[GELÖST] Zuviele Alive Yes Meldungen im Device log
Begonnen von Rampler, 14 Dezember 2014, 20:30:30
Rampler
Hallo *,
habe erfolgreich meinen Fensterkontakt (optisch) in Betrieb genommen:
Readings:
     2014-12-13 06:34:34   Activity        alive
     2014-12-09 20:44:12   CommandAccepted yes
     2014-12-09 20:44:10   D-firmware      1.0
     2014-12-09 20:44:10   D-serialNr      LEQ0919250
     2014-12-09 20:44:12   PairedTo        0x29A083
     2014-12-09 20:44:12   R-cyclicInfoMsg on
     2014-12-09 20:44:13   R-eventDlyTime  0 s
     2014-12-09 20:44:13   R-msgScPosA     open
     2014-12-09 20:44:13   R-msgScPosB     closed
     2014-12-09 20:44:12   R-pairCentral   0x29A083
     2014-12-09 20:44:12   R-sabotageMsg   on
     2014-12-09 20:44:13   R-sign          on
     2014-12-09 20:44:12   R-transmDevTryMax 6
     2014-12-09 20:44:13   R-transmitTryMax 6
     2014-12-09 20:44:12   RegL_00:        02:01 09:01 0A:29 0B:A0 0C:83 10:01 14:06 00:00
     2014-12-09 20:44:13   RegL_01:        08:01 20:9C 21:00 30:06 00:00
     2014-12-09 20:44:11   aesKeyNbr       00
     2014-12-14 19:27:42   alive           yes
     2014-12-14 19:27:42   battery         ok
     2014-12-14 19:27:42   contact         closed (to HMLAN1)
     2014-12-14 19:27:42   recentStateType info
     2014-12-14 19:27:42   sabotageError   off
     2014-12-14 19:27:42   state           closed
     2014-12-14 16:49:31   trigDst_29A083  noConfig
     2014-12-14 16:49:31   trigger_cnt     160
Mich stört allerdings, das diese Meldung (alive: yes)
ungefähr jede Stunde erscheint.
2014-12-14_16:49:31 WF.tuerkontakt contact: closed (to HMLAN1)
2014-12-14_17:31:39 WF.tuerkontakt alive: yes
2014-12-14_17:31:39 WF.tuerkontakt battery: ok
2014-12-14_17:31:39 WF.tuerkontakt sabotageError: off
2014-12-14_17:31:39 WF.tuerkontakt closed
2014-12-14_17:31:39 WF.tuerkontakt contact: closed (to HMLAN1)
2014-12-14_18:26:54 WF.tuerkontakt alive: yes
2014-12-14_18:26:54 WF.tuerkontakt battery: ok
2014-12-14_18:26:54 WF.tuerkontakt sabotageError: off
2014-12-14_18:26:54 WF.tuerkontakt closed
2014-12-14_18:26:54 WF.tuerkontakt contact: closed (to HMLAN1)
2014-12-14_19:27:42 WF.tuerkontakt alive: yes
2014-12-14_19:27:42 WF.tuerkontakt battery: ok
2014-12-14_19:27:42 WF.tuerkontakt sabotageError: off
2014-12-14_19:27:42 WF.tuerkontakt closed
2014-12-14_19:27:42 WF.tuerkontakt contact: closed (to HMLAN1)
Ich frage in einem notify den open ab, was natürlich ärgerlich ist, wenn das jede Stunde passiert.
Dachte schon das liegt am ActionDetector, doch da habe ich den Tuerkontakt entfernt.
Kann mir jemand sagen, wie ich das Alive verhalten steuern kann ?
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Trixie), ZWAVE, HM-Classic, Matter und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
LuckyDay
warum oder was hindert dich das Attribut
event-on-change-reading .*
bei dem Sensor zu setzten
Rampler
@fhem-hm-knecht
Super Tipp, sieht wesentlich besser aus..
Der Sensor macht wohl weiterhin seine Checks, die Meldungen sind aber weg...
DANKE
