HM-CC-RT-DN firmware update durchführen
Begonnen von Andreas_, 07 November 2014, 11:55:38
frank
ZitatDas mit dem changelog-link ist schwierig da gerade die downloads-Seite von eq-3 nicht erreichbar ist. Schon seit gestern....
nö, der fw-check geht trotzdem, obwohl die seite nicht erreichbar ist. auch die generierten changelog/download links.   :)
Changelog:
Version 1.4.001 - 14/10/20
** Bug
  * Modification the radio data interpretation function, if check for CONFIG_SERIALNUMBER it is also necessary to
    check the frame typ for FRAME_CONFIGURATION.
  * Modification the direct link button-switch profile.
Version 1.3.001 - 14/04/24
** Bug
  * Change in config_rt(...,...), parameter configuration is start at parameterposition 20.
    The weekly program transfer to the partner was incorrect if the first timestep > 21:15 o'clock
  * If party-mode bring into action, always the long status-message is send out instead of the
    short status-message. The party-temperature is add as last byte at the long status-message.
Version 1.2.007 - 13/12/02
** Bug
  * If all shutter-contacts cleared from device and window-open-temperature is active, temperature return from
    window-open-temperature to old temperature.
  * Internal window-open detection, send to partners.
  * Central-Order "Boost", "Comfort", "Lowering", "Change Temperature" still running, if Party-Pre-Stage is active.
** ChangeRequest
  * The operation mode still shows in lcd if a thermal control is known.
Version 1.1.001 - 13/09/16
** Bug
  * Correction at takeover the actualtemperature and the settemperature, high-byte shift was not correct.
  * Correction at takeover ccu-radio-order, if internal window-open is detected, it has to reset.
  * Correction by the radio synchronization, if a thermal control is known, the device must synchronize to the
    radio-datapacket actual/set-temperature.
FHEM: 6.0(SVN) => Pi3(buster)
laurine
Zitat von: MarcelK am 10 Februar 2016, 12:14:18
Nein, HMLAN kann das generell nicht.
Mit einem CUL geht das? Ich habe hier noch einen CC1101-USB-Lite 868 MHz ungenutzt rumliegen den ich dafür verwenden könnte.
ph1959de
Zumindest ist es --> hier --< beschrieben.
Peter
