Autor Thema: CUNO Fehler im Log: unknown message LENERR  (Gelesen 1574 mal)
Offline cfi
  • New Member
« am: 09 Oktober 2014, 20:59:22 »
Hallo CUL / CUNO Entwickler,
in meine Log taucht diese Meldung immer wieder auf. Auch die PERL Fehler häufen sich.
2014.10.09 20:50:25 2: cuno_1: unknown message LENERR
2014.10.09 20:50:31 2: cuno_1: unknown message LENERR
2014.10.09 20:50:38 2: cuno_1: unknown message LENERR
2014.10.09 20:50:44 2: cuno_1: unknown message LENERR
2014.10.09 20:50:48 2: CUL_MAX_SendQueueHandler: Missing ack from 066b66 for 0e3704031034066b66000e0e0914b2ac
2014.10.09 20:51:35 1: PERL WARNING: Use of uninitialized value $f1 in addition (+) at ./FHEM/14_CUL_MAX.pm line 300.
2014.10.09 20:51:35 1: PERL WARNING: Use of uninitialized value $f3 in bitwise and (&) at ./FHEM/14_CUL_MAX.pm line 302.
2014.10.09 20:51:35 1: PERL WARNING: Use of uninitialized value $f4 in bitwise and (&) at ./FHEM/14_CUL_MAX.pm line 303.
2014.10.09 20:51:35 1: PERL WARNING: Use of uninitialized value $f5 in bitwise and (&) at ./FHEM/14_CUL_MAX.pm line 304.
2014.10.09 20:51:35 1: PERL WARNING: Use of uninitialized value $f4 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 305.
2014.10.09 20:51:35 1: PERL WARNING: Use of uninitialized value $f5 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 305.
2014.10.09 20:51:35 1: PERL WARNING: Use of uninitialized value $f3 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 306.
2014.10.09 20:51:35 1: PERL WARNING: Use of uninitialized value $f4 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 307.
2014.10.09 20:51:35 1: PERL WARNING: Use of uninitialized value $f5 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 308.
2014.10.09 20:51:35 1: PERL WARNING: Use of uninitialized value $day in concatenation (.) or string at ./FHEM/14_CUL_MAX.pm line 310.
Ich habe es auch mit John's Hilfe in diesem Betrag nicht geschaft, dass meine MAX HT's antworten: http://forum.fhem.de/index.php/topic,26982.0.html
Der CUNO, der momentan aktiv ist, ist ein CUNO V2.4 und hat die Version V 1.54 CUNO868. Mit V 1.61 hatte ich auch diese LENERR Fehler. Deshalb bin ich auf die Version 1.54 zurück gegangen.
Was kann ich noch tun, damit die Kommunikation zwischen CUNO und MAX wieder funktioniert.
Danke und Gruß
cfi
« Letzte Änderung: 13 Oktober 2014, 20:47:40 von cfi »
