Vorstellung FHEM iOS APP
Begonnen von ak0815, 08 Januar 2015, 12:02:50
Mitch
gerne:
  "Arg":"CUL_HM_Lichtschlauch",
  "Results": [
    "Name":"CUL_HM_Lichtschlauch",
    "PossibleSets":"clear:readings,trigger,register,rssi,msgEvents,all fwUpdate getConfig getRegRaw raw regBulk regSet reset unpair",
    "PossibleAttrs":"verbose:0,1,2,3,4,5 room group comment alias eventMap userReadings do_not_notify:1,0 showtime:1,0 rawToReadable unit expert:0_off,1_on,2_full param ignore:1,0 dummy:1,0 IODev IOList IOgrp actCycle hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger rssiLog:1,0 serialNr firmware .stc .devInfo actStatus autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto msgRepeat hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger aesCommReq:1,0 repPeers peerIDs tempListTmpl levelRange levelMap event-on-change-reading event-on-update-reading event-min-interval stateFormat model:ASH550,ASH550I,CCU-FHEM,CMM,DORMA_BRC-H,DORMA_RC-H,DORMA_atent,HM-CC-RT-DN,HM-CC-RT-DN-BoM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-Dis-TD-T,HM-Dis-WM55,HM-ES-PMSw1-Pl,HM-ES-PMSw1-Pl-DN-R1,HM-ES-PMSw1-Pl-DN-R3,HM-ES-PMSw1-Pl-DN-R4,HM-ES-PMSw1-Pl-DN-R5,HM-ES-TX-WM,HM-LC-BL1-FM,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-Bl1-FM-2,HM-LC-Bl1-SM-2,HM-LC-Bl1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-PL,HM-LC-DIM1T-CV,HM-LC-DIM1T-FM,HM-LC-DIM1T-PL,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2T-SM,HM-LC-Dim1L-CV-2,HM-LC-Dim1L-CV-644,HM-LC-Dim1L-Pl-2,HM-LC-Dim1L-Pl-3,HM-LC-Dim1L-Pl-644,HM-LC-Dim1PWM-CV,HM-LC-Dim1PWM-CV-2,HM-LC-Dim1T-CV-2,HM-LC-Dim1T-CV-644,HM-LC-Dim1T-FM-2,HM-LC-Dim1T-FM-644,HM-LC-Dim1T-Pl-2,HM-LC-Dim1T-Pl-3,HM-LC-Dim1T-Pl-644,HM-LC-Dim1TPBU-FM,HM-LC-Dim1TPBU-FM-2,HM-LC-Dim2L-SM-2,HM-LC-Dim2L-SM-644,HM-LC-Dim2T-SM,HM-LC-Dim2T-SM-2,HM-LC-SW1-BA-PCB,HM-LC-SW1-FM,HM-LC-SW1-PB-FM,HM-LC-SW1-PL,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW2-DR,HM-LC-SW2-FM,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-PCB,HM-LC-SW4-SM,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-Sw1-FM-2,HM-LC-Sw1-Pl-3,HM-LC-Sw1-Pl-DN-R1,HM-LC-Sw1-Pl-DN-R2,HM-LC-Sw1-Pl-DN-R3,HM-LC-Sw1-Pl-DN-R4,HM-LC-Sw1-Pl-DN-R5,HM-LC-Sw1-SM-2,HM-LC-Sw1PBU-FM,HM-LC-Sw2-DR-2,HM-LC-Sw2-FM-2,HM-LC-Sw4-DR-2,HM-LC-Sw4-PCB-2,HM-LC-Sw4-SM-2,HM-LC-Sw4-WM-2,HM-MOD-Em-8,HM-MOD-Re-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-4,HM-RC-4-2,HM-RC-4-B,HM-RC-8,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-Key4-2,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-Sec4-2,HM-SCI-3-FM,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-RHS,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCo,HM-SEC-SD,HM-SEC-SFA-SM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-EP,HM-SEN-MDIR-SM,HM-SWI-3-FM,HM-Sec-Cen,HM-Sen-DB-PCB,HM-Sen-MDIR-O,HM-Sen-MDIR-O-2,HM-Sen-MDIR-WM55,HM-Sen-RD-O,HM-Sen-Wa-Od,HM-Sys-sRP-Pl,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550Tech,IS-WDS-TH-OD-S-R3,IS-WDS-TH-OD-S-R3,KFM-Display,KFM-Sensor,KS550,KS550LC,KS550TECH,KS888,PS-Th-Sens,PS-switch,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,Roto_ZEL-STG-RM-FFK,Roto_ZEL-STG-RM-FSS-UP3,S550IA,Schueco_263-130,Schueco_263-131,Schueco_263-132,Schueco_263-133,Schueco_263-134,Schueco_263-135,Schueco_263-144,Schueco_263-145,Schueco_263-146,Schueco_263-147,Schueco_263-155,Schueco_263-158,Schueco_263-160,Schueco_263-162,Schueco_263-167,Schueco_263-xxx,WDF-solar,WS888 subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,keyMatic,motionAndBtn,motionDetector,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,sensRain,sensor,singleButton,smokeDetector,swi,switch,thermostat,threeStateSensor,tipTronic,virtual,winMatic AlleFenster AlleFenster_map AlleHeizungen AlleHeizungen_map AlleLichter AlleLichter_map CUL_FHTTK_Bad CUL_FHTTK_Bad_map CUL_HM_HM_LC_SW1_FM_2746E0 CUL_HM_HM_LC_SW1_FM_2746E0_map DbLogExclude FHT_all FHT_all_map FensterTueren FensterTueren_map Heizung Heizung_map Licht Licht.Aussen Licht.Aussen_map Licht.Haus Licht.Haus_map Licht.Kueche Licht.Kueche_map Licht_map STATE STATE_map TYPE=CUL_FHTTK TYPE=CUL_FHTTK_map building building_map devStateIcon devStateStyle device_timeout fenster fenster_map fm_fav fm_groups fm_name fm_order fm_type fm_view fp_back1 fp_status icon lightSceneParamsToSave lightSceneRestoreOnlyIfChanged:1,0 map room_map sortby state state_map structexclude webCmd widgetOverride window window_map userattr",
    "Internals": {
      "CFGFN": "",
      "DEF": "2B2AA9",
      "HMLan_MSGCNT": "4",
      "HMLan_RAWMSG": "E2B2AA9,0000,8B0436B4,FF,FFB6,08A45F2B2AA926E9A0806A67000000000008D8FF",
      "HMLan_RSSI": "-74",
      "HMLan_TIME": "2015-01-13 13:08:12",
      "LASTInputDev": "HMLan",
      "MSGCNT": "4",
      "NAME": "CUL_HM_Lichtschlauch",
      "NR": "280",
      "STATE": "CMDs_done",
      "TYPE": "CUL_HM",
      "channel_01": "CUL_HM_Lichtschlauch_Sw",
      "channel_02": "CUL_HM_Lichtschlauch_Pwr",
      "channel_03": "CUL_HM_Lichtschlauch_Sen",
      "lastMsg": "No:4A - t:5E s:2B2AA9 d:000000 806A67000000000008DCFA",
      "protLastRcv": "2015-01-13 16:40:28",
      "protSnd": "4 last_at:2015-01-13 13:08:12",
      "protState": "CMDs_done",
      "rssi_HMLan": "max:-69 lst:-69 cnt:1 avg:-69 min:-69 ",
      "rssi_at_HMLan": "max:-74 lst:-78 cnt:93 avg:-77.25 min:-88 "
    "Readings": {
      ".protLastRcv": { "Value":"2015-01-13 16:40:28", "Time":"2015-01-13 16:40:28" },
      "Activity": { "Value":"alive", "Time":"2015-01-13 12:52:18" },
      "D-firmware": { "Value":"1.6", "Time":"2014-12-17 11:00:13" },
      "D-serialNr": { "Value":"LEQ0472266", "Time":"2014-12-17 11:00:13" },
      "PairedTo": { "Value":"0x26E9A0", "Time":"2014-12-17 11:01:30" },
      "R-intKeyVisib": { "Value":"invisib", "Time":"2014-12-17 11:01:30" },
      "R-localResDis": { "Value":"off", "Time":"2014-12-17 11:01:30" },
      "R-pairCentral": { "Value":"0x26E9A0", "Time":"2014-12-17 11:01:30" },
      "RegL_00:": { "Value":"02:01 0A:26 0B:E9 0C:A0 18:00 00:00", "Time":"2014-12-17 11:01:30" },
      "state": { "Value":"CMDs_done", "Time":"2015-01-13 13:08:12" }
    "Attributes": {
      "DbLogExclude": ".*",
      "IODev": "HMLan",
      "actCycle": "000:10",
      "actStatus": "alive",
      "autoReadReg": "4_reqStatus",
      "expert": "2_full",
      "firmware": "1.6",
      "model": "HM-ES-PMSw1-Pl",
      "serialNr": "LEQ0472266",
      "subType": "powerMeter",
      "webCmd": "getConfig:clear msgEvents"
  "totalResultsReturned":1
kein fhem mehr
OliS.
#91
Ich würde mich sehr gerne als Tester zur Verfügung stellen.
Meine Testgeräte: iPhone 5c, iPhone 6, iPad Mini, iPad 2.
Ich schick dir meine Mail per PM.
Oli
EDIT: Ach ja, hier noch meine Konfiguration: FHEM auf Raspi, Intertechno über Pilight, HM Wandthermostate, HM Heizungsthermostate, HM Bewegungsmelder, Sonos, Denon AVR, Harmony Hub, Dreambox, FB_Callmonitor. Die iOS-Devices laufen alle unter 8.1.2, außer natürlich das iPad 2.
Würde mich über eine Einladung wirklich freuen.
PVE auf MiniPC (N100) mit FHEM, Zigbee2MQTT, Homebridge, DeConz
deluxe41
Einen hab ich noch:
  "Arg":"Schalterkontakt_Flur",
  "Results": [
    "Name":"Schalterkontakt_Flur",
    "PossibleSets":"clear:readings,trigger,register,rssi,msgEvents,all getConfig getRegRaw raw regBulk regSet reset unpair",
    "PossibleAttrs":"verbose:0,1,2,3,4,5 room group comment alias eventMap userReadings do_not_notify:1,0 showtime:1,0 rawToReadable unit expert:0_off,1_on,2_full param ignore:1,0 dummy:1,0 IODev IOList IOgrp actCycle hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger rssiLog:1,0 serialNr firmware .stc .devInfo actStatus autoReadReg:0_off,1_restart,2_pon-restart,3_onChange,4_reqStatus,5_readMissing,8_stateOnly burstAccess:0_off,1_auto msgRepeat hmProtocolEvents:0_off,1_dump,2_dumpFull,3_dumpTrigger aesCommReq:1,0 repPeers peerIDs tempListTmpl levelRange levelMap event-on-change-reading event-on-update-reading event-min-interval stateFormat model:ASH550,ASH550I,CCU-FHEM,CMM,DORMA_BRC-H,DORMA_RC-H,DORMA_atent,HM-CC-RT-DN,HM-CC-RT-DN-BoM,HM-CC-SCD,HM-CC-TC,HM-CC-VD,HM-Dis-TD-T,HM-Dis-WM55,HM-ES-PMSw1-Pl,HM-ES-PMSw1-Pl-DN-R1,HM-ES-PMSw1-Pl-DN-R3,HM-ES-PMSw1-Pl-DN-R4,HM-ES-PMSw1-Pl-DN-R5,HM-ES-TX-WM,HM-LC-BL1-FM,HM-LC-BL1-PB-FM,HM-LC-BL1-SM,HM-LC-Bl1-FM-2,HM-LC-Bl1-SM-2,HM-LC-Bl1PBU-FM,HM-LC-DDC1-PCB,HM-LC-DIM1L-CV,HM-LC-DIM1L-PL,HM-LC-DIM1T-CV,HM-LC-DIM1T-FM,HM-LC-DIM1T-PL,HM-LC-DIM2L-CV,HM-LC-DIM2L-SM,HM-LC-DIM2T-SM,HM-LC-Dim1L-CV-2,HM-LC-Dim1L-CV-644,HM-LC-Dim1L-Pl-2,HM-LC-Dim1L-Pl-3,HM-LC-Dim1L-Pl-644,HM-LC-Dim1PWM-CV,HM-LC-Dim1PWM-CV-2,HM-LC-Dim1T-CV-2,HM-LC-Dim1T-CV-644,HM-LC-Dim1T-FM-2,HM-LC-Dim1T-FM-644,HM-LC-Dim1T-Pl-2,HM-LC-Dim1T-Pl-3,HM-LC-Dim1T-Pl-644,HM-LC-Dim1TPBU-FM,HM-LC-Dim1TPBU-FM-2,HM-LC-Dim2L-SM-2,HM-LC-Dim2L-SM-644,HM-LC-Dim2T-SM,HM-LC-Dim2T-SM-2,HM-LC-SW1-BA-PCB,HM-LC-SW1-FM,HM-LC-SW1-PB-FM,HM-LC-SW1-PL,HM-LC-SW1-PL-OM54,HM-LC-SW1-PL2,HM-LC-SW1-SM,HM-LC-SW1-SM-ATMEGA168,HM-LC-SW2-DR,HM-LC-SW2-FM,HM-LC-SW2-PB-FM,HM-LC-SW2-SM,HM-LC-SW4-BA-PCB,HM-LC-SW4-DR,HM-LC-SW4-PCB,HM-LC-SW4-SM,HM-LC-SW4-SM-ATMEGA168,HM-LC-SW4-WM,HM-LC-Sw1-FM-2,HM-LC-Sw1-Pl-3,HM-LC-Sw1-Pl-DN-R1,HM-LC-Sw1-Pl-DN-R2,HM-LC-Sw1-Pl-DN-R3,HM-LC-Sw1-Pl-DN-R4,HM-LC-Sw1-Pl-DN-R5,HM-LC-Sw1-SM-2,HM-LC-Sw1PBU-FM,HM-LC-Sw2-DR-2,HM-LC-Sw2-FM-2,HM-LC-Sw4-DR-2,HM-LC-Sw4-PCB-2,HM-LC-Sw4-SM-2,HM-LC-Sw4-WM-2,HM-MOD-Em-8,HM-MOD-Re-8,HM-OU-CF-PL,HM-OU-CFM-PL,HM-OU-CM-PCB,HM-OU-LED16,HM-PB-2-FM,HM-PB-2-WM,HM-PB-2-WM55,HM-PB-2-WM55-2,HM-PB-4-WM,HM-PB-4DIS-WM,HM-PB-4DIS-WM-2,HM-PB-6-WM55,HM-PBI-4-FM,HM-RC-12,HM-RC-12-B,HM-RC-12-SW,HM-RC-19,HM-RC-19-B,HM-RC-19-SW,HM-RC-4,HM-RC-4-2,HM-RC-4-B,HM-RC-8,HM-RC-KEY3,HM-RC-KEY3-B,HM-RC-Key4-2,HM-RC-P1,HM-RC-SEC3,HM-RC-SEC3-B,HM-RC-Sec4-2,HM-SCI-3-FM,HM-SEC-KEY,HM-SEC-KEY-O,HM-SEC-KEY-S,HM-SEC-MDIR,HM-SEC-MDIR-2,HM-SEC-RHS,HM-SEC-SC,HM-SEC-SC-2,HM-SEC-SCo,HM-SEC-SD,HM-SEC-SFA-SM,HM-SEC-TIS,HM-SEC-WDS,HM-SEC-WDS-2,HM-SEC-WIN,HM-SEN-EP,HM-SEN-MDIR-SM,HM-SWI-3-FM,HM-Sec-Cen,HM-Sen-DB-PCB,HM-Sen-MDIR-O,HM-Sen-MDIR-O-2,HM-Sen-MDIR-WM55,HM-Sen-RD-O,HM-Sen-Wa-Od,HM-Sys-sRP-Pl,HM-TC-IT-WM-W-EU,HM-WDC7000,HM-WDS10-TH-O,HM-WDS100-C6-O,HM-WDS20-TH-O,HM-WDS30-OT2-SM,HM-WDS30-T-O,HM-WDS40-TH-I,HM-WDS40-TH-I-2,HM-WS550,HM-WS550LCB,HM-WS550LCW,HM-WS550Tech,IS-WDS-TH-OD-S-R3,IS-WDS-TH-OD-S-R3,KFM-Display,KFM-Sensor,KS550,KS550LC,KS550TECH,KS888,PS-Th-Sens,PS-switch,ROTO_ZEL-STG-RM-DWT-10,ROTO_ZEL-STG-RM-FDK,ROTO_ZEL-STG-RM-FEP-230V,ROTO_ZEL-STG-RM-FSA,ROTO_ZEL-STG-RM-FST-UP4,ROTO_ZEL-STG-RM-FWT,ROTO_ZEL-STG-RM-FZS,ROTO_ZEL-STG-RM-FZS-2,ROTO_ZEL-STG-RM-HS-4,ROTO_ZEL-STG-RM-WT-2,Roto_ZEL-STG-RM-FFK,Roto_ZEL-STG-RM-FSS-UP3,S550IA,Schueco_263-130,Schueco_263-131,Schueco_263-132,Schueco_263-133,Schueco_263-134,Schueco_263-135,Schueco_263-144,Schueco_263-145,Schueco_263-146,Schueco_263-147,Schueco_263-155,Schueco_263-158,Schueco_263-160,Schueco_263-162,Schueco_263-167,Schueco_263-xxx,WDF-solar,WS888 subType:AlarmControl,KFM100,THSensor,blindActuator,blindActuatorSol,dimmer,keyMatic,motionAndBtn,motionDetector,outputUnit,powerMeter,powerSensor,pushButton,remote,repeater,sensRain,sensor,singleButton,smokeDetector,swi,switch,thermostat,threeStateSensor,tipTronic,virtual,winMatic alarmDevice alarmSettings devStateIcon devStateStyle fp_Heizkoerper fp_Kinderzimmer fp_Wohnzimmer fp_plotsplan fp_test3 fp_test4 fp_test5 icon sortby webCmd widgetOverride userattr",
    "Internals": {
      "CUL1_MSGCNT": "10",
      "CUL1_RAWMSG": "A0C00A44123F88126342581A200::-55.5:CUL1",
      "CUL1_RSSI": "-55.5",
      "CUL1_TIME": "2015-01-13 16:04:20",
      "DEF": "23F881",
      "LASTInputDev": "hmusb",
      "MSGCNT": "20",
      "NAME": "Schalterkontakt_Flur",
      "NR": "394",
      "TYPE": "CUL_HM",
      "channel_01": "CUL_HM_HM_SCI_3_FM_23F881_Sw_01",
      "channel_02": "CUL_HM_HM_SCI_3_FM_23F881_Sw_02",
      "channel_03": "CUL_HM_HM_SCI_3_FM_23F881_Sw_03",
      "hmusb_MSGCNT": "10",
      "hmusb_RAWMSG": "E23F881,0000,594305EB,FF,FFD7,00A44123F88126342581A200",
      "hmusb_RSSI": "-41",
      "hmusb_TIME": "2015-01-13 16:04:21",
      "lastMsg": "No:00 - t:41 s:23F881 d:263425 81A200",
      "protLastRcv": "2015-01-13 16:04:21",
      "protSnd": "12 last_at:2015-01-13 16:04:19",
      "rssi_at_CUL1": "avg:-53.1 min:-60.5 max:-48.5 lst:-55.5 cnt:10 ",
      "rssi_at_hmusb": "avg:-38.6 min:-41 max:-37 lst:-41 cnt:10 "
    "Readings": {
      "Activity": { "Value":"alive", "Time":"2015-01-13 09:38:59" },
      "CommandAccepted": { "Value":"yes", "Time":"2014-09-13 19:56:55" },
      "D-firmware": { "Value":"1.1", "Time":"2014-09-13 19:56:55" },
      "D-serialNr": { "Value":"KEQ0905193", "Time":"2014-09-13 19:56:55" },
      "PairedTo": { "Value":"0x263425", "Time":"2014-09-13 19:56:55" },
      "R-cyclicInfoMsg": { "Value":"off", "Time":"2014-09-13 19:56:55" },
      "R-pairCentral": { "Value":"0x263425", "Time":"2014-09-13 19:56:55" },
      "R-transmDevTryMax": { "Value":"6", "Time":"2014-09-13 19:56:55" },
      "RegL_00:": { "Value":"02:01 09:00 0A:26 0B:34 0C:25 14:06 00:00", "Time":"2014-09-13 19:56:55" },
      "battery": { "Value":"low", "Time":"2015-01-13 16:04:19" },
      "sabotageAttack": { "Value":"ErrIoAttack cnt:3", "Time":"2014-09-13 19:56:57" },
      "state": { "Value":"CMDs_done", "Time":"2015-01-13 16:04:19" }
    "Attributes": {
      "IODev": "hmusb",
      "IOgrp": "myVCCU:hmusb",
      "actCycle": "028:00",
      "expert": "2_full",
      "firmware": "1.1",
      "model": "HM-SCI-3-FM",
      "room": "CUL_HM",
      "serialNr": "KEQ0905193",
      "subType": "threeStateSensor",
Sent from my iPhone using Tapatalk
Fritzbox 7490 ( USV + Fall Back ), einige HM komponenten,ESPs
Mitch
gerade noch eine Kleinigkeit festgestellt:
Wenn ich das Dashboard nutze, kann ich ja Favoriten dort ablegen. Geht auch z.B. mit Keymatic.
Leider aber nicht mit dem KS300, weil man nicht doppelt klicken kann, weil sofort nach dem ersten Klick geht das Fenster auf, wo auf den Filelog zugegriffen wird.
BTW Filelog, kannst Du auch DBlog implementieren?
EDIT: Kommando zurück, es geht auch über das herz rechts obe, passt!
kein fhem mehr
ak0815
#94
@deluxe41
Danke sind beide auf meiner TODO Liste
FHEM APP für iOS
http://apple.co/1F7gNYu
ak0815
Zitat von: Mitch am 13 Januar 2015, 16:41:25
gerne:
  "Results": [
    "Internals": {
      "CFGFN": "",
      "DEF": "2B2AA9",
      "MSGCNT": "4",
      "NR": "280",
      "TYPE": "CUL_HM",
    "Readings": {
    "Attributes": {
      "IODev": "HMLan",
      "expert": "2_full",
      "firmware": "1.6",
Ist der schon richtig initialisiert?
Bei dir:
Bei mir:
"state": { "Value":"11978.2", "Time":"2015-01-13 16:21:17" },
Andy
FHEM APP für iOS
ak0815
Alles klar :-) Ja DBlog kommt noch. Dauert noch ein bisschen. Mein Raspberry packt das leider nicht. Und ein Hardware Umzug braucht etwas Zeit ;-)
FHEM APP für iOS
Mitch
Bei dir:
Bei mir:
Andy
Ja, geht ohne Probleme
kein fhem mehr
ak0815
Laut Wiki:
CMDs_done: alle Nachrichten übertragen, eine Fehler in diesem Durchgang aufgetreten
Das wird daran liegen.
FHEM APP für iOS
DanHard
wie genau funktioniert das mit dem Attribut SortRoom?
Bekomme immer den Fehler wie im Screenshot! Und wie aktiviere ich JSON.
ak0815
Sortrooms definierst du so:
attr WEB sortRooms Testraum Home Flur Küche Esszimmer Schlafzimmer
Das WEB ist dann der Ansichtsname den du in der APP eintragen musst.
jsonlist2 müsste standardmäßig installiert sein, oder?
Andy
FHEM APP für iOS
MarkusN
Ich finde es sehr beeindruckend wie schnell es hier voran geht. Fehler werden schnell behoben und Features zügig nachgerüstet. Auf euch ruht jetzt meine gesamte Hoffnung für eine brauchbare FHEM-App auf iOS  ;D.
Habe hier noch ein Jsonlist für einen Max-Fensterkontakt
  "Arg":"fenster_wohnzimmer",
  "Results": [
    "Name":"fenster_wohnzimmer",
    "PossibleSets":"wakeUp factoryReset groupid associate:thermostat_kueche,wandthermostat_schlafzimmer,thermostat_robin,thermostat_wohnzimmer,thermostat_schlafzimmer,thermostat_bad deassociate:thermostat_kueche,wandthermostat_schlafzimmer,thermostat_robin,thermostat_wohnzimmer,thermostat_schlafzimmer,thermostat_bad",
    "PossibleAttrs":"verbose:0,1,2,3,4,5 room group comment alias eventMap userReadings IODev do_not_notify:1,0 ignore:0,1 dummy:0,1 showtime:1,0 keepAuto:0,1 scanTemp:0,1 event-on-change-reading event-on-update-reading event-min-interval stateFormat DbLogExclude brenner_starts_per_hour devStateIcon devStateStyle fm_fav fm_groups fm_name fm_order fm_type fm_view fp_obergeschoss icon offset onCounter onCounter_diff room_map sortby struct_anwesenheit struct_anwesenheit_map struct_batterien struct_batterien_map struct_fenster struct_fenster_map struct_gesamtstatus struct_gesamtstatus_map structexclude webCmd widgetOverride struct_gesamtstatus struct_gesamtstatus_map structexclude userattr",
    "Internals": {
      "CHANGED": "null",
      "DEF": "ShutterContact 062421",
      "LASTInputDev": "maxlan",
      "MSGCNT": "9603",
      "NAME": "fenster_wohnzimmer",
      "NR": "23",
      "STATE": "opened",
      "TYPE": "MAX",
      "addr": "062421",
      "backend": "maxlan",
      "maxlan_MSGCNT": "9603",
      "maxlan_TIME": "2015-01-13 17:29:53",
      "rferror": "0",
      "serial": "JEQ0607489",
      "type": "ShutterContact"
    "Readings": {
      "MAXLAN_error": { "Value":"0", "Time":"2015-01-13 17:29:53" },
      "MAXLAN_errorInCommand": { "Value":"", "Time":"2015-01-13 17:29:53" },
      "MAXLAN_initialized": { "Value":"1", "Time":"2015-01-13 17:29:53" },
      "MAXLAN_isAnswer": { "Value":"0", "Time":"2015-01-13 17:29:53" },
      "MAXLAN_valid": { "Value":"1", "Time":"2015-01-13 17:29:53" },
      "battery": { "Value":"ok", "Time":"2015-01-13 17:29:53" },
      "firmware": { "Value":"1.3", "Time":"2015-01-13 17:29:53" },
      "groupid": { "Value":"1", "Time":"2015-01-13 17:29:53" },
      "onoff": { "Value":"1", "Time":"2015-01-13 17:29:53" },
      "state": { "Value":"opened", "Time":"2015-01-13 17:29:53" },
      "testresult": { "Value":"15", "Time":"2015-01-13 17:29:53" }
    "Attributes": {
      "devStateIcon": "closed:signal_Fenster_Offen.off opened:signal_Fenster_Offen.on",
      "event-on-change-reading": ".*",
      "fm_order": "4",
      "fp_obergeschoss": "3,240,0,",
      "group": "group_fenster",
      "icon": "icoLog",
      "room": "Wohnzimmer",
      "struct_batterien": "struct_alle_batterien",
      "struct_batterien_map": "battery",
      "struct_fenster": "struct_alle_fenster",
      "struct_gesamtstatus": "struct_gesamtstatus",
      "struct_gesamtstatus_map": "closed:ok",
      "userattr": "struct_gesamtstatus struct_gesamtstatus_map structexclude"
Status ist entweder opened oder closed.
Danke nochmal!
Grüße,
Markus
ak0815
  "Results": [
    "Internals": {
      "CHANGED": "null",
      "MSGCNT": "9603",
      "NR": "23",
      "STATE": "opened",
      "TYPE": "MAX",
      "addr": "062421",
      "rferror": "0",
    "Readings": {
    "Attributes": {
      "fm_order": "4",
      "icon": "icoLog",
Danke nochmal!
Grüße,
Markus
Wir geben unser bestes :-)
Danke ist auf der TODO Liste.
FHEM APP für iOS
DanHard
Wenn ich beim mir auf einen Raum gehe und dann die Daten der Temeperatursensoren und der IT Steckdosen anschauen will kommt kein Inhalt.
Kann es daran liegen das ich einen rfxtrx433 für alle Daten verwende?
ak0815
kannst du mir mal die Json von dem Raum schicken?
Gruss
Andy
FHEM APP für iOS
