Fehler in 10_CUL_HM.pm ?
Begonnen von chaot4ever, 10 Oktober 2014, 18:03:11
chaot4ever
Sei neuestem kriege ich 1-2x pro Tag den folgenden Fehler im Logfile aufgezeichnet:
Zitat2014.10.10 15:43:21 1: PERL WARNING: Argument "" isn't numeric in sprintf at /opt/fhem/FHEM/10_CUL_HM.pm line 3834.
2014.10.10 15:43:21 3: stacktrace:
2014.10.10 15:43:21 3:     main::__ANON__                      called by /opt/fhem/FHEM/10_CUL_HM.pm (3834)
2014.10.10 15:43:21 3:     main::CUL_HM_Set                    called by fhem.pl (2901)
2014.10.10 15:43:21 3:     main::CallFn                        called by fhem.pl (1437)
2014.10.10 15:43:21 3:     main::DoSet                         called by fhem.pl (1467)
2014.10.10 15:43:21 3:     main::CommandSet                    called by fhem.pl (969)
2014.10.10 15:43:21 3:     main::AnalyzeCommand                called by fhem.pl (848)
2014.10.10 15:43:21 3:     main::AnalyzeCommandChain           called by fhem.pl (2918)
2014.10.10 15:43:21 3:     main::fhem                          called by (eval 12918) (1)
2014.10.10 15:43:21 3:     (eval)                              called by fhem.pl (896)
2014.10.10 15:43:21 3:     main::AnalyzePerlCommand            called by fhem.pl (915)
2014.10.10 15:43:21 3:     main::AnalyzeCommandChain           called by /opt/fhem/FHEM/91_notify.pm (87)
2014.10.10 15:43:21 3:     main::notify_Exec                   called by fhem.pl (2906)
2014.10.10 15:43:21 3:     main::CallFn                        called by fhem.pl (2829)
2014.10.10 15:43:21 3:     main::DoTrigger                     called by fhem.pl (3569)
2014.10.10 15:43:21 3:     main::readingsEndUpdate             called by fhem.pl (3690)
2014.10.10 15:43:21 3:     main::readingsSingleUpdate          called by /opt/fhem/FHEM/98_dummy.pm (32)
2014.10.10 15:43:21 3:     main::dummy_Set                     called by fhem.pl (2901)
2014.10.10 15:43:21 3:     main::fhem                          called by (eval 12917) (1)
2014.10.10 15:43:21 3:     main::DoTrigger                     called by fhem.pl (3123)
2014.10.10 15:43:21 3:     main::Dispatch                      called by /opt/fhem/FHEM/00_HMLAN.pm (707)
2014.10.10 15:43:21 3:     main::HMLAN_Parse                   called by /opt/fhem/FHEM/00_HMLAN.pm (522)
2014.10.10 15:43:21 3:     main::HMLAN_Read                    called by fhem.pl (2906)
2014.10.10 15:43:21 3:     main::CallFn                        called by fhem.pl (595)
Ist diesen Verhalten bekannt und gibt es dafür schon einen Fix?
franky08
update machen oder stacktrace abschalten oder den Fehler beheben.  ;)
Oder warten bis Martin die 10_CUL_HM.pm gefixt hat. Den Fehler kannst du getrost ignorieren. Mach ein update, dort ist stacktrace default auf 0 gesetzt und somit bekommst du die Meldungen im Log nicht mehr angezeigt.
VG
Frank
mit FHEM aktuell
chaot4ever
Update gemacht, mit folgenden Meldungen:
Zitat2014.10.10 18:37:33 1: UPD ./CHANGED
2014.10.10 18:37:33 1: UPD ./fhem.pl
2014.10.10 18:37:33 1: UPD FHEM/00_MQTT.pm
2014.10.10 18:37:33 1: UPD FHEM/10_FBDECT.pm
2014.10.10 18:37:33 1: UPD FHEM/10_MQTT_BRIDGE.pm
2014.10.10 18:37:33 1: UPD FHEM/10_MQTT_DEVICE.pm
2014.10.10 18:37:33 1: UPD FHEM/32_withings.pm
2014.10.10 18:37:34 1: UPD FHEM/42_SYSMON.pm
2014.10.10 18:37:34 1: UPD FHEM/52_I2C_LCD.pm
2014.10.10 18:37:34 1: UPD FHEM/71_YAMAHA_AVR.pm
2014.10.10 18:37:34 1: UPD FHEM/92_FileLog.pm
2014.10.10 18:37:34 1: UPD FHEM/HMConfig.pm
2014.10.10 18:37:34 1: UPD docs/commandref.html
2014.10.10 18:37:34 1: UPD docs/commandref_DE.html
Nun warte ich mal und checke immer wieder das Logfile ....
franky08
shutdown restart nicht vergessen!!  :)
VG
Frank
mit FHEM aktuell
chaot4ever
Ja klar .....
Bis jetzt ohne Fehlermeldung!
Puschel74
es ist keine FEHLERmeldung.
Die Meldung kam immer schon nur war sie noch nie so "offensichtlich".
http://forum.fhem.de/index.php/topic,27662.0.html
Man darf auch gerne mal im Anfängerbereich die Postings lesen  ;)
das ist immer die letzte Option...
martinp876
ggf: we lautet das Kommando playTone? Welche Parameter werden mitgegeben?
chaot4ever
define AlarmExternScharfMeldung notify PraxisAlarmstatus:ExternScharf {fhem("set Funk_Gong_Signalleuchte_MP3 playTone 017")}
chaot4ever
Habs noch einmal durchgechecked, der auslösende Befehl ist: {fhem("set Funk_Gong_Signalleuchte_MP3 playTone ,4")}
Das verursacht, dass zuerst der normale Gong und gleich danach der Ton 4 gespielt wird.
chaot4ever
Mit {fhem("set Funk_Gong_Signalleuchte_MP3 playTone 0,4")} sollte das Problem nicht mehr auftreten.
martinp876
speziell für dich: wenn ein Wert in der Liste kein Integer kleiner 255 ist gibt es jetzt ein reject ;)
Newbie
ich hab mit dem heutigen Update folgende Meldungen im Log-File
2014.10.12 23:17:33.255 3: HMLAN1 device opened
2014.10.12 23:17:33.264 1: HMLAN_Parse: HMLAN1 new condition init
2014.10.12 23:17:35.056 3: Opening FritzBox device xxx.xxx.xxx.xxx:1012
2014.10.12 23:17:35.064 3: FritzBox device opened
2014.10.12 23:17:35.078 2: FB_CALLMONITOR: FritzBox found FritzBox phonebook /var/flash/phonebook
2014.10.12 23:17:35.121 2: FB_CALLMONITOR: FritzBox read xx contacts from FritzBox phonebook
2014.10.12 23:17:36.001 1: Including ./log/fhem.save
2014.10.12 23:17:38.263 1: HMLAN_Parse: HMLAN1 new condition ok
2014.10.12 23:17:40.175 3: Device BU_Thermostat added to ActionDetector with 000:10 time
2014.10.12 23:17:40.482 3: Device Bad_Thermostat added to ActionDetector with 000:10 time
2014.10.12 23:17:40.736 3: Device Flur_Thermostat added to ActionDetector with 000:10 time
2014.10.12 23:17:41.031 3: Device KU_Thermostat added to ActionDetector with 000:10 time
2014.10.12 23:17:41.386 3: Device SZ_Thermostat added to ActionDetector with 000:10 time
2014.10.12 23:17:41.469 3: Device SZ_Ventil1 added to ActionDetector with 028:00 time
2014.10.12 23:17:41.555 3: Device SZ_Ventil2 added to ActionDetector with 028:00 time
2014.10.12 23:17:41.826 3: Device WC_Thermostat added to ActionDetector with 000:10 time
2014.10.12 23:17:42.043 3: Device WZ3_Fenster added to ActionDetector with 028:00 time
2014.10.12 23:17:42.164 3: Device WZ_Thermostat added to ActionDetector with 000:10 time
2014.10.12 23:17:42.264 3: Device WZ_Ventil1 added to ActionDetector with 028:00 time
2014.10.12 23:17:42.365 3: Device WZ_Ventil2 added to ActionDetector with 028:00 time
2014.10.12 23:17:42.764 1: PERL WARNING: Use of uninitialized value in division (/) at ./FHEM/10_CUL_HM.pm line 7037.
2014.10.12 23:17:42.765 3: stacktrace:
2014.10.12 23:17:42.767 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7037)
2014.10.12 23:17:42.768 3:     main::CUL_HM_autoReadReady          called by ./FHEM/10_CUL_HM.pm (7012)
2014.10.12 23:17:42.770 3:     main::CUL_HM_appFromQ               called by ./FHEM/10_CUL_HM.pm (2246)
2014.10.12 23:17:42.771 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1054)
2014.10.12 23:17:42.772 3:     main::CUL_HM_Parse                  called by fhem.pl (3048)
2014.10.12 23:17:42.774 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (707)
2014.10.12 23:17:42.776 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (522)
2014.10.12 23:17:42.777 3:     main::HMLAN_Read                    called by fhem.pl (2911)
2014.10.12 23:17:42.778 3:     main::CallFn                        called by fhem.pl (598)
2014.10.12 23:17:42.789 3: CUL_HM set WZ_Ventil2 getConfig
2014.10.12 23:17:43.460 3: CUL_HM set Aquariumbeleuchtung statusRequest
2014.10.12 23:17:44.480 3: CUL_HM set KU2_Rollo statusRequest
2014.10.12 23:17:45.501 3: CUL_HM set SZ3_Rollo statusRequest
2014.10.12 23:17:46.524 3: CUL_HM set WZ1_Rollo statusRequest
2014.10.12 23:17:49.660 3: CUL_HM set WZ2_Rollo statusRequest
2014.10.12 23:17:49.791 1: PERL WARNING: Use of uninitialized value in division (/) at ./FHEM/10_CUL_HM.pm line 7037.
2014.10.12 23:17:49.793 3: stacktrace:
2014.10.12 23:17:49.794 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7037)
2014.10.12 23:17:49.795 3:     main::CUL_HM_autoReadReady          called by ./FHEM/10_CUL_HM.pm (7012)
2014.10.12 23:17:49.797 3:     main::CUL_HM_appFromQ               called by ./FHEM/10_CUL_HM.pm (2246)
2014.10.12 23:17:49.798 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1054)
2014.10.12 23:17:49.800 3:     main::CUL_HM_Parse                  called by fhem.pl (3048)
2014.10.12 23:17:49.801 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (707)
2014.10.12 23:17:49.802 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (522)
2014.10.12 23:17:49.804 3:     main::HMLAN_Read                    called by fhem.pl (2911)
2014.10.12 23:17:49.805 3:     main::CallFn                        called by fhem.pl (598)
2014.10.12 23:17:49.834 3: CUL_HM set BU_Thermostat getConfig
2014.10.12 23:17:50.734 3: CUL_HM set WZ3_Rollo statusRequest
2014.10.12 23:17:58.178 1: PERL WARNING: Use of uninitialized value in division (/) at ./FHEM/10_CUL_HM.pm line 7037.
2014.10.12 23:17:58.179 3: stacktrace:
2014.10.12 23:17:58.181 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7037)
2014.10.12 23:17:58.182 3:     main::CUL_HM_autoReadReady          called by ./FHEM/10_CUL_HM.pm (7012)
2014.10.12 23:17:58.184 3:     main::CUL_HM_appFromQ               called by ./FHEM/10_CUL_HM.pm (2246)
2014.10.12 23:17:58.185 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1054)
2014.10.12 23:17:58.187 3:     main::CUL_HM_Parse                  called by fhem.pl (3048)
2014.10.12 23:17:58.188 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (707)
2014.10.12 23:17:58.190 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (522)
2014.10.12 23:17:58.191 3:     main::HMLAN_Read                    called by fhem.pl (2911)
2014.10.12 23:17:58.192 3:     main::CallFn                        called by fhem.pl (598)
2014.10.12 23:17:58.220 3: CUL_HM set WC_Thermostat getConfig
2014.10.12 23:18:51.770 1: PERL WARNING: Use of uninitialized value in division (/) at ./FHEM/10_CUL_HM.pm line 7037.
2014.10.12 23:18:51.771 3: stacktrace:
2014.10.12 23:18:51.773 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7037)
2014.10.12 23:18:51.774 3:     main::CUL_HM_autoReadReady          called by ./FHEM/10_CUL_HM.pm (7012)
2014.10.12 23:18:51.776 3:     main::CUL_HM_appFromQ               called by ./FHEM/10_CUL_HM.pm (2246)
2014.10.12 23:18:51.778 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1054)
2014.10.12 23:18:51.780 3:     main::CUL_HM_Parse                  called by fhem.pl (3048)
2014.10.12 23:18:51.781 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (707)
2014.10.12 23:18:51.783 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (522)
2014.10.12 23:18:51.784 3:     main::HMLAN_Read                    called by fhem.pl (2911)
2014.10.12 23:18:51.786 3:     main::CallFn                        called by fhem.pl (598)
2014.10.12 23:18:51.793 3: CUL_HM set SZ_Thermostat statusRequest
2014.10.12 23:19:12.024 1: PERL WARNING: Use of uninitialized value in division (/) at ./FHEM/10_CUL_HM.pm line 7037.
2014.10.12 23:19:12.034 3: stacktrace:
2014.10.12 23:19:12.035 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7037)
2014.10.12 23:19:12.036 3:     main::CUL_HM_autoReadReady          called by ./FHEM/10_CUL_HM.pm (7012)
2014.10.12 23:19:12.041 3:     main::CUL_HM_appFromQ               called by ./FHEM/10_CUL_HM.pm (2246)
2014.10.12 23:19:12.042 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1054)
2014.10.12 23:19:12.044 3:     main::CUL_HM_Parse                  called by fhem.pl (3048)
2014.10.12 23:19:12.045 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (707)
2014.10.12 23:19:12.046 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (522)
2014.10.12 23:19:12.047 3:     main::HMLAN_Read                    called by fhem.pl (2911)
2014.10.12 23:19:12.049 3:     main::CallFn                        called by fhem.pl (598)
2014.10.12 23:19:12.074 3: CUL_HM set SZ_Ventil1 getConfig
2014.10.12 23:19:15.128 1: PERL WARNING: Use of uninitialized value in division (/) at ./FHEM/10_CUL_HM.pm line 7037.
2014.10.12 23:19:15.130 3: stacktrace:
2014.10.12 23:19:15.131 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7037)
2014.10.12 23:19:15.132 3:     main::CUL_HM_autoReadReady          called by ./FHEM/10_CUL_HM.pm (7012)
2014.10.12 23:19:15.134 3:     main::CUL_HM_appFromQ               called by ./FHEM/10_CUL_HM.pm (2246)
2014.10.12 23:19:15.135 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1054)
2014.10.12 23:19:15.136 3:     main::CUL_HM_Parse                  called by fhem.pl (3048)
2014.10.12 23:19:15.137 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (707)
2014.10.12 23:19:15.139 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (522)
2014.10.12 23:19:15.140 3:     main::HMLAN_Read                    called by fhem.pl (2911)
2014.10.12 23:19:15.141 3:     main::CallFn                        called by fhem.pl (598)
2014.10.12 23:19:15.166 3: CUL_HM set Flur_Thermostat getConfig
2014.10.12 23:19:17.758 1: PERL WARNING: Use of uninitialized value in division (/) at ./FHEM/10_CUL_HM.pm line 7037.
2014.10.12 23:19:17.760 3: stacktrace:
2014.10.12 23:19:17.761 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7037)
2014.10.12 23:19:17.763 3:     main::CUL_HM_autoReadReady          called by ./FHEM/10_CUL_HM.pm (7012)
2014.10.12 23:19:17.764 3:     main::CUL_HM_appFromQ               called by ./FHEM/10_CUL_HM.pm (2246)
2014.10.12 23:19:17.766 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1054)
2014.10.12 23:19:17.767 3:     main::CUL_HM_Parse                  called by fhem.pl (3048)
2014.10.12 23:19:17.769 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (707)
2014.10.12 23:19:17.770 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (522)
2014.10.12 23:19:17.771 3:     main::HMLAN_Read                    called by fhem.pl (2911)
2014.10.12 23:19:17.773 3:     main::CallFn                        called by fhem.pl (598)
2014.10.12 23:19:17.802 3: CUL_HM set KU_Thermostat getConfig
2014.10.12 23:20:10.885 1: PERL WARNING: Use of uninitialized value in division (/) at ./FHEM/10_CUL_HM.pm line 7037.
2014.10.12 23:20:10.887 3: stacktrace:
2014.10.12 23:20:10.888 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7037)
2014.10.12 23:20:10.890 3:     main::CUL_HM_autoReadReady          called by ./FHEM/10_CUL_HM.pm (7012)
2014.10.12 23:20:10.891 3:     main::CUL_HM_appFromQ               called by ./FHEM/10_CUL_HM.pm (2246)
2014.10.12 23:20:10.893 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1054)
2014.10.12 23:20:10.894 3:     main::CUL_HM_Parse                  called by fhem.pl (3048)
2014.10.12 23:20:10.896 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (707)
2014.10.12 23:20:10.897 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (522)
2014.10.12 23:20:10.899 3:     main::HMLAN_Read                    called by fhem.pl (2911)
2014.10.12 23:20:10.900 3:     main::CallFn                        called by fhem.pl (598)
2014.10.12 23:20:10.929 3: CUL_HM set Bad_Thermostat getConfig
2014.10.12 23:20:11.330 1: PERL WARNING: Use of uninitialized value in division (/) at ./FHEM/10_CUL_HM.pm line 7037.
2014.10.12 23:20:11.331 3: stacktrace:
2014.10.12 23:20:11.332 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7037)
2014.10.12 23:20:11.334 3:     main::CUL_HM_autoReadReady          called by ./FHEM/10_CUL_HM.pm (7012)
2014.10.12 23:20:11.335 3:     main::CUL_HM_appFromQ               called by ./FHEM/10_CUL_HM.pm (2246)
2014.10.12 23:20:11.336 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1054)
2014.10.12 23:20:11.338 3:     main::CUL_HM_Parse                  called by fhem.pl (3048)
2014.10.12 23:20:11.339 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (707)
2014.10.12 23:20:11.340 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (522)
2014.10.12 23:20:11.342 3:     main::HMLAN_Read                    called by fhem.pl (2911)
2014.10.12 23:20:11.343 3:     main::CallFn                        called by fhem.pl (598)
2014.10.12 23:20:11.350 3: CUL_HM set WZ_Thermostat statusRequest
mit stacktrace =0 bleibt ja immer noch die Zeile mit ....perl warning... .
FHEM läuft auf einer FritzBox 7390 mit aktueller Firmware 6.20
Hab hier im Forum schon gelesen das es sich nicht zwangsläufig um einen Fehler handels muß, trotzdem würde mich
interessieren was ich gegen diese Meldung machen kann.
vg Jens
fhem-6.1 (configDB+DbLog)  auf ODROID-XU4
martinp876
kannst du ein list des KU_Thermostat schicken?
Newbie
Hallo Martin,
hier die Daten von meinem KU_Thermostat
   DEF        227875
   HMLAN1_MSGCNT 9
   HMLAN1_RAWMSG R239021D1,0001,04017FE3,FF,FFB9,2E8002227875123ABC00
   HMLAN1_RSSI -71
   HMLAN1_TIME 2014-10-18 16:01:29
   IODev      HMLAN1
   LASTInputDev HMLAN1
   MSGCNT     9
   NAME       KU_Thermostat
   NR         119
   STATE      CMDs_pending
   TYPE       CUL_HM
   channel_01 KU_Weather
   channel_02 KU_Climate
   channel_03 KU_WindowRec
   channel_04 KU_Clima
   channel_05 KU_ClimaTeam
   channel_06 KU_remote
   lastMsg    No:2E - t:02 s:227875 d:123ABC 00
   protCmdPend 13 CMDs pending
   protLastRcv 2014-10-18 16:01:29
   protResnd  4 last_at:2014-10-18 16:01:33
   protSnd    7 last_at:2014-10-18 16:01:29
   protState  CMDs_pending
   rssi_at_HMLAN1 avg:-70.88 min:-72 max:-70 lst:-71 cnt:9
   Readings:
     2014-10-18 15:52:47   Activity        alive
     2014-10-18 16:01:29   CommandAccepted yes
     2014-10-12 23:47:11   D-firmware      1.3
     2014-10-12 23:47:11   D-serialNr      KEQ0429261
     2014-10-18 16:01:28   actuator        0
     2014-10-18 16:01:28   batteryLevel    2.7
     2014-10-18 16:01:28   desired-temp    off
     2014-10-18 16:01:28   measured-temp   18.7
     2014-10-18 16:01:33   state           CMDs_pending
     2014-10-16 01:33:17   time-request    -
     Regl_00::
       VAL
   cmdStack:
     ++A001F1000022787500040000000000
     ++A001F100002278750103
     ++A001F1000022787501040000000001
     ++A001F100002278750203
     ++A001F1000022787502040000000001
     ++A001F100002278750303
     ++A001F1000022787503040000000001
     ++A001F100002278750403
     ++A001F1000022787504040000000001
     ++A001F1000022787500040000000007
     ++A001F100002278750503
     ++A001F1000022787505040000000001
     ++A001F100002278750603
     ++A001F1000022787506040000000001
   Helper:
     cSnd       01F1000022787500040000000000
     mId        0095
     rxType     140
     Io:
       newChn     +227875,02,01,00
       nextSend   1413640889.19625
       prefIO
       rxt        2
       vccu       VCCU
       p:
         227875
         00
         01
         00
     Mrssi:
       mNo        2E
       Io:
         HMLAN1     -69
     Prt:
       bErr       0
       sProc      2
       wuReSent   2
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_hmlan1:
         avg        -70.8888888888889
         cnt        9
         lst        -71
         max        -70
         min        -72
     Shregw:
       07         04
   IODev      VCCU
   IOgrp      VCCU
   actCycle   000:10
   actStatus  alive
   autoReadReg 4_reqStatus
   expert     2_full
   firmware   1.3
   group      Heizung
   model      HM-CC-RT-DN
   room       Küche
   serialNr   KEQ0429261
   subType    thermostat
   webCmd     :burstXmit
vg Jens
