(gelöst) Fehler autocreate?
Begonnen von P.A.Trick, 29 Januar 2015, 16:54:46
P.A.Trick
Ich habe heute beim Anlernen eines MAX! Fensterkontaktes folgenden Warnhinweis bekommen!
2015.01.29 16:51:44.403 3: CUL_MAX_Parse: Pairing device 0ff6fd of type ShutterContact with serial LEQ0792663
2015.01.29 16:51:44.480 2: autocreate: define MAX_0ff6fd MAX ShutterContact 0ff6fd
2015.01.29 16:51:44.514 2: autocreate: define FileLog_MAX_0ff6fd FileLog ./log/MAX_0ff6fd-%Y.log MAX_0ff6fd
2015.01.29 16:51:44.517 1: PERL WARNING: Use of uninitialized value $param in string eq at fhem.pl line 1327.
2015.01.29 16:51:44.517 3: stacktrace:
2015.01.29 16:51:44.518 3:     main::__ANON__                      called by fhem.pl (1327)
2015.01.29 16:51:44.518 3:     main::CommandSave                   called by ./FHEM/98_autocreate.pm (242)
2015.01.29 16:51:44.519 3:     main::autocreate_Notify             called by ./FHEM/98_apptime.pm (104)
2015.01.29 16:51:44.520 3:     main::apptime_getTiming             called by ./FHEM/98_apptime.pm (74)
2015.01.29 16:51:44.520 3:     main::CallFn                        called by fhem.pl (2883)
2015.01.29 16:51:44.520 3:     main::DoTrigger                     called by fhem.pl (3154)
2015.01.29 16:51:44.521 3:     main::Dispatch                      called by ./FHEM/14_CUL_MAX.pm (344)
2015.01.29 16:51:44.521 3:     main::CUL_MAX_Parse                 called by fhem.pl (3097)
2015.01.29 16:51:44.522 3:     main::Dispatch                      called by ./FHEM/00_CUL.pm (917)
2015.01.29 16:51:44.522 3:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (782)
2015.01.29 16:51:44.523 3:     main::CUL_Read                      called by ./FHEM/98_apptime.pm (104)
2015.01.29 16:51:44.523 3:     main::apptime_getTiming             called by ./FHEM/98_apptime.pm (74)
2015.01.29 16:51:44.524 3:     main::CallFn                        called by fhem.pl (608)
2015.01.29 16:51:46.493 1: Perfmon: possible freeze starting at 16:51:45, delay is 1.493
2015.01.29 16:51:49.179 3: CUL_MAX_Parse: Pairing device 0ff6fd of type ShutterContact with serial LEQ0792663
Ich bin mir nicht sicher, woher der Fehler genau stammt, vermute aber mal die autocreate Funktion, oder?
FHEM + Homeassistant - meine HW -> https://www.trinityonline.de/hardware/
Eigentlich ein "Fehler" meiner "save ?" Erweiterung. Habs gefixt, ab morgen per update.
P.A.Trick
Klasse vielen lieben Dank!
