Buderus KM200 Kommunikationsmodul
Begonnen von Sailor, 21 Juli 2014, 12:39:47
ergerd
#1950
eventCount 2
ist fhem gerade neu gestartet worden? Mein eventCount steht jenseits 2000
Hinweis: ein List erzeugt man indem man in die Befehlszeile von fhem
list Buderus
eingibt. Dann wäre es etwas kürzer.
Und Passwörter oder IP-Adressen bitte unleserlich machen.
FHEM auf RasPi 4, ZigBee, 1Wire2WLAN, DS2423, Button+, LaCrosseGateway, PCA301, ConBee III, LuftdatenInfo, OneWireGW, Vaillant WP, eBUS Adapter, Div. ESPs u. Shellys
thburkhart
#1951
Zitat von: ergerd am 21 Dezember 2022, 23:11:17
eventCount 2
list Buderus
   DEF        192.168.9.114
   DELAYDYNVAL 60
   FUUID      639ae079-f33f-fd5f-4a91-e3b53e540fc2b780
   INTERVALDYNVAL 90
   NAME       Buderus
   NR         361
   POLLINGTIMEOUT 200
   READBACKDELAY 100
   READTEXTLEN 0
   STATE      Standby
   TYPE       km200
   URL        192.168.9.114
   eventCount 7
   Helper:
     DBLOG:
       /heatSources/systemPressure:
         dblog_THB:
           TIME       1671662704.09848
           VALUE      25.5
     2022-12-21 23:44:27   /dhwCircuits/dhw1/actualTemp 44.9
     2022-12-21 23:44:27   /dhwCircuits/dhw1/charge stop
     2022-12-21 23:44:28   /dhwCircuits/dhw1/chargeDuration 30
     2022-12-21 23:44:34   /dhwCircuits/dhw1/currentSetpoint 10
     2022-12-21 23:44:34   /dhwCircuits/dhw1/holidayMode/activated
     2022-12-21 23:44:35   /dhwCircuits/dhw1/operationMode ownprogram
     2022-12-21 23:44:35   /dhwCircuits/dhw1/singleChargeSetpoint 47
     2022-12-21 23:44:35   /dhwCircuits/dhw1/status ACTIVE
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/A/1-Mo 0700 high     2200 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/A/2-Tu 0700 high     2200 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/A/3-We 0700 high     2200 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/A/4-Th 0700 high     2200 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/A/5-Fr 0700 high     2200 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/A/6-Sa 0700 high     2300 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/A/7-Su 0700 high     2300 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/cp/1-Mo 0630 on       2200 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/cp/2-Tu 0630 on       2200 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/cp/3-We 0630 on       2200 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/cp/4-Th 0630 on       2200 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/cp/5-Fr 0630 on       2200 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/cp/6-Sa 0700 on       2300 off
     2022-12-21 23:44:36   /dhwCircuits/dhw1/switchPrograms/cp/7-Su 0700 on       2300 off
     2022-12-21 23:44:37   /dhwCircuits/dhw1/temperatureLevels/high 47
     2022-12-21 23:44:38   /dhwCircuits/dhw1/temperatureLevels/off 0
     2022-12-21 23:44:43   /dhwCircuits/dhw1/waterFlow 0
     2022-12-21 23:44:44   /dhwCircuits/dhw1/workingTime 162462
     2022-12-21 23:44:44   /gateway/DateTime 2022-12-21T23:44:00
     2022-12-21 23:44:45   /gateway/instAccess off
     2022-12-21 23:44:45   /gateway/instWriteAccess off
     2022-12-21 23:44:46   /gateway/logging/userAcceptance false
     2022-12-21 23:44:46   /gateway/update/status completed
     2022-12-21 23:44:47   /gateway/uuid   077210828
     2022-12-21 23:44:47   /gateway/versionFirmware 04.08.02
     2022-12-21 23:44:48   /gateway/versionHardware iCom_Low_NSC_v1
     2022-12-21 23:44:53   /heatSources/CHpumpModulation 0
     2022-12-21 23:44:53   /heatSources/ChimneySweeper off
     2022-12-21 23:44:54   /heatSources/actualCHPower 0
     2022-12-21 23:44:54   /heatSources/actualDHWPower 0
     2022-12-21 23:44:54   /heatSources/actualModulation 0
     2022-12-21 23:44:54   /heatSources/actualPower 0
     2022-12-21 23:44:54   /heatSources/actualSupplyTemperature 48
     2022-12-21 23:44:54   /heatSources/applianceSupplyTemperature 48
     2022-12-21 23:44:54   /heatSources/burnerModulationSetpoint 100
     2022-12-21 23:44:55   /heatSources/burnerPowerSetpoint 0
     2022-12-21 23:44:55   /heatSources/chimneyTemperature -3276.8
     2022-12-21 23:44:56   /heatSources/energyMonitoring/consumption 0
     2022-12-21 23:44:56   /heatSources/energyMonitoring/correctionFactor 1
     2022-12-21 23:44:56   /heatSources/energyMonitoring/maxTankLevel 0
     2022-12-21 23:44:56   /heatSources/energyMonitoring/minTankLevel 0
     2022-12-21 23:44:56   /heatSources/energyMonitoring/startDateTime 2022-12-21T14:34:51
     2022-12-21 23:44:57   /heatSources/energyMonitoring/tankLevel 0
     2022-12-21 23:44:57   /heatSources/fanSpeed_setpoint -10
     2022-12-21 23:44:57   /heatSources/flameStatus off
     2022-12-21 23:44:57   /heatSources/gasAirPressure -0.1
     2022-12-21 23:44:57   /heatSources/hs1/actualModulation 0
     2022-12-21 23:44:58   /heatSources/hs1/actualPower 0
     2022-12-21 23:44:58   /heatSources/hs1/flameStatus off
     2022-12-21 23:44:58   /heatSources/hs1/info/01/Id 7000
     2022-12-21 23:44:58   /heatSources/hs1/info/01/No 000000000000000000000000000000000000000000000000000000
     2022-12-21 23:44:58   /heatSources/hs1/info/01/Tok 8
     2022-12-21 23:44:58   /heatSources/hs1/info/01/Ver 01
     2022-12-21 23:45:02   /heatSources/hs1/type unknownBoiler
     2022-12-21 23:45:02   /heatSources/info/01/Id 7000
     2022-12-21 23:45:02   /heatSources/info/01/No 000000000000000000000000000000000000000000000000000000
     2022-12-21 23:45:02   /heatSources/info/01/Tok 8
     2022-12-21 23:45:02   /heatSources/info/01/Ver 01
     2022-12-21 23:45:02   /heatSources/nominalCHPower 0
     2022-12-21 23:45:03   /heatSources/nominalDHWPower 0
     2022-12-21 23:45:03   /heatSources/numberOfStarts 61229
     2022-12-21 23:45:03   /heatSources/powerSetpoint 100
     2022-12-21 23:45:03   /heatSources/returnTemperature -3200
     2022-12-21 23:45:03   /heatSources/supplyTemperatureSetpoint 11
     2022-12-21 23:45:04   /heatSources/systemPressure 25.5
     2022-12-21 23:45:04   /heatSources/workingTime/centralHeating 395589
     2022-12-21 23:45:04   /heatSources/workingTime/secondBurner 0
     2022-12-21 23:45:04   /heatSources/workingTime/totalSystem 466379
     2022-12-21 23:45:05   /heatingCircuits/hc1/activeSwitchProgram A
     2022-12-21 23:45:05   /heatingCircuits/hc1/actualSupplyTemperature 48
     2022-12-21 23:45:09   /heatingCircuits/hc1/currentRoomSetpoint 0
     2022-12-21 23:45:09   /heatingCircuits/hc1/currentSuWiMode off
     2022-12-21 23:45:10   /heatingCircuits/hc1/fastHeatupFactor 0
     2022-12-21 23:45:10   /heatingCircuits/hc1/holidayMode/activated
     2022-12-21 23:45:10   /heatingCircuits/hc1/operationMode auto
     2022-12-21 23:45:11   /heatingCircuits/hc1/pumpModulation 0
     2022-12-21 23:45:11   /heatingCircuits/hc1/roomtemperature -3276.8
     2022-12-21 23:45:12   /heatingCircuits/hc1/status ACTIVE
     2022-12-21 23:45:12   /heatingCircuits/hc1/suWiSwitchMode automatic
     2022-12-21 23:45:12   /heatingCircuits/hc1/suWiThreshold 16
     2022-12-21 23:45:12   /heatingCircuits/hc1/supplyTemperatureSetpoint 0
     2022-12-21 23:45:12   /heatingCircuits/hc1/switchPrograms/A/1-Mo 0700 comfort2 2300 eco
     2022-12-21 23:45:12   /heatingCircuits/hc1/switchPrograms/A/2-Tu 0800 comfort2 2300 eco
     2022-12-21 23:45:12   /heatingCircuits/hc1/switchPrograms/A/3-We 0800 comfort2 2300 eco
     2022-12-21 23:45:12   /heatingCircuits/hc1/switchPrograms/A/4-Th 0800 comfort2 2300 eco
     2022-12-21 23:45:12   /heatingCircuits/hc1/switchPrograms/A/5-Fr 0800 comfort2 2300 eco
     2022-12-21 23:45:12   /heatingCircuits/hc1/switchPrograms/A/6-Sa 0800 comfort2 2300 eco
     2022-12-21 23:45:12   /heatingCircuits/hc1/switchPrograms/A/7-Su 0800 comfort2 2300 eco
     2022-12-21 23:45:13   /heatingCircuits/hc1/switchPrograms/B/1-Mo 0600 comfort2 0800 eco      1600 comfort2 2300 eco
     2022-12-21 23:45:13   /heatingCircuits/hc1/switchPrograms/B/2-Tu 0600 comfort2 0800 eco      1600 comfort2 2300 eco
     2022-12-21 23:45:13   /heatingCircuits/hc1/switchPrograms/B/3-We 0600 comfort2 0800 eco      1600 comfort2 2300 eco
     2022-12-21 23:45:13   /heatingCircuits/hc1/switchPrograms/B/4-Th 0600 comfort2 0800 eco      1600 comfort2 2300 eco
     2022-12-21 23:45:13   /heatingCircuits/hc1/switchPrograms/B/5-Fr 0600 comfort2 0800 eco      1600 comfort2 2300 eco
     2022-12-21 23:45:13   /heatingCircuits/hc1/switchPrograms/B/6-Sa 0800 comfort2 2300 eco
     2022-12-21 23:45:13   /heatingCircuits/hc1/switchPrograms/B/7-Su 0800 comfort2 2300 eco
     2022-12-21 23:45:13   /heatingCircuits/hc1/temperatureLevels/comfort2 21
     2022-12-21 23:45:13   /heatingCircuits/hc1/temperatureLevels/eco 17
     2022-12-21 23:45:13   /heatingCircuits/hc1/temporaryRoomSetpoint -1
     2022-12-21 23:43:29   /recordings/dhwCircuits/dhw1/actualTemp_ThisMonth_kWh 21613.99
     2022-12-21 23:43:29   /recordings/dhwCircuits/dhw1/actualTemp_ThisYear_kWh 361638.52
     2022-12-21 23:43:28   /recordings/dhwCircuits/dhw1/actualTemp_Today_kWh 1003.00
     2022-12-21 23:43:30   /recordings/heatSources/actualCHPower_ThisMonth_kWh 423109.76
     2022-12-21 23:43:30   /recordings/heatSources/actualCHPower_ThisYear_kWh 1122459.71
     2022-12-21 23:43:29   /recordings/heatSources/actualCHPower_Today_kWh 9073.68
     2022-12-21 23:43:31   /recordings/heatSources/actualDHWPower_ThisMonth_kWh 31697.28
     2022-12-21 23:43:31   /recordings/heatSources/actualDHWPower_ThisYear_kWh 589492.58
     2022-12-21 23:43:30   /recordings/heatSources/actualDHWPower_Today_kWh 1069.13
     2022-12-21 23:43:33   /recordings/heatSources/actualPower_ThisMonth_kWh 454738.44
     2022-12-21 23:43:34   /recordings/heatSources/actualPower_ThisYear_kWh 1711823.60
     2022-12-21 23:43:33   /recordings/heatSources/actualPower_Today_kWh 10142.81
     2022-12-21 23:43:32   /recordings/heatSources/hs1/actualPower_ThisMonth_kWh 454738.44
     2022-12-21 23:43:32   /recordings/heatSources/hs1/actualPower_ThisYear_kWh 1711823.60
     2022-12-21 23:43:31   /recordings/heatSources/hs1/actualPower_Today_kWh 10142.81
     2022-12-21 23:43:33   /recordings/heatingCircuits/hc1/roomtemperature_ThisMonth_kWh -1651045.10
     2022-12-21 23:43:33   /recordings/heatingCircuits/hc1/roomtemperature_ThisYear_kWh -7075907.26
     2022-12-21 23:43:32   /recordings/heatingCircuits/hc1/roomtemperature_Today_kWh -75345.31
     2022-12-21 23:43:34   /recordings/system/sensors/temperatures/outdoor_t1_ThisMonth_kWh 1183.84
     2022-12-21 23:43:34   /recordings/system/sensors/temperatures/outdoor_t1_ThisYear_kWh 112600.29
     2022-12-21 23:43:34   /recordings/system/sensors/temperatures/outdoor_t1_Today_kWh 143.10
     2022-12-21 23:45:26   /system/appliance/actualSupplyTemperature 48
     2022-12-21 23:45:26   /system/brand   unknown
     2022-12-21 23:45:26   /system/bus     EMS2_0
     2022-12-21 23:45:26   /system/healthStatus ok
     2022-12-21 23:45:27   /system/holidayModes/hm1/dhwMode OFF
     2022-12-21 23:45:27   /system/holidayModes/hm1/hcMode ECO
     2022-12-21 23:45:27   /system/holidayModes/hm1/startStop 2009-01-01/2009-01-01
     2022-12-21 23:45:28   /system/holidayModes/hm2/dhwMode OFF
     2022-12-21 23:45:33   /system/holidayModes/hm2/hcMode ECO
     2022-12-21 23:45:33   /system/holidayModes/hm2/startStop 2009-01-01/2009-01-01
     2022-12-21 23:45:34   /system/holidayModes/hm3/dhwMode OFF
     2022-12-21 23:45:34   /system/holidayModes/hm3/hcMode ECO
     2022-12-21 23:45:34   /system/holidayModes/hm3/startStop 2009-01-01/2009-01-01
     2022-12-21 23:45:35   /system/holidayModes/hm4/dhwMode OFF
     2022-12-21 23:45:35   /system/holidayModes/hm4/hcMode ECO
     2022-12-21 23:45:35   /system/holidayModes/hm4/startStop 2009-01-01/2009-01-01
     2022-12-21 23:45:36   /system/holidayModes/hm5/dhwMode OFF
     2022-12-21 23:45:36   /system/holidayModes/hm5/hcMode ECO
     2022-12-21 23:45:36   /system/holidayModes/hm5/startStop 2009-01-01/2009-01-01
     2022-12-21 23:45:36   /system/info/01/Id 72
     2022-12-21 23:45:36   /system/info/01/No AA25304553066068718589055AAA06000000000000000000000000
     2022-12-21 23:45:36   /system/info/01/Tok 8
     2022-12-21 23:45:36   /system/info/01/Ver 03.03
     2022-12-21 23:45:36   /system/info/02/Id 158
     2022-12-21 23:45:36   /system/info/02/No 323533303435353937383539353737333831313030373100FFFFFF
     2022-12-21 23:45:36   /system/info/02/Tok 16
     2022-12-21 23:45:36   /system/info/02/Ver NF11.07
     2022-12-21 23:45:36   /system/info/03/Id 68
     2022-12-21 23:45:36   /system/info/03/No
     2022-12-21 23:45:36   /system/info/03/Tok 9
     2022-12-21 23:45:36   /system/info/03/Ver NF02.03
     2022-12-21 23:45:36   /system/minOutdoorTemp -10
     2022-12-21 23:45:37   /system/sensors/temperatures/chimney -3276.8
     2022-12-21 23:45:37   /system/sensors/temperatures/hotWater_t2 3200
     2022-12-21 23:45:37   /system/sensors/temperatures/outdoor_t1 7.8
     2022-12-21 23:45:37   /system/sensors/temperatures/return -3200
     2022-12-21 23:45:38   /system/sensors/temperatures/supply_t1 48
     2022-12-21 23:45:38   /system/sensors/temperatures/supply_t1_setpoint 11
     2022-12-21 23:45:38   /system/sensors/temperatures/switch 3200
     2022-12-21 23:45:38   /system/systemType NSC_ICOM_GATEWAY
     2022-12-21 23:45:38   fullResponse    OK
   Secret:
     CRYPTKEYINITIAL
     CRYPTKEYPRIVATE
     KM200ALLSERVICES:
       /application
       /dhwCircuits
       /dhwCircuits
       /dhwCircuits/dhw1
       /dhwCircuits/dhw1
       /dhwCircuits/dhw1/cpStartph
       /dhwCircuits/dhw1/cpoperationMode
       /dhwCircuits/dhw1/tdMode
       /dhwCircuits/dhw1/tdsetPoint
       /gateway
       /gateway/DateTime
       /gateway/boschSHPassword
       /gateway/firmware
       /gateway/haiPassword
       /gateway/instAccess
       /gateway/instPassword
       /gateway/knxPassword
       /gateway/logging
       /gateway/logging/reqBusVar
       /gateway/logging/switch
       /gateway/portalPassword
       /gateway/update
       /gateway/update/request
       /gateway/update/strategy
       /gateway/update/version
       /gateway/userpassword
       /gateway/uuid
       /gateway/version
       /gservice-tariff
       /heatSources
       /heatSources/ch
       /heatSources/ch/energyMonitoring
       /heatSources/dhw
       /heatSources/dhw/energyMonitoring
       /heatSources/electricGrid
       /heatSources/fuelCell
       /heatSources/hs1
       /heatSources/info
       /heatSources/pool
       /heatSources/pool/energyMonitoring
       /heatSources/sensors
       /heatSources/total
       /heatSources/total/energyMonitoring
       /heatingCircuits
       /heatingCircuits/hc1/controlType
       /heatingCircuits/hc1/cooling
       /heatingCircuits/hc1/currentOpModeInfo
       /heatingCircuits/hc1/designTemp
       /heatingCircuits/hc1/heatCurveMax
       /heatingCircuits/hc1/nextSetpoint
       /heatingCircuits/hc1/roomInfluence
       /heatingCircuits/hc1/roomTempOffset
       /heatingCircuits/hc1/timeToNextSetpoint
............ truncated
1 RASPI4B, 1 RASPI3B, 2 CUL, 2 Jeelink, 60 Tuya-Devices (Schalter, Dimmer, Sensoren, Cameras), 30 HUE-Lampen, 5 MAX! WTs, 16 MAX! HTs, 12 MAX! FKs, 1 Bresser 5in1, 1 OilFox, 8 ALEXA Echos und Dots, FHEM, 5 Tasmota-Devices, SonOff -Bridge, PowerFox, Buderus KM200
ergerd
Sieht eigentlich ähnlich meinem Device aus.
Was mir auffällt:
In den Attributen habe ich:
   IntervalDynVal 300
   PollingTimeout 20
   event-on-change-reading .*
und am Ende der Readings nur:
   status:
     FlagDynRequest 0
     FlagGetRequest 0
     FlagInitRequest 0
     FlagSetRequest 0
     FlagStatRequest 0
   temp:
     ServiceCounterDyn 0
     ServiceCounterInit 0
     ServiceDbLogSplitHash
     decodedcontent
     service
Allerdings stecke ich nicht tief genug in der Materie um zu sagen warum dem so ist.
thburkhart
das habe ich mal übernommen :
   IntervalDynVal 300
   PollingTimeout 20
bringt erst mal nichts
wie sieht denn deine DbLog-DEF aus?
ergerd
   COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
   CONFIGURATION ./db.conf
   DEF        ./db.conf .*:.*
   FUUID      63503bfe-f33f-e471-ef36-cc063e4b5ebb8fee
   FVERSION   93_DbLog.pm:v4.13.3-s26750/2022-11-26
   MODE       asynchronous
   MODEL      MYSQL
   NAME       myDbLog
   NR         62
   NTFY_ORDER 50-myDbLog
   PID        576
   REGEXP     .*:.*
   STATE      connected
   TYPE       DbLog
   UTF8       1
   dbconn     mysql:database=fhem;host=192.168.xxx.xxx;port=3307
   dbuser     fhemuser
   eventCount 1298
   HELPER:
     COLSET     1
     DEVICECOL  64
     EVENTCOL   512
     OLDSTATE   connected
     PACKAGE    main
     READINGCOL 64
     TC         current
     TH         history
     TYPECOL    64
     UNITCOL    32
     VALUECOL   128
     VERSION    4.13.3
     2022-12-22 10:59:34   CacheOverflowLastNum 0
     2022-10-19 20:03:42   CacheOverflowLastState normal
     2022-12-22 10:59:51   CacheUsage      9
     2022-12-22 10:59:34   NextSync        2022-12-22 11:00:04 or if CacheUsage 500 reached
     2022-12-22 10:59:34   state           connected
   DbLogExclude .*
   DbLogSelectionMode Exclude/Include
   DbLogType  History
   asyncMode  1
   cacheLimit 500
   room       DbLogging
   syncInterval 30
   verbose    0
thburkhart
#1955
ok ; Du logst alles ..
DEF        ./db.conf .*:.*
das wars ... nun alles gut bei mir   .... danke dir !!!
muss mir nur noch über Filter Gedanken machen ...
wie filterst du aus ?
ergerd
Durch
kann ich
attr buderus_kessel DbLogExclude .*
attr buderus_kessel DbLogInclude /heatSources/actualModulation,/heatSources/actualSupplyTemperature .....
machen
thburkhart
#1957
Zitat von: ergerd am 22 Dezember 2022, 12:42:03
Durch
kann ich
machen
verstehe ich richtig attr buderus_kessel DbLogExclude .* schließt erst mal alles aus
und attr buderus_kessel DbLogInclude /heatSources/actualModulation,/heatSources/actualSupplyTemperature schließt nur die genannten dann wieder explizit ein ? und das Mache ich im Device?
und   DbLogSelectionMode Exclude/Include im dblog oder auch im Device ?
ergerd
Zitatschließt nur die genannten dann wieder explizit ein ? und das Mache ich im Device?
richtig
Zitatim dblog oder auch im Device ?
Im DbLog, kannst du auch in meinem List sehen.
thburkhart
danke
läuft nun prima ..
Wie gehtst du mit solchen Werten um:
-3200
2022-12-23 11:04:0
oder
-3276.8
2022-12-23 11:04:12
ergerd
Schön, das es jetzt läuft.
Werte, die offensichtlich nicht abgegriffen werden können, oder ich einfach nicht brauche, stehen bei mir im Attribut "DoNotPoll".
thburkhart
#1961
ok .. also so:
DoNotPoll
chimney,chimneyTemperature,/heatSources/chimneyTemperature,roomtemperature
wie kriege ich die ausm DeviceOverview raus? damit das wieder übersichtlicher wird
attr Buderus DoNotPoll chimney,chimneyTemperature,/heatSources/chimneyTemperature,roomtemperature
attr Buderus IntervalDynVal 300
attr Buderus PollingTimeout 20
attr Buderus event-on-change-reading .*
attr Buderus event-on-update-reading .*
attr Buderus loglevel 2
attr Buderus room BUDERUS
#   DEF
#   DELAYDYNVAL 60
#   FUUID      639ae079-f33f-fd5f-4a91-e3b53e540fc2b780
#   INTERVALDYNVAL 300
#   NAME       Buderus
#   NR         360
#   POLLINGTIMEOUT 20
#   READBACKDELAY 100
#   READTEXTLEN 0
#   STATE      Standby
#   TYPE       km200
#   URL        192.168.9.114
#   eventCount 173
#   Helper:
#     DBLOG:
#       /dhwCircuits/dhw1/actualTemp:
#         dblog_THB:
#           TIME       1671799522.35378
#           VALUE      47.1
#       /dhwCircuits/dhw1/charge:
#         dblog_THB:
#           TIME       1671799522.64809
#           VALUE      stop
#       /dhwCircuits/dhw1/chargeDuration:
#         dblog_THB:
#           TIME       1671799522.92963
#           VALUE      30
#       /dhwCircuits/dhw1/currentSetpoint:
#         dblog_THB:
#           TIME       1671799523.73912
#           VALUE      47
#       /dhwCircuits/dhw1/holidayMode/activated:
#         dblog_THB:
#           TIME       1671799524.27727
#           VALUE
#       /dhwCircuits/dhw1/operationMode:
#         dblog_THB:
#           TIME       1671799524.55797
#           VALUE      ownprogram
#       /dhwCircuits/dhw1/singleChargeSetpoint:
#         dblog_THB:
#           TIME       1671799524.8676
#           VALUE      47
#       /dhwCircuits/dhw1/status:
#         dblog_THB:
#           TIME       1671799525.14744
#           VALUE      ACTIVE
#       /dhwCircuits/dhw1/switchPrograms/A/1-Mo:
#         dblog_THB:
#           TIME       1671799525.67812
#           VALUE      0700 high     2200 off
#       /dhwCircuits/dhw1/switchPrograms/A/2-Tu:
#         dblog_THB:
#           TIME       1671799525.68555
#       /dhwCircuits/dhw1/switchPrograms/A/3-We:
#         dblog_THB:
#           TIME       1671799525.69211
#       /dhwCircuits/dhw1/switchPrograms/A/4-Th:
#         dblog_THB:
#           TIME       1671799525.69901
#       /dhwCircuits/dhw1/switchPrograms/A/5-Fr:
#         dblog_THB:
#           TIME       1671799525.70519
#       /dhwCircuits/dhw1/switchPrograms/A/6-Sa:
#         dblog_THB:
#           TIME       1671799525.71214
#           VALUE      0700 high     2300 off
#       /dhwCircuits/dhw1/switchPrograms/A/7-Su:
#         dblog_THB:
#           TIME       1671799525.71826
#       /dhwCircuits/dhw1/switchPrograms/cp/1-Mo:
#         dblog_THB:
#           TIME       1671799526.03273
#           VALUE      0630 on       2200 off
#       /dhwCircuits/dhw1/switchPrograms/cp/2-Tu:
#         dblog_THB:
#           TIME       1671799526.03912
#       /dhwCircuits/dhw1/switchPrograms/cp/3-We:
#         dblog_THB:
#           TIME       1671799526.04735
#       /dhwCircuits/dhw1/switchPrograms/cp/4-Th:
#         dblog_THB:
#           TIME       1671799526.05383
#       /dhwCircuits/dhw1/switchPrograms/cp/5-Fr:
#         dblog_THB:
#           TIME       1671799526.06099
#       /dhwCircuits/dhw1/switchPrograms/cp/6-Sa:
#         dblog_THB:
#           TIME       1671799526.06737
#           VALUE      0700 on       2300 off
#       /dhwCircuits/dhw1/switchPrograms/cp/7-Su:
#         dblog_THB:
#           TIME       1671799526.07448
#       /dhwCircuits/dhw1/temperatureLevels/high:
#         dblog_THB:
#           TIME       1671799527.10887
#           VALUE      47
#       /dhwCircuits/dhw1/temperatureLevels/off:
#         dblog_THB:
#           TIME       1671799527.39843
#           VALUE      0
#       /dhwCircuits/dhw1/waterFlow:
#         dblog_THB:
#           TIME       1671799527.67803
#           VALUE      0
#       /dhwCircuits/dhw1/workingTime:
#         dblog_THB:
#           TIME       1671799527.95795
#           VALUE      162594
#       /gateway/DateTime:
#         dblog_THB:
#           TIME       1671799528.28784
#           VALUE      2022-12-23T13:44:44
#       /gateway/instAccess:
#         dblog_THB:
#           TIME       1671799528.79853
#           VALUE      off
#       /gateway/instWriteAccess:
#         dblog_THB:
#           TIME       1671799529.05849
#           VALUE      off
#       /gateway/logging/userAcceptance:
#         dblog_THB:
#           TIME       1671799529.82827
#           VALUE      false
#       /gateway/update/status:
#         dblog_THB:
#           TIME       1671799530.40008
#           VALUE      completed
#       /gateway/uuid:
#         dblog_THB:
#           TIME       1671799530.92105
#           VALUE      077210828
#       /gateway/versionFirmware:
#         dblog_THB:
#           TIME       1671799531.19762
#           VALUE      04.08.02
#       /gateway/versionHardware:
#         dblog_THB:
#           TIME       1671799531.37431
#           VALUE      iCom_Low_NSC_v1
#       /heatSources/CHpumpModulation:
#         dblog_THB:
#           TIME       1671799531.94895
#           VALUE      100
#       /heatSources/ChimneySweeper:
#         dblog_THB:
#           TIME       1671799532.09735
#           VALUE      off
#       /heatSources/actualCHPower:
#         dblog_THB:
#           TIME       1671799532.23739
#           VALUE      0
#       /heatSources/actualDHWPower:
#         dblog_THB:
#           TIME       1671799532.38767
#           VALUE      0
#       /heatSources/actualModulation:
#         dblog_THB:
#           TIME       1671799532.5275
#           VALUE      0
#       /heatSources/actualPower:
#         dblog_THB:
#           TIME       1671799532.6678
#           VALUE      0
#       /heatSources/actualSupplyTemperature:
#         dblog_THB:
#           TIME       1671799532.80803
#           VALUE      42
#       /heatSources/applianceSupplyTemperature:
#         dblog_THB:
#           TIME       1671799532.96945
#           VALUE      42
#       /heatSources/burnerModulationSetpoint:
#         dblog_THB:
#           TIME       1671799533.10791
#           VALUE      100
#       /heatSources/burnerPowerSetpoint:
#         dblog_THB:
#           TIME       1671799533.30189
#           VALUE      0
#       /heatSources/chimneyTemperature:
#         dblog_THB:
#           TIME       1671799533.69782
#           VALUE      -3276.8
#       /heatSources/energyMonitoring/consumption:
#         dblog_THB:
#           TIME       1671799534.40645
#           VALUE      0
#       /heatSources/energyMonitoring/correctionFactor:
#         dblog_THB:
#           TIME       1671799534.56832
#           VALUE      1
#       /heatSources/energyMonitoring/maxTankLevel:
#         dblog_THB:
#           TIME       1671799534.72836
#           VALUE      0
#       /heatSources/energyMonitoring/minTankLevel:
#         dblog_THB:
#           TIME       1671799534.88269
#           VALUE      0
#       /heatSources/energyMonitoring/startDateTime:
#         dblog_THB:
#           TIME       1671799535.0181
#           VALUE      2022-12-21T14:34:51
#       /heatSources/energyMonitoring/tankLevel:
#         dblog_THB:
#           TIME       1671799535.16795
#           VALUE      0
#       /heatSources/fanSpeed_setpoint:
#         dblog_THB:
#           TIME       1671799535.30814
#           VALUE      -10
#       /heatSources/flameStatus:
#         dblog_THB:
#           TIME       1671799535.44812
#           VALUE      off
#       /heatSources/gasAirPressure:
#         dblog_THB:
#           TIME       1671799535.71823
#           VALUE      -0.1
#       /heatSources/hs1/actualModulation:
#         dblog_THB:
#           TIME       1671799535.98831
#           VALUE      0
#       /heatSources/hs1/actualPower:
#         dblog_THB:
#           TIME       1671799536.12796
#           VALUE      0
#       /heatSources/hs1/flameStatus:
#         dblog_THB:
#           TIME       1671799536.26805
#           VALUE      off
#       /heatSources/hs1/info/01/Id:
#         dblog_THB:
#           TIME       1671799536.40919
#           VALUE      7000
#       /heatSources/hs1/info/01/No:
#         dblog_THB:
#           TIME       1671799536.42992
#           VALUE      000000000000000000000000000000000000000000000000000000
#       /heatSources/hs1/info/01/Tok:
#         dblog_THB:
#           TIME       1671799536.42333
#           VALUE      8
#       /heatSources/hs1/info/01/Ver:
#         dblog_THB:
#           TIME       1671799536.41616
#           VALUE      01
#       /heatSources/hs1/type:
#         dblog_THB:
#           TIME       1671799536.56844
#           VALUE      unknownBoiler
#       /heatSources/info/01/Id:
#         dblog_THB:
#           TIME       1671799536.72153
#           VALUE      7000
#       /heatSources/info/01/No:
#         dblog_THB:
#           TIME       1671799536.72828
#       /heatSources/info/01/Tok:
#         dblog_THB:
#           TIME       1671799536.70795
#           VALUE      8
#       /heatSources/info/01/Ver:
#         dblog_THB:
#           TIME       1671799536.71495
#           VALUE      01
#       /heatSources/nominalCHPower:
#         dblog_THB:
#           TIME       1671799536.86829
#           VALUE      0
#       /heatSources/nominalDHWPower:
#         dblog_THB:
#           TIME       1671799537.0182
#           VALUE      0
#       /heatSources/numberOfStarts:
#         dblog_THB:
#           TIME       1671799537.15918
#           VALUE      61268
#       /heatSources/powerSetpoint:
#         dblog_THB:
#           TIME       1671799537.54731
#           VALUE      100
#       /heatSources/returnTemperature:
#         dblog_THB:
#           TIME       1671799537.68818
#           VALUE      -3200
#       /heatSources/supplyTemperatureSetpoint:
#         dblog_THB:
#           TIME       1671799537.95215
#           VALUE      42
#       /heatSources/systemPressure:
#         dblog_THB:
#           TIME       1671799538.08848
#           VALUE      25.5
#       /heatSources/workingTime/centralHeating:
#         dblog_THB:
#           TIME       1671799538.59905
#           VALUE      395861
#       /heatSources/workingTime/secondBurner:
#         dblog_THB:
#           TIME       1671799538.81824
#           VALUE      0
#       /heatSources/workingTime/totalSystem:
#         dblog_THB:
#           TIME       1671799539.07811
#           VALUE      466690
#       /heatingCircuits/hc1/activeSwitchProgram:
#         dblog_THB:
#           TIME       1671799539.68821
#           VALUE      A
#       /heatingCircuits/hc1/actualSupplyTemperature:
#         dblog_THB:
#           TIME       1671799539.89879
#           VALUE      42
#       /heatingCircuits/hc1/currentRoomSetpoint:
#         dblog_THB:
#           TIME       1671799540.52808
#           VALUE      21
#       /heatingCircuits/hc1/currentSuWiMode:
#         dblog_THB:
#           TIME       1671799540.66778
#           VALUE      forced
#       /heatingCircuits/hc1/fastHeatupFactor:
#         dblog_THB:
#           TIME       1671799540.9283
#           VALUE      0
#       /heatingCircuits/hc1/holidayMode/activated:
#         dblog_THB:
#           TIME       1671799541.52141
#           VALUE
#       /heatingCircuits/hc1/operationMode:
#         dblog_THB:
#           TIME       1671799541.7887
#           VALUE      auto
#       /heatingCircuits/hc1/pumpModulation:
#         dblog_THB:
#           TIME       1671799541.94794
#           VALUE      100
#       /heatingCircuits/hc1/roomtemperature:
#         dblog_THB:
#           TIME       1671799542.45816
#           VALUE      -3276.8
#       /heatingCircuits/hc1/status:
#         dblog_THB:
#           TIME       1671799542.59861
#           VALUE      ACTIVE
#       /heatingCircuits/hc1/suWiSwitchMode:
#         dblog_THB:
#           TIME       1671799542.78
#           VALUE      automatic
#       /heatingCircuits/hc1/suWiThreshold:
#         dblog_THB:
#           TIME       1671799542.92
#           VALUE      16
#       /heatingCircuits/hc1/supplyTemperatureSetpoint:
#         dblog_THB:
#           TIME       1671799546.15756
#           VALUE      42
#       /heatingCircuits/hc1/switchPrograms/A/1-Mo:
#         dblog_THB:
#           TIME       1671799546.43055
#           VALUE      0700 comfort2 2300 eco
#       /heatingCircuits/hc1/switchPrograms/A/2-Tu:
#         dblog_THB:
#           TIME       1671799546.43813
#           VALUE      0800 comfort2 2300 eco
#       /heatingCircuits/hc1/switchPrograms/A/3-We:
#         dblog_THB:
#           TIME       1671799546.44484
#       /heatingCircuits/hc1/switchPrograms/A/4-Th:
#         dblog_THB:
#           TIME       1671799546.45455
#       /heatingCircuits/hc1/switchPrograms/A/5-Fr:
#         dblog_THB:
#           TIME       1671799546.46235
#       /heatingCircuits/hc1/switchPrograms/A/6-Sa:
#         dblog_THB:
#           TIME       1671799546.46905
#       /heatingCircuits/hc1/switchPrograms/A/7-Su:
#         dblog_THB:
#           TIME       1671799546.47647
#       /heatingCircuits/hc1/switchPrograms/B/1-Mo:
#         dblog_THB:
#           TIME       1671799546.66822
#           VALUE      0600 comfort2 0800 eco      1600 comfort2 2300 eco
#       /heatingCircuits/hc1/switchPrograms/B/2-Tu:
#         dblog_THB:
#           TIME       1671799546.676
#       /heatingCircuits/hc1/switchPrograms/B/3-We:
#         dblog_THB:
#           TIME       1671799546.68298
#       /heatingCircuits/hc1/switchPrograms/B/4-Th:
#         dblog_THB:
#           TIME       1671799546.69097
#       /heatingCircuits/hc1/switchPrograms/B/5-Fr:
#         dblog_THB:
#           TIME       1671799546.69874
#       /heatingCircuits/hc1/switchPrograms/B/6-Sa:
#         dblog_THB:
#           TIME       1671799546.70551
#       /heatingCircuits/hc1/switchPrograms/B/7-Su:
#         dblog_THB:
#           TIME       1671799546.71328
#       /heatingCircuits/hc1/temperatureLevels/comfort2:
#         dblog_THB:
#           TIME       1671799546.98797
#           VALUE      21
#       /heatingCircuits/hc1/temperatureLevels/eco:
#         dblog_THB:
#           TIME       1671799547.19192
#           VALUE      17
#       /heatingCircuits/hc1/temporaryRoomSetpoint:
#         dblog_THB:
#           TIME       1671799547.32822
#           VALUE      -1
#       /system/appliance/actualSupplyTemperature:
#         dblog_THB:
#           TIME       1671799551.79123
#           VALUE      41.9
#       /system/brand:
#         dblog_THB:
#           TIME       1671799551.96832
#           VALUE      unknown
#       /system/bus:
#         dblog_THB:
#           TIME       1671799552.12802
#           VALUE      EMS2_0
#       /system/healthStatus:
#         dblog_THB:
#           TIME       1671799552.38853
#           VALUE      ok
#       /system/holidayModes/hm1/dhwMode:
#         dblog_THB:
#           TIME       1671799553.02828
#           VALUE      OFF
#       /system/holidayModes/hm1/hcMode:
#         dblog_THB:
#           TIME       1671799553.28758
#           VALUE      ECO
#       /system/holidayModes/hm1/startStop:
#         dblog_THB:
#           TIME       1671799553.45995
#           VALUE      2009-01-01/2009-01-01
#       /system/holidayModes/hm2/dhwMode:
#         dblog_THB:
#           TIME       1671799554.01769
#           VALUE      OFF
#       /system/holidayModes/hm2/hcMode:
#         dblog_THB:
#           TIME       1671799554.18774
#           VALUE      ECO
#       /system/holidayModes/hm2/startStop:
#         dblog_THB:
#           TIME       1671799554.40764
#       /system/holidayModes/hm3/dhwMode:
#         dblog_THB:
#           TIME       1671799554.97788
#           VALUE      OFF
#       /system/holidayModes/hm3/hcMode:
#         dblog_THB:
#           TIME       1671799555.11807
#           VALUE      ECO
#       /system/holidayModes/hm3/startStop:
#         dblog_THB:
#           TIME       1671799555.25854
#       /system/holidayModes/hm4/dhwMode:
#         dblog_THB:
#           TIME       1671799556.19834
#           VALUE      OFF
#       /system/holidayModes/hm4/hcMode:
#         dblog_THB:
#           TIME       1671799556.36149
#           VALUE      ECO
#       /system/holidayModes/hm4/startStop:
#         dblog_THB:
#           TIME       1671799556.59874
#       /system/holidayModes/hm5/dhwMode:
#         dblog_THB:
#           TIME       1671799558.2883
#           VALUE      OFF
#       /system/holidayModes/hm5/hcMode:
#         dblog_THB:
#           TIME       1671799558.45818
#           VALUE      ECO
#       /system/holidayModes/hm5/startStop:
#         dblog_THB:
#           TIME       1671799558.59908
#       /system/info/01/Id:
#         dblog_THB:
#           TIME       1671799558.78361
#           VALUE      72
#       /system/info/01/No:
#         dblog_THB:
#           TIME       1671799558.76874
#           VALUE      AA25304553066068718589055AAA06000000000000000000000000
#       /system/info/01/Tok:
#         dblog_THB:
#           TIME       1671799558.77601
#           VALUE      8
#       /system/info/01/Ver:
#         dblog_THB:
#           TIME       1671799558.79102
#           VALUE      03.03
#       /system/info/02/Id:
#         dblog_THB:
#           TIME       1671799558.80622
#           VALUE      158
#       /system/info/02/No:
#         dblog_THB:
#           TIME       1671799558.82187
#           VALUE      323533303435353937383539353737333831313030373100FFFFFF
#       /system/info/02/Tok:
#         dblog_THB:
#           TIME       1671799558.7988
#           VALUE      16
#       /system/info/02/Ver:
#         dblog_THB:
#           TIME       1671799558.81377
#           VALUE      NF11.07
#       /system/info/03/Id:
#         dblog_THB:
#           TIME       1671799558.83706
#           VALUE      68
#       /system/info/03/No:
#         dblog_THB:
#           TIME       1671799558.82963
#           VALUE
#       /system/info/03/Tok:
#         dblog_THB:
#           TIME       1671799558.85243
#           VALUE      9
#       /system/info/03/Ver:
#         dblog_THB:
#           TIME       1671799558.84484
#           VALUE      NF02.03
#       /system/minOutdoorTemp:
#         dblog_THB:
#           TIME       1671799560.50865
#           VALUE      -10
#       /system/sensors/temperatures/chimney:
#         dblog_THB:
#           TIME       1671799560.93852
#           VALUE      -3276.8
#       /system/sensors/temperatures/hotWater_t2:
#         dblog_THB:
#           TIME       1671799561.20855
#           VALUE      3200
#       /system/sensors/temperatures/outdoor_t1:
#         dblog_THB:
#           TIME       1671799561.46961
#           VALUE      11.7
#       /system/sensors/temperatures/return:
#         dblog_THB:
#           TIME       1671799561.69138
#           VALUE      -3200
#       /system/sensors/temperatures/supply_t1:
#         dblog_THB:
#           TIME       1671799561.88982
#           VALUE      41.8
#       /system/sensors/temperatures/supply_t1_setpoint:
#         dblog_THB:
#           TIME       1671799562.0389
#           VALUE      42
#       /system/sensors/temperatures/switch:
#         dblog_THB:
#           TIME       1671799562.2187
#           VALUE      3200
#       /system/systemType:
#         dblog_THB:
#           TIME       1671799562.40777
#           VALUE      NSC_ICOM_GATEWAY
#       fullResponse:
#         dblog_THB:
#           TIME       1671799562.41556
#           VALUE      OK
#   READINGS:
#     2022-12-23 13:45:22   /dhwCircuits/dhw1/actualTemp 47.1
#     2022-12-23 13:45:22   /dhwCircuits/dhw1/charge stop
#     2022-12-23 13:45:22   /dhwCircuits/dhw1/chargeDuration 30
#     2022-12-23 13:45:23   /dhwCircuits/dhw1/currentSetpoint 47
#     2022-12-23 13:45:24   /dhwCircuits/dhw1/holidayMode/activated
#     2022-12-23 13:45:24   /dhwCircuits/dhw1/operationMode ownprogram
#     2022-12-23 13:45:24   /dhwCircuits/dhw1/singleChargeSetpoint 47
#     2022-12-23 13:45:25   /dhwCircuits/dhw1/status ACTIVE
#     2022-12-23 13:45:25   /dhwCircuits/dhw1/switchPrograms/A/1-Mo 0700 high     2200 off
#     2022-12-23 13:45:25   /dhwCircuits/dhw1/switchPrograms/A/2-Tu 0700 high     2200 off
#     2022-12-23 13:45:25   /dhwCircuits/dhw1/switchPrograms/A/3-We 0700 high     2200 off
#     2022-12-23 13:45:25   /dhwCircuits/dhw1/switchPrograms/A/4-Th 0700 high     2200 off
#     2022-12-23 13:45:25   /dhwCircuits/dhw1/switchPrograms/A/5-Fr 0700 high     2200 off
#     2022-12-23 13:45:25   /dhwCircuits/dhw1/switchPrograms/A/6-Sa 0700 high     2300 off
#     2022-12-23 13:45:25   /dhwCircuits/dhw1/switchPrograms/A/7-Su 0700 high     2300 off
#     2022-12-23 13:45:26   /dhwCircuits/dhw1/switchPrograms/cp/1-Mo 0630 on       2200 off
#     2022-12-23 13:45:26   /dhwCircuits/dhw1/switchPrograms/cp/2-Tu 0630 on       2200 off
#     2022-12-23 13:45:26   /dhwCircuits/dhw1/switchPrograms/cp/3-We 0630 on       2200 off
#     2022-12-23 13:45:26   /dhwCircuits/dhw1/switchPrograms/cp/4-Th 0630 on       2200 off
#     2022-12-23 13:45:26   /dhwCircuits/dhw1/switchPrograms/cp/5-Fr 0630 on       2200 off
#     2022-12-23 13:45:26   /dhwCircuits/dhw1/switchPrograms/cp/6-Sa 0700 on       2300 off
#     2022-12-23 13:45:26   /dhwCircuits/dhw1/switchPrograms/cp/7-Su 0700 on       2300 off
#     2022-12-23 13:45:27   /dhwCircuits/dhw1/temperatureLevels/high 47
#     2022-12-23 13:45:27   /dhwCircuits/dhw1/temperatureLevels/off 0
#     2022-12-23 13:45:27   /dhwCircuits/dhw1/waterFlow 0
#     2022-12-23 13:45:27   /dhwCircuits/dhw1/workingTime 162594
#     2022-12-23 13:45:28   /gateway/DateTime 2022-12-23T13:44:44
#     2022-12-23 13:45:28   /gateway/instAccess off
#     2022-12-23 13:45:29   /gateway/instWriteAccess off
#     2022-12-23 13:45:29   /gateway/logging/userAcceptance false
#     2022-12-23 13:45:30   /gateway/update/status completed
#     2022-12-23 13:45:30   /gateway/uuid   077210828
#     2022-12-23 13:45:31   /gateway/versionFirmware 04.08.02
#     2022-12-23 13:45:31   /gateway/versionHardware iCom_Low_NSC_v1
#     2022-12-23 13:45:31   /heatSources/CHpumpModulation 100
#     2022-12-23 13:45:32   /heatSources/ChimneySweeper off
#     2022-12-23 13:45:32   /heatSources/actualCHPower 0
#     2022-12-23 13:45:32   /heatSources/actualDHWPower 0
#     2022-12-23 13:45:32   /heatSources/actualModulation 0
#     2022-12-23 13:45:32   /heatSources/actualPower 0
#     2022-12-23 13:45:32   /heatSources/actualSupplyTemperature 42
#     2022-12-23 13:45:32   /heatSources/applianceSupplyTemperature 42
#     2022-12-23 13:45:33   /heatSources/burnerModulationSetpoint 100
#     2022-12-23 13:45:33   /heatSources/burnerPowerSetpoint 0
#     2022-12-23 13:45:33   /heatSources/chimneyTemperature -3276.8
#     2022-12-23 13:45:34   /heatSources/energyMonitoring/consumption 0
#     2022-12-23 13:45:34   /heatSources/energyMonitoring/correctionFactor 1
#     2022-12-23 13:45:34   /heatSources/energyMonitoring/maxTankLevel 0
#     2022-12-23 13:45:34   /heatSources/energyMonitoring/minTankLevel 0
#     2022-12-23 13:45:35   /heatSources/energyMonitoring/startDateTime 2022-12-21T14:34:51
#     2022-12-23 13:45:35   /heatSources/energyMonitoring/tankLevel 0
#     2022-12-23 13:45:35   /heatSources/fanSpeed_setpoint -10
#     2022-12-23 13:45:35   /heatSources/flameStatus off
#     2022-12-23 13:45:35   /heatSources/gasAirPressure -0.1
#     2022-12-23 13:45:35   /heatSources/hs1/actualModulation 0
#     2022-12-23 13:45:36   /heatSources/hs1/actualPower 0
#     2022-12-23 13:45:36   /heatSources/hs1/flameStatus off
#     2022-12-23 13:45:36   /heatSources/hs1/info/01/Id 7000
#     2022-12-23 13:45:36   /heatSources/hs1/info/01/No 000000000000000000000000000000000000000000000000000000
#     2022-12-23 13:45:36   /heatSources/hs1/info/01/Tok 8
#     2022-12-23 13:45:36   /heatSources/hs1/info/01/Ver 01
#     2022-12-23 13:45:36   /heatSources/hs1/type unknownBoiler
#     2022-12-23 13:45:36   /heatSources/info/01/Id 7000
#     2022-12-23 13:45:36   /heatSources/info/01/No 000000000000000000000000000000000000000000000000000000
#     2022-12-23 13:45:36   /heatSources/info/01/Tok 8
#     2022-12-23 13:45:36   /heatSources/info/01/Ver 01
#     2022-12-23 13:45:36   /heatSources/nominalCHPower 0
#     2022-12-23 13:45:37   /heatSources/nominalDHWPower 0
#     2022-12-23 13:45:37   /heatSources/numberOfStarts 61268
#     2022-12-23 13:45:37   /heatSources/powerSetpoint 100
#     2022-12-23 13:45:37   /heatSources/returnTemperature -3200
#     2022-12-23 13:45:37   /heatSources/supplyTemperatureSetpoint 42
#     2022-12-23 13:45:38   /heatSources/systemPressure 25.5
#     2022-12-23 13:45:38   /heatSources/workingTime/centralHeating 395861
#     2022-12-23 13:45:38   /heatSources/workingTime/secondBurner 0
#     2022-12-23 13:45:39   /heatSources/workingTime/totalSystem 466690
#     2022-12-23 13:45:39   /heatingCircuits/hc1/activeSwitchProgram A
#     2022-12-23 13:45:39   /heatingCircuits/hc1/actualSupplyTemperature 42
#     2022-12-23 13:45:40   /heatingCircuits/hc1/currentRoomSetpoint 21
#     2022-12-23 13:45:40   /heatingCircuits/hc1/currentSuWiMode forced
#     2022-12-23 13:45:40   /heatingCircuits/hc1/fastHeatupFactor 0
#     2022-12-23 13:45:41   /heatingCircuits/hc1/holidayMode/activated
#     2022-12-23 13:45:41   /heatingCircuits/hc1/operationMode auto
#     2022-12-23 13:45:41   /heatingCircuits/hc1/pumpModulation 100
#     2022-12-23 13:45:42   /heatingCircuits/hc1/roomtemperature -3276.8
#     2022-12-23 13:45:42   /heatingCircuits/hc1/status ACTIVE
#     2022-12-23 13:45:42   /heatingCircuits/hc1/suWiSwitchMode automatic
#     2022-12-23 13:45:42   /heatingCircuits/hc1/suWiThreshold 16
#     2022-12-23 13:45:46   /heatingCircuits/hc1/supplyTemperatureSetpoint 42
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/A/1-Mo 0700 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/A/2-Tu 0800 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/A/3-We 0800 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/A/4-Th 0800 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/A/5-Fr 0800 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/A/6-Sa 0800 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/A/7-Su 0800 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/B/1-Mo 0600 comfort2 0800 eco      1600 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/B/2-Tu 0600 comfort2 0800 eco      1600 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/B/3-We 0600 comfort2 0800 eco      1600 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/B/4-Th 0600 comfort2 0800 eco      1600 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/B/5-Fr 0600 comfort2 0800 eco      1600 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/B/6-Sa 0800 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/switchPrograms/B/7-Su 0800 comfort2 2300 eco
#     2022-12-23 13:45:46   /heatingCircuits/hc1/temperatureLevels/comfort2 21
#     2022-12-23 13:45:47   /heatingCircuits/hc1/temperatureLevels/eco 17
#     2022-12-23 13:45:47   /heatingCircuits/hc1/temporaryRoomSetpoint -1
#     2022-12-23 13:45:51   /system/appliance/actualSupplyTemperature 41.9
#     2022-12-23 13:45:51   /system/brand   unknown
#     2022-12-23 13:45:52   /system/bus     EMS2_0
#     2022-12-23 13:45:52   /system/healthStatus ok
#     2022-12-23 13:45:53   /system/holidayModes/hm1/dhwMode OFF
#     2022-12-23 13:45:53   /system/holidayModes/hm1/hcMode ECO
#     2022-12-23 13:45:53   /system/holidayModes/hm1/startStop 2009-01-01/2009-01-01
#     2022-12-23 13:45:54   /system/holidayModes/hm2/dhwMode OFF
#     2022-12-23 13:45:54   /system/holidayModes/hm2/hcMode ECO
#     2022-12-23 13:45:54   /system/holidayModes/hm2/startStop 2009-01-01/2009-01-01
#     2022-12-23 13:45:54   /system/holidayModes/hm3/dhwMode OFF
#     2022-12-23 13:45:55   /system/holidayModes/hm3/hcMode ECO
#     2022-12-23 13:45:55   /system/holidayModes/hm3/startStop 2009-01-01/2009-01-01
#     2022-12-23 13:45:56   /system/holidayModes/hm4/dhwMode OFF
#     2022-12-23 13:45:56   /system/holidayModes/hm4/hcMode ECO
#     2022-12-23 13:45:56   /system/holidayModes/hm4/startStop 2009-01-01/2009-01-01
#     2022-12-23 13:45:58   /system/holidayModes/hm5/dhwMode OFF
#     2022-12-23 13:45:58   /system/holidayModes/hm5/hcMode ECO
#     2022-12-23 13:45:58   /system/holidayModes/hm5/startStop 2009-01-01/2009-01-01
#     2022-12-23 13:45:58   /system/info/01/Id 72
#     2022-12-23 13:45:58   /system/info/01/No AA25304553066068718589055AAA06000000000000000000000000
#     2022-12-23 13:45:58   /system/info/01/Tok 8
#     2022-12-23 13:45:58   /system/info/01/Ver 03.03
#     2022-12-23 13:45:58   /system/info/02/Id 158
#     2022-12-23 13:45:58   /system/info/02/No 323533303435353937383539353737333831313030373100FFFFFF
#     2022-12-23 13:45:58   /system/info/02/Tok 16
#     2022-12-23 13:45:58   /system/info/02/Ver NF11.07
#     2022-12-23 13:45:58   /system/info/03/Id 68
#     2022-12-23 13:45:58   /system/info/03/No
#     2022-12-23 13:45:58   /system/info/03/Tok 9
#     2022-12-23 13:45:58   /system/info/03/Ver NF02.03
#     2022-12-23 13:46:00   /system/minOutdoorTemp -10
#     2022-12-23 13:46:00   /system/sensors/temperatures/chimney -3276.8
#     2022-12-23 13:46:01   /system/sensors/temperatures/hotWater_t2 3200
#     2022-12-23 13:46:01   /system/sensors/temperatures/outdoor_t1 11.7
#     2022-12-23 13:46:01   /system/sensors/temperatures/return -3200
#     2022-12-23 13:46:01   /system/sensors/temperatures/supply_t1 41.8
#     2022-12-23 13:46:02   /system/sensors/temperatures/supply_t1_setpoint 42
#     2022-12-23 13:46:02   /system/sensors/temperatures/switch 3200
#     2022-12-23 13:46:02   /system/systemType NSC_ICOM_GATEWAY
#     2022-12-23 13:46:02   fullResponse    OK
#   Secret:
#     CRYPTKEYINITIAL ػ�:q���b��q�V���П�/��ȟ�;��+
#     CRYPTKEYPRIVATE ػ�:q���b��q�VV�h�����ƶ�����
#     KM200ALLSERVICES:
#       /application
#       /dhwCircuits
#       /dhwCircuits
#       /dhwCircuits/dhw1
#       /dhwCircuits/dhw1
#       /dhwCircuits/dhw1/cpStartph
#       /dhwCircuits/dhw1/cpoperationMode
#       /dhwCircuits/dhw1/tdMode
#       /dhwCircuits/dhw1/tdsetPoint
#       /gateway
#       /gateway/DateTime
#       /gateway/boschSHPassword
#       /gateway/firmware
#       /gateway/haiPassword
#       /gateway/instPassword
#       /gateway/knxPassword
#       /gateway/logging
#       /gateway/logging/reqBusVar
#       /gateway/logging/switch
#       /gateway/portalPassword
#       /gateway/update
#       /gateway/update/request
#       /gateway/update/strategy
#       /gateway/update/version
#       /gateway/userpassword
#       /gateway/uuid
#       /gateway/version
#       /gservice-tariff
#       /heatSources
#       /heatSources/ch
#       /heatSources/ch/energyMonitoring
#       /heatSources/dhw
#       /heatSources/dhw/energyMonitoring
#       /heatSources/electricGrid
#       /heatSources/fuelCell
#       /heatSources/hs1
#       /heatSources/info
#       /heatSources/pool
#       /heatSources/pool/energyMonitoring
#       /heatSources/sensors
#       /heatSources/total
#       /heatSources/total/energyMonitoring
#       /heatingCircuits
#       /heatingCircuits/hc1/controlType
#       /heatingCircuits/hc1/cooling
#       /heatingCircuits/hc1/currentOpModeInfo
#       /heatingCircuits/hc1/designTemp
#       /heatingCircuits/hc1/heatCurveMax
#       /heatingCircuits/hc1/nextSetpoint
#       /heatingCircuits/hc1/roomInfluence
#       /heatingCircuits/hc1/roomTempOffset
#       /heatingCircuits/hc1/switchPrograms/B<br /
ergerd
Die Einträge in DoNotPoll werden mit Leerzeichen separiert.
Zitatdeletereading Buderus .*
Dann sind sie alle weg und beim nächsten pollen sollten nur noch die gewünschten da sein.
Bitte beim posten darauf achten, das die Listen zwischen den Code-Tags sind, sonst wird es unübersichlich.
thburkhart
perfekt !
werden die nicht gepollten auch nicht in die Db geschrieben oder muss ich explizit excluden?
zu den Buderus Apps:
Ich verwende "HomeCom" und "My Buderus" sehe ich richtig, dass "HomeCom"die neuere ist und alle Funktionen auch von "MyBuderus" hat und eben noch mehr - wie die schön dargestellten "Energiedaten"
ergerd
Die nicht gepollten erzeugen auch kein Event und landen daher auch nicht in der DB.
Zitatzu den Buderus Apps:
ich habe zwar die App MyBuderus, aber ich nutze sie nicht, meine Kesselsteurung habe ich verboten ins Internet zu gehen.
