FHEM startet nicht
Begonnen von Cihan, 01 April 2015, 00:12:39
Cihan
Ich habe mein RPi ordnungsgemäß heruntergefahren, weil ich den wlan stick brauchte.
Dann habe ich ihn wieder angeschlossen und seitdem startet mein FHEM nicht mehr.
2015.04.01 00:00:03 3: [UtilsHourCounter] Init Done with Version 1.0.1.0 - 10.12.2014 (john)
2015.04.01 00:00:03 1: Including fhem.cfg
2015.04.01 00:00:03 3: telnetPort: port 7072 opened
2015.04.01 00:00:03 3: WEB: port 8083 opened
2015.04.01 00:00:03 3: WEBphone: port 8084 opened
2015.04.01 00:00:03 3: WEBtablet: port 8085 opened
2015.04.01 00:00:04 2: eventTypes: loaded 9984 events from ./log/eventTypes.txt
2015.04.01 00:00:04 3: HourCounter HourCounter Initialize.220 Init Done with Version 1.0.1.2 - 24.12.2014
2015.04.01 00:00:04 0: HourCounter CN.Pumpe Define.228 parameters: CN.Pumpe HourCounter DI03:reading:.on DI03:reading:.off
2015.04.01 00:00:04 0: HourCounter CN.brenner Define.228 parameters: CN.brenner HourCounter DI02:reading:.on DI02:reading:.off
2015.04.01 00:00:04 1: HMLAN_Parse: hmusb new condition disconnected
2015.04.01 00:00:05 3: Opening hmusb device 127.0.0.1:1234
2015.04.01 00:00:05 3: hmusb device opened
2015.04.01 00:00:45 3: [UtilsHourCounter] Init Done with Version 1.0.1.0 - 10.12.2014 (john)
2015.04.01 00:00:45 1: Including fhem.cfg
2015.04.01 00:00:45 3: telnetPort: port 7072 opened
2015.04.01 00:00:46 3: WEB: port 8083 opened
2015.04.01 00:00:46 3: WEBphone: port 8084 opened
2015.04.01 00:00:46 3: WEBtablet: port 8085 opened
2015.04.01 00:00:46 2: eventTypes: loaded 9984 events from ./log/eventTypes.txt
2015.04.01 00:00:47 3: HourCounter HourCounter Initialize.220 Init Done with Version 1.0.1.2 - 24.12.2014
2015.04.01 00:00:47 0: HourCounter CN.Pumpe Define.228 parameters: CN.Pumpe HourCounter DI03:reading:.on DI03:reading:.off
2015.04.01 00:00:47 0: HourCounter CN.brenner Define.228 parameters: CN.brenner HourCounter DI02:reading:.on DI02:reading:.off
2015.04.01 00:00:47 1: HMLAN_Parse: hmusb new condition disconnected
2015.04.01 00:00:47 3: Opening hmusb device 127.0.0.1:1234
2015.04.01 00:00:47 3: hmusb device opened
2015.04.01 00:06:24 3: [UtilsHourCounter] Init Done with Version 1.0.1.0 - 10.12.2014 (john)
2015.04.01 00:06:25 1: Including fhem.cfg
2015.04.01 00:06:25 3: telnetPort: port 7072 opened
2015.04.01 00:06:26 3: WEB: port 8083 opened
2015.04.01 00:06:26 3: WEBphone: port 8084 opened
2015.04.01 00:06:26 3: WEBtablet: port 8085 opened
2015.04.01 00:06:28 2: eventTypes: loaded 9984 events from ./log/eventTypes.txt
2015.04.01 00:06:29 3: HourCounter HourCounter Initialize.220 Init Done with Version 1.0.1.2 - 24.12.2014
2015.04.01 00:06:29 0: HourCounter CN.Pumpe Define.228 parameters: CN.Pumpe HourCounter DI03:reading:.on DI03:reading:.off
2015.04.01 00:06:29 0: HourCounter CN.brenner Define.228 parameters: CN.brenner HourCounter DI02:reading:.on DI02:reading:.off
2015.04.01 00:06:29 1: HMLAN_Parse: hmusb new condition disconnected
2015.04.01 00:06:29 3: Opening hmusb device 127.0.0.1:1234
2015.04.01 00:06:29 3: hmusb device opened
2015.04.01 00:12:03 3: [UtilsHourCounter] Init Done with Version 1.0.1.0 - 10.12.2014 (john)
2015.04.01 00:12:03 1: Including fhem.cfg
2015.04.01 00:12:03 3: telnetPort: port 7072 opened
2015.04.01 00:12:04 3: WEB: port 8083 opened
2015.04.01 00:12:04 3: WEBphone: port 8084 opened
2015.04.01 00:12:04 3: WEBtablet: port 8085 opened
2015.04.01 00:12:04 2: eventTypes: loaded 9984 events from ./log/eventTypes.txt
2015.04.01 00:12:05 3: HourCounter HourCounter Initialize.220 Init Done with Version 1.0.1.2 - 24.12.2014
2015.04.01 00:12:05 0: HourCounter CN.Pumpe Define.228 parameters: CN.Pumpe HourCounter DI03:reading:.on DI03:reading:.off
2015.04.01 00:12:05 0: HourCounter CN.brenner Define.228 parameters: CN.brenner HourCounter DI02:reading:.on DI02:reading:.off
2015.04.01 00:12:05 1: HMLAN_Parse: hmusb new condition disconnected
2015.04.01 00:12:05 3: Opening hmusb device 127.0.0.1:1234
2015.04.01 00:12:05 3: hmusb device opened
Der Log ensteht nur wenn ich im Terminal folgendes Eingebe
pi@raspberrypi ~ $ sudo /etc/init.d/fhem start
Starting fhem...
Daemon with PID 13502 started!
Can't bind socket: Address already in use
RPi4 Shelly Zigbee
