Alternative culfw
Begonnen von bjoernh, 15 März 2015, 12:01:06
ffdec
Hallo, ich habe zwei Probleme:
- Hideki (TE923)-Sensoren werden nicht erkannt
- weitere Klimasensoren liefern falsche Feuchte-Werte
Kann mir geholfen werden?
2016.10.01 17:07:16 4: CUL_Parse: nanoCUL s4C10C4F000E3;  400: 4080
2016.10.01 17:07:16 5: nanoCUL dispatch s4C10C4F000E3;  400: 4080
2016.10.01 17:07:16 5: nanoCUL dispatch P7#4C10C4F000
2016.10.01 17:07:16 4: SD_WS07_Parse  SD_WS07 (P7#4C10C4F000) length: 10
2016.10.01 17:07:16 5: SD_WS07 converted to bits: 01001100 0 001 000011000100 1111 00000000
2016.10.01 17:07:16 4: SD_WS07_T decoded protocolid: 7 sensor id=4C, channel=2, temp=19.6, hum=0, bat=low
2016.10.01 17:07:16 4: nanoCUL using longid: 1 model: SD_WS07_T
2016.10.01 17:07:38 3: CUL_HM set TH_BAD statusRequest
2016.10.01 17:07:39 5: CUL/RAW: /s52200CE100EA;  480: 9184
2016.10.01 17:07:39 4: CUL_Parse: nanoCUL s52200CE100EA;  480: 9184
2016.10.01 17:07:39 5: nanoCUL dispatch s52200CE100EA;  480: 9184
2016.10.01 17:07:39 4: CUL_TCM97001 using longid: 1 model: NC_WS
2016.10.01 17:07:56 5: CUL/RAW: /tA076690694D9
2016.10.01 17:07:56 4: CUL_Parse: nanoCUL tA076690694D9 -93.5
2016.10.01 17:07:56 5: nanoCUL dispatch TXA076690694
2016.10.01 17:07:56 1: Error dewpoint: humidity invalid: 0
2016.10.01 17:08:02 5: CUL/RAW: /omAAAAAAA8DC
2016.10.01 17:08:02 4: CUL_Parse: nanoCUL omAAAAAAA8DC
2016.10.01 17:08:02 5: nanoCUL dispatch omAAAAAAA8DC
2016.10.01 17:08:02 5: CUL_REDIRECT (mAAAAAAA8DC) length: 11 RSSI: -92
2016.10.01 17:08:02 5: CUL_REDIRECT (mAAAAAAA8DC) match Manchester COODE length: 11
2016.10.01 17:08:02 5: CUL_REDIRECT decode Oregon 2 (AAAAAAA8DC)
2016.10.01 17:08:02 5: bitdata: 1010101010101010101010101010100011011100
2016.10.01 17:08:02 5: CUL_REDIRECT decode Oregon 3 (AAAAAAA8DC)
2016.10.01 17:08:02 5: CUL_REDIRECT decode Hideki (AAAAAAA8DC)
2016.10.01 17:08:02 5: nanoCUL: search in 1010101010101010101010101010100011011100
2016.10.01 17:08:02 5: protocol does not match, ignore received package (AAAAAAA8DC) Reason: Not a hideki protocol
2016.10.01 17:08:14 5: CUL/RAW: /s52200CE100EB;  432: 9216
HMUARTLGW HMLAN Alarmanlage ZPumpe VCONTROL Viessmann 333-F MySensors CO2 Floorplan IT Raspberry 3 CC1101 Firmata Arduino nanoCUL868
ArduPino
Frage zu einer Einstellung des nanoCUL:
In einer nanoCUL Selbstbau Anleitung habe ich dies gefunden
culfw/clib/rf_send.h Zeile 17
#define MAX_CREDIT 900       // max 9 seconds burst / 25% of the hourly budget
ändern in
#define MAX_CREDIT 3600       // max 9 seconds burst / 100% of the hourly budget
Damit wird das zulässige Limit auf das Maximale gestellt.
Wie ist das hier bei der a-cul FW ? Kann (und soll) man das auch ändern ?
Hat das etwas mit dieser 1% Regelung zu tun ? Betrifft das nur den CUL selber wenn dieser sendet oder auch wenn er empfängt ?
Burny4600
Bekomme immer wieder Temperatur und Feuchte Einträge im LOG die nicht zugeordnen werden.
Kommen die vom nanoCUL?
2016.10.02 14:28:06.894 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:06.895 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:06.930 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:06.931 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:06.932 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:07.398 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:07.401 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:07.590 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:07.664 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:07.844 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:07.847 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:14.316 5: CUL/RAW: /omD
2016.10.02 14:28:14.318 5: CUL/RAW: omD/624483B8340C
2016.10.02 14:28:14.320 5: CUL/RAW: omD624483B8340C/A03803B80DE
2016.10.02 14:28:14.322 5: CUL/RAW: omD624483B8340CA03803B80DE
2016.10.02 14:28:14.323 4: CUL_Parse: nanoCUL433 omD624483B8340CA03803B80DE
2016.10.02 14:28:14.325 5: nanoCUL433 dispatch omD624483B8340CA03803B80DE
2016.10.02 14:28:14.329 5: CUL_REDIRECT (mD624483B8340CA03803B80DE) length: 25 RSSI: -91
2016.10.02 14:28:14.330 5: CUL_REDIRECT (mD624483B8340CA03803B80DE) match Manchester COODE length: 25
2016.10.02 14:28:14.330 5: CUL_REDIRECT decode Oregon 2 (D624483B8340CA03803B80DE)
2016.10.02 14:28:14.331 5: bitdata: 110101100010010001001000001110111000001101000000110010100000001110000000001110111000000011011110
2016.10.02 14:28:14.332 5: CUL_REDIRECT decode Oregon 3 (D624483B8340CA03803B80DE)
2016.10.02 14:28:14.333 5: bitdata: 110101100010010001001000001110111000001101000000110010100000001110000000001110111000000011011110
2016.10.02 14:28:14.334 5: CUL_REDIRECT decode Hideki (D624483B8340CA03803B80DE)
2016.10.02 14:28:14.334 5: nanoCUL433: search in 110101100010010001001000001110111000001101000000110010100000001110000000001110111000000011011110
2016.10.02 14:28:14.335 5: protocol does not match, ignore received package (D624483B8340CA03803B80DE) Reason: Not a hideki protocol
2016.10.02 14:28:28.861 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:28.862 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:28.863 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:28.898 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:28.899 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:28.900 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:29.366 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:29.367 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:29.368 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:29.403 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:29.404 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:29.405 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:29.866 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:29.868 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:29.868 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:29.903 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:29.904 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:29.905 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:30.371 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:30.372 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:30.373 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:30.408 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:30.409 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:30.410 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:30.872 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:30.873 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:30.873 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:30.908 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:30.909 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:30.910 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:31.377 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:31.378 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:31.378 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:31.413 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:31.414 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:31.415 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:31.877 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:31.878 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:31.879 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:31.914 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:31.915 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:31.915 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:32.382 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:32.383 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:32.384 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:32.419 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:32.420 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:32.420 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:32.882 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:32.884 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:32.884 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:32.919 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:32.920 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:32.921 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:33.388 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:33.389 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:33.389 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:33.424 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:33.425 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:33.426 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:33.991 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:33.992 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:33.992 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:34.027 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:34.028 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:34.029 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:34.496 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:34.497 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:34.497 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:34.532 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:34.533 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:34.534 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:34.996 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:34.997 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:34.998 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:35.032 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:35.034 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:35.034 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:35.501 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:35.502 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:35.503 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:35.538 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:35.539 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:35.539 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:36.001 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:36.002 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:36.003 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:36.050 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:36.052 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:36.053 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:36.515 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:36.516 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:36.517 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:36.563 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:36.564 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:36.565 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:37.015 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:37.017 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:37.018 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:37.063 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:37.065 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:37.066 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:37.522 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:37.523 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:37.524 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:37.570 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:37.571 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:37.572 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:38.021 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:38.023 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:38.024 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:38.118 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:38.119 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:38.120 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:39.541 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4584.
2016.10.02 14:28:39.608 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4584.
2016.10.02 14:28:39.676 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4584.
2016.10.02 14:28:39.728 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4584.
2016.10.02 14:28:39.783 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4584.
2016.10.02 14:28:40.852 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:40.853 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:40.854 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:41.227 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:41.228 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:41.229 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:41.526 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:41.527 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:41.528 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:41.973 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:41.974 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:41.975 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:42.386 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:42.387 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:42.388 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:42.502 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:42.503 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:42.504 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:43.623 5: CUL/RAW: /omA8C1808DE18BA1FFD460C046F0C5D0FFEA3060237862E80029
2016.10.02 14:28:43.624 4: CUL_Parse: nanoCUL433 omA8C1808DE18BA1FFD460C046F0C5D0FFEA3060237862E80029
2016.10.02 14:28:43.625 5: nanoCUL433 dispatch omA8C1808DE18BA1FFD460C046F0C5D0FFEA3060237862E80029
2016.10.02 14:28:43.629 5: CUL_REDIRECT (mA8C1808DE18BA1FFD460C046F0C5D0FFEA3060237862E80029) length: 51 RSSI: -53.5
2016.10.02 14:28:43.630 5: CUL_REDIRECT (mA8C1808DE18BA1FFD460C046F0C5D0FFEA3060237862E80029) match Manchester COODE length: 51
2016.10.02 14:28:43.631 5: CUL_REDIRECT decode Oregon 2 (A8C1808DE18BA1FFD460C046F0C5D0FFEA3060237862E80029)
2016.10.02 14:28:43.632 5: bitdata: 10101000110000011000000010001101111000011000101110100001111111111101010001100000110000000100011011110000110001011101000011111111111010100011000001100000001000110111100001100010111010000000000000101001
2016.10.02 14:28:43.633 5: CUL_REDIRECT decode Oregon 3 (A8C1808DE18BA1FFD460C046F0C5D0FFEA3060237862E80029)
2016.10.02 14:28:43.633 5: bitdata: 10101000110000011000000010001101111000011000101110100001111111111101010001100000110000000100011011110000110001011101000011111111111010100011000001100000001000110111100001100010111010000000000000101001
2016.10.02 14:28:43.634 5: OSV3 protocol detected (A8C1808DE18BA1FFD460C046F0C5D0FFEA3060237862E80029)
2016.10.02 14:28:43.635 5: nanoCUL433: byte in order 01010001
2016.10.02 14:28:43.635 5: nanoCUL433: byte reversed 10001010 , as hex: 8A
2016.10.02 14:28:43.636 5: nanoCUL433: byte in order 10000011
2016.10.02 14:28:43.637 5: nanoCUL433: byte reversed 11000001 , as hex: C1
2016.10.02 14:28:43.637 5: nanoCUL433: byte in order 00000001
2016.10.02 14:28:43.638 5: nanoCUL433: byte reversed 10000000 , as hex: 80
2016.10.02 14:28:43.639 5: nanoCUL433: byte in order 00011011
2016.10.02 14:28:43.639 5: nanoCUL433: byte reversed 11011000 , as hex: D8
2016.10.02 14:28:43.640 5: nanoCUL433: byte in order 11000011
2016.10.02 14:28:43.641 5: nanoCUL433: byte reversed 11000011 , as hex: C3
2016.10.02 14:28:43.641 5: nanoCUL433: byte in order 00010111
2016.10.02 14:28:43.642 5: nanoCUL433: byte reversed 11101000 , as hex: E8
2016.10.02 14:28:43.643 5: nanoCUL433: byte in order 01000011
2016.10.02 14:28:43.643 5: nanoCUL433: byte reversed 11000010 , as hex: C2
2016.10.02 14:28:43.644 5: nanoCUL433: byte in order 11111111
2016.10.02 14:28:43.645 5: nanoCUL433: byte reversed 11111111 , as hex: FF
2016.10.02 14:28:43.645 5: nanoCUL433: byte in order 10101000
2016.10.02 14:28:43.646 5: nanoCUL433: byte reversed 00010101 , as hex: 15
2016.10.02 14:28:43.647 5: nanoCUL433: byte in order 11000001
2016.10.02 14:28:43.647 5: nanoCUL433: byte reversed 10000011 , as hex: 83
2016.10.02 14:28:43.648 5: nanoCUL433: byte in order 10000000
2016.10.02 14:28:43.649 5: nanoCUL433: byte reversed 00000001 , as hex: 1
2016.10.02 14:28:43.649 5: nanoCUL433: byte in order 10001101
2016.10.02 14:28:43.650 5: nanoCUL433: byte reversed 10110001 , as hex: B1
2016.10.02 14:28:43.650 5: nanoCUL433: byte in order 11100001
2016.10.02 14:28:43.651 5: nanoCUL433: byte reversed 10000111 , as hex: 87
2016.10.02 14:28:43.652 5: nanoCUL433: byte in order 10001011
2016.10.02 14:28:43.652 5: nanoCUL433: byte reversed 11010001 , as hex: D1
2016.10.02 14:28:43.653 5: nanoCUL433: byte in order 10100001
2016.10.02 14:28:43.654 5: nanoCUL433: byte reversed 10000101 , as hex: 85
2016.10.02 14:28:43.654 5: nanoCUL433: byte in order 11111111
2016.10.02 14:28:43.655 5: nanoCUL433: byte reversed 11111111 , as hex: FF
2016.10.02 14:28:43.656 5: nanoCUL433: byte in order 11010100
2016.10.02 14:28:43.656 5: nanoCUL433: byte reversed 00101011 , as hex: 2B
2016.10.02 14:28:43.657 5: nanoCUL433: byte in order 01100000
2016.10.02 14:28:43.658 5: nanoCUL433: byte reversed 00000110 , as hex: 6
2016.10.02 14:28:43.658 5: nanoCUL433: byte in order 11000000
2016.10.02 14:28:43.659 5: nanoCUL433: byte reversed 00000011 , as hex: 3
2016.10.02 14:28:43.659 5: nanoCUL433: byte in order 01000110
2016.10.02 14:28:43.660 5: nanoCUL433: byte reversed 01100010 , as hex: 62
2016.10.02 14:28:43.661 5: nanoCUL433: byte in order 11110000
2016.10.02 14:28:43.662 5: nanoCUL433: byte reversed 00001111 , as hex: F
2016.10.02 14:28:43.662 5: nanoCUL433: byte in order 11000101
2016.10.02 14:28:43.663 5: nanoCUL433: byte reversed 10100011 , as hex: A3
2016.10.02 14:28:43.664 5: nanoCUL433: byte in order 11010000
2016.10.02 14:28:43.664 5: nanoCUL433: byte reversed 00001011 , as hex: B
2016.10.02 14:28:43.665 5: CUL_REDIRECT: OSV3 protocol converted to hex: (B88AC180D8C3E8C2FF1583 1B187D185FF2B 6 362 FA3 B) with length (192) bits
2016.10.02 14:28:43.666 5: nanoCUL433 Dispatch now to Oregon Module.
2016.10.02 14:28:43.667 5: converted Data to (B88AC180D8C3E8C2FF1583 1B187D185FF2B 6 362 FA3 B)
2016.10.02 14:28:43.668 5: nanoCUL433 dispatch B88AC180D8C3E8C2FF1583 1B187D185FF2B 6 362 FA3 B
2016.10.02 14:28:43.715 3: nanoCUL433: Unknown code B88AC180D8C3E8C2FF1583 1B187D185FF2B 6 362 FA3 B, help me!
2016.10.02 14:28:43.716 5: CUL_REDIRECT decode Hideki (A8C1808DE18BA1FFD460C046F0C5D0FFEA3060237862E80029)
2016.10.02 14:28:43.717 5: nanoCUL433: search in 10101000110000011000000010001101111000011000101110100001111111111101010001100000110000000100011011110000110001011101000011111111111010100011000001100000001000110111100001100010111010000000000000101001
2016.10.02 14:28:43.718 5: protocol does not match, ignore received package (A8C1808DE18BA1FFD460C046F0C5D0FFEA3060237862E80029) Reason: Not a hideki protocol
2016.10.02 14:28:44.047 1: ModbusTCPServer_Parse: incomplete frame received, sent: SimpleWrite [00 50 00 00 00 06] 0A 04 00 50 00 02, received 7 bytes
2016.10.02 14:28:45.285 1: ModbusTCPServer_Parse: incomplete frame received, sent: SimpleWrite [01 6C 00 00 00 06] 0A 04 01 6C 00 02, received 7 bytes
2016.10.02 14:28:46.635 5: CUL/RAW: /tA01
2016.10.02 14:28:46.637 5: CUL/RAW: tA01/1649648F1
2016.10.02 14:28:46.638 4: CUL_Parse: nanoCUL433 tA011649648F1 -81.5
2016.10.02 14:28:46.640 5: nanoCUL433 dispatch TXA011649648
2016.10.02 14:28:46.760 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:46.761 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:46.762 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:47.513 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:47.515 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:47.516 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:47.750 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:47.751 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:47.752 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:47.991 1: Error: T: 15.4 H: 94 BAT: ok has no TYPE
2016.10.02 14:28:47.992 1: Error: T: 16.1 H: 92 BAT: ok has no TYPE
2016.10.02 14:28:47.993 1: Error: T: 22.8 H: 37 BAT: ok has no TYPE
2016.10.02 14:28:53.796 5: CUL/RAW: /omEFFFFF5497F9E3FEFBF8FFF1
2016.10.02 14:28:53.797 4: CUL_Parse: nanoCUL433 omEFFFFF5497F9E3FEFBF8FFF1
2016.10.02 14:28:53.799 5: nanoCUL433 dispatch omEFFFFF5497F9E3FEFBF8FFF1
2016.10.02 14:28:53.804 5: CUL_REDIRECT (mEFFFFF5497F9E3FEFBF8FFF1) length: 25 RSSI: -81.5
2016.10.02 14:28:53.805 5: CUL_REDIRECT (mEFFFFF5497F9E3FEFBF8FFF1) match Manchester COODE length: 25
2016.10.02 14:28:53.806 5: CUL_REDIRECT decode Oregon 2 (EFFFFF5497F9E3FEFBF8FFF1)
2016.10.02 14:28:53.807 5: bitdata: 111011111111111111111111010101001001011111111001111000111111111011111011111110001111111111110001
2016.10.02 14:28:53.808 5: CUL_REDIRECT decode Oregon 3 (EFFFFF5497F9E3FEFBF8FFF1)
2016.10.02 14:28:53.809 5: bitdata: 111011111111111111111111010101001001011111111001111000111111111011111011111110001111111111110001
2016.10.02 14:28:53.809 5: OSV3 protocol detected (EFFFFF5497F9E3FEFBF8FFF1)
2016.10.02 14:28:53.810 5: nanoCUL433: byte in order 01010100
2016.10.02 14:28:53.811 5: nanoCUL433: byte reversed 00101010 , as hex: 2A
2016.10.02 14:28:53.812 5: nanoCUL433: byte in order 10010111
2016.10.02 14:28:53.813 5: nanoCUL433: byte reversed 11101001 , as hex: E9
2016.10.02 14:28:53.813 5: nanoCUL433: byte in order 11111001
2016.10.02 14:28:53.814 5: nanoCUL433: byte reversed 10011111 , as hex: 9F
2016.10.02 14:28:53.815 5: nanoCUL433: byte in order 11100011
2016.10.02 14:28:53.816 5: nanoCUL433: byte reversed 11000111 , as hex: C7
2016.10.02 14:28:53.816 5: nanoCUL433: byte in order 11111110
2016.10.02 14:28:53.817 5: nanoCUL433: byte reversed 01111111 , as hex: 7F
2016.10.02 14:28:53.818 5: nanoCUL433: byte in order 11111011
2016.10.02 14:28:53.819 5: nanoCUL433: byte reversed 11011111 , as hex: DF
2016.10.02 14:28:53.819 5: nanoCUL433: byte in order 11111000
2016.10.02 14:28:53.820 5: nanoCUL433: byte reversed 00011111 , as hex: 1F
2016.10.02 14:28:53.821 5: nanoCUL433: byte in order 11111111
2016.10.02 14:28:53.821 5: nanoCUL433: byte reversed 11111111 , as hex: FF
2016.10.02 14:28:53.822 5: CUL_REDIRECT: ERROR: To short: OSV3 protocol converted to hex: (402AE99FC77FDF1FFF) with length (72) bits
2016.10.02 14:28:53.823 5: CUL_REDIRECT decode Hideki (EFFFFF5497F9E3FEFBF8FFF1)
2016.10.02 14:28:53.824 5: nanoCUL433: search in 111011111111111111111111010101001001011111111001111000111111111011111011111110001111111111110001
2016.10.02 14:28:53.825 5: protocol does not match, ignore received package (EFFFFF5497F9E3FEFBF8FFF1) Reason: Not a hideki protocol
2016.10.02 14:28:57.448 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4584.
LG Chris
Raspberry Pi 2-5, Bullseye Lite, Bookworm Lite
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
tkaiser
Hallo
Ich habe ein problem die a-cul FW zu instalieren was daran liegt das ich der totale Anfänger bin, könnte mir jemand eine
Schritt für Schritt Anleitung geben.
Ich habe einen PI3 und einen CUL 868
Ich habe noch eine alte TCM Wetterstation mit 2 Außen Sensoren
Danke schon einmal
TomTom
HM-ES-PMSw1-Pl, HM-TC-IT-WM-W-EU, HM-CC-RT-DN,
HM-LC-DIM1T-FM, HM-SEC-SCo, Harmony-Hub,Raspi3.
CUL 868, nanoCUL 433
KölnSolar
ZitatIch habe ein problem die a-cul FW zu instalieren
wobei genau ? Wo es die hex-datei gibt steht im ersten Post. Und dann halt flashen, siehe http://culfw.de/culfw.html
also Flip auf dem Windows-pc, hex-file laden, CUL Mit GEDRÜCKTEM Mikrotaster in USB stecken, Run klicken......fertig.
Grüße Markus
tkaiser
Hallo
ich habe ja einen CUL-v3 nur weiss ich nicht welches Divice ich auswählen muß. bevor ich die hex. Datei laden kann.
ich habe Flip 3.4.7 zum flashen des Culs
tomtom
chris1284
den chip der verbaut ist ?! ATMega32U4
dieoma
ich benutze die letzte Version der a-culfw. In meiner fhem.conf habe ich z.B. drei Intertechno Devices von REV wie folgt definiert und sie funktionieren auch prima: define REV1 IT 1FFF1FF0FF FF 00
define REV2 IT 1FFFF1F0FF FF 00
define REV3 IT 1FFFFF10FF FF 00
Wenn ich die Fernbedienung nun parallel benutze bekomme ich im Log 2016.10.07 11:53:30 3: CUL433 IT: Code 10 not supported by IT_1FFF1FF000 und im Event Monitor 2016-10-07 11:55:24 CUL CUL433 UNKNOWNCODE id5d40c ich bin recht sicher in älteren Firmware Versionen kam nix mit "Code 10" - was genau ist das? Bezüglich "id5d40c" - was genau ist das? Muss man das irgendwie umrechnen?
Besten Dank für Eure Hilfe vorab!
Markus
FHEM5.8 auf Raspi 2, HomeMatic über HMLan mit einigen Aktoren, IT433 Steckosen über CUL, Squeezebox und Tablet-UI
bjoernh
Das ist der an/aus Code.
Evtl.  Musst du den im Device anpassen,  oder der Cul empfängt den Code falsch.
dieoma
du meinst id5d40c wäre der an/aus code? Da die Devices mit der genannten Definition gut schalten verstehe ich nicht was da umzudefinieren sein sollte - kannst du mir ein Beispiel geben? Das wäre sehr hilfreich da ich auch bei diesem Teme noch voll auf dem Schlauch stehe: https://forum.fhem.de/index.php/topic,58091.0.html Wenn ich weiß wie ich es undefinierten muss schlage ich vielleicht zwei Fliegen mit einer Klappe  ::)
tkaiser
Hallo Chris,
ich habe jetzt das Problem das ich die CUL 868 Hex Datei nicht auf meinen CUL flashen kann.nehme ich zB. die CUL 433 Hex Datei damit kann ich flashen, und der CUL wird wieder erkannt.
Hat jemand eine IDEE?
TomTom
Lichti
Habe ein ähnliches Problem:
Wollte auf meinen CUL V3.3 die a-culfw_v1.21.00_build_71 flashen (Auswahl  4 = CUL_V3 868MHZ)
und bekomme die Meldung:
Bootloader and code overlap.
Use --suppress-bootloader-mem to ignore
Woran könnte das liegen?
Danke und Gruß
bjoernh
Zitat von: tkaiser am 07 Oktober 2016, 22:52:21
Hallo Chris,
TomTom
Danke und Gruß
Daran  dass der Code zu groß ist.
Der Speicher ist einfach aufgebraucht und weitere Funktionen können nur in den Code gebracht werden,  wenn andere entfallen.
Was wollt ihr überhaupt machen?
Für die 868er könnt ihr eigentlich immer die original culfw nehmen.  An den Protokollen für den 868er Empfang hat sich nichts geändert.
Für das senden solltet ihr aus Gründen der Reichweite eh immer einen echten 433er nehmen.
Lichti
#958
Danke für die Antwort.
Ich möchte neben 868 MHz für FS20 auch 433 MHZ für Intertechno nutzen.
Könnte der CUL 433 denn auch beides?
Gruß und schönes Wochenende
tkaiser
Hallo bjoernh
Ich wollte ein paar Aussensensoren von meiner alten Wetterstation WS-7078 empfangen.
Ich habe mir auch schon ein sniffer und sender für 433Mhz angeschaft und kann damit allte Steckdosen schalten,
Leider bekomme ich es nicht hin die Wettersensoren zu empfangen.
Hast du dafür eine Lösung
