« Antwort #7 am: 27 September 2015, 12:59:45 »
Danke für den Tipp.
Habe einen Eintrag gefunden:
[ 3.686944] usb 1-1.4: cp210x converter now attached to ttyUSB1
Nur kann das nicht stimmen, da ich definitiv den USB3 Anschluß mit dem TEK603 verwende.
Hier werden auch die Readings angelegt bzw. aktuallisiert, nur sind das Einträge die keinen Sinn ergeben.
pi@ccs-ht-rasp ~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.6-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #810 SMP PREEMPT Tue Aug 18 15:32:12 BST 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x3d800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 253952
[ 0.000000] free_area_init_node: node 0, pgdat 8085af80, node_mem_map bcf3a000
[ 0.000000] Normal zone: 2232 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 253952 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @bcef9000 s20608 r8192 d24448 u53248
[ 0.000000] pcpu-alloc: s20608 r8192 d24448 u53248 alloc=13*4096
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 251720
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0x19142f2d smsc95xx.macaddr=B8:27:EB:14:2F:2D bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3ea00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 cgroup_enable=memory elevator=deadline rootwait
[ 0.000000] Enabling memory control group subsystem
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 988236K/1015808K available (5958K kernel code, 534K rwdata, 1644K rodata, 420K init, 757K bss, 19380K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xbe800000 - 0xff000000 (1032 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbe000000 ( 992 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80774c6c (7604 kB)
[ 0.000000] .init : 0x80775000 - 0x807de000 ( 420 kB)
[ 0.000000] .data : 0x807de000 - 0x80863af4 ( 535 kB)
[ 0.000000] .bss : 0x80866000 - 0x8092378c ( 758 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000030] Switching to timer-based delay loop, resolution 52ns
[ 0.000317] Console: colour dummy device 80x30
[ 0.002104] console [tty1] enabled
[ 0.002169] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.002268] pid_max: default: 32768 minimum: 301
[ 0.002638] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002707] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004038] Initializing cgroup subsys blkio
[ 0.004120] Initializing cgroup subsys memory
[ 0.004216] Initializing cgroup subsys devices
[ 0.004278] Initializing cgroup subsys freezer
[ 0.004351] Initializing cgroup subsys net_cls
[ 0.004461] CPU: Testing write buffer coherency: ok
[ 0.004583] ftrace: allocating 20203 entries in 60 pages
[ 0.054064] CPU0: update cpu_capacity 1024
[ 0.054151] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.054198] [bcm2709_smp_prepare_cpus] enter
[ 0.054356] Setting up static identity map for 0x8240 - 0x8274
[ 0.113937] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.114244] [bcm2709_secondary_init] enter cpu:1
[ 0.114296] CPU1: update cpu_capacity 1024
[ 0.114305] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.133921] [bcm2709_boot_secondary] cpu:2 started (0) 16
[ 0.134171] [bcm2709_secondary_init] enter cpu:2
[ 0.134201] CPU2: update cpu_capacity 1024
[ 0.134210] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.153956] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.154135] [bcm2709_secondary_init] enter cpu:3
[ 0.154164] CPU3: update cpu_capacity 1024
[ 0.154173] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.154267] Brought up 4 CPUs
[ 0.154401] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.154444] CPU: All CPU(s) started in SVC mode.
[ 0.155448] devtmpfs: initialized
[ 0.180237] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.180595] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.181787] pinctrl core: initialized pinctrl subsystem
[ 0.182618] NET: Registered protocol family 16
[ 0.188389] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.189629] bcm2709.uart_clock = 3000000
[ 0.194643] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.194715] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.194951] Serial: AMBA PL011 UART driver
[ 0.195173] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.195800] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.265556] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x7f35
[ 0.266164] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.266217] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.266984] SCSI subsystem initialized
[ 0.267252] usbcore: registered new interface driver usbfs
[ 0.267405] usbcore: registered new interface driver hub
[ 0.267605] usbcore: registered new device driver usb
[ 0.268351] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-09-02 14:58
[ 0.295712] Switched to clocksource arch_sys_counter
[ 0.345571] FS-Cache: Loaded
[ 0.346088] CacheFiles: Loaded
[ 0.359513] NET: Registered protocol family 2
[ 0.360931] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.361128] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.361368] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.361521] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.361617] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.362028] NET: Registered protocol family 1
[ 0.362562] RPC: Registered named UNIX socket transport module.
[ 0.362617] RPC: Registered udp transport module.
[ 0.362655] RPC: Registered tcp transport module.
[ 0.362692] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.363848] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.365331] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.381350] VFS: Disk quotas dquot_6.6.0
[ 0.381786] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.384441] FS-Cache: Netfs 'nfs' registered for caching
[ 0.385659] NFS: Registering the id_resolver key type
[ 0.385831] Key type id_resolver registered
[ 0.385872] Key type id_legacy registered
[ 0.388648] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.388906] io scheduler noop registered
[ 0.388963] io scheduler deadline registered (default)
[ 0.389322] io scheduler cfq registered
[ 0.391893] BCM2708FB: allocated DMA memory fdc00000
[ 0.391972] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.397586] Console: switching to colour frame buffer device 82x26
[ 0.402807] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[ 0.405684] vc-cma: Videocore CMA driver
[ 0.407397] vc-cma: vc_cma_base = 0x00000000
[ 0.409066] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.410676] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.412438] vc-mem: phys_addr:0x00000000 mem_base=0x3ea00000 mem_size:0x3f000000(1008 MiB)
[ 0.431723] brd: module loaded
[ 0.442321] loop: module loaded
[ 0.444778] vchiq: vchiq_init_state: slot_zero = 0xbdc80000, is_master = 0
[ 0.448059] Loading iSCSI transport class v2.0-870.
[ 0.450506] usbcore: registered new interface driver smsc95xx
[ 0.452137] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.654015] Core Release: 2.80a
[ 0.655486] Setting default values for core params
[ 0.657036] Finished setting default values for core params
[ 0.858958] Using Buffer DMA mode
[ 0.860472] Periodic Transfer Interrupt Enhancement - disabled
[ 0.862033] Multiprocessor Interrupt Enhancement - disabled
[ 0.863628] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.865197] Dedicated Tx FIFOs mode
[ 0.867108] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbdc14000 dma = 0xfdc14000 len=9024
[ 0.870302] FIQ FSM acceleration enabled for :
[ 0.870302] Non-periodic Split Transactions
[ 0.870302] Periodic Split Transactions
[ 0.870302] High-Speed Isochronous Endpoints
[ 0.876803] dwc_otg: Microframe scheduler enabled
[ 0.876884] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80401038
[ 0.878530] WARN::hcd_init_fiq:413: FIQ ASM at 0x80401394 length 36
[ 0.880183] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbe89a000
[ 0.881824] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.883443] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.885087] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 0.886739] Init: Port Power? op_state=1
[ 0.888284] Init: Power Port (0)
[ 0.890077] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.891679] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.893263] usb usb1: Product: DWC OTG Controller
[ 0.894810] usb usb1: Manufacturer: Linux 4.1.6-v7+ dwc_otg_hcd
[ 0.896401] usb usb1: SerialNumber: 3f980000.usb
[ 0.898890] hub 1-0:1.0: USB hub found
[ 0.900473] hub 1-0:1.0: 1 port detected
[ 0.902395] dwc_otg: FIQ enabled
[ 0.902410] dwc_otg: NAK holdoff enabled
[ 0.902421] dwc_otg: FIQ split-transaction FSM enabled
[ 0.902462] Module dwc_common_port init
[ 0.902852] usbcore: registered new interface driver usb-storage
[ 0.904589] mousedev: PS/2 mouse device common for all mice
[ 0.906994] bcm2835-cpufreq: min=600000 max=900000
[ 0.908830] sdhci: Secure Digital Host Controller Interface driver
[ 0.910359] sdhci: Copyright(c) Pierre Ossman
[ 0.912320] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.913880] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 0.946065] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.952705] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.954570] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.956511] usbcore: registered new interface driver usbhid
[ 0.958149] usbhid: USB HID core driver
[ 0.960153] Initializing XFRM netlink socket
[ 0.961806] NET: Registered protocol family 17
[ 0.966882] Key type dns_resolver registered
[ 0.968975] Registering SWP/SWPB emulation handler
[ 0.971547] registered taskstats version 1
[ 0.973304] vc-sm: Videocore shared memory driver
[ 0.974790] [vc_sm_connected_init]: start
[ 0.976639] vc_vchi_sm_init: failed to open VCHI service (-1)
[ 0.976772] [vc_sm_connected_init]: failed to initialize shared memory service
[ 0.979776] [vc_sm_connected_init]: end - returning -1
[ 0.982932] Waiting for root device /dev/mmcblk0p2...
[ 1.014277] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.020659] mmc0: new high speed SDHC card at address 0002
[ 1.022959] mmcblk0: mmc0:0002 SD16G 14.9 GiB
[ 1.027487] mmcblk0: p1 p2
[ 1.095874] Indeed it is in host mode hprt0 = 00021501
[ 1.105803] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.109080] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.111972] devtmpfs: mounted
[ 1.114368] Freeing unused kernel memory: 420K (80775000 - 807de000)
[ 1.275782] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.277854] Indeed it is in host mode hprt0 = 00001101
[ 1.476144] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.478110] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.480918] hub 1-1:1.0: USB hub found
[ 1.482942] hub 1-1:1.0: 5 ports detected
[ 1.765897] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.866207] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.868175] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.873125] smsc95xx v1.0.4
[ 1.931538] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:14:2f:2d
[ 2.015840] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 2.286574] udevd[174]: starting version 175
[ 2.497916] usb 1-1.2: New USB device found, idVendor=0403, idProduct=6001
[ 2.501683] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.503645] usb 1-1.2: Product: FT232R USB UART
[ 2.505559] usb 1-1.2: Manufacturer: FTDI
[ 2.507547] usb 1-1.2: SerialNumber: A98J3XX9
[ 2.635872] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[ 3.118612] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001
[ 3.122495] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.124537] usb 1-1.3: Product: FT232R USB UART
[ 3.126641] usb 1-1.3: Manufacturer: FTDI
[ 3.128616] usb 1-1.3: SerialNumber: A9ULXRVF
[ 3.255827] usb 1-1.4: new full-speed USB device number 6 using dwc_otg
[ 3.365137] usb 1-1.4: New USB device found, idVendor=10c4, idProduct=ea60
[ 3.367139] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.369012] usb 1-1.4: Product: CP2102 USB to UART Bridge Controller
[ 3.370828] usb 1-1.4: Manufacturer: Silicon Labs
[ 3.372563] usb 1-1.4: SerialNumber: 0001
[ 3.455768] usb 1-1.5: new full-speed USB device number 7 using dwc_otg
[ 3.581758] usb 1-1.5: New USB device found, idVendor=0403, idProduct=6001
[ 3.583509] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.585198] usb 1-1.5: Product: RFXtrx433
[ 3.586863] usb 1-1.5: Manufacturer: RFXCOM
[ 3.588496] usb 1-1.5: SerialNumber: A1YUXLCQ
[ 3.590959] random: nonblocking pool is initialized
[ 3.651794] usbcore: registered new interface driver usbserial
[ 3.653697] usbcore: registered new interface driver usbserial_generic
[ 3.655403] usbserial: USB Serial support registered for generic
[ 3.674230] usbcore: registered new interface driver ftdi_sio
[ 3.676208] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.677470] usbcore: registered new interface driver cp210x
[ 3.679518] usbserial: USB Serial support registered for cp210x
[ 3.681462] cp210x 1-1.4:1.0: cp210x converter detected
[ 3.681870] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
[ 3.682076] usb 1-1.2: Detected FT232RL
[ 3.688778] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 3.690786] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[ 3.694537] usb 1-1.3: Detected FT232RL
[ 3.699244] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB2
[ 3.701630] ftdi_sio 1-1.5:1.0: FTDI USB Serial Device converter detected
[ 3.704078] usb 1-1.5: Detected FT232RL
[ 3.708468] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB3
[ 5.175999] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.440838] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 9.900119] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 11.528347] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 13.154053] cfg80211: Calling CRDA to update world regulatory domain
[ 16.305777] cfg80211: Calling CRDA to update world regulatory domain
[ 19.465796] cfg80211: Calling CRDA to update world regulatory domain
[ 22.625815] cfg80211: Calling CRDA to update world regulatory domain
[ 25.785827] cfg80211: Calling CRDA to update world regulatory domain
[ 26.238881] uart-pl011 3f201000.uart: no DMA platform data
[ 28.945844] cfg80211: Calling CRDA to update world regulatory domain
[ 32.105828] cfg80211: Calling CRDA to update world regulatory domain
[ 35.265803] cfg80211: Calling CRDA to update world regulatory domain
[ 38.425847] cfg80211: Calling CRDA to update world regulatory domain
[ 41.585854] cfg80211: Calling CRDA to update world regulatory domain
[ 44.745890] cfg80211: Calling CRDA to update world regulatory domain
[ 47.905895] cfg80211: Exceeded CRDA call max attempts. Not calling CRDA
« Letzte Änderung: 08 Oktober 2015, 15:42:30 von Burny4600 »
Gespeichert
Mfg Chris
Raspberry Pi 2/2+/3/3+/4 / Betriebssystem: Bullseye Lite
Schnittstellen: RFXtrx433E, SIGNALduino, MQTT, nanoCUL, HM-MOD-UART, 1-Wire, LAN, ser2net, FHEM2FEHEM
Devices: S.USV, APC-USV, Fronius Datalogger Web 2, FS20, IT, Resol VBUS & DL2, TEK603, WMR200, YouLess, Homematic, MQTT
