Peer bzw entPeer-Problem. HM-LC-Bl1PBU-FM
Begonnen von Himbeere, 24 Januar 2015, 00:52:26
Himbeere
Hallo. Habe das Problem dass sich irgendwie mein Beamer mit der Leinwand gepeert hat. Beides steuern die HM-LC-Bl1PBU-FM. Ich weiß leider nicht wie ich die wieder "entpeere". :-(
Kann mir jemand (vielleicht sogar mit richtigem Kommando) weiterhelfen?
Danke schonmal
hier noch die Readings meines Leinwandschalters.
ZitatReadings
CommandAccepted
yes
2015-01-11 02:53:50
D-firmware
2.3
2015-01-11 02:50:49
D-serialNr
LEQ0767544
2015-01-11 02:50:49
PairedTo
0xF11234
2015-01-11 02:50:58
R-Beamer_chn-01-lgActionType
jmpToTarget
2015-01-05 20:30:29
R-Beamer_chn-01-lgBlJtDlyOff
refOff
2015-01-05 20:30:29
R-Beamer_chn-01-lgBlJtDlyOn
refOn
2015-01-05 20:30:29
R-Beamer_chn-01-lgBlJtOff
dlyOn
2015-01-05 20:30:29
R-Beamer_chn-01-lgBlJtOn
dlyOff
2015-01-05 20:30:29
R-Beamer_chn-01-lgBlJtRampOff
off
2015-01-05 20:30:29
R-Beamer_chn-01-lgBlJtRampOn
on
2015-01-05 20:30:29
R-Beamer_chn-01-lgBlJtRefOff
off
2015-01-05 20:30:29
R-Beamer_chn-01-lgBlJtRefOn
on
2015-01-05 20:30:29
R-Beamer_chn-01-lgCtDlyOff
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-lgCtDlyOn
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-lgCtOff
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-lgCtOn
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-lgCtRampOff
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-lgCtRampOn
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-lgCtRefOff
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-lgCtRefOn
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-lgCtValHi
100
2015-01-05 20:30:29
R-Beamer_chn-01-lgCtValLo
50
2015-01-05 20:30:29
R-Beamer_chn-01-lgDriveMode
direct
2015-01-05 20:30:29
R-Beamer_chn-01-lgMaxTimeF
0.5 s
2015-01-05 20:30:29
R-Beamer_chn-01-lgMultiExec
on
2015-01-05 20:30:29
R-Beamer_chn-01-lgOffDly
0 s
2015-01-05 20:30:29
R-Beamer_chn-01-lgOffLevel
0 %
2015-01-05 20:30:29
R-Beamer_chn-01-lgOffTime
unused
2015-01-05 20:30:29
R-Beamer_chn-01-lgOffTimeMode
absolut
2015-01-05 20:30:29
R-Beamer_chn-01-lgOnDly
0 s
2015-01-05 20:30:29
R-Beamer_chn-01-lgOnLevel
100 %
2015-01-05 20:30:29
R-Beamer_chn-01-lgOnTime
unused
2015-01-05 20:30:29
R-Beamer_chn-01-lgOnTimeMode
absolut
2015-01-05 20:30:29
R-Beamer_chn-01-shActionType
jmpToTarget
2015-01-05 20:30:29
R-Beamer_chn-01-shBlJtDlyOff
refOff
2015-01-05 20:30:29
R-Beamer_chn-01-shBlJtDlyOn
refOn
2015-01-05 20:30:29
R-Beamer_chn-01-shBlJtOff
dlyOn
2015-01-05 20:30:29
R-Beamer_chn-01-shBlJtOn
dlyOff
2015-01-05 20:30:29
R-Beamer_chn-01-shBlJtRampOff
off
2015-01-05 20:30:29
R-Beamer_chn-01-shBlJtRampOn
on
2015-01-05 20:30:29
R-Beamer_chn-01-shBlJtRefOff
off
2015-01-05 20:30:29
R-Beamer_chn-01-shBlJtRefOn
on
2015-01-05 20:30:29
R-Beamer_chn-01-shCtDlyOff
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-shCtDlyOn
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-shCtOff
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-shCtOn
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-shCtRampOff
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-shCtRampOn
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-shCtRefOff
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-shCtRefOn
geLo
2015-01-05 20:30:29
R-Beamer_chn-01-shCtValHi
100
2015-01-05 20:30:29
R-Beamer_chn-01-shCtValLo
50
2015-01-05 20:30:29
R-Beamer_chn-01-shDriveMode
direct
2015-01-05 20:30:29
R-Beamer_chn-01-shMaxTimeF
unused
2015-01-05 20:30:29
R-Beamer_chn-01-shOffDly
0 s
2015-01-05 20:30:29
R-Beamer_chn-01-shOffLevel
0 %
2015-01-05 20:30:29
R-Beamer_chn-01-shOffTime
unused
2015-01-05 20:30:29
R-Beamer_chn-01-shOffTimeMode
absolut
2015-01-05 20:30:29
R-Beamer_chn-01-shOnDly
0 s
2015-01-05 20:30:29
R-Beamer_chn-01-shOnLevel
100 %
2015-01-05 20:30:29
R-Beamer_chn-01-shOnTime
unused
2015-01-05 20:30:29
R-Beamer_chn-01-shOnTimeMode
absolut
2015-01-05 20:30:29
R-confBtnTime
permanent
2014-12-12 20:10:13
R-driveDown
50 s
2015-01-11 02:50:59
R-driveTurn
0.5 s
2014-12-12 20:10:14
R-driveUp
50 s
2015-01-11 02:50:59
R-intKeyVisib
invisib
2015-01-11 02:50:58
R-localResDis
off
2014-12-12 20:10:13
R-pairCentral
0xF11234
2015-01-11 02:50:58
R-refRunCounter
0
2015-01-03 02:07:47
R-sign
off
2015-01-03 02:07:47
R-statusInfoMinDly
2 s
2014-12-12 20:10:14
R-statusInfoRandom
1 s
2014-12-12 20:10:14
R-transmitTryMax
6
2015-01-03 02:07:47
RegL_00:
02:01 0A:F1 0B:12 0C:34 15:FF 18:00 00:00
2015-01-11 02:50:58
RegL_01:
08:00 09:00 0A:00 0B:01 0C:F4 0D:01 0E:F4 0F:05 10:00 30:06 57:24 00:00
2015-01-11 02:50:59
deviceMsg
52 (to CUL_HM)
2015-01-11 02:53:50
level
52
2015-01-11 02:53:50
motor
down:52
2015-01-11 02:53:50
pct
52
2015-01-11 02:53:50
recentStateType
ack
2015-01-11 02:53:50
state
52
2015-01-11 02:53:50
timedOn
off
[/size][/size]
myrave
http://www.fhemwiki.de/wiki/Homematic_Peering_Beispiele
Zitatset <sensChan> peerChan 0 <actChan> [single|dual] [set|unset]
Zum Entpeeren dann hinten "single unset both" wählen und das Peering sollte weg sein.
Himbeere
#2
ich checks nicht. was ist in meinem Fall der sensChan und was der ActChan?
set Leinwand peerChan 0 Beamer single unset both
darauf folgt:
ZitatUnknown argument peerChan, choose one of clear:readings,trigger,register,rssi,msgEvents,all down fwUpdate getConfig getRegRaw getSerial getVersion inhibit:on,off off on pair pct:slider,0,1,100 peerBulk peerIODev press raw regBulk regSet reset sign:on,off statusRequest stop toggle unpair up
frank
ZitatBeides steuern die HM-LC-Bl1PBU-FM. Ich weiß leider nicht wie ich die wieder "entpeere".
du hast also 2 bl1pbu gegenseitig gepeert? das sind ja 2 aktoren. wie hast du das geschafft? zur not jeweils resetten.
FHEM: 6.0(SVN) => Pi3(buster)
martinp876
in so einem .... seltsamen .... fall kannst du es roh machen (oder einmal einen reset?)
set Leinwand peerBulk <id wie in attr peerIDs beschrieben> unset
set Beamer peerBulk <id wie in attr peerIDs beschrieben> unset
bitte nicht die "00000000" "unsetten"
Himbeere
leider ist ausser der 00000000 keine andere peerID hinterlegt. wie finde ich die noch raus?
martinp876
Wenn die daten erfolgreich gelesen sind - worauf das 00000000 hindeuted - und sonst keine werte drin stehen, ist auch nichts gepeert.
