HomeMatic Funk-Statusanzeige - HM-Dis-WM55
Begonnen von Roaster, 14 November 2014, 20:33:48
Koppl
Zitat von: MadMax-FHEM am 03 November 2017, 22:37:19
sub myLineA ($$); entfernen...
Bzw.
package main;
use strict;
use warnings;
use POSIX;
sub myUtils_Initialize($$)
   my ($hash) = @_;
und dann weitere Subs...
siehe: https://wiki.fhem.de/wiki/99_myUtils_anlegen
Welche Fehler es gibt wäre auch hilfreich (gewesen)...
Gruß, Joachim
Sorry habe ich vergessen. Danke für die Hilfe.
Ich hab es geändert. Bekomme aber beim laden folgende Fehler:
2017.11.03 23:34:08 1: PERL WARNING: Subroutine myUtils_Initialize redefined at ./FHEM/99_myUtils.pm line 71.
2017.11.03 23:34:08 1: reload: Error:Modul 99_myUtils deactivated:
Global symbol "$t" requires explicit package name (did you forget to declare "my $t"?) at ./FHEM/99_myUtils.pm line 120.
Global symbol "$c" requires explicit package name (did you forget to declare "my $c"?) at ./FHEM/99_myUtils.pm line 120.
Global symbol "$t" requires explicit package name (did you forget to declare "my $t"?) at ./FHEM/99_myUtils.pm line 121.
Global symbol "$p" requires explicit package name (did you forget to declare "my $p"?) at ./FHEM/99_myUtils.pm line 122.
Unmatched right curly bracket at ./FHEM/99_myUtils.pm line 123, at end of line
syntax error at ./FHEM/99_myUtils.pm line 123, near "}"
2017.11.03 23:34:08 1: PERL WARNING: Useless use of a variable in void context at ./FHEM/99_myUtilsTelefon.pm line 184.
2017.11.03 23:34:09 1: Including fhem.cfg
2017.11.03 23:34:09 1: PERL WARNING: Subroutine myUtils_Initialize redefined at ./FHEM/99_myUtils.pm line 10, <$fh> line 5.
2017.11.03 23:34:09 1: PERL WARNING: Subroutine CurrentTime redefined at ./FHEM/99_myUtils.pm line 17, <$fh> line 5.
2017.11.03 23:34:09 1: PERL WARNING: Subroutine WakeOnLan redefined at ./FHEM/99_myUtils.pm line 24, <$fh> line 5.
2017.11.03 23:34:09 1: PERL WARNING: Subroutine myUtils_Initialize redefined at ./FHEM/99_myUtils.pm line 71, <$fh> line 5.
2017.11.03 23:34:09 1: PERL WARNING: Subroutine myUtil_Define redefined at ./FHEM/99_myUtils.pm line 85, <$fh> line 5.
2017.11.03 23:34:09 1: PERL WARNING: Subroutine myUtil_Undef redefined at ./FHEM/99_myUtils.pm line 89, <$fh> line 5.
2017.11.03 23:34:09 1: PERL WARNING: Subroutine myLineA redefined at ./FHEM/99_myUtils.pm line 94, <$fh> line 5.
2017.11.03 23:34:09 1: PERL WARNING: Subroutine myTh redefined at ./FHEM/99_myUtils.pm line 103, <$fh> line 5.
2017.11.03 23:34:09 1: PERL WARNING: Subroutine myTx redefined at ./FHEM/99_myUtils.pm line 113, <$fh> line 5.
99_myUtils.pm
# $Id: 99_myUtils.pm
package main;
use strict;
use warnings;
use POSIX;
   my ($hash) = @_;
######## Liefert aktueller Zeitstempel ############
sub
CurrentTime()
  return strftime("%H:%M:%S", localtime());
######## WakeOnLan von OpenWRT ############
sub
WakeOnLan
my $mac = shift;
my $ret = "";
$ret .= qx(etherwake -i br-lan $mac);
$ret =~ s,[\r\n]*,,g;    # remove CR from return-string
Log 1, "sendEmail to $mac: $ret";
######## HM-DIS-55WM ############
sub myLineA ($$);
# define counter and counterlimit per press-type
# presstype are 0: btn1 short
# presstype are 1: btn1 long
# presstype are 2: btn2 short
# presstype are 3: btn2 long
my @cnt   ; #init one counter per press
my @cntMax; #number of entries per press
# structure per button/itteration/press
# insert the function to be executes to fill the line with test, color and icon
# Number of itterations can be extended as desired. At least one should be present.
# obey the end of the line (is open) and the number of parameters you send to the funktion
my %lineArr = (0 =>{#============Btn Type 0: Btn1 short
                     0 =>{#-------itteration 0
                           1=>'{myTx("Wohnen:","",'    #  line 1
                          ,2=>'{myTh("","wz_Thermometer",'
                          ,3=>'{myTx("Obergeschoss:","",'
                          ,4=>'{myTh("" ,"og_Thermometer ",'
                          ,5=>'{myTx("Terrasse:","","",'
                          ,6=>'{myTx("","","",'
                    ,1 =>{#-------itteration 1
sub myUtils_Initialize($$) {
   my ($hash) = @_;
# Normal devices
   $hash->{DefFn}   = "myUtil_Define";
   $hash->{UndefFn} = "myUtil_Undef";
   $hash->{AttrList}= $readingFnAttributes;
   @cntMax = (scalar keys %{$lineArr{0}}
             ,scalar keys %{$lineArr{1}}
             ,scalar keys %{$lineArr{2}}
             ,scalar keys %{$lineArr{3}});
   push @cnt,"0" foreach (keys %lineArr);
sub myUtil_Define($$) {########################################################
   my ($hash, $def) = @_;
   return ;
sub myUtil_Undef($$) {#########################################################
   my ($hash, $arg) = @_;
   return undef;
sub myLineA($$){# main entry - do not change!!!
   my ($line,$type) = @_;
   $cnt[$type] = ($cnt[$type] +1)%$cntMax[$type] if ($line == 1); # rotate counter per type
   return (eval $lineArr{$type}{$cnt[$type]}{$line}.'"t")}'
          ,eval $lineArr{$type}{$cnt[$type]}{$line}.'"c")}'
          ,eval $lineArr{$type}{$cnt[$type]}{$line}.'"i")}'
sub myTh($$$){#temp sensor
   # line 't' calculates the text
   # line 'c' calculates the color
   # line 'i' calculates the icon
   my ($p,$e,$t) = @_;
   if($t eq "t"){return $p.ReadingsVal($e,"temperature","no")."-".ReadingsVal($e,"humidity","");  }
   if($t eq "c"){return    ReadingsVal($e,"temperature",0)>20 ? "red" : "blue" }
   if($t eq "i"){return    ReadingsVal($e,"battery",0)    ? "ok"  : "no"  }
   return "nix";
sub myTx($$$$){#text only
   my ($p,$c,$icon,$t) = @_;
   if($t eq "t"){return $p;  }
   if($t eq "c"){return ($c?$c:"white");}
   if($t eq "i"){return ($icon?$icon:"noIcon");}
   return $p;
   if($t eq "i"){return "noIcon";}
   return $p;
1;
MadMax-FHEM
Steht eigentlich alles in den Fehlermeldungen.
Die jetzt im Einzelnen durchzugehen sprengt den Rahmen, dazu sind es zu viele...
Bitte den verlinkten Wiki durchgehen und folgende Dinge (zusätzlich zu den Meldungen) mal beachten:
Die Initialize ist doppelt drin
Du hast Deklaratonen etc. ohne sub...
Eine sub wie folgt:
sub Name($$$) # Parameter optional
my $Variablen; # optional
Funktionsaufrufe; # optional
return; # optional
Und dann evtl. einen neuen Thread zur Problematik myUtils aufmachen, da das hier nichts mit dem Display zu tun hat...
Gruß, Joachim
FHEM PI3 Buster (Test)
connormcl
#452
Hallo Zusammen,
Ich habe das Problem, dass ich bei einer Zeile den Text nicht wegbekomme....
Ich kann einen Text setzen:
set HM-Dis-WM55_Dis_01 displayWM short line1 test red error
Ich kann dann das Icon löschen:
set HM-Dis-WM55_Dis_01 displayWM short line1 test red noIcon
Aber ich kann den Text nicht löschen:
set HM-Dis-WM55_Dis_01 displayWM short line1 nc nc noIcon
Die Zeile mit den "nc" wird von fhem akzeptiert, aber die Readingsbelegung ändert sich nicht und der Text am Display bleibt auch wie zuvor.
Woran kann das liegen? Gibt es eine andere Methode, um den Text einer Zeile oder alle Zeilen zu löschen?
connormcl
Konnte es mittlerweile nach Code-Analyse von 10_HM_CUL.pm selbst in Erfahrung bringen...
Im Wiki ist das falsch/veraltet dargestellt und müsste angepasst werden:
- kein darzustellender Text wird mittels "off" realisiert und nicht mittels "nc" -> "nc" bedeutet "no change"
- Leerzeichen werden nicht mittels "\_" dargestellt; das "\_" wird in ein scharfes S "ß" konvertiert. In der Konvertierungstabelle fehlt das Leerzeichen; -> somit derzeit keine Leerzeichendarstellung, so weit ich das in Erfahrung bringen konnte. (ob das Display Leerzeichen darstellen kann, weiss ich nicht...)
HeikoE
Ich füttere das Display mit dynamischen Daten, in Anlehnung ans Wiki umgesetzt. Da sind Leerzeichen in den übergebenen Strings kein Problem. Die statischen Texte habe ich nie ausprobiert, da sie mir zu unflexibel sind.
Gruß Heiko
connormcl
Soweit ich das Wiki verstanden habe, sind das was ich benutze dynamische Texte (halt direkt ohne das 99_myUtils Framework). Evtl. wird dort eine zusätzliche Leerzeichen-Codierung verwendet, ich sehe sie aber mangels Perl Erfahrung noch nicht.
Ein statischer Text wäre etwas mit txtXX_X:
Zitatset HM-Dis-WM55_Dis_01 displayWM short line2 txt01_1 red error
VolkerGBenner
gibt es eine Zeichenersetzung, um im Display einen Unterstrich "_" darzustellen?
1x  RasPiB3+  mit RPI-RF-MOD und pivccu3
1x HM-TC-IT-WM-W-EU, 1x HM-CC-RT-DN, 1xHM-SEC-SCo,
HM-LC-Sw4-DR, HM-WDS30-OT2-SM, HM-Dis-WM55, 7x HmIP-eTRV-B,...
connormcl
"_" wird vom Display auf "ß" gemappt; ist also selbst nicht darstellbar.
Was geht, ist ein Spiegelstrich "-"
VolkerGBenner
Dann muss ich wohl alle Unterstriche in meinen DeviceNamen per Script vor der Ausgabe in "-" umwandeln lassen. Wird das einfachste sein.😔
HeikoE
Hallo Volker,
die beschriebene Zeichenersetzungen habe ich einfach durch Probieren ermittelt.
Wenn Du sowas wie
   $text =~ s/_/-/g;
in Dein Script einbaust, wird der Unterstrich ersetzt.
Gruß Heiko
meier81
Hallo und guten Abend,
habe mal eine Frage bezüglich des Displays. Habe mir eins zugelegt und wollte dieses nun mittels FHEM benutzen. Bei mir läuft auf dem Raspberry auch piVCCU für die Homematic-Umgebung, habe nämlich auch ein paar HM-IP Devices. Dementsprechend hätte ich nun probiert das Display über den Weg anzusprechen, so wie ich das hier aber verstehe ist hier die Grundlage das ganze über einen CUL direkt anzusprechen.
Deswegen wollte ich von euch mal wissen ob es eine Möglichkeit gibt das ganze auch über piVCCU abzuwickeln oder ob ich mir noch einen CUL zulegen sollte.
Markus
QNAP NAS mit Debian VM, darauf FHEM, debmatic, influxdb2 und Grafana || HB-RF-ETH || WS980 Wetterstation || Xiaomi Mi Robot mit valetudo-FW || Buderus web KM100 || div. Tasmota-Devices || mehrere Homematic-IP und Homematic-Devices
otto
Hallo hätte auch noch ein Frage zum Display,
kann man mehr wie 2 Farben nach Temperatur anzeigenlassen ?
if($t eq "c"){return    ReadingsVal($e,"state",0)>25 ? "red" : "green" }
so mit "blau grün rot" z.B.   ?
Pfriemler
nicht mit einem Readingsval. Aber ich hatte eine eigene Temperatur-Subroutine geschrieben und so erweitert, dass etliche if/elseif in eine Variable den Farbwert ablegten und erst dann ein return kam.
"Änd're nie in fhem.cfg, denn das tut hier allen weh!" *** bookworm@Raspi(5), HMCUN+HMUART, CUL868(SlowRF) für FHT+KS+FS20, miniCUL433, WMBUS, Rademacher DuoFern *** "... kaum macht man es richtig, funktioniert es ..."
