Update Darstellung
Begonnen von Tom111, 27 Januar 2015, 08:37:21
Tom111
Wohl nicht gerade ein Fehler, aber ich wollte nur mal darauf aufmerksam machen.
So sieht mein Updateverlauf aus :
Events (global only):
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:03 Global global RMDIR: ./restoreDir/2015-01-23
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:03 Global global UPD ./CHANGED
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:03 Global global UPD FHEM/10_CUL_HM.pm
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:04 Global global UPD FHEM/23_KOSTALPIKO.pm
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:04 Global global UPD FHEM/42_SYSMON.pm
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:04 Global global UPD FHEM/70_ENIGMA2.pm
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:05 Global global UPD FHEM/HMConfig.pm
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:05 Global global UPD docs/commandref.html
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:06 Global global UPD docs/commandref_DE.html
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:07 Global global UPD www/pgm2/ios7style.css
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:07 Global global New entries in the CHANGED file:
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:07 Global global update finished, "shutdown restart" is needed to activate the changes.
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:08 Global global
#FHEMWEB:WEB<<$('#saveCheck').css('visibility','hidden')<< 2015-01-26 11:21:10 Global global fheminfo server response: ==> ok
FHEM 5.9 auf Raspberry Pi - 3B+ - Stretch-5.10.88+ | CUL868 CC1101 - USB - Lite module - V3 FW 1.67
Fritz!Box 7490 OS 07.29 / Fritz!Dect200 / Fritz!Powerline 546E
FS20ST-4/ FS20 DI-5/ FS20LS/ FS20 PIRI-2-KU/ FS20 TFK/ FS20S4A/FS20 SU-3/FS20 S20-3
HMS100TF/FHT80TF-2/ASH2200/S300TH/MiLight-Bridge V
Gefixt, ab morgen per update
Hallo Rudolf,
da ja sicher die meisten sich nur melden wenn es Probleme gibt:
Bei mir lief das Update ohne jeden Fehler!
Save Config jetzt mit Hinweisen  :) 8) Super!
Und ich wollte mal Danke sagen! Für das tolle System!
Tom111
