Pairing-Probleme
Begonnen von Karitzel, 22 März 2015, 22:40:53
frank
poste doch endlich mal einen ausschnitt aus fhem.log und ein list der vccu.
FHEM: 6.0(SVN) => Pi3(buster)
Karitzel
Hier erst einmal die List vccu:
   DEF        424242
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     4
   NAME       vccu
   NR         21
   STATE      hmusb:ok,
   TYPE       CUL_HM
   assignedIOs hmusb
   hmusb_MSGCNT 4
   hmusb_RAWMSG EDEE2E4,0000,009022AE,FF,FFBF,77E218DEE2E424E414F4F4ECDC1B1D
   hmusb_RSSI -65
   hmusb_TIME 2015-03-23 14:18:55
   Readings:
     2015-03-23 14:18:55   unknown_DEE2E4  received
     2015-03-23 13:43:51   unknown_E4D4E4  received
     2015-03-23 14:17:40   unknown_E525D8  received
   Helper:
     mId        FFF0
     rxType     1
     Io:
       prefIO
       vccu
       ioList:
         hmusb
     Mrssi:
       mNo
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       vrt        1
   IODev      hmusb
   IOList     hmusb
   expert     2_full
   model      CCU-FHEM
   subType    virtual
   webCmd     virtual:update
Und hier aus der FHEM.log (vorher habe ich FHEM noch ein Update verpasst)
2015.03.23 11:48:22 1: Including fhem.cfg
2015.03.23 11:48:22 3: telnetPort: port 7072 opened
2015.03.23 11:48:23 3: WEB: port 8083 opened
2015.03.23 11:48:23 3: WEBphone: port 8084 opened
2015.03.23 11:48:23 3: WEBtablet: port 8085 opened
2015.03.23 11:48:24 2: eventTypes: loaded 13 events from ./log/eventTypes.txt
2015.03.23 11:48:24 1: HMLAN_Parse: hmusb new condition disconnected
2015.03.23 11:48:24 3: Opening hmusb device 127.0.0.1:1234
2015.03.23 11:48:24 3: hmusb device opened
2015.03.23 11:48:24 1: HMLAN_Parse: hmusb new condition init
2015.03.23 11:48:27 1: Including ./log/fhem.save
2015.03.23 11:48:27 1: usb create starting
2015.03.23 11:48:29 3: Probing CUL device /dev/ttyAMA0
2015.03.23 11:48:29 3: Probing TCM_ESP3 device /dev/ttyAMA0
2015.03.23 11:48:30 3: Probing FRM device /dev/ttyAMA0
2015.03.23 11:48:35 1: usb create end
2015.03.23 11:48:35 0: Server started with 11 defined entities (version $Id: fhem.pl 8265 2015-03-22 13:58:15Z rudolfkoenig $, os linux, user fhem, pid 5539)
2015.03.23 11:48:35 1: HMLAN_Parse: hmusb new condition ok
2015.03.23 11:51:09 3: CUL_HM set vccu hmPairForSec 120
2015.03.23 12:03:57 1: PERL WARNING: Argument "undefined" isn't numeric in numeric lt (<) at ./FHEM/10_CUL_HM.pm line 4434.
2015.03.23 12:17:49 1: PERL WARNING: Argument "All" isn't numeric in numeric lt (<) at ./FHEM/10_CUL_HM.pm line 6304.
2015.03.23 13:38:57 0: Server shutdown
2015.03.23 13:39:01 1: Including fhem.cfg
2015.03.23 13:39:03 1: HMLAN_Parse: hmusb new condition disconnected
2015.03.23 13:39:03 1: HMLAN_Parse: hmusb new condition init
2015.03.23 13:39:06 1: Including ./log/fhem.save
2015.03.23 13:39:06 1: usb create starting
2015.03.23 13:39:13 1: usb create end
2015.03.23 13:39:13 0: Server started with 14 defined entities (version $Id: fhem.pl 8265 2015-03-22 13:58:15Z rudolfkoenig $, os linux, user fhem, pid 5576)
2015.03.23 13:39:14 1: HMLAN_Parse: hmusb new condition ok
2015.03.23 13:42:59.294 0: Server shutdown
2015.03.23 13:43:03.480 1: Including fhem.cfg
2015.03.23 13:43:05.391 1: HMLAN_Parse: hmusb new condition disconnected
2015.03.23 13:43:05.448 1: HMLAN_Parse: hmusb new condition init
2015.03.23 13:43:08.286 1: Including ./log/fhem.save
2015.03.23 13:43:08.323 1: usb create starting
2015.03.23 13:43:16.094 1: usb create end
2015.03.23 13:43:16.105 0: Server started with 14 defined entities (version $Id: fhem.pl 8265 2015-03-22 13:58:15Z rudolfkoenig $, os linux, user fhem, pid 5584)
2015.03.23 13:43:16.213 1: HMLAN_Parse: hmusb new condition ok
2015.03.23 13:58:03.318 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm line 7317.
2015.03.23 14:18:38.902 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/10_CUL_HM.pm line 5620.
frank
in deiner fhem.cfg gibt es ein notify, oder so, dass usb create startet. loesche dieses. dann setze beim hmusb das attr logIDs all,sys. dann tauchen noch weitere 3 usb geraete auf. entferne die erstmal. danach neu booten.
Karitzel
Habe das USB create gelöscht und auch den hmusb geändert, leider wurden mir die 3 neuen USB nicht angezeigt.
2015.03.23 15:10:46.374 1: PERL WARNING: Use of uninitialized value $re in concatenation (.) or string at ./FHEM/91_notify.pm line 35.
2015.03.23 15:10:46.375 1: PERL WARNING: Use of uninitialized value $re in pattern match (m//) at ./FHEM/91_notify.pm line 42.
2015.03.23 15:10:46.376 1: PERL WARNING: Use of uninitialized value $re in regexp compilation at ./FHEM/91_notify.pm line 43.
2015.03.23 15:10:46.378 1: PERL WARNING: Use of uninitialized value $re in regexp compilation at ./FHEM/91_notify.pm line 48.
2015.03.23 15:10:46.390 1: PERL WARNING: Use of uninitialized value $re in pattern match (m//) at fhem.pl line 3983.
2015.03.23 15:10:46.394 1: PERL WARNING: Use of uninitialized value $re in regexp compilation at ./FHEM/91_notify.pm line 75.
2015.03.23 15:10:46.428 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/91_notify.pm line 197.
2015.03.23 15:11:53.459 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:11:53.476 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C0A2A3 IDcnt:0001
2015.03.23 15:12:18.469 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:12:18.503 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C10457 IDcnt:0001
2015.03.23 15:12:43.471 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:12:43.498 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C165FE IDcnt:0001
2015.03.23 15:13:08.474 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:13:08.493 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C1C7A9 IDcnt:0001
2015.03.23 15:13:33.481 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:13:33.520 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C22959 IDcnt:0001
2015.03.23 15:13:58.485 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:13:58.515 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C28B03 IDcnt:0001
2015.03.23 15:14:23.494 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:14:23.510 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C2ECB2 IDcnt:0001
2015.03.23 15:14:48.498 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:14:48.505 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C34E5F IDcnt:0001
2015.03.23 15:14:51.098 0: Server shutdown
2015.03.23 15:14:55.179 1: Including fhem.cfg
2015.03.23 15:14:56.973 1: HMLAN_Parse: hmusb new condition disconnected
2015.03.23 15:14:57.027 1: HMLAN_Parse: hmusb new condition init
2015.03.23 15:14:59.711 1: Including ./log/fhem.save
2015.03.23 15:14:59.755 0: Server started with 14 defined entities (version $Id: fhem.pl 8265 2015-03-22 13:58:15Z rudolfkoenig $, os linux, user fhem, pid 5618)
2015.03.23 15:14:59.761 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C36F93 IDcnt:0001
2015.03.23 15:14:59.768 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C36F93 IDcnt:0001
2015.03.23 15:14:59.770 0: HMLAN_Parse: hmusb R:R46FC8853 stat:0002 t:00000000 d:FF r:7FFF     m:99 8112 999999 000000
2015.03.23 15:14:59.771 1: HMLAN_Parse: hmusb new condition ok
2015.03.23 15:15:22.034 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:15:22.045 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C3D15D IDcnt:0000
2015.03.23 15:15:40.777 0: Server shutdown
2015.03.23 15:15:44.819 1: Including fhem.cfg
2015.03.23 15:15:46.597 1: HMLAN_Parse: hmusb new condition disconnected
2015.03.23 15:15:46.651 1: HMLAN_Parse: hmusb new condition init
2015.03.23 15:15:49.303 1: Including ./log/fhem.save
2015.03.23 15:15:49.347 0: Server started with 14 defined entities (version $Id: fhem.pl 8265 2015-03-22 13:58:15Z rudolfkoenig $, os linux, user fhem, pid 5624)
2015.03.23 15:15:49.352 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C4316A IDcnt:0000
2015.03.23 15:15:49.360 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C4316A IDcnt:0000
2015.03.23 15:15:49.362 0: HMLAN_Parse: hmusb R:R46FD4A2A stat:0002 t:00000000 d:FF r:7FFF     m:99 8112 999999 000000
2015.03.23 15:15:49.363 1: HMLAN_Parse: hmusb new condition ok
2015.03.23 15:16:11.673 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:16:11.684 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C49345 IDcnt:0000
2015.03.23 15:16:36.701 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:16:36.711 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C4F507 IDcnt:0000
2015.03.23 15:17:01.705 0: HMLAN_Send:  hmusb I:K
2015.03.23 15:17:01.738 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00C556B2 IDcnt:0000
2015.03.23 15:17:04.682 0: HMLAN_Parse: hmusb R:EE40424   stat:0000 t:00C5622D d:FF r:FFC7     m:77 E006 E40424 E41CE4 E020E51A23E3
frank
es sollen keine weiteren usb devices angezeigt werden. es sah vorhin so aus als haettest du noch welche. bis auf den letzten logeintrag sieht es seit 15:15 erstmal ok aus. jetzt solltest du langsam deinen tempsensor sehen koennen.
paire nun nochmal.
Karitzel
Habe jetzt nochmal neu gepairt aber sehe weiterhin nur unknown_<6-stelliger Hexcode>. Es ist zum verzweifeln  :(
Ich setze es auf define <unknown_hex> CUL_HM <hexcode>. Davor befindet es sich in den readings im vccu.
Mir wird nachdem ich das unknown einem Raum zugewiesen habe nur IODev hmusb; autoReadReg 4_reqStatus; expert 2_full und der zugewiesene Raum angezeigt.
frank
ZitatHabe jetzt nochmal neu gepairt aber sehe weiterhin nur unknown_<6-stelliger Hexcode>
das ist auch ok so. hier wirst du nie was anderes sehen. nach jedem restart werden unbekannte devices mit einem unknown reading angelegt, solange die devices nicht gepairt und in fhem angelegt sind. selbst wenn das pairing irgendwann klappt, ändern sich die readings nicht in "known" readings.
was zeigt nun fhem.log?
Karitzel
Bin gestern nicht mehr dazu gekommen hier nochmal zu schreiben.
2015.03.23 16:16:13.502 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FB8876 IDcnt:0002
2015.03.23 16:16:27.455 0: HMLAN_Send:  hmusb S:S4734D80A stat:  00 t:00000000 d:01 r:4734D80A m:05 A001 424242 BCCBBC 00040000000000
2015.03.23 16:16:28.096 0: HMLAN_Parse: hmusb R:R4734D80A stat:0008 t:00000000 d:FF r:7FFF     m:05 A001 424242 BCCBBC 00040000000000
2015.03.23 16:16:28.098 0: HMLAN_Parse: hmusb no ACK from BCCBBC
2015.03.23 16:16:31.879 0: HMLAN_Send:  hmusb S:S4734E952 stat:  00 t:00000000 d:01 r:4734E952 m:05 A001 424242 BCCBBC 00040000000000
2015.03.23 16:16:32.513 0: HMLAN_Parse: hmusb R:R4734E952 stat:0008 t:00000000 d:FF r:7FFF     m:05 A001 424242 BCCBBC 00040000000000
2015.03.23 16:16:32.578 0: HMLAN_Parse: hmusb no ACK from BCCBBC
2015.03.23 16:16:36.133 0: HMLAN_Send:  hmusb S:S4734F9F0 stat:  00 t:00000000 d:01 r:4734F9F0 m:05 A001 424242 BCCBBC 00040000000000
2015.03.23 16:16:36.769 0: HMLAN_Parse: hmusb R:R4734F9F0 stat:0008 t:00000000 d:FF r:7FFF     m:05 A001 424242 BCCBBC 00040000000000
2015.03.23 16:16:36.771 0: HMLAN_Parse: hmusb no ACK from BCCBBC
2015.03.23 16:16:38.472 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:16:38.498 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FBEA1F IDcnt:0002
2015.03.23 16:16:40.596 0: HMLAN_Send:  hmusb S:S47350B5F stat:  00 t:00000000 d:01 r:47350B5F m:05 A001 424242 BCCBBC 00040000000000
2015.03.23 16:16:41.218 0: HMLAN_Parse: hmusb R:R47350B5F stat:0008 t:00000000 d:FF r:7FFF     m:05 A001 424242 BCCBBC 00040000000000
2015.03.23 16:16:41.220 0: HMLAN_Parse: hmusb no ACK from BCCBBC
2015.03.23 16:17:03.479 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:17:03.492 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FC4BD1 IDcnt:0002
2015.03.23 16:17:28.482 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:17:28.520 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FCAD7A IDcnt:0002
2015.03.23 16:17:53.489 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:17:53.515 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FD0F29 IDcnt:0002
2015.03.23 16:18:18.514 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:18:18.542 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FD70EB IDcnt:0002
2015.03.23 16:18:43.541 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:18:43.569 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FDD2AC IDcnt:0002
2015.03.23 16:19:08.544 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:19:08.564 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FE3455 IDcnt:0002
2015.03.23 16:19:33.569 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:19:33.590 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FE9618 IDcnt:0002
2015.03.23 16:19:58.574 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:19:58.586 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FEF7C3 IDcnt:0002
2015.03.23 16:20:23.593 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:20:23.613 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FF597E IDcnt:0002
2015.03.23 16:20:48.597 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:20:48.608 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00FFBB28 IDcnt:0002
2015.03.23 16:21:13.623 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:21:13.635 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01001CEB IDcnt:0002
2015.03.23 16:21:38.649 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:21:38.662 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01007EAD IDcnt:0002
2015.03.23 16:22:03.670 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:22:03.689 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0100E068 IDcnt:0002
2015.03.23 16:22:28.673 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:22:28.684 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01014212 IDcnt:0002
2015.03.23 16:22:53.683 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:22:53.711 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0101A3C5 IDcnt:0002
2015.03.23 16:23:18.709 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:23:18.738 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01020586 IDcnt:0002
2015.03.23 16:23:43.734 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:23:43.765 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01026747 IDcnt:0002
2015.03.23 16:24:08.737 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:24:08.760 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0102C8F2 IDcnt:0002
2015.03.23 16:24:23.711 0: HMLAN_Send:  hmusb S:S473C1C6A stat:  00 t:00000000 d:01 r:473C1C6A m:06 A001 424242 BCCBBC 00040000000000
2015.03.23 16:24:24.346 0: HMLAN_Parse: hmusb R:R473C1C6A stat:0008 t:00000000 d:FF r:7FFF     m:06 A001 424242 BCCBBC 00040000000000
2015.03.23 16:24:24.348 0: HMLAN_Parse: hmusb no ACK from BCCBBC
2015.03.23 16:24:28.794 0: HMLAN_Send:  hmusb S:S473C3045 stat:  00 t:00000000 d:01 r:473C3045 m:06 A001 424242 BCCBBC 00040000000000
2015.03.23 16:24:29.434 0: HMLAN_Parse: hmusb R:R473C3045 stat:0008 t:00000000 d:FF r:7FFF     m:06 A001 424242 BCCBBC 00040000000000
2015.03.23 16:24:29.436 0: HMLAN_Parse: hmusb no ACK from BCCBBC
2015.03.23 16:24:33.740 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:24:33.755 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01032A9C IDcnt:0002
2015.03.23 16:24:34.040 0: HMLAN_Send:  hmusb S:S473C44C3 stat:  00 t:00000000 d:01 r:473C44C3 m:06 A001 424242 BCCBBC 00040000000000
2015.03.23 16:24:34.651 0: HMLAN_Parse: hmusb R:R473C44C3 stat:0008 t:00000000 d:FF r:7FFF     m:06 A001 424242 BCCBBC 00040000000000
2015.03.23 16:24:34.653 0: HMLAN_Parse: hmusb no ACK from BCCBBC
2015.03.23 16:24:38.735 0: HMLAN_Send:  hmusb S:S473C571A stat:  00 t:00000000 d:01 r:473C571A m:06 A001 424242 BCCBBC 00040000000000
2015.03.23 16:24:39.356 0: HMLAN_Parse: hmusb R:R473C571A stat:0008 t:00000000 d:FF r:7FFF     m:06 A001 424242 BCCBBC 00040000000000
2015.03.23 16:24:39.369 0: HMLAN_Parse: hmusb no ACK from BCCBBC
2015.03.23 16:24:58.752 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:24:58.782 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01038C55 IDcnt:0002
2015.03.23 16:25:23.761 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:25:23.777 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0103EE07 IDcnt:0002
2015.03.23 16:25:48.764 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:25:48.772 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01044FAE IDcnt:0002
2015.03.23 16:26:13.790 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:26:13.799 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0104B170 IDcnt:0002
2015.03.23 16:26:38.816 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:26:38.826 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01051333 IDcnt:0002
2015.03.23 16:27:03.836 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:27:03.853 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:010574F1 IDcnt:0002
2015.03.23 16:27:28.839 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:27:28.848 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0105D69C IDcnt:0002
2015.03.23 16:27:53.849 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:27:53.875 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01063851 IDcnt:0002
2015.03.23 16:28:18.868 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:28:18.902 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01069A0F IDcnt:0002
2015.03.23 16:28:43.894 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:28:43.932 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0106FBD1 IDcnt:0002
2015.03.23 16:29:08.898 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:29:08.924 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01075D7B IDcnt:0002
2015.03.23 16:29:33.924 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:29:33.951 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0107BF3F IDcnt:0002
2015.03.23 16:29:58.939 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:29:58.979 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01082104 IDcnt:0002
2015.03.23 16:30:23.963 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:30:23.974 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:010882B5 IDcnt:0002
2015.03.23 16:30:48.967 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:30:49.000 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0108E45F IDcnt:0002
2015.03.23 16:31:13.989 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:31:14.028 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:01094624 IDcnt:0002
2015.03.23 16:31:39.005 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:31:39.023 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0109A7D6 IDcnt:0002
2015.03.23 16:32:04.022 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:32:04.050 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:010A0994 IDcnt:0002
2015.03.23 16:32:29.026 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:32:29.046 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:010A6B38 IDcnt:0002
2015.03.23 16:32:54.036 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:32:54.072 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:010ACCEB IDcnt:0002
2015.03.23 16:33:19.062 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:33:19.099 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:010B2EAD IDcnt:0002
2015.03.23 16:33:44.079 0: HMLAN_Send:  hmusb I:K
2015.03.23 16:33:44.095 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:010B9069 IDcnt:0002
2015.03.23 16:34:07.147 0: Server shutdown
2015.03.23 16:34:29.568 1: Including fhem.cfg
2015.03.23 16:34:36.951 1: HMLAN_Parse: hmusb new condition disconnected
2015.03.23 16:34:37.129 1: HMLAN_Parse: hmusb new condition init
2015.03.24 07:58:47.739 1: Including ./log/fhem.save
2015.03.24 07:58:47.868 0: Server started with 15 defined entities (version $Id: fhem.pl 8265 2015-03-22 13:58:15Z rudolfkoenig $, os linux, user fhem, pid 2058)
2015.03.24 07:58:47.870 0: HMLAN_Send:  hmusb I:T1CA3B997,04,00,00000000
2015.03.24 07:58:47.872 0: HMLAN_Send:  hmusb I:K
2015.03.24 07:58:47.881 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00008C72 IDcnt:0000
2015.03.24 07:58:47.910 0: HMLAN_Parse: hmusb R:R474578A9 stat:0002 t:00000000 d:FF r:7FFF     m:99 8112 999999 000000
2015.03.24 07:58:47.927 1: HMLAN_Parse: hmusb new condition ok
2015.03.24 07:58:47.965 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0000A7EA IDcnt:0000
2015.03.24 07:58:52.827 0: HMLAN_Send:  hmusb I:+BCCBBC,00,01,00
2015.03.24 07:59:12.886 0: HMLAN_Send:  hmusb I:K
2015.03.24 07:59:12.907 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00010989 IDcnt:0001
2015.03.24 07:59:37.912 0: HMLAN_Send:  hmusb I:K
2015.03.24 07:59:37.934 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00016B45 IDcnt:0001
2015.03.24 08:00:02.929 0: HMLAN_Send:  hmusb I:K
2015.03.24 08:00:02.961 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0001CCFE IDcnt:0001
2015.03.24 08:00:27.931 0: HMLAN_Send:  hmusb I:K
2015.03.24 08:00:27.957 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00022EA6 IDcnt:0001
frank
ein shutdown restart der 16 stunden braucht?? wieso gibt es überhaupt so viele shutdowns bei dir?
welches device ist BCCBBC und 999999?
hier funkt kein sensor, kein pairing. was treibst du bloss?  ;)
Karitzel
Der Raspberry Pi war über Nacht aus. Stromversorgung gekappt.
Was das 9999999 ist keine Ahnung, das BCCBBC ist der Versuch des pairing mit dem Funk-Temperatur-/Luftfeuchtesensor, innen.
frank
Zitatdas BCCBBC ist der Versuch des pairing mit dem Funk-Temperatur-/Luftfeuchtesensor, innen.
nee.
hast du BCCBBC selbst definiert? dann lösche es. die id sieht ausgedacht aus. ausserdem hat bei dir noch nie ein device eine anlernmessage gesendet.
Karitzel
Gut hab es gelöscht obwohl ich BCCBBC nicht selbst definiert habe. Ich verstehe nicht warum ich nichts gepairt bekomme, egal wie oft ich es versuche!
frank
ZitatIch verstehe nicht warum ich nichts gepairt bekomme, egal wie oft ich es versuche!
entweder deine devices funken nichts, oder dein hmusb empfängt/sendet nichts. wenn du ein device in den anlernmodus bringst, muss im log eine anlernmessage auftauchen.
nach deinen logs wurde bisher nichts empfangen, rein garnichts.
Karitzel
Ich hoffe doch mal das der USB-Konfigurator nicht kaputt ist.
Nochmal ein .log Eintrag nach erneutem Anlern-Versuch:
2015.03.24 10:18:34.589 0: HMLAN_Parse: hmusb R:E25E5D4   stat:0000 t:00809FBC d:FF r:FFD7     m:71 1FE7 25E5D4 F5FD1C 2424C4FAD220
2015.03.24 10:18:52.429 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:18:52.447 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0080E59C IDcnt:0001
2015.03.24 10:19:17.432 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:19:17.474 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0081474F IDcnt:0001
2015.03.24 10:19:42.448 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:19:42.469 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0081A8FE IDcnt:0001
2015.03.24 10:20:07.459 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:20:07.496 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00820AB0 IDcnt:0001
2015.03.24 10:20:32.465 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:20:32.491 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00826C5D IDcnt:0001
2015.03.24 10:20:57.238 0: HMLAN_Send:  hmusb I:+564546,00,00,
2015.03.24 10:20:57.242 0: HMLAN_Send:  hmusb S:+564546,00,01,00
2015.03.24 10:20:57.243 0: HMLAN_Send:  hmusb S:S4B15BAE5 stat:  00 t:00000000 d:01 r:4B15BAE5 m:04 A001 424242 564546 00040000000000
2015.03.24 10:20:57.471 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:20:57.502 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0082CE0C IDcnt:0002
2015.03.24 10:20:57.966 0: HMLAN_Parse: hmusb R:R4B15BAE5 stat:0008 t:00000000 d:FF r:7FFF     m:04 A001 424242 564546 00040000000000
2015.03.24 10:20:57.968 0: HMLAN_Parse: hmusb no ACK from 564546
2015.03.24 10:21:01.948 0: HMLAN_Send:  hmusb S:S4B15CD47 stat:  00 t:00000000 d:01 r:4B15CD47 m:04 A001 424242 564546 00040000000000
2015.03.24 10:21:02.575 0: HMLAN_Parse: hmusb R:R4B15CD47 stat:0008 t:00000000 d:FF r:7FFF     m:04 A001 424242 564546 00040000000000
2015.03.24 10:21:02.577 0: HMLAN_Parse: hmusb no ACK from 564546
2015.03.24 10:21:07.898 0: HMLAN_Send:  hmusb S:S4B15E485 stat:  00 t:00000000 d:01 r:4B15E485 m:04 A001 424242 564546 00040000000000
2015.03.24 10:21:08.527 0: HMLAN_Parse: hmusb R:R4B15E485 stat:0008 t:00000000 d:FF r:7FFF     m:04 A001 424242 564546 00040000000000
2015.03.24 10:21:08.529 0: HMLAN_Parse: hmusb no ACK from 564546
2015.03.24 10:21:09.136 0: HMLAN_Parse: hmusb R:E24E4D4   stat:0000 t:0082FB7F d:FF r:FFD7     m:71 1FE7 24E4D4 F5FD1C 2424C4FBD320
2015.03.24 10:21:12.215 0: HMLAN_Send:  hmusb S:S4B15F562 stat:  00 t:00000000 d:01 r:4B15F562 m:04 A001 424242 564546 00040000000000
2015.03.24 10:21:12.848 0: HMLAN_Parse: hmusb R:R4B15F562 stat:0008 t:00000000 d:FF r:7FFF     m:04 A001 424242 564546 00040000000000
2015.03.24 10:21:12.850 0: HMLAN_Parse: hmusb no ACK from 564546
2015.03.24 10:21:22.474 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:21:22.481 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00832FB5 IDcnt:0002
2015.03.24 10:21:47.476 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:21:47.508 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:00839160 IDcnt:0002
2015.03.24 10:22:12.482 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:22:12.503 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0083F30C IDcnt:0002
2015.03.24 10:22:37.484 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:22:37.498 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:008454B7 IDcnt:0002
2015.03.24 10:23:02.496 0: HMLAN_Send:  hmusb I:K
2015.03.24 10:23:02.525 0: HMLAN_Parse: hmusb V:03C7 sNo:LEQ1197638 d:308476 O:424242 t:0084B66C IDcnt:0002
Mein RSSI-Wert liegt derzeit bei -41    ???
frank
hier empfängst du erstmalig, zumindestens funk zwischen 2 devices.
ein anlernvorgang ist hier nicht enthalten. nur ein getconfig versuch auf ein nicht antwortendes device 564546.
