98_WOL: Big update of WOL. Module now uses Blockingcall. By using the new attribute useUdpBroadcast you can specify a Broardcastadress wher the Magicattribute is sent. When using 0 as interal you can ...
Begonnen von System, 19 Januar 2015, 00:00:20
System
98_WOL: Big update of WOL. Module now uses Blockingcall. By using the new attribute useUdpBroadcast you can specify a Broardcastadress wher the Magicattribute is sent. When using 0 as interal you can switch checking for the device offView Changes
Source: 98_WOL: Big update of WOL. Module now uses Blockingcall. By using the new attribute useUdpBroadcast you can specify a Broardcastadress wher the Magicattribute is sent. When using 0 as interal you can ...
