HM485_LAN: Response: (172) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (173)
2014.07.31 21:04:41 3: HM485_LAN: Response: (173) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (174)
2014.07.31 21:04:41 3: HM485_LAN: Response: (174) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (175)
2014.07.31 21:04:41 3: HM485_LAN: Response: (175) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (176)
2014.07.31 21:04:41 3: HM485_LAN: Response: (176) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (177)
2014.07.31 21:04:41 3: HM485_LAN: Response: (177) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (178)
2014.07.31 21:04:41 3: HM485_LAN: Response: (178) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (179)
2014.07.31 21:04:41 3: HM485_LAN: Response: (179) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (180)
2014.07.31 21:04:41 3: HM485_LAN: Response: (180) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (181)
2014.07.31 21:04:41 3: HM485_LAN: Response: (181) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (182)
2014.07.31 21:04:41 3: HM485_LAN: Response: (182) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (183)
2014.07.31 21:04:41 3: HM485_LAN: Response: (183) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (184)
2014.07.31 21:04:41 3: HM485_LAN: Response: (184) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (185)
2014.07.31 21:04:41 3: HM485_LAN: Response: (185) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (186)
2014.07.31 21:04:41 3: HM485_LAN: Response: (186) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:41 3: HM485_LAN: ACK: (187)
2014.07.31 21:04:41 3: HM485_LAN: Response: (187) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (188)
2014.07.31 21:04:42 3: HM485_LAN: Response: (188) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (189)
2014.07.31 21:04:42 3: HM485_LAN: Response: (189) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (190)
2014.07.31 21:04:42 3: HM485_LAN: Response: (190) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (191)
2014.07.31 21:04:42 3: HM485_LAN: Response: (191) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (192)
2014.07.31 21:04:42 3: HM485_LAN: Response: (192) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (193)
2014.07.31 21:04:42 3: HM485_LAN: Response: (193) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (194)
2014.07.31 21:04:42 3: HM485_LAN: Response: (194) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (195)
2014.07.31 21:04:42 3: HM485_LAN: Response: (195) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (196)
2014.07.31 21:04:42 3: HM485_LAN: Response: (196) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (197)
2014.07.31 21:04:42 3: HM485_LAN: Response: (197) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (198)
2014.07.31 21:04:42 3: HM485_LAN: Response: (198) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (199)
2014.07.31 21:04:42 3: HM485_LAN: Response: (199) FFFFFFFFFFFF000000DDA202010000DD
2014.07.31 21:04:42 3: HM485_LAN: ACK: (200)
2014.07.31 21:04:42 3: HM485_LAN: Response: (200) A202FFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:42 3: HM485_LAN: ACK: (201)
2014.07.31 21:04:42 3: HM485_LAN: Response: (201) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:43 3: HM485_LAN: ACK: (202)
2014.07.31 21:04:43 3: HM485_LAN: Response: (202) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:43 3: HM485_LAN: ACK: (203)
2014.07.31 21:04:43 3: HM485_LAN: Response: (203) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:43 3: HM485_LAN: ACK: (204)
2014.07.31 21:04:43 3: HM485_LAN: Response: (204) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:43 3: HM485_LAN: ACK: (205)
2014.07.31 21:04:43 3: HM485_LAN: Response: (205) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:43 3: HM485_LAN: ACK: (206)
2014.07.31 21:04:43 3: HM485_LAN: Response: (206) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:43 3: HM485_LAN: ACK: (207)
2014.07.31 21:04:43 3: HM485_LAN: Response: (207) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:43 3: HM485_LAN: ACK: (208)
2014.07.31 21:04:43 3: HM485_LAN: Response: (208) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:43 3: HM485_LAN: ACK: (209)
2014.07.31 21:04:43 3: HM485_LAN: Response: (209) FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
2014.07.31 21:04:43 3: HM485_LAN: ACK: (210)
2014.07.31 21:04:43 3: HM485_LAN: Response: (210) 6902C800
HM485log im Anhang
cerberus
Hallo Gevoo, heute habe ich auch mal wieder die Zeit gefunden die aktuellste Version einzuspielen und zu testen. Die Kanäle digital_output scheinen den Status wieder zu übernehmen, das ging zwischenzeitlich bei mir nicht. Was noch nicht funktioniert ist der Status der Kanäle digital_analog_output, on noch off werden als Status nicht übernommen. Anbei die Logs sowie Screenshots.
cerberus
Banana PI mit Bananian + Fhem 5.5, 2x SCC SlowRF/Homematic + RS485 LAN Gateway HMW-LGW-O-DR-GS-EU + RPI2 I2C to 1-Wire Host Adapter for Raspberry Pi
stephan-221
Hallo Cerberus,
die digital_analog_output Kanäle kannst du analog bzw. digital benutzen.
Wenn die Funktion wie bei den anderen sein soll, musst du folgende drei Schritte ausführen:
2 Befehle eingeben:
set HM485_LAN RAW 0000A99A 98 00000002 57000701FF
set HM485_LAN RAW 0000A99A 98 00000002 43
0000A99A Sollte die Adresse deines HMW Moduls sein.
Danach gehts du auf das Modul auf die Detailseite und führst "get config all" aus.
Anschließend auf save und guck dir den Status deine Ausgänge an.
VG
Stephan
gevoo
Hallo Stephan,
danke für deinen Test. Habe wieder einige Kleinigkeiten geändert, die uns dem Ziel hoffentlich etwas näher bringen. Version 0.3.46 hängt dran. Da du mehrere HMW- Module hast, beim nächsten Test bitte die Logs der ersten 30 s.
ZitatÜbrigens kann ich deine Version leider nicht dauerhaft laufen lassen. Die Logs bringen irgendwann nach Stunden fhem zum einfrieren. Der Raspberry kann aber noch angesprochen werden.
Ist bei mir auch so. Das ist ja auch erst eine Testversion. Alle zusätzlichen Logs, die ich nicht mehr brauche nehme ich schon raus. Am Ende sollen nur noch die für den Betrieb notwendigen Logs drinbleiben. Dann wird es laufen. Habe mir zwischendurch schon mal so eine Version gemacht. Die hält durch.
Bis bald gevoo
stephan-221
Hallo Gevoo,
hier die kompletten Logfiles ab restart.
Ich habe noch ein get config all danach gemacht.
Stephan
cerberus
Hallo stephan-221, danke für den Tipp, ich habe alles so gemacht wie du geschrieben hast. Ich muss aber dazu sagen das dich die Ein- und Ausgänge bereits vorher schon via CCU auf digital gesetzt hatte. Leider hat, nachdem ich alles nach deiner Beschreibung ausgeführt habe, sich an dem fehlenden Status der digital_analog_outputs nichts geändert.
cerberus
stephan-221
Hallo Cerberus,
stehen die Ausgänge denn auf "digital" wenn du bei den einzelnen Channels auf die Detailseite gehst?
cerberus
Hallo stephan-221, ja sie stehen auf digital.
Siehe Sreenshot
stephan-221
Hallo Cerberus,
STATE ist bei dir leer.  Bei den Ausgängen die funktionieren ist STATE nicht leer.
was passiert, wenn du get state für den Kanal machst?
Danach sollte der Status dort vorhanden sein, und auch auf der Übersicht zu sehen sein!
VG
Stephan
cerberus
Hallo stephan-221, get state bewirkt nichts. Der Status ist weiter ohne Wert. Bei digital_output funktioniert der State nur eben nicht bei analog_digital_output.
cerberus
stephan-221
Hallo Cerberus,
du hast eine andere FW im Modul.
Bei mir ist es Version 0.5 Bei dir Version 1.
Super...    Wahrscheinlich wirds daran liegen.
Stephan
cerberus
Kann durchaus sein, das letzte mal als die CCU angeschlossen war (PI mit CCU FW) wurde die FW aktualisiert.
cerberus
gevoo
Hallo Stephan,
bei den noch nicht erkannten Kanälen, werden Teile "verschluckt". Ich habe dafür noch ein paar logs einbauen müssen, damit wir die Ursache finden können.
Deshalb als Anlage die Version 0.3.47. Bitte wieder Starten und die logs der ersten 30s posten.
Lg. gevoo
stephan-221
Hallo Gevoo,
angehängt die Logfiles ab Bootvorgang.
Stephan
gevoo
Hallo Stephan,
die Aktion gestaltet sich etwas komplizierter. Auch die Eingänge beziehen Daten aus dem Eprom, der bei diesem Modul noch nicht abgerufen wird. Aber Dirk arbeitet an einer neuen Konfiguration.
Gruß gevoo
